T5 Multi Function Display Enabling
Walkingshaw
C?ID=300791
My 2010 T5.1 van has had cruise and MFD stalks installed. The cruise has been enabled and works fine but we cannot get the MFD to come alive, the rocker switch on the stalk deos nothing and the central display shows outside temperature most of the time.
Can anyone help with the necessary coding?
Andy
Thursday,07,May,2020,19:49:56:27147
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 69 0B
VIN: WV1ZZZ7HZBH001268   Mileage: 107060km-66523miles
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X35 9126
   Revision: 26X35---    Serial number: 00000000000000
   Coding: 01194012233400080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
   ROD: EV_ECM20TDI01103L906022CH_002.rod
   VCID: ED9295EA3CFB7527FC-80B8
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 F    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0104
   Revision: 00H43001
   Coding: 708724AD89A40E9624A49177A96610
   Shop #: WSC 02736 790 49152
   VCID: B5227D8A1C2BFDE7C4-80E0
                    Reset counter: 116
                    Mileage: 105585 km
                    Date: 2014.05.10
                    Time: 15:12:53
                    Count: 6161
                    Count: 128
                    Count: 250
   Part No SW: 7E5 907 047 AA    HW: 7E5 907 047 AA
   Component: Climatic-T5   H10 0101
   Revision: 00004001
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01002
   ROD: EV_ClimaT5Basis.rod
   VCID: EE9092E631FD8E3FC5-80BA
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 D    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0221
   Revision: BO047001    Serial number: 0347 140100528
   Coding: A0A0303A0E612431802040003C2B8C540080430F60060000300000000000
   Shop #: WSC 02736 790 12345
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Part No SW: 7E0 919 475     HW: 7E0 919 475
   Component: PARKHILFE 4K  H10 0008
   Revision: --------    Serial number: 33031007900159
   Coding: 100002
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_VW75XParkAssis4K A01003
   ROD: EV_VW75XParkAssis4K_A01.rod
   VCID: EFAE8FE236F78737CE-80BA
1079316 - Center Rear Right Parking Aid Sensor
          B1078 14 [008] - Open or Short to Ground
                    Fault Frequency: 26
                    Reset counter: 118
                    Mileage: 106036 km
                    Date: 2020.03.05
                    Time: 13:57:44
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag009 H05 0013
   Revision: --------    Serial number: 003HL000655E
   Coding: 000000000000000000000000000000003039
   Shop #: WSC 02734 790 50316
   VCID: B5227D8A142BFDE7C4-80E0
   Part No SW: 7E0 920 960 C    HW: 7E0 920 960 C
   Component: KOMBI         H04 0204
   Coding: 460A00
   Shop #: WSC 02756 790 50316
   VCID: A91AA1FAC893A90750-80FC
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 0221
   Coding: 042300
   VCID: F0AC8C9E23C998CFD7-80A4
   Component: IMMO          H04 0204
   VCID: EA989EF60D15621F99-80BE
Address 56: Radio
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000402969681
   Coding: 4100000101000000
   Shop #: WSC 12345 123 12345
   VCID: B2284696ED45EADFE1-80E6
02025 - Supply Voltage for External Components
                    Fault Status: 00101010
                    Fault Frequency: 148
                    Reset counter: 113
                    Mileage: 97989 km
                    Date: 2012.12.21
                    Time: 10:23:21
End----(Elapsed Time: 01:38, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
iichel
Netherlands, eastern part
C?ID=284912
This is strange, it should work (byte 1 bit 3 is enabled in 0x17).
Are you sure the wiring/stalks are correctly installed? Can you verify with DVOM that wires short to GND when you press a button?
Walkingshaw
C?ID=300791
Thank you. I will ask the technician who fitted the stalks to check the wiring.
Regards
Andy
Spacewalker
C?ID=159607
I think 7E0 920 960 C is a lowLine . withount any function
7E0 920 970 is with MFA
NEtech
C?ID=56995
Looks like it,
WV1ZZZ7HZBH001268
PR-Code 9Q0 Without multi-function display/trip computer
Walkingshaw
C?ID=300791
Thanks for your input guys.
I understand from searching elsewhere that the 960 cluster (Midline?) won't work (easily) with the MFSW but should work fine with the column stalk.
As standard it shows the outside temperature and, for a while after fuelling) it shows the range so it must be capable of calculating the fuel consumption.
Spacewalker
C?ID=159607
Looks like it,
WV1ZZZ7HZBH001268
MFA is a High Line cluster (cluster number 7E0920970 for example)
you can try add stalk
I never care about lowLine cluster what options they show as they are LowLine
is a like a ADD remote control for 2chanell TV receiver ...no point
dnoermann
C?ID=358118
The lowline cluster is showing some parts of Multifunction-Display, too when Stalk is added.
Spacewalker
C?ID=159607
aha ...so who why they charge soo much money for Highline cluster ...if it show this same ?
dnoermann
C?ID=358118
Whell it is VW, they charge it because we pay it :)
The lowline Cluster does not have more "Pages" to display.
But with the MFL you can change between those Values, sorry German:
Temperatur
Reichweite
Durchschnittsverbrauch
Durchschnittsgeschwindigkeit
Fahrzeit in 2 Ebenen (Kurzzeit- sowie Langzeitspeicher).
This was validated on a T6.
Walkingshaw
C?ID=300791
First prize goes to you iichel. Thank you. There were three wires that had to be added from the column switch to the instruments.
It was difficult to find the correct information online but eventually the answer was here:
https://www.vwt4forum.co.uk/threads...display-on-a-t5-1-with-lowline-screen.269550/
