Audi a3 8v
zeeshan
C?ID=327143
hi got issuse can any one point the write direction thanks
Main issue
airbags
parking sensors
Saturday,25,January,2020,18:03:17:56296
VIN: WAUZZZ8V1GA056600   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V1GA056600   Mileage: 34560km-21474miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BR    HW: 04L 907 309 R
   Component: R4 2,0L EDC   X22 1540
   Revision: B5X22---
   Coding: 02190012032501082000
   Shop #: WSC 26214 051 00000
   ASAM Dataset: EV_ECM20TDI01104L906026BR 002003
   ROD: EV_ECM20TDI01104L906026BR_002.rod
   VCID: 7BA200ED3368DE5F9C5-802E
21605 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [039] - Malfunction
                    Mileage: 34560 km
                    Date: 2020.01.25
                    Time: 18:54:27
                    Engine speed: 776.50 /min
                    Normed load value: 23.1 %
                    Coolant temperature: 56 °C
                    Intake air temperature: 49 °C
                    Voltage terminal 30: 14.680 V
                    Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 138.6 °C
                    Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: 117.1 °C
                    Particle filt.inlet temp.sens.1 bank 1: raw value: 112.0 °C
                    Particle filter outlet temp.sens.1 bank 1: raw value: 109.4 °C
                    Exh. gas recirc.temp. sens. 2 bank 1: raw value: 2222.0 °C
                    Shut-off timer: last engine shut-off time: 740 s
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 62555000000431
   Coding: 12F18AA234250A72037D060041C32948512C50C0608294F5026100788408
   Shop #: WSC 06314 790 00021
   VCID: 7EA409F9207ACB77BBB-802A
16411 - Display for Tire Pressure Monitoring
                    Reset counter: 26
                    Mileage: 34560 km
                    Date: 2020.01.25
                    Time: 18:54:37
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000735735
   Coding: 03100104002000011000000000001100
   VCID: 3332E8CD5BB8D61F045-8066
   Serial number: 2FC8C8C7000000000001
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 26
                    Mileage: 34560 km
                    Date: 2020.01.25
                    Time: 18:54:24
                    Outside air temperature: ERROR
                    Engine speed: 770.00 /min
                    Temperature after evaporator: 13.0 °C
                    Refrigerant pressure: 1.0 bar
459527 - Databus
                    Reset counter: 26
                    Mileage: 34560 km
                    Date: 2020.01.25
                    Time: 18:54:24
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061526400833
   Coding: 07040A46C24122FD03844004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094E6A2569B4FCCF9E9-805C
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150826  042 0580
   Serial number:         150902160835
   Coding: 0A47F7
   Serial number: 20663136
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
   Serial number: 20 07 2015  00000424
   Serial number: 000000000ZY15217163G
   Serial number: 00000000000033267789
137217 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Reset counter: 26
                    Mileage: 34560 km
                    Date: 2020.01.25
                    Time: 19:01:00
263435 - Glass Breakage Sensor
          B145F 13 [009] - Open Circuit
                    Reset counter: 26
                    Mileage: 34560 km
                    Date: 2020.01.25
                    Time: 19:01:00
   Revision: --------    Serial number: 39391526009001
   Coding: 0010050001
   VCID: 43D2B80D0B18669F945-8016
13637888 - Databus
          [Steuergerät für Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen]
                    Reset counter: 26
                    Mileage: 34560 km
                    Date: 2020.01.25
                    Time: 18:54:25
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    012 0361
   Serial number: 003M2R12ZNTF
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4BC2902D2348AEDF6C5-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 709 15
   Serial number: 35767000000AD6B4D616
   Subsystem 2 - Part No SW: -----------    HW: 480 001 709 15
   Serial number: 358670000006C6B4D612
   Subsystem 3 - Part No SW: -----------    HW: 480 401 609 15
   Serial number: 3516502AD1D25F724019
   Subsystem 4 - Part No SW: -----------    HW: 480 401 509 15
   Serial number: 3526502A31CB0C23232+
   Subsystem 5 - Part No SW: -----------    HW: 480 401 108 15
   Serial number: 3556502BB1D1B625338F
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 309 15
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502B91C1EFA1C27Y
   Subsystem 7 - Part No SW: -----------    HW: 480 400 309 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502A31D1B623122
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 309 15
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502AB1C1EFA5012E
9451547 - Igniter 1 for pedestrian protection
          B1038 1B [137] - Resistance Too High
                    Mileage: 34560 km
                    Date: 2020.01.25
                    Time: 19:00:18
9451803 - Igniter 2 for pedestrian protection
          B1039 1B [137] - Resistance Too High
                    Mileage: 34560 km
                    Date: 2020.01.25
                    Time: 19:00:18
1054981 - Databus
          [NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
                    Reset counter: 26
                    Mileage: 34560 km
                    Date: 2020.01.25
                    Time: 19:00:22
   Part No SW: 8V0 953 521 EH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 19091508490588
   Coding: A408
   VCID: 04507B114E96A1A7EDF-8050
   Part No SW: 8V0 920 971 R    HW: 8V0 920 971 R
   Component: KOMBI         H03 6420
   Coding: 27A409002B8026000100E8001000000000000000
   VCID: 4CC093312646A9E765F-8018
13639936 - Databus
          [Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
                    Reset counter: 26
                    Mileage: 34560 km
                    Date: 2020.01.25
                    Time: 18:54:24
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1224
   Revision: --------    Serial number: 0003963582
   Coding: 030100041F0873005B000248080B00000001010000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 75B616D5154C882FEA1-8020
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 01 09 2015  A0003717
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001509093002
   Serial number: 010915BI102489
   Coding: 00518A205C01040000001002
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 8103
   VCID: 44D0BB110E1661A7ADF-8010
   Serial number: 030915BI212167
   Coding: 005182205E01040000001002
   VCID: 42DCBD0914026F979F3-8016
   Coding: 019E000001000000
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 C    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    042 0461
   Serial number: A7F01609151051
   Coding: 017303010000000021111102000A00002F0004260100010006
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 3C20C3F176E61967D5F-8068
   Subsystem 1 - Part No SW: 8V0 919 866 C    HW: -----------
   Component:  ECE 2015  --- 0045
   Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30D5R2
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000001071500030242
   Serial number: 090715BG820445
   Coding: 004182204001040000001002
   VCID: 45D6A615052C58AFBA1-8010
   Serial number: 090715BG808669
End----------(Elapsed Time: 01:17, VBatt start/end: 14.8V/14.6V)-----------
Morski
Cheshire UK
C?ID=90186
Wow, you should put the car back together first, clear fault codes and then see what you have left.
Airbag issue needs new bonnet actuators. These blow after a frontal impact and raise the bonnet upwards at the hinge side.
zeeshan
C?ID=327143
hi have put everthing back together but these fault not going is there any way to bypass the bonnet hinges with resistor for temporary
Put back together how? Did you install new bonnet actuators?
Morski
Cheshire UK
C?ID=90186
Yes, Audi sell bypass resistors. Just ask the parts department which airbag you want to bypass and they will supply you one. Steering airbag resistors are always in stock.
Morski
Cheshire UK
C?ID=90186
Sorry...my sarcasm comes across as a bit strong at times.. :D
zeeshan
C?ID=327143
Wednesday,29,January,2020,10:12:27:56296
VIN: WAUZZZ8V1GA056600   Mileage: 34561km-21475miles
   Revision: B5X22---
          P0070 00 [175] - Malfunction
                    Mileage: 34561 km
                    Date: 2020.01.29
                    Time: 10:51:24
                    Engine speed: 1061.50 /min
                    Normed load value: 18.8 %
                    Coolant temperature: 53 °C
                    Intake air temperature: 47 °C
                    Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 158.0 °C
                    Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: 114.0 °C
                    Particle filt.inlet temp.sens.1 bank 1: raw value: 105.6 °C
                    Particle filter outlet temp.sens.1 bank 1: raw value: 89.5 °C
                    Shut-off timer: last engine shut-off time: 55518 s
Readiness: 1 1 0 0 1
                    Reset counter: 26
                    Mileage: 34561 km
                    Date: 2020.01.29
                    Time: 11:04:32
                    Reset counter: 26
                    Mileage: 34561 km
                    Date: 2020.01.29
                    Time: 10:51:37
                    Engine speed: 1040.50 /min
                    Temperature after evaporator: 9.0 °C
                    Refrigerant pressure: 1.2 bar
459527 - Databus
                    Reset counter: 26
                    Mileage: 34561 km
                    Date: 2020.01.29
                    Time: 10:51:37
   Coding: 0A47F7
   Coding: 00006C
8970 - Bulb for Right Fog Lamp
          B1220 15 [009] - Open or Short to Plus
                    Reset counter: 26
                    Mileage: 34561 km
                    Date: 2020.01.29
                    Time: 10:51:42
                    Reset counter: 26
                    Mileage: 34561 km
                    Date: 2020.01.29
                    Time: 10:51:42
                    Reset counter: 26
                    Mileage: 34561 km
                    Date: 2020.01.29
                    Time: 10:51:42
   Coding: 0010050001
13637888 - Databus
                    Reset counter: 26
                    Mileage: 34561 km
                    Date: 2020.01.29
                    Time: 11:12:06
1054981 - Databus
                    Reset counter: 26
                    Mileage: 34561 km
                    Date: 2020.01.29
                    Time: 10:51:52
   Coding: A408
13639936 - Databus
                    Reset counter: 26
                    Mileage: 34561 km
                    Date: 2020.01.29
                    Time: 11:11:04
   Coding: 8103
End----(Elapsed Time: 01:20, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
zeeshan
C?ID=327143
still parking sensors and tpms not working
