2006 A4 need to measure HPFP
Matt6
C?ID=392695
What is the measuring block(s) and what numbers are good and bad. When started (cold) it idles somewhat rough and after choke idle turns off it goes really rough and Mean shaking bad rough.
Hi and welcome.
2006 A4s were available with more than one engine. It might be useful to know which one you have. ;)
Ideally, you would post an Auto-Scan so people could see exactly what your car is made of.
Matt6
C?ID=392695
sorry went to car to test gonna put up a log here in a minute or.. as soon as i figure this out oh and it is a 2,0T
Matt6
C?ID=392695
Friday,24,January,2020,13:17:48:57523
VIN: WAUAF78E56A143067   License Plate: MATT
Mileage: 262390km-163041mi   Repair Order:
          67 69 75 76 77
VIN: WAUAF78E56A143067   Mileage: 262390km-163041miles
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 8E3 910 155 C    HW: 01J 927 156 HT
   Component: V30 01J 2.0TFSI USA 0010
   Revision: 00000010    Serial number: 00000001213967
   Shop #: WSC 22606 444 58779
   VCID: 2809FF553EFD1077A17-807C
17134 - Shift Solenoid 1 (N88)
            P0750 - 000 - Malfunction - Intermittent
                    RPM: 192 /min
                    (no units): 13.0
                    Torque: 72.0 Nm
                    Temperature: 15.0°C
                    T.B. Angle: 0.0°
                    Bin. Bits: 0101 0 0
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 D    HW: 8E0 614 517 AK
   Component: ESP8 front      H05 0120
   Coding: 0004525
   Shop #: WSC 06335 000 00000
                    Fault Frequency: 20
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x4222
                    Hex Value: 0x0024
                    Hex Value: 0x01AB
                    Hex Value: 0x0000
00493 - ESP-Sensor Unit (G419)
                    Reset counter: 1
                    Hex Value: 0x06C0
                    Hex Value: 0x4002
                    Hex Value: 0x001B
                    Hex Value: 0x3AB2
                    Hex Value: 0x0000
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x6222
                    Hex Value: 0x0028
                    Hex Value: 0x01AA
                    Hex Value: 0x0000
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2832
   Coding: 00000
   VCID: 6D87CE41D48FF55F121-5160
00710 - Defroster Flap Positioning Motor (V107)
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  USA 0504
   Coding: 00003
   Shop #: WSC 06335
   VCID: 3B233019DA7BABEFDC5-4B00
            30-00 - Open or Short to Plus
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H11 3540
   Revision: 91H1135    Serial number: 0036N0013ZM7
   Coding: 0032607
   VCID: 3C213305DA65ACD7D5F-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 35TET
   Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB40244C796Rÿ†63
   Subsystem 5 - Serial number: 4C796Rÿ†6342DRB402439227Dÿ†63
   Subsystem 6 - Serial number: 39227Dÿ†6352ARB400BA59D5Zÿ†63
   Subsystem 7 - Serial number: A59D5Zÿ†6362ARB400B69EA8+ÿ†63
   Subsystem 8 - Serial number: 69EA8+ÿ†63729RB400C51B4CSÿ†63
   Subsystem 9 - Serial number: 51B4CSÿ†63829RB400C51A77Qÿ
   Subsystem 10 - Serial number: 51A77Qÿ
00532 - Supply Voltage B+
                    Fault Frequency: 27
                    Reset counter: 39
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 02021
   Shop #: WSC 06335
   VCID: 41DF42F1B897C13F869-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 951 G    HW: 8E0 920 951 G
   Component: KOMBI+WFS 4     H12 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0022261
   Shop #: WSC 22133 444 103364
   VCID: 2E05094D1C094E476BB-5184
01128 - Immobilizer Pickup Coil (D2)
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0022261
   Part No: 8E0 959 433 BT
   Component: Komfortgerát T7B    3332
   Coding: 11836
   Shop #: WSC 06335
   VCID: 04518BE5E7051417EDF-4B00
   Component: Tõrsteuer.FS BRM 0506
   Component: Tõrsteuer.BF BRM 0205
   Component: Tõrsteuer.HL BRM 0606
   Component: Tõrsteuer.HR BRM 0606
            35-00 - -
            35-00 - -
            35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
            35-00 - -
00955 - Key 1
            35-10 - - - Intermittent
   Part No: 8E0 035 195 H
   Component: symphony II PM6    0460
   Coding: 01005
   Shop #: WSC 22016
   VCID: 2C0103452F253C5745F-508A
00879 - Connection to Speaker Front Right
            29-10 - Short to Ground - Intermittent
End----------(Elapsed Time: 05:44, VBatt start/end: 14.0V/14.0V)-----------
Matt6
C?ID=392695
Ok this is odd because there seems to be no engine faults and the check engine light stopped flashing I just purchased VCDS and and do not really know it very well
Even more odd to me: 01-Engine is conspicuously absent from that scan. :confused:
Matt6
C?ID=392695
Sunday,26,January,2020,12:42:14:57523
VIN: WAUAF78E56A143067 License Plate: SUNDAY1/26
Address 01: Engine (8E0 910 115 M)
12:41:57 Group 103: Fuel Injection (Fuel Pump Adaptation)
5.12 bar Current Fuel Pressure
4 Fuel Pressure Regulator
478 Adaptation Value elect. Fuel Pump
Test OFF Fuel Pump Adapt. Status
12:41:57 Group 032: Lambda Control (Mixture Adaptation)
1.3 % Adaptation (Idle) Bank 1 Sensor 1
0.0 % Adaptation (Partial) Bank 1 Sensor 1
Matt6
C?ID=392695
just not sure if 5.12bar is good or bad
I did do a heat soak test as per a video you guys made so at least I know the injectors are not leaking
and the fuel tank pump i tested with a gauge and it held at around 68-70 so i figure thats good which leaves us the hpfp cam follower is new too.
