- May 14, 2019
- 13
- 24
- Netherlands
- C?ID=129250
@DV52
Sorry for the late respons. Some issues here
I already noticed that there are a few difference. The lights have different channels at some places and more possible options also for other things.
You showed that above. But it works the same i think as the Golf 7 but now its works with more channels. Also dynamic blinker haven different options and also drl and more. But can try what it does untill we can login with VCDS or VCP.
Is the reason why we do not see the full adaptions values because VCDS only reads out the module without login in? @Uwe Is that possible? Or did the locked this out like they did with the pq35 modules (byte 18) set to 00
I managed to code the Golf 8 with a dongle wich do connect with the VW server to get the login codes from the car. But this is only possible at this time with there one click functions. The dongle is OBDapp. You do not see what codes are used.
I only can code between 9 - 17h. That is the time the server is online from vw.
Here i did i code the taillights with drl:
I need to read out the adaptions from 09 before and after the coding to see what did change but i need to get a car at the dealer again. I was short in time and that was the reason i tryed a few things voor test purpose. I will make time to try to find out what changed because the was more possible and i did more coding.
Let me now off you want to now more and i will look into it. I have acces to a Golf 8 whenever i need and the car is there.
