HEX-USB+CAN firmware update failed
morskoi
Pirate
Walking the Plank
Russia
HC558896 (CLONE!)
Hello, I'm trying to use VCDS 14.10.0 with HEX-USB+CAN adapter. When I press "test" i see this message
VCDS: Port Test
Port Status: OK
USB Library Version: 03.02.07
USB Driver Version: 02.10.00
Interface: Found!
Type: Ross-Tech HEX-USB+CAN
Version: 1.92
Status: Firmware Update Required!
CAN: Questionable
ОК
I click OK and I see next message
The Firmware in your HEX interface is out of date!
Current HEX Firmware version: 1.92
This version of VCDS requires: 1.93
I click UPDATE, and I see
Previous version: 1.92
Please Wait...
Unable to Update!
You are using an illegally pirated clone of our product. You should return it to whomever you bought it from and demand a full refund. If no refund is forthcoming, you should take the matter up with your payment processor and/or law enforcement authorities.
Real ones are available directly from us:
http://store.ross-tech.com/shop/cat/IC.html
... or from any of our authorized resellers:
http://www.ross-tech.com/distributors.html
Dana
Western PA, USA
