Audi A3 2.0 TFSI DSG - Basic Settings
cos140
Wales, UK
C?ID=398446
Hi all,
Recently joined the forum so be gentle :-D
OK, had an A3 in for repair with DSG issue with the usual PRNDS lights flashing. Read codes and came up with Solenoid N88 Open or short circuit to ground.
After lots of reading up it all pointed towards faulty links inside the mecha unit so luckily I'm in the electronics game so no big issue for me.
Removed the unit and removed the cover on the ECU of the mecha unit and two wire links has become detached from the PCB..great...I thought!
So, repaired the links, checked continuity and resealed the unit and fitted it back to the gearbox.
Turned on ignition and not lights flashing, switched on engine and PRNDS flashing again. Scanned and same N88 fault appeared. So, proceeded to clear codes and then lights stopped flashing but still not Reverse gear or 1st gear, only 2nd gear, which I think is a limp mode.
So, reading further on it was suggested I perform the Basic Settings, went to group 061 and hit GO but It just comes up with ERROR., same as 062 etc etc
Doing further investigation I can see Supply voltage 1 at zero volts and Supply voltage 2 at battery voltage when engine idling...
So, where are these voltages fed from and would this be stopping the procedure of 061?
Thanks for all your help
Bruce
Near Philadelphia, PA, USA
Welcome to our forum. To really help and answer questions like these, we need a full autoscan from the car so we can see the part numbers, rev levels, and software installed. Sure, you are going to say these are not going to help solve this problem and you will be correct - they may not. But they will help us to find information on that vehicle by which we may be able to assist.
Please post an Autoscan.
cos140
Wales, UK
C?ID=398446
Hi Bruce,
Many thanks for the reply, I will connect back up to the car when I finish work and post the scan results on here...
Cheers
cos140
Wales, UK
C?ID=398446
Hi Bruce,
OK, just done 2 full scans, 1st is with just ignition, and 2nd with engine started. The second you will see the N88 error on the DSG but if you clear that it goes and doesn't come back (unless you turn engine off and restart)
Friday,06,March,2020,16:53:47:08939
VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8P87A048768   License Plate:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: WAUZZZ8P87A048768   Mileage: 134490km-83568miles
   Part No SW: 8P0 907 115 K    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: --H14---    Serial number: AUX7Z0F6FNR042
   Coding: 010300031C070060
   Shop #: WSC 00385 210 90023
   VCID: 3A2CC906D05DB767C71-806E
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 008 -  - Intermittent
                    Mileage: 134494 km
                    Date: 2020.02.27
                    Time: 02:22:05
                    RPM: 1190 /min
                    Load: 38.8 %
                    Temperature: 11.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.478 V
Readiness: 0010 0001
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1110
   Revision: 04507000    Serial number: 00000607050864
   Shop #: WSC 06314 000 00000
   VCID: 147047BE9279A1177DD-8040
   Revision: 00H11001
   Coding: 0021122
   Shop #: WSC 00383 383 80878
   VCID: 73B22422B7B7062FC47-8026
   Part No SW: 8P0 820 043 Q    HW: 8P0 820 043 Q
   Component: KlimavollautomatH18 0300
   Revision: 036026      Serial number: 8P0820043Q
00796 - Fan for Interior Temp Sensor (V42)
                    Fault Frequency: 60
                    Reset counter: 82
                    Mileage: 117872 km
                    Date: 2019.02.13
                    Time: 07:36:52
                    Voltage: 13.20 V
                    Temperature: 9.5°C
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H43 1201
   Revision: 00H43000    Serial number: 00000006331823
   Coding: 018CCF06A01410000A000000000000000009FE1F5C0100
   Shop #: WSC 00383 210 80550
   VCID: 40D8BBEEB681EDB7895-8014
   Subsystem 1 - Part No: 8P2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00064784
   Shop #: WSC 00383
02092 - Enabling Heated Seat
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 83
                    Mileage: 134494 km
                    Date: 2020.02.27
                    Time: 02:25:00
                    Voltage: 14.25 V
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 H    HW: 8P0 959 655 H
   Component:    Airbag 9.41  H12 3720
   Revision: 91H12372    Serial number: 0037W0G01N2+
   Coding: 0071612
   VCID: 47CAA0F293AFDA8F48F-8012
   Subsystem 1 - Serial number: 63328RB40179E4E0R
   Subsystem 2 - Serial number: 63428RB40178A0308
   Subsystem 3 - Serial number: 63528RB40179E527P
   Subsystem 4 - Serial number: 63628RB40178A033D
   Subsystem 5 - Serial number: 63729RB4017B488AW
   Subsystem 6 - Serial number: 63829RB4017B7338O
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H34 0070
   Coding: 0011112
   VCID: 41DEBEEABD8BE4BF86B-8014
   Component: E0221           H03 0080
   Part No SW: 8P0 920 981 G    HW: 8P0 920 981 G
   Component: KOMBIINSTR. VDO H18 0560
   Revision: D0H18002    Serial number: 2246F002000863
   Coding: 0000418
   Shop #: WSC 54064 067 57207
   VCID: 3C20CF1EDA698957D5D-8068
   Part No SW: 1K0 907 530 J    HW: 1K0 907 951
   Component: J533__Gateway   H12 0160
   Revision:   H12       Serial number: 32001067178324
   Coding: 3F0F034207000101
   VCID: 2E04F5561C156BC76B9-807A
   Revision: D0H18002    Serial number: AUX7Z0F6FNR042
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
   Part No: 8P0 959 801 H
   Component: Tuer-SG         020 0090
   Coding: 0000560
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.079 H07 1806
   VCID: 3536DA3AF943581F2A3-8060
   Part No: 8P0 959 433 C
   Component:    KSG          H04 0050
   Coding: 188000186D288505489AC63300
   Component: Neigungssensor  005 0003
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH25 0160
   Revision: 00003       Serial number: 10000001176540
   VCID: 70B82B2EC6A13D37395-8024
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Coding: 0000560
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 195     HW: 8P0 035 195
   Component: symphony II EU  H58 0460
   Revision:      23S    Serial number: AUZ5Z4F6221902
   Coding: 0001001
   VCID: 6FBA2852DB9F22CF20F-803A
End----(Elapsed Time: 03:48, VBatt start/end: 11.9V/12.0V. VIgn 12.0V)-----
2nd scan whilst engine idling
Friday,06,March,2020,16:56:02:08939
                    Mileage: 134494 km
                    Date: 2020.02.27
                    Time: 02:22:05
                    RPM: 1190 /min
                    Load: 38.8 %
                    Temperature: 11.0°C
                    Temperature: 9.0°C
                    Voltage: 14.478 V
17135 - Shift Solenoid 1 (N88)
            P0751 - 000 - Open or Short to Ground
                    Fault Frequency: 255
                    Reset counter: 40
                    Mileage: 134494 km
                    Date: 2020.02.28
                    Time: 02:44:30
   Revision: 00H11001
   Coding: 0021122
                    Fault Frequency: 60
                    Reset counter: 82
                    Mileage: 117872 km
                    Date: 2019.02.13
                    Time: 07:36:52
                    Voltage: 13.20 V
                    Temperature: 9.5°C
   Coding: 00064784
   Shop #: WSC 00383
                    Reset counter: 83
                    Mileage: 134494 km
                    Date: 2020.02.27
                    Time: 02:25:00
                    Voltage: 14.25 V
   Coding: 0071612
   Coding: 0011112
   Coding: 0000418
   Coding: 0000560
   Coding: 0000560
   Coding: 0001001
End----------(Elapsed Time: 01:03, VBatt start/end: 14.4V/14.3V)-----------
cos140
Wales, UK
C?ID=398446
Oh, any chance you can change the post title to A3 and not A2? Typo my end sorry and I can't seem to edit it..
Thank you
Done.
Also got you Verified and moving to Car Repair Support.
cos140
Wales, UK
C?ID=398446
Spot on, than you :)
cos140
Wales, UK
C?ID=398446
Update;
OK, enough was enough with the mechantronic unit and its issues so I've got hold of another used gearbox from a car with build date of the same year, the only difference is the engine. The one it came off was a 2.0 diesel and the one it's going onto is the 2.0 TFSI petrol.
I have heard it will need programming, does anyone have a procedure to do this?
Thank you
Justin
At an absolute minimum, it will need to have appropriate software flashed into it. VCDS does not do that.
cos140
Wales, UK
C?ID=398446
Ok thank you...is this a dealer only option of can the programming software be purchased?
Bruce
You could get a J2534 pass through tool, purchase a subscription to the VAG ODIS software, and jump through any hoops VAG requires to have you do the flash through your tool.
Do note, a proper J2534 pass through tool is not inexpensive. The subscription to ODIS at one time was reasonable and could be had for just a few days. Not sure that VAG still offers the short term subscription.
There is no other way to flash other than going to the dealer to the best of our knowledge. VAG keeps their flashes in their own systems and no other party is permitted to distribute them.
I'm not sure ODIS will allow willy-nilly changing of the software in a Mechatronic.
I would suppose there are aftermarket solutions for flashing them, but I'm not familiar with them.
cos140
Wales, UK
C?ID=398446
Just a quick question, does anyone know here: If I purchased a gearbox from an identical car, same year, same engine etc etc, will the new DSG gearbox work perfectly fine in it's new location or will this once again need programming/flashing?
Thank you
On the 8P chassis A3, I think you can.
NitrousOxide
Jamaica
C?ID=269481
My understanding is that only the gearbox code that matters (such as KCZ, KNC, MSY, etc). They would come stock with matching firmware to be Plug & Play.
What I mean is that you can get one from a MK5 or MK6 Golf, or Audi TT with the same gearbox code whenever you are searching.
NitrousOxide
Jamaica
C?ID=269481
My clone copy of ODIS and AVDI does, but will give you a warning of a hardware mismatch and the usual warning about bricking if one proceeds. Proceeding just the same initiates, and completes the flash in the 2 cases I've tried it on. What I noticed is that the software version is updated, but the hardware version stays the same as it was before.
