2006 Passat B6 2.0T Parking Brake Fault
akitchens
C?ID=273674
Hello all,
Newbie here. I purchased a 2006 Passat 2.0T B6 from my niece. Got it up and running and I get a "error" message on the dash and also see parking brake fault. I have changed the back parking brake motors and issue continues.
I have noticed that the ABS is not coded as per the readings.
Anyone help with this below info?
Wednesday,22,January,2020,18:45:45:59102
VIN: WVWEK73CX6P187147   License Plate:
Mileage: 216100km-134278mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
          72
VIN: WVWEK73CX6P187147   Mileage: 216100km-134278miles
   Part No SW: 3C0 907 115 F    HW: 3C0 907 115 F
   Revision: --H14---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 25129 444 64221
   VCID: 2313E981D7DB95FFF45-8076
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - Intermittent
                    Load: 0.0 %
                    Temperature: 18.0∞C
                    Temperature: 18.0∞C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 11.938 V
008851 - Fuel Pressure Regulator Valve (N276)
               P2293 - 002 - Mechanical Malfunction - Intermittent
                    Mileage: 216062 km
                    Date: 2019.12.27
                    Time: 15:00:44
                    RPM: 2812 /min
                    Load: 49.0 %
                    Speed: 55.0 km/h
                    Temperature: 93.0∞C
                    Temperature: 28.0∞C
                    Voltage: 13.843 V
012555 - Low Pressure Fuel regulation
               P310B - 008 - Fuel Pressure Outside Specification - Intermittent
                    Fault Frequency: 7
                    Mileage: 216062 km
                    Date: 2019.12.27
                    Time: 15:00:44
                    RPM: 2827 /min
                    Load: 35.7 %
                    Speed: 57.0 km/h
                    Temperature: 93.0∞C
                    Temperature: 25.0∞C
                    Voltage: 13.843 V
               P310B - 004 - Fuel Pressure Outside Specification - Intermittent
                    Mileage: 216072 km
                    Date: 2019.12.27
                    Time: 18:07:03
                    RPM: 763 /min
                    Load: 23.1 %
                    Temperature: 95.0∞C
                    Temperature: 30.0∞C
                    Voltage: 13.843 V
000568 - Manifold Pressure / Boost Sensor (G31)
               P0238 - 001 - Signal too High - Intermittent
                    Fault Status: 00100001
                    Mileage: 216079 km
                    Load: 0.0 %
                    Temperature: 18.0∞C
                    Temperature: 18.0∞C
                    Voltage: 11.938 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 008 -  - Intermittent
                    Mileage: 216090 km
                    Date: 2019.12.30
                    Time: 16:54:21
                    RPM: 895 /min
                    Load: 29.0 %
                    Temperature: 91.0∞C
                    Temperature: 18.0∞C
                    Voltage: 14.097 V
Readiness: 0000 0001
   Part No SW: 09G 927 750 HJ    HW: 09G 927 750 CJ
   Component: AQ 250 6F           1068
   Revision: 00H38000    Serial number:
   Coding: 0000072
   VCID: 0059860D660D6EE7C97-8054
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0667269566
   Coding: 0010000
   Shop #: WSC 00028 028 00001
   VCID: 303916CD962D3E67797-8064
                    Fault Frequency: 99
                    Reset counter: 175
                    Mileage: 215711 km
                    Date: 2019.12.14
                    Time: 16:18:06
                    Fault Frequency: 35
                    Reset counter: 238
                    Mileage: 215763 km
                    Date: 2019.12.15
                    Time: 16:10:38
                    Fault Frequency: 35
                    Reset counter: 238
                    Mileage: 215763 km
                    Date: 2019.12.15
                    Time: 16:10:38
   Part No: 1K0 820 047 EC
   Component: Climatic PQ35   090 0505
   VCID: 698FBBA975778FAF7E9-803C
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Revision: 00H52000    Serial number: 00000000602253
   Coding: 14058E234004150007140000001400000008730B5C0000
   VCID: 6B83C1A17F8B9DBF0C5-803E
   Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer VW461 001   0101
   Coding: 00063445
                    Fault Status: 01101100
                    Reset counter: 202
                    Mileage: 214839 km
                    Date: 2019.11.19
                    Time: 00:24:00
                    Voltage: 12.95 V
00156 - Control Circuit for Windshield Washer Pump
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 22
                    Reset counter: 202
                    Mileage: 214950 km
                    Date: 2019.11.21
                    Time: 23:08:00
                    Voltage: 14.00 V
02399 - Control Circuit for Terminal 30 for Interior Illumination
                    Fault Status: 01111001
                    Reset counter: 202
                    Mileage: 214839 km
                    Date: 2019.11.19
                    Time: 00:19:00
                    Voltage: 12.05 V
00059 - Terminal 30 for Interior Lighting
                    Reset counter: 202
                    Mileage: 214839 km
                    Date: 2019.11.19
                    Time: 00:19:00
                    Voltage: 12.05 V
00975 - Heated Rear Window (Z1)
                    Fault Status: 00100110
                    Reset counter: 221
                    Mileage: 215030 km
                    Date: 2019.11.25
                    Time: 15:53:00
                    Voltage: 13.80 V
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7E0040619
   VCID: 2B0301A1BF0B5DBF4C5-807E
                    Fault Frequency: 115
                    Reset counter: 242
                    Mileage: 208556 km
                    Date: 2017.10.22
                    Time: 14:58:02
01304 - Radio
                    Fault Status: 01101000
                    Fault Frequency: 169
                    Reset counter: 40
                    Mileage: 208556 km
                    Date: 2017.10.22
                    Time: 14:58:01
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0N AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P0KBM6E
   Coding: 0012366
   VCID: 2E0508B58C1928976BB-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 00000000031JXZ
   Subsystem 3 - Serial number: 0001.01.000000600000000000ˇÜ63
   Subsystem 4 - Serial number: 000000ˇÜ6332MSME102D0B143ˇÜ63
   Subsystem 5 - Serial number: D0B143ˇÜ6342MSME1039677FKˇÜ63
   Subsystem 6 - Serial number: 9677FKˇÜ6351HTS63IKAD6924ˇÜ63
   Subsystem 7 - Serial number: AD6924ˇÜ6361HTS63IKAT2U2 ˇÜ63
   Subsystem 8 - Serial number: AT2U2 ˇÜ63727TS61IKI6KR2SˇÜ63
   Subsystem 9 - Serial number: I6KR2SˇÜ63827TS64IK635L2$ˇ
   Subsystem 10 - Serial number: 635L2$ˇ
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C5953507P
   Coding: 0002111
   Component: E0221           006 0080
   Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: V0033000    Serial number: 00000000000000
   Coding: 0007205
   VCID: 333319C1673B057F045-8066
                    Fault Frequency: 38
                    Reset counter: 233
                    Mileage: 213831 km
                    Date: 2017.12.03
                    Time: 16:24:32
00532 - Supply Voltage B+
                    Reset counter: 233
                    Mileage: 214195 km
                    Date: 2018.02.22
                    Time: 00:01:31
00771 - Fuel Level Sensor (G)
                    Fault Status: 00101010
                    Fault Frequency: 8
                    Reset counter: 233
                    Mileage: 214195 km
                    Date: 2018.03.18
                    Time: 19:38:09
                    Reset counter: 233
                    Mileage: 213831 km
                    Date: 2017.12.03
                    Time: 00:00:02
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 48
                    Mileage: 205145 km
                    Date: 2016.04.03
                    Time: 00:02:19
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C062181192
   Coding: 3FFD0E04D31002
   VCID: 211FE389CDC787EFE69-8074
01304 - Radio
                    Reset counter: 194
                    Mileage: 216065 km
                    Date: 2019.12.27
                    Time: 15:15:04
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0002
   Revision: 00005000    Serial number: 1166279TQDDX04
   VCID: 6D87CFB9419F938F121-8038
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    IMMO         041 0364
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 25129 444 54633
   VCID: 2A0D04A5B0F144B7B73-807E
   Subsystem 1 - Part No: 3C0 905 861 D
   Component:    ELV          024 0370
   3C0905861D     ELV          024 0370
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2801
   Coding: 0001205
   VCID: 363520D57449105723B-8062
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
00750 - Warning Lamp
                    Mileage: 5000 km
                    Temperature: 41.0∞C
                    Voltage: 12.60 V
                    Voltage: 12.30 V
   Component:    KSG PQ46 RDK 041 0213
   Coding: 13910F8801862E521804141FF00A0F0E081800
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 200
   Part No: 1K0 959 702 K
   Coding: 0001204
   VCID: 372B2DD17343E95F38D-8062
   Revision:   013
   Coding: 0010000
01316 - ABS Control Module
                    Fault Status: 11101101
                    Reset counter: 202
                    Mileage: 214192 km
                    Date: 2018.03.18
                    Time: 00:00:00
                    Voltage: 11.80 V
                    Count: 236
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 116
                    Voltage: 11.90 V
                    Count: 171
Address 56: Radio
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2436
   Coding: 0000144
   VCID: 313F13C99D27376F769-8064
   Component:    RDK              0391
   Coding: 0100101
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323D1CC598210C770F3-8066
End----(Elapsed Time: 01:31, VBatt start/end: 11.5V/11.6V. VIgn 11.6V)-----
akitchens
C?ID=273674
Thanks. Since I’m new at this, do you have a easy way to get this programmed into it?
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Just copy /paste that coding in ABS .
If you do not know how then read how to use VCDS on Ross-Tech website .
akitchens
C?ID=273674
Thanks for all's help. I was able to get it programmed and still have the "Error" on the dash with the parking brake fault. I have run another readings to see if you can help. A couple stick out to me but unsure what to do.
Thanks again
Monday,27,January,2020,10:38:56:59102
Mileage: 216110km-134284mi   Repair Order:
          72
VIN: WVWEK73CX6P187147   Mileage: 216110km-134284miles
                    Load: 0.0 %
                    Temperature: 18.0∞C
                    Temperature: 18.0∞C
                    Voltage: 11.938 V
                    Mileage: 216062 km
                    Date: 2019.12.27
                    Time: 15:00:44
                    RPM: 2812 /min
                    Load: 49.0 %
                    Speed: 55.0 km/h
                    Temperature: 93.0∞C
                    Temperature: 28.0∞C
                    Voltage: 13.843 V
                    Fault Frequency: 7
                    Mileage: 216062 km
                    Date: 2019.12.27
                    Time: 15:00:44
                    RPM: 2827 /min
                    Load: 35.7 %
                    Speed: 57.0 km/h
                    Temperature: 93.0∞C
                    Temperature: 25.0∞C
                    Voltage: 13.843 V
                    Mileage: 216072 km
                    Date: 2019.12.27
                    Time: 18:07:03
                    RPM: 763 /min
                    Load: 23.1 %
                    Temperature: 95.0∞C
                    Temperature: 30.0∞C
                    Voltage: 13.843 V
                    Mileage: 216079 km
                    Load: 0.0 %
                    Temperature: 18.0∞C
                    Temperature: 18.0∞C
                    Voltage: 11.938 V
                    Mileage: 216090 km
                    Date: 2019.12.30
                    Time: 16:54:21
                    RPM: 895 /min
                    Load: 29.0 %
                    Temperature: 91.0∞C
                    Temperature: 18.0∞C
                    Voltage: 14.097 V
   Coding: 0000072
   Coding: 0013755
   Coding: 00063445
                    Reset counter: 203
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:00
                    Voltage: 14.40 V
                    Reset counter: 203
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:00
                    Voltage: 14.40 V
                    Reset counter: 203
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:23
01304 - Radio
                    Reset counter: 203
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:22
   Coding: 0012366
   Coding: 0002111
   Coding: 0007205
            014 - Defective
                    Fault Frequency: 48
                    Mileage: 205145 km
                    Date: 2016.04.03
                    Time: 00:02:19
01304 - Radio
                    Reset counter: 203
                    Mileage: 216110 km
                    Date: 2020.01.27
                    Time: 10:30:27
   Coding: 0001205
   Coding: 0001204
   Revision:   013
   Coding: 0000013
                    Reset counter: 203
                    Mileage: 214192 km
                    Date: 2018.03.18
                    Time: 00:00:00
                    Voltage: 11.80 V
                    Count: 236
Address 56: Radio
   Coding: 0000144
   Component:    RDK              0391
   Coding: 0100101
   Coding: 0000144
End----------(Elapsed Time: 01:32, VBatt start/end: 14.2V/14.2V)-----------
