Help required for ABS coding.
rocket ron
Hi.
My name is Ronnie. New here on ross tech.
Need a bit of help. Have a 2007 Seat Leon 2.0 TFSI. Purchased the car end of January. Car had quite bad damage. I run a full scan when i got the car.
VIN: VSSZZZ1PZ7R091548   License Plate: LEON
Mileage: 175950km-109330mi   Repair Order:
Chassis Type: 1P (1K0)
VIN: VSSZZZ1PZ7R091548   Mileage: 175950km-109330miles
   Part No SW: 1P0 907 115     HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: 5BH16---    Serial number: SEZ7Z0G3756072
   Coding: 030300031C070160
   Shop #: WSC 06441 785 00200
   VCID: 68D4B60A5B1E590F0F-803C
9 Faults Found:
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -  - MIL ON
001089 - EVAP Emission Control Sys
               P0441 - 001 - Incorrect Flow - MIL ON
001287 - Idle Control System RPM
               P0507 - 001 - Higher than Expected. - Intermittent
               P0300 - 002 -  - Intermittent
000771 - Cylinder 3
               P0303 - 002 - Misfire Detected - Intermittent
000770 - Cylinder 2
               P0302 - 002 - Misfire Detected - Intermittent
000769 - Cylinder 1
               P0301 - 008 - Misfire Detected - Intermittent
000772 - Cylinder 4
               P0304 - 002 - Misfire Detected - Intermittent
008825 - Leak in Air Intake System
               P2279 - 002 -
Readiness: 0000 0001
   Part No SW: 02E 300 043 Q    HW: 02E 927 770 AE
   Component: GSG DSG         081 1309
   Revision: 04508010    Serial number: 00000702070353
   VCID: 2240E422FDA2735F91-8076
17106 - Transmission Output Speed Sensor (G195)
            P0722 - 000 - No Signal - Intermittent
18201 - Transmission Output Speed Sensor 2 (G196)
            P1793 - 000 - No Signal - Intermittent
   Revision: 00H11001
   Coding: 0004738
   VCID: 73EED16612D8AAD7AA-8026
   Part No: 1P0 907 044
   Component: ClimatronicPQ35 010 0502
   VCID: 69D2B30E4014600710-803C
01273 - Fresh Air Blower (V2)
            010 - Open or Short to Plus
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004715857
   Coding: 818C0F2F00041000431D00000000000000017F075C4000
   VCID: 6CDCCA1A4FE6752F6B-8038
   Subsystem 1 - Part No: 1P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 070307 022  0601
   Coding: 00056208
   Shop #: WSC 06441
10 Faults Found:
00984 - Left Tail Light (M4)
00985 - Right Tail Light (M2)
01506 - Bulb for Rear Fog; Right (L47)
   Part No SW: 3C0 909 605 L    HW: 3C0 909 605 L
   Component: R4 AIRBAG VW8   030 2522
   Revision: 12030000    Serial number: 003B0P40NFYT
   Coding: 0021044
   VCID: 2F661D16BE70CE370E-807A
   Subsystem 1 - Serial number: 6332MSME17734B3E
   Subsystem 2 - Serial number: 6342MSME171A6A2B
   Subsystem 3 - Serial number: 6351HTS65JHC49G6
   Subsystem 4 - Serial number: 6361HTS6LNFKK3A7
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01218 - Side Airbag Igniter; Passenger Side (N200)
01589 - Igniter for Head-Airbag; Passenger Side (N252)
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           636 0070
   Coding: 0012142
   VCID: 01028BAE58648847A8-8054
   Part No: 1P0 920 925 B
   Component: KOMBIINSTRUMENT VO3 0422
   Coding: 0002401
   Shop #: WSC 00606 067 57207
   VCID: 2E580012B97AC73F05-807A
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H12 0170
   Revision:   H12       Serial number: 330010721902E6
   Coding: 3F3F034007000203
   Component: IMMO            VO3 0422
   Shop #: WSC 00137 211 56823
01176 - Key
   Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1130
   Revision: 31008001    Serial number: 00000017478103
   Coding: 0000688
   VCID: 3B7E39467A082297B2-806E
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.142 H07 1806
   VCID: 356A2F7E5C2CF4E744-8060
   Component:    KSG PQ35 G2  020 0203
   Coding: 998000005283CC7F0006050560085F86107880
   Shop #: WSC 19310 148 574531
   VCID: 030E81A642789A57BA-8056
   Subsystem 5 - Part No: 1P0 951 171
   Component: Innenraumueberw.010 4971
   Coding: 00000000
   Shop #: WSC 19310
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Component:       NGS n.mounted
00893 - Switch for Trunk Handle (E234)
   Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1130
   Revision: 31008001    Serial number: 00000523378116
   Coding: 0000688
   VCID: 3C7C3A5A7F0625AFBB-8068
01553 - Motor for Central Locking; Passenger Door (V57); Lock
   Part No: 1P2 035 186 A
   Component: Radio BVX           0006
   Coding: 0040424
   VCID: 2B5E09068A68B21722-FFFE
   Part No SW: 1K0 959 703 N    HW: 1K0 959 795 H
   Component: J388   TUER-SG HL   1108
   Revision: 11006001    Serial number: 00000001309936
   Coding: 0000144
01813 - Supply Voltage for Door Controller; Rear Left (J388)
   Part No SW: 1K0 959 704 N    HW: 1K0 959 794 H
   Component: J389   TUER-SG HR   1108
   Revision: 11006001    Serial number: 00000001273945
   Coding: 0000144
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End---------------------(Elapsed Time: 03:12, udsna)-----------------------
the ABS pump had to be replaced and i arranged for it to be done. The garage contacted me after a considerable time saying they couldnt fix the problem and gave me the car back. They have replaced the ABS pump but now im stuck.
Here is the scan now.
VIN: VSSZZZ1PZ7R091548   License Plate: LEON APRIL
Mileage: 175980km-109348mi   Repair Order:
VIN: VSSZZZ1PZ7R091548   Mileage: 175980km-109348miles
   Shop #: WSC 66565 257 00032
Readiness: 0010 0001
   Part No: 1K0 907 379 D
   Coding: 0021126
   Shop #: WSC 06435 123 12345
   VCID: 336E11665258EAD76A-8066
01486 - System Function Test Activated
            003 - Mechanical Failure
            014 - Defective
   Coding: 00056208
   Shop #: WSC 06441
   Coding: 0021044
   Coding: 0012142
   Coding: 0002401
00003 - Control Module
   Coding: 0000688
   Coding: 00000000
   Shop #: WSC 19310
   Coding: 0000688
   Coding: 0040424
   VCID: 2B5E09068A68B21722-807E
00856 - Radio Antenna
   Coding: 0000144
   Coding: 0000144
End---------------------(Elapsed Time: 01:52, udsna)-----------------------
Please help with any info that may help me.
Many Many Thanks
Ronnie.
Is 1K0-907-379-D a suitable replacement for 1K0-907-379-AC ?
Have you tried coding it the same as the old module?
PS: Please Get Verified.
rocket ron
yes. i have tried to code it as old unit. but wont accept that number. is the pump not compatable ?
ronnie.
That is indeed a question that should be asked. But I personally do not have access to a proper parts catalog, so I'm not in a position to answer it.
rjgarciasr
C?ID=374478
ABS pump
ronnie.
I can't answer as to its compatibility, but I recently had an issue with my daughter's 2005 VW Passat 1.8T wagon.
It started out with not so good brakes.
I scanned the module and got an ABS pump fault code, my daughter convinced me that I couldn't fix it and to send it to an online repair service, so I did.
Got it back install it and VCDS couldn't communicate with it. So while waiting for it to be repaired (again under warranty) I bought a used one, but I made it absolutely clear that the part numbers had to match, no if and, or buts.
Installed, coded, and bled it, worked just fine. This all took time mind you, researching, searching, testing power & ground, scoping the CAN bus, buying the right module with manifold block which cost me less than the module repair which didn't work and was a waste of time.
I didn't install the unit, just connected the module to the car, once it was coded, then I connected it to the brake lines.
I'm not sure if this helps you any, just keep it in the back of your mind as you go through your issues.
-rjgarciasr
