B7 A4 Dead starts/stalls
Dcprice85
MD, USA
C?ID=124251
Saturday,07,March,2020,21:27:48:20475
VCDS Version: 19.6.2.0 (x64)
VIN: WAUEF78E96A043443   License Plate: DARE1
Mileage: broke   Repair Order:
          67 69 75 76 77
   Part No SW: 8E0 910 115 M    HW: 8E0 907 115 D
   Component: 2.0l R4/4V TFSI     0080
   Revision: --H10---    Serial number:
   Coding: 0104010A180F0120
   Shop #: WSC 09110 444 11712
   VCID: 2B5F01278A4ACB1722-807E
049493 - No Communication with Instrument Cluster
               U0155 - 008 -
                    Temperature: 3.0°C
                    Temperature: 5.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 11.176 V
049412 - No Communication with Cruise Control Module
               U0104 - 008 -
                    Temperature: 3.0°C
                    Temperature: 5.0°C
                    Voltage: 11.176 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 008 -
                    Temperature: 3.0°C
                    Temperature: 5.0°C
                    Voltage: 11.176 V
001299 - Incorrect Immobilizer Key
               P0513 - 008 -
                    RPM: 521 /min
                    Load: 60.0 %
                    Temperature: 3.0°C
                    Temperature: 5.0°C
                    Voltage: 10.287 V
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
   Component: ESP8 quattro    H04 0120
   Coding: 0004526
   Shop #: WSC 06335 000 00000
   VCID: 2953FB2F80B6D907D0-807C
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x4202
                    Hex Value: 0x0013
                    Hex Value: 0x2994
                    Hex Value: 0x0001
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x4202
                    Hex Value: 0x0024
                    Hex Value: 0x0187
                    Hex Value: 0x0001
   Part No: 8E0 820 043 AM
   Component:   A4 Klimaautomat   2831
   Coding: 00000
   VCID: 6CDDC23B1CC40C2F6B-513C
            49-00 - No Communications
            27-00 - Implausible Signal
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  USA 0504
   Coding: 01003
   Shop #: WSC 65536
   VCID: 3B7F3167292A5B97B2-4B18
            79-00 - Please Check Fault Codes
01312 - Powertrain Data Bus
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H11 3540
   Revision: 91H1135    Serial number: 0036N000P1P/
   Coding: 0032607
   VCID: 3C7D327B7F245CAFBB-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 33WJJ
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB401C0C620Gÿ†63
   Subsystem 5 - Serial number: 0C620Gÿ†6342DRB401C2CB9D1ÿ†63
   Subsystem 6 - Serial number: 2CB9D1ÿ†6352ARB400710E70Bÿ†63
   Subsystem 7 - Serial number: 10E70Bÿ†6362ARB4006F3323Fÿ†63
   Subsystem 8 - Serial number: F3323Fÿ†63729RB4008CED41Zÿ†63
   Subsystem 9 - Serial number: CED41Zÿ†63829RB4008CEE830ÿ
   Subsystem 10 - Serial number: CEE830ÿ
                    Fault Status: 11100100
   Part No: 8E0 953 549 R
   Component: Lenksáulenmodul     0501
   Coding: 04041
   Shop #: WSC 08213
   VCID: 42814C834EC02A5FF1-4B18
6 Faults Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            37-00 - Faulty
01301 - Control Module for Voice Recognition (J507)
01304 - Radio
   Part No: 8E0 959 433 BT
   Component: Komfortgerát T7B    3332
   Coding: 11896
   Shop #: WSC 06335
   VCID: 040D8A9B1454E46F83-4B32
   Component: Tõrsteuer.FS BRM 0406
   Component: Tõrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0205
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0205
6 Faults Found:
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
00955 - Key 1
            35-00 - -
End-------------------------(Elapsed Time: 07:00)--------------------------
Address 09: DTCs cleared
The car will start and shut off. I have no power to the instrument cluster or radio. The windows work. The alarm worked until I did a capacitor discharge. I am not able to reach module 17 instruments I believe it is. Please help.
Bruce
Near Philadelphia, PA, USA
Fuses? Maybe some have blown?
Dcprice85
MD, USA
C?ID=124251
I checked the panel left of the dash. They all were ok.
Well, it sure looks like there are a number of things that aren't powering up. You're going to need Wiring Diagrams to see where the things that aren't powering up get power.
Dcprice85
MD, USA
C?ID=124251
Pulled cluster. Checked for 12+ and grounds. All good at the pins. Pulled cluster from donor car plugged in and it lit up like a Christmas tree.
Is there a reputable recon company that can repair these or take the used one I have to the dealer to swap? Or new from the dealer.
