Adaption files Golf 8
Antera
C?ID=129250
Here you can download the full adaption map from every module in the new Golf 8 with full options.
https://transferxl.com/08jDhLvWxHkxLK
Autoscan:
https://transferxl.com/08jDV7rnxS8YCw
Coding is not yet possible and iff anyone can share your files from this car it would be nice.
I'm busy to get the inlogcodes wich are not the same as before
hadez16
C?ID=289891
First of all: Thank you!!
But where is the Auto-Scan? :)
Antera
C?ID=129250
Do you still have access to this car?
As Long the keep this car as a demo I have acces to it and also 2 other one's iff needed and there are still there
Nice. I think you already got an e-mail from us with a test request. :)
ohaue
New Member
The provided links are dead :-(
Best regards
Otto
wojo
C?ID=253691 (NRRT)
Hi, Did you manage to find out what are the Security Accesses to Modules?
I need up to 13 (ACC) and A5 (Front cam - line assist etc)
Thanks
Antera
C?ID=129250
You can't code with only login code's. All modulec are locked and not accesable with a simple login code
wojo
C?ID=253691 (NRRT)
Not all modules require an SFD Token, ACC does not exist, an access code is needed
wojo
C?ID=253691 (NRRT)
For doing what ?
I want to activate an option (e.g. road signs, TJA - generally the all Travel Assist package becouse the seller forgot when ordering a car for me ...)
I seriously doubt you will be able to do that with VCDS. Those kinds of features required FEC codes from the factory even on some of the previous generation cars even if you have all the appropriate hardware, because it's considered "Software as a Product".
Antera
C?ID=129250
Will there be any progress to code the Golf 8 with VCDS?
Are you asking whether VCDS will be able to code features that VW considers saleable products and charges money for?
Antera
C?ID=129250
Coding is an issue because we need login's to code the Golf 8. All adaptions are the same as the Golf 7(,5) so when we can unlock the module's it would be possible to code again.
And of course the SFD is needed and i'm curious iff you will do something about that?
We will see what is possible. :)
DV52
C?ID=194404
@Antera : Hi.
I was intrigued by the bolded part of your post - I had never really considered what similarities there might be between the 2 x model Golfs
So, galvanized into action by the prospect of just being able to translate mk7/mk7.5 tweak instructions onto the mk8 platform (ignoring SFD for the moment) - I decided to compare the adaptation-channel databases in the BCM s from a mk8 and a mk7.5
For the purpose of my exercise, I chose the BCM admaps as follows:
Gold mk8 - from @Mari dropbox .ZIP file (thank you for providing this resource): 5WA-937-086-J
Golf mk7.5: 5Q0-937-084-CP
I used MS Excel and MS Access for the comparison.
GolfBCMTotal - Channel CountTotal - Unique Channel NamesChannel names common to both BCMs
Mk85WA-937-086-J28002439361
Mk7.55Q0-937-084-CP20451684361
As you can see, my numbers don't bode well for the prospect of being able to simply transfer previous mk7/7.5 tweaks onto the mk8 platform (at least not for the 2 x BCM s above)!
As an example of the difference, I was particularly interested in how the mk8 BCM handled Leuchte-Sets. In the older vehicles, these consisted of a bunch of 19 x adaptation channels. In mk8s, it appears that each Leuchte-set is now a group of 23 channels. I compare the structure of a Leuchte-set for the old and new platforms in the picture below (hope it makes sense):
This means that any attempt to apply tweak instructions relating to light function changes from a mk7/7.5 (and there are lots of these) will be problematic at best!!
