HVAC basic settings guide not matching software
kpm
C?ID=342561
1048578 instrument cluster fault code
Hi
Car is 2014 A3 tdi
I have an error code about missing basic settings since I had heater matrix replaced a while ago. System works fine but I want to perform basic settings so I can clear the code.
I followed instructions to perform basic settings but the instructions don’t match my screen.
The guide says 08 module > basic settings > 001 > go > etc
But I see 08 module > basic settings > IDE codes with brief descriptions.
I thought perhaps I found an old guide on rosstech so I attempted “resetting of all adaptations” and I get warning “likely not reversible, may require dealer tool”. I tried it anyway and it says “not running”.
Help! Thanks, Kris
downtime
C?ID=280813
NEVER EVER select the reset all adaptations. It might wipe the module clean which means a dealer visit or in worst case a new module.
Is the basic setting for compressor run in or flap end stops? Run the basic setting for flap end stops first. Then start engine and choose the basic setting for compressor run in.
Just as a sidenote, I’ve never been able to execute the compressor run in basic setting with vcds. I had to use dealer tools when I replaced the climatronic module.
darkchina811
ITALY
C?ID=333184
if you did the "reset all adaptations" and now you have an error that reads something like "dataset", then you just won a trip to the dealer.
just do like downtime said, when I replaced the panel I completed everything with VCDS. go figure.
downtime
C?ID=280813
HVAC modules luckily don’t have parameters in them so OPs luck. Otherwise it would be like darkchina wrote.
It would be nice to see full autoscan so we could see what are the exact errors?
kpm
C?ID=342561
I shall consider myself fortunate that I've not broken anything with my exuberance. I performed the flap operation but having gone over the issue again I think I've completely missed the landing spot. I've obviously googled the codes, got distracted, had dinner, gone to bed, woke up and started this thread. Appreciate the support.
Here's the full code:
Monday,27,January,2020,16:19:25:42375
Mileage: 201915km-125464mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: Mileage: 201915km-125464miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 7539
   Revision: 81H22---
   Coding: 02190012032501082000
   Shop #: WSC 29392 003 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
   ROD: EV_ECM20TDI01104L906021AE.rod
   VCID: 77ABE8D7FF471CCFF8D-8022
11901 - Manifold Pressure / Boost Sensor (G31)
          P0236 00 [032] - Implausible Signal
                    Time: 00:00:00
                    Coolant temperature: 8 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 12.360 V
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 2440.2 hPa
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
19210 - EGR System
          P0402 00 [096] - Excessive Flow
                    Mileage: 201859 km
                    Date: 2020.01.24
                    Time: 16:50:58
                    Engine speed: 1576.00 /min
                    Normed load value: 40.8 %
                    Vehicle speed: 14 km/h
                    Coolant temperature: 10 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 14.620 V
                    Exhaust recirculation valve 1 bank 1: mass flow - nominal value: 67.2 kg/h
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
                    Exhaust recirculation valve 2 bank 1: mass flow - nominal value: 0.0 kg/h
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 0.00 %
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 0.18 %
                    Air mass at air mass meter 1: 105.0 kg/h
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 3.2979
5169 - Manifold Pressure / Boost Sensor (G31)
          P0238 00 [032] - Signal too High
17448 - ROD - Unknown Error Code
          - 00 [032]
4113 - Camshaft Position Sensor (G40)
          P0341 00 [096] - Implausible Signal
   Revision: 00000000    Serial number: 62004000002468
   Coding: 12F18AA234230A74017E060241CB2948512C5080608294F4026100788608
   VCID: 45D7521FF52BBE5FBA1-8010
   Revision: 20026000    Serial number: 00000000387850
   Coding: 03100104002000011000000000001100
   Shop #: WSC 06314 790 00021
   VCID: 33331CC7ABBF30EF045-8066
   Serial number: 0319CD37000000000001
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011419804312
   Coding: 07040A46C24322FD03844004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 0059830BAA895B77C97-8054
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140713  041 0580
   Serial number:         140716220904
   Coding: 0A47F7
   Serial number: 63282863
   Coding: 02006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
   Serial number: 26 01 2016  00001031
   Serial number: 000000000ZY141681KG4
   Serial number: 00000000000030264090
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39231420400990
   Coding: 0000050001
   VCID: 3B2334E783EFF8AFDC5-806E
   Serial number: 003M2R07T4KS
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4BC36427D34F482F6C5-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 607 14
   Serial number: 357670000003EAD0001Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 607 14
   Serial number: 35867000000DDAD0001-
   Subsystem 3 - Part No SW: -----------    HW: 480 402 107 14
   Serial number: 3516502C515F3C34B23C
   Subsystem 4 - Part No SW: -----------    HW: 480 402 107 14
   Serial number: 3526502C515F3C324166
   Subsystem 5 - Part No SW: -----------    HW: 480 401 706 14
   Serial number: 35565029D1697520A136
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 807 14
   Serial number: 2286502C11656B83C307
   Subsystem 7 - Part No SW: -----------    HW: 480 400 807 14
   Serial number: 2296502C11656B8393CH
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 807 14
   Serial number: 23065029B1656B853287
   Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 17071408490481
   Coding: A408
   ROD: EV_SMLSKLOMQB_010_AU37.rod
   VCID: 0655951388AD7547F3B-8052
   Part No SW: 8V0 920 971 E    HW: 8V0 920 971 E
   Component: KOMBI         H02 4291
   Coding: 27A509002B8026000100EA001000000000000000
   VCID: 3FDB40F797F7E48FF0D-806A
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 192
                    Mileage: 189435 km
                    Date: 2018.11.16
                    Time: 11:51:48
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002290549
   Coding: 030100040F0876005B000248080B00000001010000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011.rod
   VCID: 42DD4903E40589679F3-8016
   Serial number: 12 07 2014  D0038904
   Serial number: 3110563903
131602 - Power Steering Control Module
          U101D 00 [008] - No Communication
          [Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
                    Reset counter: 124
                    Mileage: 201680 km
                    Date: 2020.01.22
                    Time: 10:03:23
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: OFF
   Serial number: 14071403110089
   Coding: 00108E204001040000001002
   VCID: 40D9430BEA099B77897-8014
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF460FE103927F869-8014
   Serial number: 12071404080092
   Coding: 001086204001040000001002
   Coding: 019C000001000000
   VCID: 75B7E2DFE54B6EDFEA1-8020
   Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    041 0420
   Serial number: A7F01907140514
   Coding: 01730301FF0A000021111101000A00002F0004460100010006
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_VW37.rod
   Subsystem 1 - Part No SW: 8V0 919 866 B    HW: -----------
   Component:  ECE 2014  --- 0036
   Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY304V8J
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Serial number: C1000007061400020173
   Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0025
   Serial number: 11071401100167
   Coding: 000086204001040000001002
   Component: TSG HBFS      020 0025
   Serial number: 11071402090166
End----(Elapsed Time: 01:27, VBatt start/end: 11.6V/11.8V. VIgn 11.9V)-----
Address 17: DTCs cleared
downtime
C?ID=280813
I see no problems with HVAC module.
Your instrument cluster is saying no basic setting.
kpm
C?ID=342561
Is there a fix for that? I watched some Ross-Tech videos for resetting service interval but none match my car.
Edit: I dug deeper and found some instructions, I performed SRI reset but fault code is still present
kpm
C?ID=342561
Hi, yes tried that method. I also tried with the SRI button and “Reset FIX&ESI” option below. Both methods showed as performed successfully and I can see the reset intervals in the MMI each time.
“On the latest cars using UDS/ODX diagnostic protocols for the Instrument Cluster, the SRI Reset function may only show choices for oil change "Reset ESI / OIL,(North America) or (Rest of World second service and later)" and time based service "Reset FIX&ESI / INSP,(North America) or (Rest of World second service and later)".“
downtime
C?ID=280813
Sorry, I was being too vague. Did you do this : Distance and Time based Service? So manually changed the adaptation channel values? That should force the values to be correct and hopefully clear that basic setting error.
kpm
C?ID=342561
Hi yes followed to the tee, did the three separate stages of esi reset, distance to zero and time to zero
kpm
C?ID=342561
Interesting thanks, will try the fix in the thread
kpm
C?ID=342561
Hi, unfortunately the resolution in that thread didn’t resolve the issue.
Mine showed -
max km 15000
min km 15000
days 365
I changed max to 30000 and cleared the fault code but instantly returned
downtime
C?ID=280813
Did you also change the days to 720? Looks like the dealer has set your maintenance to fixed period instead of variable. That's probably the issue, car thinks it's on variable service.
kpm
C?ID=342561
Hi, no the instructions from Wolfgang in the other thread said to go with 365 days. My car does need to be on fixed service intervals. Thanks
kpm
C?ID=342561
yes tried it this morning, used the car for a bit and checked for codes, still there, cleared, returned immediately. appreciate your efforts here. i've been googling last night but i'm stumped.
