rocket ron
New Member
Hi.
My name is Ronnie. New here on ross tech.
Need a bit of help. Have a 2007 Seat Leon 2.0 TFSI. Purchased the car end of January. Car had quite bad damage. I run a full scan when i got the car.
the ABS pump had to be replaced and i arranged for it to be done. The garage contacted me after a considerable time saying they couldnt fix the problem and gave me the car back. They have replaced the ABS pump but now im stuck.
Here is the scan now.
Please help with any info that may help me.
Many Many Thanks
Ronnie.
VIN: VSSZZZ1PZ7R091548 License Plate: LEON
Mileage: 175950km-109330mi Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ7R091548 Mileage: 175950km-109330miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1P0 907 115 HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH16--- Serial number: SEZ7Z0G3756072
Coding: 030300031C070160
Shop #: WSC 06441 785 00200
VCID: 68D4B60A5B1E590F0F-803C
9 Faults Found:
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - - MIL ON
001089 - EVAP Emission Control Sys
P0441 - 001 - Incorrect Flow - MIL ON
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected. - Intermittent
P0300 - 002 - - Intermittent
000771 - Cylinder 3
P0303 - 002 - Misfire Detected - Intermittent
000770 - Cylinder 2
P0302 - 002 - Misfire Detected - Intermittent
000769 - Cylinder 1
P0301 - 008 - Misfire Detected - Intermittent
000772 - Cylinder 4
P0304 - 002 - Misfire Detected - Intermittent
008825 - Leak in Air Intake System
P2279 - 002 -
Readiness: 0000 0001
Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
Component: GSG DSG 081 1309
Revision: 04508010 Serial number: 00000702070353
VCID: 2240E422FDA2735F91-8076
17106 - Transmission Output Speed Sensor (G195)
P0722 - 000 - No Signal - Intermittent
18201 - Transmission Output Speed Sensor 2 (G196)
P1793 - 000 - No Signal - Intermittent
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0004738
VCID: 73EED16612D8AAD7AA-8026
Part No: 1P0 907 044
Component: ClimatronicPQ35 010 0502
VCID: 69D2B30E4014600710-803C
01273 - Fresh Air Blower (V2)
010 - Open or Short to Plus
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004715857
Coding: 818C0F2F00041000431D00000000000000017F075C4000
VCID: 6CDCCA1A4FE6752F6B-8038
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 070307 022 0601
Coding: 00056208
Shop #: WSC 06441
10 Faults Found:
00984 - Left Tail Light (M4)
00985 - Right Tail Light (M2)
01506 - Bulb for Rear Fog; Right (L47)
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R4 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0P40NFYT
Coding: 0021044
VCID: 2F661D16BE70CE370E-807A
Subsystem 1 - Serial number: 6332MSME17734B3E
Subsystem 2 - Serial number: 6342MSME171A6A2B
Subsystem 3 - Serial number: 6351HTS65JHC49G6
Subsystem 4 - Serial number: 6361HTS6LNFKK3A7
00532 - Supply Voltage B+
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01589 - Igniter for Head-Airbag; Passenger Side (N252)
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0012142
VCID: 01028BAE58648847A8-8054
Component: E0221 002 0010
Part No: 1P0 920 925 B
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002401
Shop #: WSC 00606 067 57207
VCID: 2E580012B97AC73F05-807A
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 330010721902E6
Coding: 3F3F034007000203
Component: IMMO VO3 0422
Shop #: WSC 00137 211 56823
01176 - Key
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1130
Revision: 31008001 Serial number: 00000017478103
Coding: 0000688
VCID: 3B7E39467A082297B2-806E
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.142 H07 1806
VCID: 356A2F7E5C2CF4E744-8060
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 998000005283CC7F0006050560085F86107880
Shop #: WSC 19310 148 574531
VCID: 030E81A642789A57BA-8056
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 19310
Subsystem 6 - Part No: 1K0 951 605 C
Subsystem 7 - Component: NGS n.mounted
00893 - Switch for Trunk Handle (E234)
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1130
Revision: 31008001 Serial number: 00000523378116
Coding: 0000688
VCID: 3C7C3A5A7F0625AFBB-8068
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Part No: 1P2 035 186 A
Component: Radio BVX 0006
Coding: 0040424
VCID: 2B5E09068A68B21722-FFFE
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000001309936
Coding: 0000144
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000001273945
Coding: 0000144
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End---------------------(Elapsed Time: 03:12, udsna)-----------------------
VIN: VSSZZZ1PZ7R091548 License Plate: LEON APRIL
Mileage: 175980km-109348mi Repair Order:
VIN: VSSZZZ1PZ7R091548 Mileage: 175980km-109348miles
Shop #: WSC 66565 257 00032
Readiness: 0010 0001
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0021126
Shop #: WSC 06435 123 12345
VCID: 336E11665258EAD76A-8066
003 - Mechanical Failure
01542 - Yaw Rate Sensor (G202)
014 - Defective
Coding: 00056208
Shop #: WSC 06441
Coding: 0021044
Coding: 0012142
Coding: 0002401
00003 - Control Module
Coding: 0000688
Coding: 00000000
Shop #: WSC 19310
Coding: 0000688
Coding: 0040424
VCID: 2B5E09068A68B21722-807E
00856 - Radio Antenna
Coding: 0000144
Coding: 0000144
End---------------------(Elapsed Time: 01:52, udsna)-----------------------
Many Many Thanks
Ronnie.
