B109D71 - Air distribution door motor Actuator jammed
Frank Reynolds
C?ID=192933
Edit: Updated with current VCDS scan. I'm at a loss here. The AC does not blow cold. One scan tool gives a fault, VCDS does not show a fault (no faults were cleared)
As I understand it there are 2 locations that have the potentially faulty part. Is there a way to scan and locate which one is faulty? I took the glovebox down and felt the actuator motor at location V425 (passenger side glovebox area). I feel movement but I don't know if it is the correct movement, as the fault code states it is jammed, not dead. I get plenty of airflow from all vents but the air does not get cold. Any tips or tricks on this one? Thanks
Updated with VCDS Autoscan. It produced no fault for the HVAC this time. However, a previous scan when the AC blew cold produced this fault:
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 00020004200100000000000000000002
Shop #: WSC 01383 790 50316
ROD: EV_ACManueBHBVW37X_SK48.rod
VCID: 4683BED1F9CF1E7193-8012
329220 - Motor for Air Distribution Flap
B109D 71 [008] - Actuator stuck
Reset counter: 103
Mileage: 56775 km
Date: 2017.03.12
Time: 11:01:46
Voltage terminal 30: 13.1 V
Outside air temperature: 20.5 °C
Air distribution flap: actual value: 225
Air distribution flap: actual value: 73.5 %
Air distribution flap: specified value: 47
NEW SCAN
Monday,25,May,2020,08:02:49:26867
VCDS Version: 20.4.1.0 (x64)
VIN: 3VW4T7AU1GM018790   License Plate:
Mileage: 143503km-89168mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AU1GM018790   Mileage: 143503km-89168miles
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00124424002F0000
   Shop #: WSC 00066 790 00060
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F6DFB757675BFFEA2-807A
17178 - Databus
   Part No SW: 0D9 300 041 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4903
   Revision: 06253104    Serial number: TFK01507160187
   ROD: EV_TCMDQ250021.rod
   VCID: 183F20A9E3FB5846D3-804C
          P1734 00 [002] - -
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 52205000001352
   Coding: 01FA6BA134210974007E020981C32980D62C9000408194B400430050C008
   Shop #: WSC 12345 123 61029
   VCID: 4B958FE5E2ADE3DEAE-801E
   Revision: 00001K01
   VCID: 4683BED1F9CF1EB671-8012
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86580307151630
   Coding: 000018464041804969E44000001407201000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AFB1A21FDB7AA5645-802E
   Component: WWS    150703  043 0581
   Serial number:         150829093803
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
   Serial number: 003GCR02SAW1
   VCID: 479DB3D5FEC507BE8A-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH00000000000386WCL
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 907 15
   Serial number: 3570000000095294551C
   Subsystem 3 - Part No SW: -----------    HW: 480 000 307 15
   Serial number: 358000000001DC78A41T
   Subsystem 4 - Part No SW: -----------    HW: 480 400 707 15
   Serial number: 3510002A31B7E8F4D1FR
   Subsystem 5 - Part No SW: -----------    HW: 480 400 707 15
   Serial number: 3520002A31B7E8F14358
   Subsystem 6 - Part No SW: -----------    HW: 480 401 407 15
   Serial number: 3550002AB1B7E8F2805L
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 407 15
   Serial number: 3560002AD1B7E8F3708R
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150718400233
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3F8DAB35A6154F7E32-806A
   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
   Component: KOMBI         342 6420
   Coding: 03BD090AA180CF0502087A001000000000000000
   VCID: 2C57EC794763C4E687-8078
   Part No SW: 5Q0 907 530 AE    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2223
   Revision: --------    Serial number: 02081510803718
   Coding: 0101000830085900FB0000281C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07027
   ROD: EV_GatewConti_013.rod
   VCID: 74E73419DFD3DC261F-8020
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29150001307980025264
   Coding: 31FFFF
131687 - No Communications with Emergency Call Module
          U10E1 00 [008] - -
                    Reset counter: 14
                    Mileage: 142713 km
                    Date: 2020.04.03
                    Time: 16:14:34
                    Supply voltage: Terminal 30: 12.7 V
                    Terminal 15: OFF
   Serial number: 270615060505SR
   Coding: 003E03200000040000000000
   VCID: 4385A7C5CAFD2B9E56-8016
   Serial number: 00000000000001838711
   Coding: 011000
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Fault Frequency: 16
                    Reset counter: 15
                    Mileage: 134937 km
                    Date: 2019.12.02
                    Time: 11:49:07
65799 - Door Warning / Entry Lighting
          B1775 01 [009] - Electrical Failure
                    Reset counter: 251
                    Mileage: 134906 km
                    Date: 2019.12.02
                    Time: 00:13:40
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8102
   VCID: 3979C52DB831614E0C-806C
   Serial number: 230615060505CF
   VCID: 428BA2C1D5E722965D-8016
   Serial number: 00000000000001767969
   Coding: 091000
                    Reset counter: 215
                    Mileage: 134910 km
                    Date: 2019.12.02
                    Time: 09:43:35
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 02730000FF00000051220001001808001F0203D40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 6CD72C7987E304E6C7-8038
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H52 1028
   Serial number: VWZ8Z9RES00ENK
1600 - Data Set Implausible
          B2012 00 [008] - -
                    Reset counter: 37
                    Mileage: 139959 km
                    Date: 2020.02.06
                    Time: 00:57:21
                    Voltage terminal 30: 12.3 V
1659 - Data Set Implausible
          B2012 00 [008] - -
                    Reset counter: 37
                    Mileage: 139959 km
                    Date: 2020.02.06
                    Time: 00:57:21
1660 - Data Set Implausible
          B2012 00 [008] - -
                    Reset counter: 37
                    Mileage: 139959 km
                    Date: 2020.02.06
                    Time: 00:57:21
1661 - Data Set Implausible
          B2012 00 [008] - -
                    Reset counter: 37
                    Mileage: 139959 km
                    Date: 2020.02.06
                    Time: 00:57:21
          B11CF 53 [009] - Deactivated
                    Reset counter: 251
                    Mileage: 134906 km
                    Date: 2019.12.02
                    Time: 00:14:38
                    Voltage terminal 30: 12.2 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 134 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
   Component: OCULowMQBUS   007 0566
   Coding: 02730002C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 150620200270
   VCID: 6BD52F6582ED03DECE-803E
End-------------------------(Elapsed Time: 03:42)--------------------------
Log-3VW4T7AU1GM018790-143503km-89168mi.txt
Displaying Log-3VW4T7AU1GM018790-143503km-89168mi.txt.
I do not know what tool the above data is from, but it isn't VCDS. Since this is the Ross-Tech forum, please post data from VCDS.
Frank Reynolds
C?ID=192933
Sorry about that I got my scans confused. I will post the current VCDS scan shortly. Apologies for the mistake.
Frank Reynolds
C?ID=192933
Is this a situation where I need to reposition/calibrate the door actuators to properly open flaps? Is it as simple as a recharge to the AC? I can’t figure out why the air isn’t cold.
NostraJackAss
Did you put gauges on AC system to qualify pressures?
Does AC compressor & radiator fans engage when requested?
If it does, does the AC line low side, "fat line" under hood get cold?
If it does did you move flap manually to see if air can be forced across evaporator to cool it?
