Fitting Cruise Control MK6 2010 VW Golf
SilentService
C?ID=397182
Nothing is ever as simple as it seems eh?
I've tried to fit Crusie Control to my MK6 1.6 TDI Golf. I followed a guide online using VCDS to amend my coding on the engine and steering wheel modules and fitting a new indicator stalk. The coding seemed to be accepted no problem using the standard BCM and I had no major issues fitting the new stalk.
Once it was all back together I cleared any fault codes and took it for a test drive. straight away on the dash, a cruise control error came up and the cruise control itself didn't function.
I plugged back in when I got in and the fault code 00895 (cruise control switch defective) had popped up. I took the whole thing apart again and make sure I hadn't screwed something up. everything seemed fine, but the fault code is still there.
Has anyone come across this problem before? The stalk is brand new so maybe I got a broken one? or am I making a mistake with the coding?
Any help would be gratefully received. I've added a few photos and my Autoscan below:
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZAP142332   Mileage: 203270km-126306miles
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 B    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 5863
   Coding: 00114014032500080000
   Shop #: WSC 00028 028 00023
   ASAM Dataset: EV_ECM16TDI02103L906023B 001005
   ROD: EV_ECM16TDI02103L906023A_001.rod
   VCID: 2517F7E0556CDDD3004-8070
6116 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 203279 km
                    Date: 2020.04.09
                    Time: 00:18:03
                    Engine speed: 832.75 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 58 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 12.424 V
                    Environmental conditions-PV_AV_ENVD: 0.0 %
                    Environmental conditions-FRF_STATE_CRU_SWI_POS: 2
6118 - Cruise Control Switch (E45)
          P0568 00 [036] - Implausible Signal
                    Time: 00:00:00
                    Coolant temperature: 55 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.649 V
Readiness: 1010 0000
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Revision: 00H30001
   Coding: 133B200D092600FCC80E04E7901B0081300000
   Shop #: WSC 00028 028 00001
   VCID: 78A9EE94B2DE903B6B2-802C
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6D87CFC0CD1C2593884-8038
          B10AB F0 [009] - Too Low
                    Reset counter: 54
                    Mileage: 154521 km
                    Date: 2018.06.08
                    Time: 15:41:57
   Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
   Component: BCM PQ35  B   103 0575
   Revision: 00103 AG
   Coding: 40180A3A9025180044000080000000E443010088524D8160648000200000
   VCID: 2D070FC00D1CE593C84-8078
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 25021  21  0512
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 131
                    Mileage: 203279 km
                    Date: 2014.08.31
                    Time: 00:09:32
                    Voltage: 13.90 V
                        Term 50 Off
                    Reset counter: 131
                    Mileage: 203279 km
                    Date: 2014.08.31
                    Time: 00:09:32
                    Voltage: 13.90 V
                        Term 50 Off
                    Reset counter: 131
                    Mileage: 203279 km
                    Date: 2014.08.31
                    Time: 00:09:46
                    Voltage: 13.90 V
                        Term 50 Off
                    Reset counter: 131
                    Mileage: 203279 km
                    Date: 2014.08.31
                    Time: 00:09:46
                    Voltage: 13.90 V
                        Term 50 Off
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 131
                    Mileage: 203279 km
                    Date: 2014.08.31
                    Time: 00:09:46
                    Voltage: 13.90 V
                        Term 50 Off
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKD04J4XP
   Coding: 00003133
   Shop #: WSC 01383 790 00063
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B233198C3E87B23460-806E
   Serial number: 3572MSME31186350ZZZK
   Serial number: 3582MSME626F6150ZZZZ
   Serial number: 3512QSME3E22520AZZZT
   Serial number: 3522QSME1A22517DZZZX
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000034
   VCID: 03538978F718C3E34E0-8056
00895 - Cruise Control Switch (E45)
            014 - Defective
   Part No SW: 5K0 920 960 N    HW: 5K0 920 960 N
   Component: KOMBI         H04 0308
   Coding: 470B00
   VCID: 38292E94F2DE503BAB2-806C
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 020310F2001592
   Coding: E9801F06000202000001
   VCID: 698FBBD0F57439B3E4C-803C
   Component: IMMO          H04 0308
   VCID: 6A8DC4DCFCF232ABED6-803E
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2138
   Coding: 0000564
   VCID: 333319B8E738B3639E0-8066
   Part No: 1K0 909 144 J
   Revision: 00H17000
   VCID: 313F13B01D248173ECC-8064
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Coding: 0000564
   VCID: 34311AA4E236B45B87A-8060
Address 56: Radio
End----------(Elapsed Time: 00:44, VBatt start/end: 14.0V/14.0V)-----------
golfi_vend
Tartu, Estonia
C?ID=195131
I'm guessing not OE stalk?
Non-oe stalks have 2 major issues. One is the slider not making contact to pcb. Other is the signal wire needs to be soldered to fit 2008+ swcm-s.
SilentService
C?ID=397182
I've just had a look into the stalk I bought. It could be that I haven't got the right one. I've ordered a different one from 'Meyle' who seems to be a decent brand. we'll see if it fixes it
Cheers for the help
golfi_vend
Tartu, Estonia
C?ID=195131
How can it be different?
If it physically fits, it is correct one. Sometimes minor fixes need to be done to cheaper alternatives.
SilentService
C?ID=397182
Ah, I wondered whether the one I had may have been incompatible. The listing wasn't the clearest what models it worked with. Either way the new one is ordered now so i'll give it a go. Would you mind explaining those two common faults a bit more? I'll be honest I don't know what SWCM-S is
Cheers
golfi_vend
Tartu, Estonia
C?ID=195131
Cheers
I don't have any pictures of the defective slider, but just open the rear cover of the stalk. You can pull it apart with Your fingernail.
Second issue You can read here: https://forums.ross-tech.com/showthread.php?7272-Mk6-golf-steering-wheel-into-mk5-issues&styleid=5
