Received a message saying "please send this scan to Ross-Tech"
technodevotee
Worcester, UK
C?ID=339141
Just scanned my 2020 model Touareg with my HEX-NET and using the web interface it said that ASAM data was missing which isn't really surprising.
I tried the download the first time and tried again but got the same message so I cancelled the download the second time so that I could save the log file but it isn't showing up in saved logs.
I connected the hex-net to my computer and did a scan. When it finished it said that ROD(s) were missing and asked me to send you the log files. So here it is:
Saturday,28,March,2020,16:43:16:52412
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4513.4
VIN: WVGZZZCRZLD003566   License Plate: BJ69LJL
Mileage: 10801km-6711mi   Repair Order:
Chassis Type: CR-VW53 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 42 44 46 52 5F 69 6C 6D
          74 81 A5 AC BB BC CB D6 D7 DE
VIN: WVGZZZCRZLD003566   Mileage: 10801km-6711miles
CB-Rear Axle Steering -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: OK 0000
Address 01: Engine (J623-DENA)       Labels: None
   Part No SW: 760 907 401 G    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0002
   Revision: CAH26---
   Coding: 292A4032057E050335180000000400000000000000000000
   Shop #: WSC 31414 039 00001
   ASAM Dataset: EV_ECM30TDI011760907401G 001002
   ROD: N/A
   VCID: 197A3B6B18550E8742-804C
No ASAM data for: "EV_ECM30TDI011760907401G" (VW53)
31519 - ROD - Unknown Error Code
          - 00 [100]
                    Mileage: 10688 km
                    Date: 2020.03.21
                    Time: 13:38:50
21583 - ROD - Unknown Error Code
          - 00 [032]
Address 02: Auto Trans (J217)       Labels:* Redir Fail!
   Part No SW: 760 927 158 B    HW: 0D5 927 156 N
   Component: 0D5  30TDIRdW H05 1003
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011.rod
   VCID: 1F0E1573067160B7BC-804A
   Part No SW: 4M6 907 379 AC    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0856
   Coding: 1DA732B730A20B99DEA34897188356EAE93AE1B84C0CD07B12186A57975C87
   ASAM Dataset: EV_ESP9BOSCHCMP 004011
   ROD: EV_ESP9BOSCHCMP_VW53.rod
   VCID: 7EB008F7E13BC9BFD7-802A
200960 - Databus
          [Signal_LWR_Hoehenwert_VL_error_(255)]
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000384427733
   Coding: 0138B8000000A88188000101210100008900000707008F8F00000000015000
   Shop #: WSC 31414 043 00001
   ROD: EV_SCMPasseSideCONTIAU736_VW53.rod
   VCID: 3D32CFFBACBD12A78E-8068
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ8001250619402580D7
   Coding: BF2F00
   Part No SW: 4N0 907 063 KG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0691
   Coding: 07501143E1790009070D97085BBE8C40000B30100000009301100800FB2476011BC500BB12B6C6170000010000D128181800000044010104000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016_VW53.rod
   VCID: 7DB20FFBEC3DD2A7CE-8028
   Subsystem 1 - Part No SW: 762 955 113     HW: 762 955 113
   Component: WIPER 250719  011 0420
   Serial number: VZ1SKA 1000917250719
   Serial number: 23357623X81A955555A0
   Coding: 02006D
   Light switch:
   Subsystem 3 - Part No SW: 762 941 633     HW: 762 941 633
   Component: E1 - LTM  H06 0054
   Serial number: 13S27.06.1900140204
   Subsystem 4 - Part No SW: 3G0 857 511 AL    HW: 3G0 857 511 AL
   Serial number: GX1CE130041920810040
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 760 947 105 N    HW: 760 947 105 N
   Component: Dachelektroni  H32 0057
   Serial number: 00000774360000000000
405507 - Functional Limitation due to Energy Management
          B10CD 00 [009] - -
          [Function limitation due to energy management system]
                    Reset counter: 183
                    Mileage: 10801 km
                    Date: 2020.03.27
                    Time: 12:01:12
                    average_Voltage_terminals: 11.40 V
                    Outside air temperature sensor-Resistance: 0.00 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 8.50 °C
                    interior_temperature: 15.50 °C
                    Vehicle speed: 0.00 km/h
   Part No SW: 760 907 561 C    HW: 760 907 561
   Component: LRR4R         H04 0333
   Coding: 32657FCB78000400000020A000000010051246484401009E00
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 1C74227F17677BAF59-8048
   Part No SW: 4M0 959 655 J    HW: 4M0 959 655 J
   Component: AirbagVW31    H07 2720
   Serial number: 003YQM020RRC
   Coding: 88CCC0C00C800000585400EF308D41A80065
   Shop #: WSC 31414 030 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 42C8BC07D5436D5FF3-8016
   Subsystem 1 - Part No SW: -----------    HW: 480 002 207 19
   Serial number: 357000000004BC819E3Y
   Subsystem 2 - Part No SW: -----------    HW: 480 002 207 19
   Serial number: 35800000000D0B152E3M
   Subsystem 3 - Part No SW: -----------    HW: 480 032 507 19
   Component: SideSensor_Dr  002 0149
   Serial number: 351001C24B8AC8C07B0L
   Subsystem 4 - Part No SW: -----------    HW: 480 032 507 19
   Component: SideSensor_Pr  002 0149
   Serial number: 352001C1CC740CA03B1A
   Subsystem 5 - Part No SW: -----------    HW: 480 030 606 19
   Component: FrontSensor_D  002 0189
   Serial number: 355001C20FF2EDF0CB95
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 030 606 19
   Component: FrontSensor_P  002 0189
   Serial number: 356001C20FF326A07ABM
   Pedestrian Protection Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 032 606 19
   Component: PedP_Sensor_D  002 014A
   Serial number: 228001C208FD7590192A
   Subsystem 8 - Part No SW: -----------    HW: 480 031 807 19
   Component: PedP_Sensor_P  002 014A
   Serial number: 229001C2462C0020BC90
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 480 032 506 19
   Component: PedP_Sensor_C  002 014A
   Serial number: 230001C208F57E711D6B
   Subsystem 10 - Part No SW: -----------    HW: 480 001 406 19
   Serial number: I0M00000000B1438CCBG
   Subsystem 11 - Part No SW: -----------    HW: 480 001 406 19
   Serial number: I0N00000000E1438CCBK
   Part No SW: 760 953 507 B    HW: 760 953 507 B
   Component: Lenks.Modul   H03 0006
   ROD: EV_SMLSKLOAU736_VW53.rod
   Part No SW: 762 920 790 A    HW: 762 920 790 A
   Component: FBenRDW       H12 0208
   Coding: A5A631E27F94260001A86322B0E06808E40000A0
   ASAM Dataset: EV_DashBoardAU65X 001017
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 1B76216312697C9750-804E
   Operating Unit Drive Mode Selection:
   Subsystem 1 - Part No SW: 760 927 531 G    HW: 760 927 531 G
   Component: E881 BedieFPA  001 0460
   Serial number: 000000091171SG3000M1
   Level control system control head:
   Subsystem 2 - Part No SW: 760 927 135 B    HW: 760 927 135 B
   Component: E281 BedieNiv  001 0110
   Serial number: 000000091171SG3001CH
   Part No SW: 4N2 907 468 BB    HW: 4N2 907 468 AB
   Component: Gateway       H16 0052
   Revision: BD000001    Serial number: 018BD855619725
   Coding: 0301000300008E407F07000000DB0532589E00070C000000037D078E10000100
   ASAM Dataset: EV_CGateCONTIAU491 004190
   ROD: EV_CGateCONTIAU491_004_VW53.rod
   VCID: 7AB804E7FD13E59FEB-802E
   Subsystem 1 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190001239260049243
   Coding: 2FFFFF
   Serial number: 7379992105
8519683 - Energy Management Active
          U140B 00 [009] - -
                    Reset counter: 183
                    Mileage: 10801 km
                    Date: 2020.03.27
                    Time: 12:01:03
                    EM_vehicle_state: 00 10
                    Static current shutdown level: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000192483014
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 3424EADF9FF7D3EF71-8060
   Component: MEM-FS        009 0044
   Serial number: 00000384338324
   Coding: 01389A400000A48188000101210100008900000707008F8F00000000015000
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ8001250619402580CF
   Coding: BF2F00
   Part No SW: 4M1 959 593 J    HW: 4M1 959 593 D
   Component: TSG FS002 0421
   Serial number: YE007SFF28625
   Coding: 003F9A00DE01040000013082
   ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
   ROD: EV_DCU2DriveSideMAXHKLO_VW53.rod
   VCID: 44C4BA1FCF57636FC1-8010
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0505
   Coding: B2150101000100
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 3228ECC765E3DDDF63-8066
   Part No SW: 4N0 907 064 DP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H15 0202
   Coding: 01350000AFB000487329A0041C00480203000000004704502F0400000508803F001F31C4010001
   ASAM Dataset: EV_BCM2CONTIAU651 010009
   ROD: EV_BCM2CONTIAU651_010_VW53.rod
   VCID: 004C760F9BCFBF4FA5-8054
   Ignition key:
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY1916516JJ
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000487902
   Rear Spoiler Adjustment:
   Part No SW: 4M1 959 592 J    HW: 4M1 959 592 D
   Component: TSG BFS002 0421
   Serial number: YE007SFF3060B
   Coding: 003F9A00DE01040000013080
   ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 43C6B903CA596457F8-8016
   Part No SW: 760 035 063 A    HW: 760 035 063 A
   Component: MU-H-LND-EU   049 2648
   Coding: 02350601FF00000043110101C08808301F0206E601A004009F
   Shop #: WSC 31414 152 00001
   ASAM Dataset: EV_MUHigGen2pALPI 001001
   ROD: EV_MUHigGen2pALPI_VW53.rod
   VCID: 0F6E4533D691D0372C-805A
   Subsystem 1 - Part No SW: 762 919 618     HW: 762 919 618
   Component: ABT_Prem_R  H40 5211
   Serial number: VWZ6ZGW1710136
   Subsystem 2 - Part No: V03 959 805 HG
   Component: MIB2P_EU_Q119  0360
   Subsystem 3 - Part No: V03 959 800 EG
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 762 927 341     HW: 762 927 341
   Component: VW536LLB  H06 0109
   Serial number: 2019050600000182
   Media socket:
   Subsystem 5 - Part No SW: 5G0 035 953 D    HW: 0
H08 0014
   Part No SW: 4M0 907 383 G    HW: 4M0 907 383 B
   Component: Anhaenger     H33 0273
   Revision: 9A001003    Serial number: 0522821047
   Coding: 0110000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 3620D0D7898BC1FF4F-8062
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 760 980 568     HW: 760 980 568
   Component: RVC Compact+  H09 0250
   Coding: 0135060123002015000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMLBEv 001001
   ROD: EV_CamSysRVRVCARPANAMLBEv_VW53.rod
   VCID: 618A538B70851647CA-8034
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4
   Coding: 17D8
   ROD: EV_DeckLidCONTIAU736_VW53.rod
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4M0 907 777 S    HW: 4M0 907 777 B
   Component: Fahrwerk-SG   H37 1253
   Serial number: 0807190824
   Coding: B0504940F8
   ASAM Dataset: EV_ChassContrContiAU426 001004
   ROD: EV_ChassContrContiAU426.rod
   VCID: 49DAAB2BE875BE0732-801C
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130657889
   Coding: 303030
   Part No SW: 762 713 041 B    HW: 4M2 713 041 G
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 19061753171127
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 116A434BC0A5C6C73A-8044
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AL    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0293
   Coding: 04C2840000000000000806000090C63C18075300000000000000000000000000000000000000000000000000000000000000000000000000000040000000000000001004000000700000004000000000008040000020
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_VW53.rod
   VCID: 095A6B2BA8F5FE07F2-805C
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_VW53.rod
   Part No SW: 4M1 959 595 J    HW: 4M1 959 595 D
   Component: TSG HFS004 0421
   Serial number: YE007SFK23657
   Coding: 003E92000000040000013080
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   VCID: 46C0A017F96B517FDF-8012
   Component: TSG HBFS004 0421
   Serial number: YE007SFK23656
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0698
   Revision: --------    Serial number: CCC_098_B_1122_
   Coding: 42250E00
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010.rod
   VCID: 6FAE25B3B651B0374C-803A
   Part No SW: 7P5 941 591 BH    HW: 7P5 941 591 B
   Component: LED1L         H07 0009
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   VCID: 034679038AD9A457B8-8056
   Component: LED1R         H07 0009
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW53.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 400000
   ASAM Dataset: EV_Charg1MobilDevicAU651 004001
   ROD: EV_Charg1MobilDevicAU651.rod
   VCID: 230619832A19445798-8076
End----(Elapsed Time: 02:14, VBatt start/end: 11.3V/11.4V. VIgn 11.3V)-----
Saturday,28,March,2020,16:44:22:52412
I expect there will be a new version of VCDS out next week that will address this.
PS: As this issue is not HEX-NET specific, I'm moving it to VCDS Support.
technodevotee
Worcester, UK
C?ID=339141
Thanks very much. I'll keep an eye out for that and report back.
technodevotee
Worcester, UK
C?ID=339141
Actually, there are a number of issues here which may or may not be related to each other.
I forgot to mention that I can't get into the advanced section on the engine (I only wanted to check the adblue level) but I assume that is because of the missing data file.
Maybe I should have posted them separately?
icardiag
Europe
C?ID=113031
Looking forward to a new version of VCDS too :thumbs:
I contacted the support this week due to similar issue with new Octavia NX (SK38) which I was not able to scan at all :cry:
I would not have high hopes for SK38 just yet.
icardiag
Europe
C?ID=113031
:cry::cry::cry:
I hope at least scanning and adp reading will be available. Regarding SFD, well we'll see...
:cry::cry::cry:
You will certainly be able to try, and provide feedback. :)
DV52
C?ID=194404
Just scanned my 2020 model Touareg with my HEX-NET. So here it is:
Wow- that's the second-longest long-code string I've seen on a module!!!
PetrolDave
Westbury, UK
C?ID=1423
Kinda makes switching from (very) long coding to all adaptation channels more understandable IMHO.
technodevotee
Worcester, UK
C?ID=339141
Installed latest Version this morning and did an update and does seem to have fixed VCDS but I got the missing ASAM messages in VCDS-Mobile again and it wouldn't update.
It just hangs at 2% (6kb) like before. Just goes round in circles, error message, downloading, hanging.
I was able to save the auto-scan by scrolling to the bottom of the page but I couldn't upload it to the web and had to bring it indoors and do it.
While indoors, I used to PC to update it again and that seems to have worked but I need to try another scan in mobile to see if it is working properly.
#hndoc:?docid=00005AE2&xt=hnh:D3614DEF7F9D06EADD2FBD6747482CA816BE0CEC6CF6CF2B7475B07696571201
VCDS Mobile 0.4513.0.4
BB-Door Rear Drv Side -- Status: OK 0000
BC-Door Rear Pass Side -- Status: OK 0000
Address 01: Engine  (DENA2 J623)	Labels: None
	Revision: CAH26---
	ROD: N/A
	VCID: 19755E67B2553A8355ECB7-804C
No fault codes found.
Address 02: Auto Trans  (J217)	Labels: None
	Revision: --H05---
	Coding: 100000
	ROD: N/A
	VCID: 1F01707FAC7154B3AB28F9-804A
	No ASAM data for: "EV_TCMALX52011"
	ROD: N/A
	VCID: 7EBF6DFB4B3BFDBBC0FECC-802B
	No ASAM data for: "EV_ESP9BOSCHCMP"
200960 - ROD - Unknown faultcode
Address 06: Seat Mem. Pass  (J521)	Labels: None
	ROD: N/A
	VCID: 3D3DAAF706BD26A3997403-8068
	No ASAM data for: "EV_SCMPasseSideCONTIAU736"
	Subsystem 1 - 	Part No SW: 4N0-907-182
	Component: N477 VB1 BFSvH04 0011
	Serial Number: SJ8001250619402580D7
	Coding: BF2F00
Address 09: Cent. Elect.  (J519)	Labels: None
	ROD: N/A
	VCID: 7DBD6AF7463DE6A3D9F4C3-8028
	No ASAM data for: "EV_BCM1BOSCHAU651"
	Subsystem 1 - 	Part No SW: 762-955-113
	Serial Number: VZ1SKA 1000917250719
	Subsystem 2 - 	Part No SW: 81A-955-555-A
	Serial Number: 23357623X81A955555A0
	Coding: 02006D
	Subsystem 3 - 	Part No SW: 762-941-633
	Serial Number: 13S27.06.1900140204
	Subsystem 4 - 	Part No SW: 3G0-857-511-AL
	Component: Y7_InnenspiegH09 0002
	Serial Number: GX1CE130041920810040
	Coding: 030000
	Subsystem 5 - 	Part No SW: 760-947-105-N
	Component: DachelektroniH32 0057
	Serial Number: 00000774360000000000
405507 - ROD - Unknown faultcode
Address 13: Auto Dist. Reg  (J428)	Labels: None
	ROD: N/A
	VCID: 1C7B4773BD674FAB4E0A96-8049
	No ASAM data for: "EV_ACCBOSCHAU65X"
Address 15: Airbags  (J234)	Labels: None
	ROD: N/A
	VCID: 42C7D90B7F43595BE48678-8017
	No ASAM data for: "EV_AirbaVW31SMEAU65x"
	Subsystem 1 - 	Part No SW: --------------
	Component: SideSensor_Df001 0887
	Serial Number: 357000000004BC819E3Y
	Subsystem 2 - 	Part No SW: --------------
	Component: SideSensor_Pf001 0887
	Serial Number: 35800000000D0B152E3M
	Subsystem 3 - 	Part No SW: --------------
	Component: SideSensor_Dr002 0149
	Serial Number: 351001C24B8AC8C07B0L
	Subsystem 4 - 	Part No SW: --------------
	Component: SideSensor_Pr002 0149
	Serial Number: 352001C1CC740CA03B1A
	Subsystem 5 - 	Part No SW: --------------
	Component: FrontSensor_D002 0189
	Serial Number: 355001C20FF2EDF0CB95
	Subsystem 6 - 	Part No SW: --------------
	Component: FrontSensor_P002 0189
	Serial Number: 356001C20FF326A07ABM
	Subsystem 7 - 	Part No SW: --------------
	Component: PedP_Sensor_D002 014A
	Serial Number: 228001C208FD7590192A
	Subsystem 8 - 	Part No SW: --------------
	Component: PedP_Sensor_P002 014A
	Serial Number: 229001C2462C0020BC90
	Subsystem 9 - 	Part No SW: --------------
	Component: PedP_Sensor_C002 014A
	Serial Number: 230001C208F57E711D6B
	Subsystem 10 - 	Part No SW: --------------
	Component: PedPSensor_D2001 0887
	Serial Number: I0M00000000B1438CCBG
	Subsystem 11 - 	Part No SW: --------------
	Component: PedPSensor_P2001 0887
	Serial Number: I0N00000000E1438CCBK
	Shop #: WSC 00000 000
	ROD: N/A
	No ASAM data for: "EV_SMLSKLOAU736"
Address 17: Instruments  (J285)	Labels: None
	ROD: N/A
	VCID: 1B79446FB869489347008D-804E
	No ASAM data for: "EV_DashBoardAU65X"
	Subsystem 1 -
Address 19: CAN Gateway  (J533)	Labels: None
	Revision: BD000001
	ROD: N/A
	VCID: 7AB761EB5713D19BFCD6E0-802F
	No ASAM data for: "EV_CGateCONTIAU491"
	Subsystem 1 - 	Part No SW: 5G0-959-442-AB	Labels: 3C8-959-537.clb
	Component: E221__MFL-MD9H18 0052
	Serial Number: 39190001239260049243
	Coding: 2FFFFF
	Subsystem 2 - 	Part No SW: 8S0-915-181-C
	Component: J367-BDMHellaH10 9070
	Serial Number: 7379992105
8519683 - ROD - Unknown faultcode
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	ROD: N/A
	VCID: 342B8FD335F7E7EB661A9E-8061
	No ASAM data for: "EV_ELVMarqMQBA0"
Address 36: Seat Mem. Drvr  (J136)	Labels: None
	ROD: N/A
	No ASAM data for: "EV_SCMDriveSideCONTIAU736"
	Serial Number: SJ8001250619402580CF
	Coding: BF2F00
Address 42: Door Elect, Driver  (J386)	Labels: None
	Component: TSG FS
	ROD: N/A
	VCID: 44CBDF136557576BD6BA4E-8011
	No ASAM data for: "EV_DCU2DriveSideMAXHKLO"
Address 44: Steering Assist  (J500)	Labels: None
	ROD: N/A
	VCID: 322789CBCFE3E9DB74E688-8067
	No ASAM data for: "EV_EPSVWBSAU426"
Address 46: Central Conv.  (J393)	Labels: None
	ROD: N/A
	VCID: 80439303B1CF0B4B321222-80D5
	No ASAM data for: "EV_BCM2CONTIAU651"
	Subsystem 1 - 	Coding: 000000
	Subsystem 2 - 	Part No SW: 5Q0-951-172
	Serial Number: 000000000ZY1916516JJ
	Subsystem 3 - 	Part No SW: 5Q0-951-605-B
	Serial Number: 00000000000000487902
	Subsystem 4 -
Address 52: Door Elect, Pass.  (J387)	Labels: None
	Component: TSG BFS
	ROD: N/A
	VCID: 43C9DC0F60595053EFB045-8016
	No ASAM data for: "EV_DCU2PasseSideMAXHKLO"
Address 5F: Information Electr.  (J794)	Labels: None
	ROD: N/A
	VCID: 0F61203F7C91E4333B8809-805A
	No ASAM data for: "EV_MUHigGen2pALPI"
	Subsystem 1 - 	Part No SW: 762-919-618
	Serial Number: VWZ6ZGW1710136
	Subsystem 2 - 	Part No SW: V03-959-805-HG
	Component: MIB2P_EU_Q1190360
	Subsystem 3 -
	Subsystem 4 - 	Part No SW: V03-959-800-EG
Address 69: Trailer  (J345)	Labels: 5Q0-907-383.clb
	Revision: 9A001003
	ROD: N/A
	VCID: 362FB5DB238BF5FB580EF4-8063
	No ASAM data for: "EV_TrailFunctGener2Hella"
Address 6C: Back-up Cam.  (J772)	Labels: None
	ROD: N/A
	VCID: E185B6875A85A2435DDC0F-80B4
	No ASAM data for: "EV_CamSysRVRVCARPANAMLBEv"
Address 6D: Trunk Elect.  (J605)	Labels: 5Q0-959-107.clb
	Revision: --------
	Coding: 17D8
	ROD: N/A
	No ASAM data for: "EV_DeckLidCONTIAU736"
Address 74: Chassis Control  (J775)	Labels: None
	Coding: B0504940F8
	ROD: N/A
	VCID: 49D5CE2742758A0325CC87-801C
	No ASAM data for: "EV_ChassContrContiAU426"
	Revision: 0L0D5012
	ROD: N/A
	VCID: 116526476AA5F2C32DBC1F-8044
	No ASAM data for: "EV_GSMWaehlZFAU736"
Address A5: Frt Sens. Drv. Assist  (J1121)	Labels: None
	ROD: N/A
	VCID: 89558E2782F54A03654C47-80DC
	No ASAM data for: "EV_ZFASAU516"
2117691 - ROD - Unknown faultcode
2117692 - ROD - Unknown faultcode
	ROD: N/A
	No ASAM data for: "EV_RDCMINERGAU736"
Address BB: Door Rear Drv Side  (J388)	Labels: None
	Component: TSG HFS
	ROD: N/A
	VCID: 46CFC51B536B657BC8AEA4-8013
	No ASAM data for: "EV_DCU2RearDriveMAXHKLO"
Address BC: Door Rear Pass Side  (J389)	Labels: None
	Component: TSG HBFS
	ROD: N/A
	No ASAM data for: "EV_DCU2RearPasseMAXHKLO"
Address CB: Rear Axle Steering  (J1019)	Labels: None
	Revision: --------
	Coding: 42250E00
	ROD: N/A
	VCID: 6FA140BF1C5184335B4869-803A
	No ASAM data for: "EV_RearAxleSteerZFAU736"
	ROD: N/A
	VCID: 83499C0FA0D910532F3005-80D6
	No ASAM data for: "EV_LED_PLUS_L_KEBODAVW416"
	ROD: N/A
	No ASAM data for: "EV_LED_PLUS_R_KEBODAVW416"
Address DE: Charger 1 for mobile dev  (J1146)	Labels: None
	Coding: 400000
	ROD: N/A
	VCID: 23097C8F801970538F7025-8076
	No ASAM data for: "EV_Charg1MobilDevicAU651"
End--(Elapsed Time: 03:16, VBatt start/end: 12.0/12.0 Vign: 11.9)-
technodevotee
Worcester, UK
C?ID=339141
How does the update mechanism work?
Does VCIConfig look to see what errors were generated and download the missing files?
Why does vcds-mobile go round and round in circles failing with an error message, attempting to download, failing etc?
It would be really helpful if there was an error log that we could read to see why it isn't working.
Please be assured that I'm not being critical, I'm just trying to understand what is going on and if there's anything I can do to help.
Shaun
I've switched your interface to the alpha testing channel, please give the latest alpha VCDS-Mobile dataset a try. Use the following procedure to get up to date:
1. Update with VCIConfig, to get alpha codeblock and base data
2. Autoscan vehicle with mobile
3. Check for updates with VCIConfig again, to download alpha rods
technodevotee
Worcester, UK
C?ID=339141
Well I'll go to the foot of our stairs!
It worked perfectly. No errors and no updates after the autoscan.
#hndoc:?docid=00005AEA&xt=hnh:03B6372F75E8BE0F8F21A5117CCB6F7A732E3343C30AAB585CF9EDCDAACB4C52
VCDS Mobile 0.4523.0.4
	Revision: CAH26---
	ROD: EV_ECM30TDI011760907401G.rod
	VCID: 19755E67B2553A8355ECBD-804C
Address 02: Auto Trans  (J217)	Labels: 76-02.clb
	Revision: --H05---
	Coding: 100000
	ROD: EV_TCMALX52011_VW53.rod
	VCID: 1F01707FAC7154B3AB28F3-804A
Address 03: ABS Brakes  (J104)	Labels: 4M-03.clb
	VCID: 7EBF6DFB4B3BFDBBC0FEC6-802B
200960 - Databus
	VCID: 3D3DAAF706BD26A3997409-8068
	Coding: BF2F00
Address 09: Cent. Elect.  (J519)	Labels: 4N-09.clb
	ROD: EV_BCM1BOSCHAU651_016.rod
	VCID: 7DBD6AF7463DE6A3D9F4C9-8028
	Coding: 02006D
	Coding: 030000
	B10CD 00 [008] -  -
	VCID: 1C7B4773BD674FAB4E0A9C-8049
	VCID: 42C7D90B7F43595BE48672-8017
	VCID: 1B79446FB8694893470087-804E
	Subsystem 1 -
	Revision: BD000001
	VCID: 7AB761EB5713D19BFCD6EA-802F
	Coding: 2FFFFF
	U140B 00 [008] -
	ROD: EV_ELVMarqMQBA0_VW53.rod
	VCID: 342B8FD335F7E7EB661A94-8061
	ROD: EV_SCMDriveSideCONTIAU736_VW53.rod
	Coding: BF2F00
	Component: TSG FS
	ROD: EV_DCU2DriveSideMAXHKLO.rod
	VCID: 44CBDF136557576BD6BA44-8011
	VCID: 322789CBCFE3E9DB74E682-8067
	ROD: EV_BCM2CONTIAU651_010.rod
	VCID: 80439303B1CF0B4B321228-80D5
	Subsystem 4 -
	Component: TSG BFS
	ROD: EV_DCU2PasseSideMAXHKLO.rod
	VCID: 43C9DC0F60595053EFB04F-8016
Address 5F: Information Electr.  (J794)	Labels: 76-5f.clb
	VCID: 0F61203F7C91E4333B8803-805A
	Subsystem 3 -
	Revision: 9A001003
	ROD: EV_TrailFunctGener2Hella_VW53.rod
	VCID: 362FB5DB238BF5FB580EFE-8063
	ROD: EV_CamSysRVRVCARPANAMLBEv.rod
	VCID: E185B6875A85A2435DDC05-80B4
	Revision: --------
	Coding: 17D8
	ROD: EV_DeckLidCONTIAU736.rod
	Coding: B0504940F8
	VCID: 49D5CE2742758A0325CC8D-801C
	Revision: 0L0D5012
	VCID: 116526476AA5F2C32DBC15-8044
	ROD: EV_ZFASAU516_001.rod
	VCID: 89558E2782F54A03654C4D-80DC
2117691 - Ethernet Databus
	U11C4 00 [008] - No Communications
2117692 - Control unit for information electronics 1
	U1054 00 [008] - No Communication
	Component: TSG HFS
	VCID: 46CFC51B536B657BC8AEAE-8013
	Component: TSG HBFS
	Revision: --------
	Coding: 42250E00
	VCID: 6FA140BF1C5184335B4863-803A
	ROD: EV_LED_PLUS_L_KEBODAVW416_VW53.rod
	VCID: 83499C0FA0D910532F300F-80D6
Address DE: Charger 1 for mobile dev  (J1146)	Labels: 4N0-035-502.clb
	Coding: 400000
	ROD: EV_Charg1MobilDevicAU651_VW53.rod
	VCID: 23097C8F801970538F702F-8076
End--(Elapsed Time: 03:17, VBatt start/end: 12.2/12.3 Vign: 12.3)-
Great Stuff!
