What is the measuring block(s) and what numbers are good and bad. When started (cold) it idles somewhat rough and after choke idle turns off it goes really rough and Mean shaking bad rough.
Friday,24,January,2020,13:17:48:57523
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
VIN: WAUAF78E56A143067 License Plate: MATT
Mileage: 262390km-163041mi Repair Order:
67 69 75 76 77
VIN: WAUAF78E56A143067 Mileage: 262390km-163041miles
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E3 910 155 C HW: 01J 927 156 HT
Component: V30 01J 2.0TFSI USA 0010
Revision: 00000010 Serial number: 00000001213967
Coding: 0000001
Shop #: WSC 22606 444 58779
VCID: 2809FF553EFD1077A17-807C
17134 - Shift Solenoid 1 (N88)
P0750 - 000 - Malfunction - Intermittent
RPM: 192 /min
(no units): 13.0
Torque: 72.0 Nm
Temperature: 15.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H05 0120
Coding: 0004525
Shop #: WSC 06335 000 00000
Fault Frequency: 20
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x0024
Hex Value: 0x01AB
Hex Value: 0x0000
00493 - ESP-Sensor Unit (G419)
Reset counter: 1
Hex Value: 0x06C0
Hex Value: 0x4002
Hex Value: 0x001B
Hex Value: 0x3AB2
Hex Value: 0x0000
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Hex Value: 0x0000
Hex Value: 0x6222
Hex Value: 0x0028
Hex Value: 0x01AA
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00000
VCID: 6D87CE41D48FF55F121-5160
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul USA 0504
Coding: 00003
Shop #: WSC 06335
VCID: 3B233019DA7BABEFDC5-4B00
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H11 3540
Revision: 91H1135 Serial number: 0036N0013ZM7
Coding: 0032607
VCID: 3C213305DA65ACD7D5F-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 35TET
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB40244C796Rÿ†63
Subsystem 5 - Serial number: 4C796Rÿ†6342DRB402439227Dÿ†63
Subsystem 6 - Serial number: 39227Dÿ†6352ARB400BA59D5Zÿ†63
Subsystem 7 - Serial number: A59D5Zÿ†6362ARB400B69EA8+ÿ†63
Subsystem 8 - Serial number: 69EA8+ÿ†63729RB400C51B4CSÿ†63
Subsystem 9 - Serial number: 51B4CSÿ†63829RB400C51A77Qÿ
Subsystem 10 - Serial number: 51A77Qÿ
Fault Frequency: 27
Reset counter: 39
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02021
Shop #: WSC 06335
VCID: 41DF42F1B897C13F869-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 G HW: 8E0 920 951 G
Component: KOMBI+WFS 4 H12 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0022261
Shop #: WSC 22133 444 103364
VCID: 2E05094D1C094E476BB-5184
01128 - Immobilizer Pickup Coil (D2)
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0022261
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3332
Coding: 11836
Shop #: WSC 06335
VCID: 04518BE5E7051417EDF-4B00
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0506
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0205
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
00962 - Alarm via. Tilt Sensor
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
35-00 - -
00955 - Key 1
35-10 - - - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II PM6 0460
Coding: 01005
Shop #: WSC 22016
VCID: 2C0103452F253C5745F-508A
00879 - Connection to Speaker Front Right
36-10 - Open Circuit - Intermittent
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
End----------(Elapsed Time: 05:44, VBatt start/end: 14.0V/14.0V)-----------
