Hello all,
Newbie here. I purchased a 2006 Passat 2.0T B6 from my niece. Got it up and running and I get a "error" message on the dash and also see parking brake fault. I have changed the back parking brake motors and issue continues.
I have noticed that the ABS is not coded as per the readings.
Anyone help with this below info?
Wednesday,22,January,2020,18:45:45:59102
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWEK73CX6P187147 License Plate:
Mileage: 216100km-134278mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
72
VIN: WVWEK73CX6P187147 Mileage: 216100km-134278miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 F HW: 3C0 907 115 F
Component: 2.0l R4/4V TFSI 0030
Revision: --H14--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 25129 444 64221
VCID: 2313E981D7DB95FFF45-8076
6 Faults Found:
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Temperature: 18.0∞C
Temperature: 18.0∞C
Absolute Pres.: 980.0 mbar
Voltage: 11.938 V
008851 - Fuel Pressure Regulator Valve (N276)
P2293 - 002 - Mechanical Malfunction - Intermittent
Mileage: 216062 km
Date: 2019.12.27
Time: 15:00:44
RPM: 2812 /min
Load: 49.0 %
Speed: 55.0 km/h
Temperature: 93.0∞C
Temperature: 28.0∞C
Voltage: 13.843 V
012555 - Low Pressure Fuel regulation
P310B - 008 - Fuel Pressure Outside Specification - Intermittent
Fault Frequency: 7
Mileage: 216062 km
Date: 2019.12.27
Time: 15:00:44
RPM: 2827 /min
Load: 35.7 %
Speed: 57.0 km/h
Temperature: 93.0∞C
Temperature: 25.0∞C
Voltage: 13.843 V
P310B - 004 - Fuel Pressure Outside Specification - Intermittent
Mileage: 216072 km
Date: 2019.12.27
Time: 18:07:03
RPM: 763 /min
Load: 23.1 %
Temperature: 95.0∞C
Temperature: 30.0∞C
Voltage: 13.843 V
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 001 - Signal too High - Intermittent
Fault Status: 00100001
Mileage: 216079 km
Temperature: 18.0∞C
Temperature: 18.0∞C
Voltage: 11.938 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - - Intermittent
Mileage: 216090 km
Date: 2019.12.30
Time: 16:54:21
RPM: 895 /min
Load: 29.0 %
Temperature: 91.0∞C
Temperature: 18.0∞C
Voltage: 14.097 V
Readiness: 0000 0001
Part No SW: 09G 927 750 HJ HW: 09G 927 750 CJ
Component: AQ 250 6F 1068
Revision: 00H38000 Serial number:
Coding: 0000072
VCID: 0059860D660D6EE7C97-8054
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0667269566
Coding: 0010000
Shop #: WSC 00028 028 00001
VCID: 303916CD962D3E67797-8064
Fault Frequency: 99
Reset counter: 175
Mileage: 215711 km
Date: 2019.12.14
Time: 16:18:06
Fault Frequency: 35
Reset counter: 238
Mileage: 215763 km
Date: 2019.12.15
Time: 16:10:38
00810 - Sensor 1/2 for Brake Pressure
Fault Frequency: 35
Reset counter: 238
Mileage: 215763 km
Date: 2019.12.15
Time: 16:10:38
Part No: 1K0 820 047 EC
Component: Climatic PQ35 090 0505
VCID: 698FBBA975778FAF7E9-803C
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000000602253
Coding: 14058E234004150007140000001400000008730B5C0000
VCID: 6B83C1A17F8B9DBF0C5-803E
Subsystem 1 - Part No: 3C1 955 419 Labels: 1KX-955-119.CLB
Component: Wischer VW461 001 0101
Coding: 00063445
Reset counter: 202
Mileage: 214839 km
Date: 2019.11.19
Time: 00:24:00
Voltage: 12.95 V
00156 - Control Circuit for Windshield Washer Pump
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 22
Reset counter: 202
Mileage: 214950 km
Date: 2019.11.21
Time: 23:08:00
Voltage: 14.00 V
02399 - Control Circuit for Terminal 30 for Interior Illumination
Fault Status: 01111001
Reset counter: 202
Mileage: 214839 km
Date: 2019.11.19
Time: 00:19:00
Voltage: 12.05 V
00059 - Terminal 30 for Interior Lighting
Reset counter: 202
Mileage: 214839 km
Date: 2019.11.19
Time: 00:19:00
Voltage: 12.05 V
00975 - Heated Rear Window (Z1)
Fault Status: 00100110
Reset counter: 221
Mileage: 215030 km
Date: 2019.11.25
Time: 15:53:00
Voltage: 13.80 V
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E0040619
VCID: 2B0301A1BF0B5DBF4C5-807E
Fault Frequency: 115
Reset counter: 242
Mileage: 208556 km
Date: 2017.10.22
Time: 14:58:02
01304 - Radio
Fault Frequency: 169
Reset counter: 40
Mileage: 208556 km
Date: 2017.10.22
Time: 14:58:01
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0N AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P0KBM6E
Coding: 0012366
VCID: 2E0508B58C1928976BB-807A
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000031JXZ
Subsystem 3 - Serial number: 0001.01.000000600000000000ˇÜ63
Subsystem 4 - Serial number: 000000ˇÜ6332MSME102D0B143ˇÜ63
Subsystem 5 - Serial number: D0B143ˇÜ6342MSME1039677FKˇÜ63
Subsystem 6 - Serial number: 9677FKˇÜ6351HTS63IKAD6924ˇÜ63
Subsystem 7 - Serial number: AD6924ˇÜ6361HTS63IKAT2U2 ˇÜ63
Subsystem 8 - Serial number: AT2U2 ˇÜ63727TS61IKI6KR2SˇÜ63
Subsystem 9 - Serial number: I6KR2SˇÜ63827TS64IK635L2$ˇ
Subsystem 10 - Serial number: 635L2$ˇ
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507P
Coding: 0002111
Component: E0221 006 0080
Part No SW: 3C0 920 970 R HW: 3C0 920 970 R
Revision: V0033000 Serial number: 00000000000000
Coding: 0007205
VCID: 333319C1673B057F045-8066
Fault Frequency: 38
Reset counter: 233
Mileage: 213831 km
Date: 2017.12.03
Time: 16:24:32
00532 - Supply Voltage B+
Reset counter: 233
Mileage: 214195 km
Date: 2018.02.22
Time: 00:01:31
00771 - Fuel Level Sensor (G)
Fault Status: 00101010
Reset counter: 233
Mileage: 214195 km
Date: 2018.03.18
Time: 19:38:09
Reset counter: 233
Mileage: 213831 km
Date: 2017.12.03
Time: 00:00:02
00003 - Control Module
014 - Defective
Fault Status: 01101110
Fault Frequency: 48
Mileage: 205145 km
Date: 2016.04.03
Time: 00:02:19
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C062181192
Coding: 3FFD0E04D31002
VCID: 211FE389CDC787EFE69-8074
01304 - Radio
Reset counter: 194
Mileage: 216065 km
Date: 2019.12.27
Time: 15:15:04
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0002
Revision: 00005000 Serial number: 1166279TQDDX04
VCID: 6D87CFB9419F938F121-8038
Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
Component: IMMO 041 0364
Revision: 00041000 Serial number: VWZCZ000000000
Shop #: WSC 25129 444 54633
VCID: 2A0D04A5B0F144B7B73-807E
Subsystem 1 - Part No: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2801
Coding: 0001205
VCID: 363520D57449105723B-8062
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
00750 - Warning Lamp
Mileage: 5000 km
Temperature: 41.0∞C
Voltage: 12.60 V
Voltage: 12.30 V
Component: KSG PQ46 RDK 041 0213
Coding: 13910F8801862E521804141FF00A0F0E081800
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 200
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001204
VCID: 372B2DD17343E95F38D-8062
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0010000
Fault Status: 11101101
Reset counter: 202
Mileage: 214192 km
Date: 2018.03.18
Time: 00:00:00
Voltage: 11.80 V
Count: 236
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 116
Voltage: 11.90 V
Count: 171
Address 56: Radio
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2436
Coding: 0000144
VCID: 313F13C99D27376F769-8064
Component: RDK 0391
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323D1CC598210C770F3-8066
End----(Elapsed Time: 01:31, VBatt start/end: 11.5V/11.6V. VIgn 11.6V)-----
