Edit: Updated with current VCDS scan. I'm at a loss here. The AC does not blow cold. One scan tool gives a fault, VCDS does not show a fault (no faults were cleared)
As I understand it there are 2 locations that have the potentially faulty part. Is there a way to scan and locate which one is faulty? I took the glovebox down and felt the actuator motor at location V425 (passenger side glovebox area). I feel movement but I don't know if it is the correct movement, as the fault code states it is jammed, not dead. I get plenty of airflow from all vents but the air does not get cold. Any tips or tricks on this one? Thanks
Updated with VCDS Autoscan. It produced no fault for the HVAC this time. However, a previous scan when the AC blew cold produced this fault:
NEW SCAN
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 00020004200100000000000000000002
Shop #: WSC 01383 790 50316
ROD: EV_ACManueBHBVW37X_SK48.rod
VCID: 4683BED1F9CF1E7193-8012
329220 - Motor for Air Distribution Flap
B109D 71 [008] - Actuator stuck
Reset counter: 103
Mileage: 56775 km
Date: 2017.03.12
Time: 11:01:46
Voltage terminal 30: 13.1 V
Outside air temperature: 20.5 °C
Air distribution flap: actual value: 225
Air distribution flap: actual value: 73.5 %
Air distribution flap: specified value: 47
NEW SCAN
Monday,25,May,2020,08:02:49:26867
VCDS Version: 20.4.1.0 (x64)
VIN: 3VW4T7AU1GM018790 License Plate:
Mileage: 143503km-89168mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AU1GM018790 Mileage: 143503km-89168miles
Address 01: Engine (J623-CXCA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00124424002F0000
Shop #: WSC 00066 790 00060
ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
ROD: EV_ECM20TFS0205G0906259D.rod
VCID: 2F6DFB757675BFFEA2-807A
17178 - Databus
Part No SW: 0D9 300 041 C HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4903
Revision: 06253104 Serial number: TFK01507160187
ROD: EV_TCMDQ250021.rod
VCID: 183F20A9E3FB5846D3-804C
P1734 00 [002] - -
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 52205000001352
Coding: 01FA6BA134210974007E020981C32980D62C9000408194B400430050C008
Shop #: WSC 12345 123 61029
VCID: 4B958FE5E2ADE3DEAE-801E
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Revision: 00001K01
VCID: 4683BED1F9CF1EB671-8012
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 86580307151630
Coding: 000018464041804969E44000001407201000000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 7AFB1A21FDB7AA5645-802E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150703 043 0581
Serial number: 150829093803
204546 - Remote key 2
B147A 18 [008] - Current Too Low
Component: AirbagVW20 010 0830
Serial number: 003GCR02SAW1
VCID: 479DB3D5FEC507BE8A-8012
Occupant Detection:
Component: BF-Gewichtss. H11 0021
Serial number: IBH00000000000386WCL
Coding: 30305A
Subsystem 2 - Part No SW: ----------- HW: 480 000 907 15
Serial number: 3570000000095294551C
Subsystem 3 - Part No SW: ----------- HW: 480 000 307 15
Serial number: 358000000001DC78A41T
Subsystem 4 - Part No SW: ----------- HW: 480 400 707 15
Serial number: 3510002A31B7E8F4D1FR
Subsystem 5 - Part No SW: ----------- HW: 480 400 707 15
Serial number: 3520002A31B7E8F14358
Subsystem 6 - Part No SW: ----------- HW: 480 401 407 15
Serial number: 3550002AB1B7E8F2805L
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 407 15
Serial number: 3560002AD1B7E8F3708R
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150718400233
Coding: 0410
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F8DAB35A6154F7E32-806A
Part No SW: 5G1 920 856 A HW: 5G1 920 856 A
Component: KOMBI 342 6420
Coding: 03BD090AA180CF0502087A001000000000000000
VCID: 2C57EC794763C4E687-8078
Part No SW: 5Q0 907 530 AE HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2223
Revision: -------- Serial number: 02081510803718
Coding: 0101000830085900FB0000281C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07027
ROD: EV_GatewConti_013.rod
VCID: 74E73419DFD3DC261F-8020
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0101
Serial number: 29150001307980025264
Coding: 31FFFF
131687 - No Communications with Emergency Call Module
U10E1 00 [008] - -
Reset counter: 14
Mileage: 142713 km
Date: 2020.04.03
Time: 16:14:34
Supply voltage: Terminal 30: 12.7 V
Terminal 15: OFF
Component: TSG FS 020 0041
Serial number: 270615060505SR
Coding: 003E03200000040000000000
VCID: 4385A7C5CAFD2B9E56-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001838711
Coding: 011000
B1487 54 [008] - Missing Calibration / Basic Setting
Fault Frequency: 16
Reset counter: 15
Mileage: 134937 km
Date: 2019.12.02
Time: 11:49:07
65799 - Door Warning / Entry Lighting
B1775 01 [009] - Electrical Failure
Reset counter: 251
Mileage: 134906 km
Date: 2019.12.02
Time: 00:13:40
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8102
VCID: 3979C52DB831614E0C-806C
Component: TSG BFS 020 0041
Serial number: 230615060505CF
VCID: 428BA2C1D5E722965D-8016
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001767969
Coding: 091000
Reset counter: 215
Mileage: 134910 km
Date: 2019.12.02
Time: 09:43:35
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US 620 0613
Coding: 02730000FF00000051220001001808001F0203D40120010002
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 6CD72C7987E304E6C7-8038
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H52 1028
Serial number: VWZ8Z9RES00ENK
1600 - Data Set Implausible
B2012 00 [008] - -
Reset counter: 37
Mileage: 139959 km
Date: 2020.02.06
Time: 00:57:21
Voltage terminal 30: 12.3 V
1659 - Data Set Implausible
B2012 00 [008] - -
Reset counter: 37
Mileage: 139959 km
Date: 2020.02.06
Time: 00:57:21
1660 - Data Set Implausible
B2012 00 [008] - -
Reset counter: 37
Mileage: 139959 km
Date: 2020.02.06
Time: 00:57:21
1661 - Data Set Implausible
B2012 00 [008] - -
Reset counter: 37
Mileage: 139959 km
Date: 2020.02.06
Time: 00:57:21
B11CF 53 [009] - Deactivated
Reset counter: 251
Mileage: 134906 km
Date: 2019.12.02
Time: 00:14:38
Voltage terminal 30: 12.2 V
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 134 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0566
ROD: EV_OCULowMQB.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150620200270
VCID: 6BD52F6582ED03DECE-803E
End-------------------------(Elapsed Time: 03:42)--------------------------
Log-3VW4T7AU1GM018790-143503km-89168mi.txt
Displaying Log-3VW4T7AU1GM018790-143503km-89168mi.txt.
