HVAC basic settings guide not matching software
downtime
C?ID=280813
Ok, one more thing. Try to set it to variable interval first. Save the variable interval values and clear the codes. See if they come back.
Then set the fixed service interval values, save them and see if the errors come back.
   #22
DV52
C?ID=194404
^^^ hmmm.... perhaps knowing the setting for IDE00515-ESI: oil quality on OP's hex17 module might help? If the adaptation channel is set to poor oil quality , then the FIX bunch of channels are pertinent for the SRI procedure
   #23
kpm
C?ID=342561
here is the full list
Tuesday,11,February,2020,14:13:17:42375
VCDS Release 19.6.2:  SRI Reset-SRI3.CLB
Control Module Part Number: 8V0 920 971 E       Labels:  .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI         H02 4291, Coding:27A509002B8026000100EA001000000000000000
Channel        Description                                                 	Current val.                                                	New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	no warning                                                  	---
IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	185 km                                                      	---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	5 d                                                         	---
IDE00515-ESI: oil quality        ESI: Oil Quality                                            	poor oil quality                                            	---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                          	100 km                                                      	---
IDE00518-ESI: thermal load        ESI: Thermal Load                                           	100 km                                                      	---
IDE01153-SIA: maximum value of distance to service                                                  	SIA: Maximum Distance to Service                            	19000 km                                                    	---
IDE01154-SIA: maximum value of time to service                                                      	SIA: Maximum Time to Service                                	365 d                                                       	---
IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	30600 km                                                    	---
IDE03350-FIX: Maximum time until next time-dependent inspection                                     	FIX: Maximum Time to Inspection                             	730 d                                                       	---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	200 km                                                      	---
IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	9 d                                                         	---
   #24
kpm
C?ID=342561
I see maximum distance is 30600 which was one of the flags from the other thread. This was set to 15000 when I checked it last week, however I can see in Instrument adaptions (also on the other thread) there is alot more data and a maximum value for service and inspection, perhaps I changed the wrong one last, or was it reset when I performed the oil reset on the MMI? Anyway I'll get an adaption map of the Instrument cluster for a complete view and share.
   #25
kpm
C?ID=342561
ok here's the full adaption from instrument module, minus anything that doesn't seem to be related to servicing
;SW:8V0-920-971-E   HW:8V0-920-971-E ---  Instruments
;Component:KOMBI         H02 4291	 Coding:27A509002B8026000100EA001000000000000000
;EV_DashBoardVDDMQBAB	9040
;Tuesday	11
;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
;VCID: 3FDB40F797F7E48FF0D-806A
IDE00510-ESI: distance driven from inspection	192 km
IDE00511-ESI: time from inspection	5 d
IDE00512-ESI: minimum value km-driving distance/inspection	15000 km
IDE00513-ESI: maximum value km-driving distance/inspection	30000 km
IDE00514-ESI: maximum value of time between inspections	365 d
IDE00515-ESI: oil quality	poor oil quality
IDE00517-ESI: soot entry	100 km
IDE00518-ESI: thermal load	100 km
IDE00827-ESI: minimum value of time between inspections	730 d
IDE01153-SIA: maximum value of distance to service	19000 km
IDE01154-SIA: maximum value of time to service	365 d
IDE03349-FIX: Max. distance until next mileage-related inspection	30600 km
IDE03350-FIX: Maximum time until next time-dependent inspection	730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection	200 km
IDE03352-FIX: Time since last time-dependent inspection	9 d
Looking back over Wolfgangs instructions from the other thread, the ESI minimum distance and ESI maximum distance are ok at 15000/30000, but it looks like I changed ESI maximum value to 365d instead of ESI minimum value to 365d, so I can rectify that and see what it does for the fault code.
I've tried to make head and tail of the data and from what I can see:
ESI is extended service interval;
SIA is the service reminder = oil service??
and FIX would be fixed service interval...
Is there an adaption that tells the car whether its on fixed or extended, or is it just a case of setting correct day/km for both ESI and FIX. I read oil quality - Poor = fixed. Does this mean Good = extended?
I'm thinking ESI min/max is irrelevant if I'm on fixed.
SIA should be 15000km/365d
FIX should be 30000km/730d
and I can adjust 'ESI distance/time from inspection' to match up with the fact I'm 6 months into my service year, and the same with the FIX distance/time from inspection.
..... I think
   #26
downtime
C?ID=280813
I think FIX should be also 15000/365 and not 30k/730 as that is the extended service interval duration. Fixed should be always 15k/365d
   #27
kpm
C?ID=342561
I think Audi fixed interval is oil service every 15k/365 and oil-inspection service every 30k/730d. If I set SIA and FIX to 15k/365d that would intimate both services every 365d?
   #28
downtime
C?ID=280813
What's the difference on those?
All VAG cars nowadays have 15k/365d inspection service and 30k/730d oil service. And this on variable service interval.
So going with fixed service interval, add oil change to the inspection as well? Sorry this fixed interval is not very familiar to me as I've always kept the cars on variable service intervals :)
   #29
kpm
C?ID=342561
Variable servicing can mean no oil change for 30k/730d. The joys of long life oil.
Edit: for me I just see fixed as minor service/oil change every year and major service every two years. I think with Variable you get an inspection but not necessarily an oil change at 15k.
   #30
downtime
C?ID=280813
Yes exactly. 15k inspection does not have oil change unless the car says that oil needs to be changed (which has never ever happened to me). And this is on variable service interval.
   #32
kpm
C?ID=342561
Changing this value to 15000km removed the fault code: IDE01153-SIA: maximum value of distance to service 19000 km
It appears the garage that did the service reset it to 19000 in line with the maximum mileage limit on variable inspection, but didn't convert km to miles.
For the next guy to find this problem - I ended up resetting a few of the values for ESI, SIA and FIX to bring them back in line with my actual service interval, here's the final map. Note this is for fixed interval servicing (oil change every 15000km, inspection every 30000km). If you are on variable/longlife servicing I think the SIA values will be 30000km/730d.
IDE00510-ESI: distance driven from inspection	4500 km (only changed to be in line with my current service interval. yours will vary.)
IDE00511-ESI: time from inspection	161 d (only changed to be in line with my current service interval. yours will vary.)
IDE00514-ESI: maximum value of time between inspections	730 d
IDE01153-SIA: maximum value of distance to service	15000 km
IDE03349-FIX: Max. distance until next mileage-related inspection	30000 km
IDE03351-FIX: Distance covered since last mileage-dependent inspection	4500 km (only changed to be in line with my current service interval. yours will vary.)
IDE03352-FIX: Time since last time-dependent inspection	161 d (only changed to be in line with my current service interval. yours will vary.)
IDE05931-FIX: Reset value for next mileage-dependent inspection	30600 km
IDE05932-FIX: Reset value for next time-dependent inspections	730 d
   #33
kpm
C?ID=342561
A minor issue popped up, ever since updating the values above I keep getting the warning "service due in 6600 miles" everytime I start and stop the car. What value change would resolve this? Full code from today:
;EV_DashBoardVDDMQBAB	9040	EV_DashBoardVDDMQBAB_009_VW37.rod
;Monday	17	February	2020	12:12:36:42375
IDE00295-Oil temperature display	On 	1
IDE00301-Distance	202591 km	3
IDE00342-ESI: Resetting ESI	Warning active 	1
IDE00343-Language version	English 	1
IDE00499-Display correction of consumptions and operating range	100%	1
IDE00500-Hour	12 H	1
IDE00501-Minute	12 min	1
IDE00502-Year	2020 yr	2
IDE00503-Month	2 mon	1
IDE00504-Day	17 d	1
IDE00510-ESI: distance driven from inspection	4729 km	3
IDE00511-ESI: time from inspection	166 d	2
IDE00512-ESI: minimum value km-driving distance/inspection	15000 km	2
IDE00513-ESI: maximum value km-driving distance/inspection	30000 km	2
IDE00514-ESI: maximum value of time between inspections	730 d	2
IDE00515-ESI: oil quality	poor oil quality 	1
IDE00517-ESI: soot entry	300 km	2
IDE00518-ESI: thermal load	200 km	2
IDE00819-Day counter	2026 d	2
IDE00820-Activating and deactivating all development messages	not active 	1
IDE00827-ESI: minimum value of time between inspections	730 d	2
IDE01153-SIA: maximum value of distance to service	15000 km	2
IDE01154-SIA: maximum value of time to service	365 d	2
IDE02489-Display depiction	Not available 	1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.8 l	5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.8 l	5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	12.7 l	5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.7 l	5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.7 l	5
IDE03329-Driving profiled for range remaining	6.1 l/100km	2
IDE03346-IDE00301-Units adjusted-Distance	miles 	3
IDE03346-MAS01230-Units adjusted-Date	dd_mm_yy 	3
IDE03346-MAS01456-Units adjusted-Speed	Miles per hour 	3
IDE03346-MAS02201-Units adjusted-Temperature	Degrees Celsius 	3
IDE03346-MAS02957-Units adjusted-Time	24h 	3
IDE03346-MAS03032-Units adjusted-Volume	gallons (UK) 	3
IDE03346-MAS03034-Units adjusted-Pressure	bar 	3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)	kg per 100 km 	3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Miles per gallon (UK) 	3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive	kWh per 100 km 	3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground	kilogram (kg) 	3
IDE03348-MAS01456-Speed warning-Speed	15	2
IDE03348-MAS01561-Speed warning-Unit	Miles per hour 	2
IDE03348-Speed warning-	not active 	2
IDE03349-FIX: Max. distance until next mileage-related inspection	30000 km	2
IDE03350-FIX: Maximum time until next time-dependent inspection	730 d	2
IDE03351-FIX: Distance covered since last mileage-dependent inspection	4700 km	2
IDE03352-FIX: Time since last time-dependent inspection	166 d	2
IDE03372-Source for synchronization of time	GPS 	1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On 	5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s	5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	On 	5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On 	5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h	5
IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s	5
IDE03568-ENG104099-Service-key settings-p_write_distance	20 km	5
IDE03867-Deactivate seat belt warning	No 	1
IDE04169-Display correction of consumption and operating range: gas	100%	1
IDE05930-Service notification in days	30 d	1
IDE05931-FIX: Reset value for next mileage-dependent inspection	30600 km	2
IDE05932-FIX: Reset value for next time-dependent inspections	730 d	2
IDE05971-Vehicle Positioning System Interface Control Module	not installed 	1
IDE06425-Roller test bench mode: functional	not activated 	1
IDE06588-Ignition active message: actuator	Driver door 	1
IDE06922-No-voltage display	Unknown (2)	1
IDE07221-Cylinder shut-off	Display 	1
IDE08140-Driving profiled for range remaining CNG	6.0 kg/100 km	2
IDE08247-Driving profile for range remaining LPG	10.0 l/100km	2
MAS03685-Digital speedometer	Display 	1
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF 	20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF 	20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF 	20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF 	20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF 	20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF 	20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF 	20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF 	20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF 	20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF 	20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF 	20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF 	20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF 	20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF 	20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF 	20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF 	20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF 	20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF 	20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF 	20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF 	20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF 	20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF 	20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF 	20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF 	20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF 	20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF 	20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF 	20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF 	20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF 	20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF 	20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF 	20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF 	20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF 	20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF 	20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF 	20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF 	20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF 	20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF 	20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	OFF 	20
ENG119875-defuel_threshold	45 l	1
ENG119880-ENG101574-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X1	0	12
ENG119880-ENG99557-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X2	0A 	12
ENG119880-ENG102140-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X3	64	12
ENG119880-ENG102936-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X4	96	12
ENG119880-ENG103548-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X5	DC 	12
ENG119880-ENG113992-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X6	FD 	12
ENG119880-ENG99777-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y1	2	12
ENG119880-ENG100480-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y2	2	12
ENG119880-ENG100773-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y3	10	12
ENG119880-ENG100631-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y4	1E 	12
ENG119880-ENG102174-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y5	3C 	12
ENG119880-ENG113993-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y6	64	12
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1	0	12
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2	0A 	12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3	64	12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4	96	12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5	DC 	12
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6	FD 	12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1	3	12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2	3	12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3	10	12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4	1E 	12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5	3C 	12
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6	64	12
ENG119881-ENG101574-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X1	0	12
ENG119881-ENG99557-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X2	0A 	12
ENG119881-ENG102140-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X3	64	12
ENG119881-ENG102936-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X4	96	12
ENG119881-ENG103548-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X5	DC 	12
ENG119881-ENG113992-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X6	FD 	12
ENG119881-ENG99777-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y1	2	12
ENG119881-ENG100480-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y2	2	12
ENG119881-ENG100773-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y3	10	12
ENG119881-ENG100631-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y4	1E 	12
ENG119881-ENG102174-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y5	3C 	12
ENG119881-ENG113993-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y6	64	12
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0	12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2	6E 	12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3	82	12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4	96	12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5	AA 	12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD 	12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	0	12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	0	12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	5	12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	14	12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	50	12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64	12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0	12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A 	12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3	64	12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4	96	12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5	DC 	12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD 	12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	4	12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	4	12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	40	12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	52	12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	5F 	12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64	12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1	0	12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2	0A 	12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3	64	12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4	96	12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5	DC 	12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6	FD 	12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1	8	12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2	8	12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3	64	12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4	64	12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5	64	12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6	64	12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1	0	12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2	0A 	12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3	64	12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4	96	12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5	DC 	12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6	FD 	12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1	0A 	12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2	0A 	12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3	32	12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4	5F 	12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5	64	12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6	64	12
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00 	20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32 	20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64 	20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 C8 	20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4 	20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00 	20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 32 	20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 64 	20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 C8 	20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD 	20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0	12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	0A 	12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	64	12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	96	12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	DC 	12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6	FD 	12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	3	12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	3	12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	19	12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	28	12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	46	12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6	64	12
ENG119874-Gas_functionality	not active 	1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xs_bus 	1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	lds 	1
ENG119882-init_fuel_algorithm	No 	1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s	16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 °C	16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 °C	16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 °C	16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.0 km	16
ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h	16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min	16
ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s	16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.0 °C	16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s	16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2	16
ENG119825-Picture_Upload_Download	not active 	1
ENG119876-Service_Key_Clear_All_Counter	Yes 	1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms	2.0 s	18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s	18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt	30 s	18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms	18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms	255 s	18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s	18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms	6 s	18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms	0 s	18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms	0 s	18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms	10 s	18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms	3 s	18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms	10 s	18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ	0.20 s	18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse	3	18
ENG109442-ENG101663-time_parameter_display-tDD15_off	0.25	18
ENG109442-ENG103975-time_parameter_display-tDD15_on	0.5	18
ENG109442-ENG100026-time_parameter_display-tDDWUP	0.5	18
ENG112418-ENG112412-total_range_gas-consumption_factor	0	4
ENG112418-ENG112411-total_range_gas-consumption_profile	consumption_profile_calculation 	4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor	consumption_factor_CAN 	4
ENG112418-ENG99298-total_range_gas-State	not active 	4
   #34
You still have:
You could reset that, but I expect doing so will also reset:
and
to zero, so you may want to tweak those back to their current values afterward, (assuming those values reflect reality).
