I have a problem. On my audi a3 8v 2016 year I try to retrofit from Xenon lights to Dynamic AFS Xenon (8q5). My car originally have Xenon lights but not afs. There was another control unit (5q0.....) than I needed. So changed headlamps to 8V0941032 and afs control unit 7P6907357d. I changed all necessary wires. Left fault codes of 4h0941329 (slaves) control units: No coded. I tried to code master unit but no luck. In master coding is changing and after them doing basic settings but coding of slaves don't changes (still 1f0000) and fault codes also appears. Also tried to flash to A version and put parameters (ZDC). But now is bad coding of master unit. There is all 00000 and can't recore: Write that error 31 request is rejected. May you can help?
