Nothing is ever as simple as it seems eh?
I've tried to fit Crusie Control to my MK6 1.6 TDI Golf. I followed a guide online using VCDS to amend my coding on the engine and steering wheel modules and fitting a new indicator stalk. The coding seemed to be accepted no problem using the standard BCM and I had no major issues fitting the new stalk.
Once it was all back together I cleared any fault codes and took it for a test drive. straight away on the dash, a cruise control error came up and the cruise control itself didn't function.
I plugged back in when I got in and the fault code 00895 (cruise control switch defective) had popped up. I took the whole thing apart again and make sure I hadn't screwed something up. everything seemed fine, but the fault code is still there.
Has anyone come across this problem before? The stalk is brand new so maybe I got a broken one? or am I making a mistake with the coding?
Any help would be gratefully received. I've added a few photos and my Autoscan below:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZAP142332 Mileage: 203270km-126306miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 B HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 5863
Revision: -------- Serial number: 00000000000000
Coding: 00114014032500080000
Shop #: WSC 00028 028 00023
ASAM Dataset: EV_ECM16TDI02103L906023B 001005
ROD: EV_ECM16TDI02103L906023A_001.rod
VCID: 2517F7E0556CDDD3004-8070
6116 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Mileage: 203279 km
Date: 2020.04.09
Time: 00:18:03
Engine speed: 832.75 /min
Normed load value: 15.7 %
Coolant temperature: 58 °C
Intake air temperature: 25 °C
Voltage terminal 30: 12.424 V
Environmental conditions-PV_AV_ENVD: 0.0 %
Environmental conditions-FRF_STATE_CRU_SWI_POS: 2
6118 - Cruise Control Switch (E45)
P0568 00 [036] - Implausible Signal
Time: 00:00:00
Coolant temperature: 55 °C
Intake air temperature: 27 °C
Voltage terminal 30: 12.649 V
Readiness: 1010 0000
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 133B200D092600FCC80E04E7901B0081300000
Shop #: WSC 00028 028 00001
VCID: 78A9EE94B2DE903B6B2-802C
Part No SW: 3C8 907 336 AB HW: 3C8 907 336 AB
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
ROD: EV_ClimaBasis_VW36.rod
VCID: 6D87CFC0CD1C2593884-8038
B10AB F0 [009] - Too Low
Reset counter: 54
Mileage: 154521 km
Date: 2018.06.08
Time: 15:41:57
Part No SW: 1K0 937 084 B HW: 1K0 937 084 B
Component: BCM PQ35 B 103 0575
Revision: 00103 AG
Coding: 40180A3A9025180044000080000000E443010088524D8160648000200000
VCID: 2D070FC00D1CE593C84-8078
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 25021 21 0512
Coding: 009795
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 131
Mileage: 203279 km
Date: 2014.08.31
Time: 00:09:32
Term 15 On
Voltage: 13.90 V
Term 50 Off
Reset counter: 131
Mileage: 203279 km
Date: 2014.08.31
Time: 00:09:32
Term 15 On
Voltage: 13.90 V
Term 50 Off
Reset counter: 131
Mileage: 203279 km
Date: 2014.08.31
Time: 00:09:46
Term 15 On
Voltage: 13.90 V
Term 50 Off
Reset counter: 131
Mileage: 203279 km
Date: 2014.08.31
Time: 00:09:46
Term 15 On
Voltage: 13.90 V
Term 50 Off
014 - Defective
Fault Status: 01101110
Reset counter: 131
Mileage: 203279 km
Date: 2014.08.31
Time: 00:09:46
Term 15 On
Voltage: 13.90 V
Term 50 Off
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKD04J4XP
Coding: 00003133
Shop #: WSC 01383 790 00063
ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B233198C3E87B23460-806E
Serial number: 3572MSME31186350ZZZK
Serial number: 3582MSME626F6150ZZZZ
Serial number: 3512QSME3E22520AZZZT
Serial number: 3522QSME1A22517DZZZX
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000034
VCID: 03538978F718C3E34E0-8056
00895 - Cruise Control Switch (E45)
014 - Defective
Part No SW: 5K0 920 960 N HW: 5K0 920 960 N
Component: KOMBI H04 0308
Coding: 470B00
VCID: 38292E94F2DE503BAB2-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 020310F2001592
Coding: E9801F06000202000001
VCID: 698FBBD0F57439B3E4C-803C
Component: IMMO H04 0308
VCID: 6A8DC4DCFCF232ABED6-803E
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2138
Coding: 0000564
VCID: 333319B8E738B3639E0-8066
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 313F13B01D248173ECC-8064
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Coding: 0000564
VCID: 34311AA4E236B45B87A-8060
Address 56: Radio
End----------(Elapsed Time: 00:44, VBatt start/end: 14.0V/14.0V)-----------
