Q7 4L 3.0TDI not starting after high pressure pump change
Yamahaboy
Norway
C?ID=61326
We got in a Q7 3.0tdi year 2011 that was running but with fault low fuel pressure.
Local VW dealer changed High pressure pump, and after that they could not get it running. They don`t have Audi license anymore so they could not do any adaptations on it they said, so they have given up get it running after one week...
I have now updated it to the newest Audi SW version, can clear fault codes on engine, but once I try to start it they come back, also not starting either.
Fault codes are no power to injector bank A and B, P2146 and P2149. They are cleared in the autoscan, but attached after that.
Anyone know what next step is to try? Or what could cause this? Car was running after all before they changed the pump.
Thanks in advance if anyone could help here.
Tuesday,21,January,2020,17:46:29:37173
VCDS Version: 19.6.2.0 (x64)
Dealer/Shop Name: ES Tuning
Workshop Code: 123 00123 012345
VIN: WAUZZZ4L3BD009290   License Plate: Q7
Mileage:    Repair Order: etter0009
                Address 01: Engine       Labels: 059-907-401-V2.clb
Control Module Part Number: 4L1 910 401 H    HW: 4L0 907 401 C
  Component and/or Version: 3.0TDI EDC17  H37 0009
           Software Coding: 2A2A4012A57601020000
            Work Shop Code: WSC 31414 790 00001
              ASAM Dataset: EV_ECM30TDI0114L1910401H 001014 (AU56)
                       ROD: EV_ECM30TDI0114L1910401H.rod
                      VCID: 2854453853622E0FCF-807C
5060 - Supply Voltage for Fuel Injector Group A
          P2146 00 [101] - Open Circuit
                    Mileage: 180436 km
                    Date: 2020.01.19
                    Time: 20:49:41
                    Engine speed: 195.00 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 1 °C
                    Intake air temperature: 2 °C
                    Voltage terminal 30: 9.540 V
                    Allowed number of injections-Bits 0-7: 3
                    Injection release status-Bits 0-7: 56
                    Desired injection characteristic-Bits 0-7: 56
                    Mean injection quantity: 39.31 mg/stroke
                    Rail pressure regulation: status-Bits 0-7: 5
                    Fuel high pressure: actual value: 346300 hPa
                    Control Module temperature: 21.6 °C
5061 - Supply Voltage for Fuel Injector Group B
          P2149 00 [101] - Open Circuit
                    Mileage: 180436 km
                    Date: 2020.01.19
                    Time: 20:49:41
                    Engine speed: 193.50 /min
                    Voltage terminal 30: 9.600 V
                    Fuel high pressure: actual value: 574600 hPa
                    Control Module temperature: 20.4 °C
Welcome OP
Please post a compete auto-scan!
Did you check wiring and supply bus + fuses yet?
Well, if there's no supply voltage to the fuel injectors, that certainly could keep it from starting, no?
If I were chasing this, I'd get wiring diagrams and check things out with a multimiter.
And in addition to what Uwe aforementioned you check with DVOM, you know you must qualify the amperage in series with multi meter, not just voltage to circuit, right?
Yamahaboy
Norway
C?ID=61326
Thanks for your reply.
Here complete autoscan.
I haven’t started checked the wiring yet, that will be the next thing I figure.
But as they said at the VW shop who replaced the part, they didnt have access to the ecu because of the license.
Is there anything that need adapation to Get it running after high pressure pump? N276 basic settings?
Also, if I clear the fault codes when I crank the engine it tries to start for a very short time and then the fault codes comes again. As is it gets spray from the injectors for a short time.
Any clues from this?
Thanks,
 Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 13 15 16 17 18 19 20 34 3C 42 46 4F 52
          55 56 5F 62 69 6C 6D 6F 72 76
VIN: WAUZZZ4L3BD009290   Mileage: 180430km-112114miles
Address 01: Engine (J623-CJGA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L1 910 401 H    HW: 4L0 907 401 C
   Component: 3.0TDI EDC17  H37 0003
   Revision: 53H37---    Serial number:
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114L1910401H 001008
   Part No SW: 0C8 927 750 AE    HW: 0C8 927 750 AE
   Component: AL1000 AISIN  001 1783
   Coding: 001578
   Shop #: WSC 19081 001 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_AU56.rod
   VCID: 6FE66E24B60C39374E-803A
Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Component: ESP ALLRAD MK25E1   0020
   Revision: 00H02001
   Coding: 2724961
   VCID: 346CA14857AA5AEF73-8060
                    Reset counter: 21
                    Mileage: 180435 km
                    Date: 2020.01.14
                    Time: 19:47:23
                    Count: 321
                    Count: 297
                    Count: 50432
                    Reset counter: 21
                    Mileage: 180435 km
                    Date: 2020.01.17
                    Time: 21:39:50
                    Count: 64
                    Count: 2113
                    Count: 128
                    Count: 33792
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10602901655846
   Coding: 0000131
   VCID: 254A4C0CEC703367F4-8070
   Subsystem 1 - Part No: 4F0 910 132 E
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 IDG   H01 0054
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0060
   Revision: 00---022    Serial number: 00000000246955
   Coding: 01009016
   VCID: 254A4C0C2C703367F4-8070
                    Fault Frequency: 9
                    Reset counter: 21
                    Mileage: 180435 km
                    Date: 2020.01.17
                    Time: 21:39:52
                    Voltage: 9.40 V
   Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
   Component: ILM Fahrer      H29 0390
   Coding: 0023221
   VCID: 6FE66E247E0C39374E-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H17 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
00924 - Relay for Headlamp Cleaning System (J39)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 236
                    Mileage: 180432 km
                    Date: 2020.01.14
                    Time: 19:47:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 152A7CCCFC10A3E764-8040
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4L0 910 561 A    HW: 4L0 907 561
   Component: ABSTANDSREGELUNGH06 0160
   Revision: --------    Serial number: 00000000000000
   Coding: 0031161
   VCID: 27564604967C2177C6-8072
01316 - ABS Control Module
                    Fault Status: 00101101
                    Fault Frequency: 11
                    Reset counter: 21
                    Mileage: 180435 km
                    Date: 2020.01.14
                    Time: 19:47:22
                    Temperature: 22.0°C
                    Voltage: 13.95 V
                    Bin. Bits:    01000
                    Hex Value: 0x0442
                    Hex Value: 0x0002
                    Speed: -3.6 km/h
                    Lateral Accel.: 0.00 m/s^2
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D071W2X
   Coding: 0014128
   VCID: 2E58B320B986703F05-807A
   Subsystem 1 - Serial number: 6332QSME09694608H
   Subsystem 2 - Serial number: 6342QSME0969150AG
   Subsystem 3 - Serial number: 6352QSME116E070CI
   Subsystem 4 - Serial number: 6362QSME3F6D3114O
   Subsystem 5 - Serial number: 63734SME714C4F348
   Subsystem 6 - Serial number: 63834SME584B07284
00532 - Supply Voltage B+
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90025102360289
   Coding: 0002052
   Component: E0221           H02 0100
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 932 D    HW: 4L0 920 932 D
   Component: KOMBIINSTR.   H10 0209
   Revision: 00000000    Serial number: FLA20HV8A
   Coding: 0F5663040C010008000000
   VCID: 2D5AB42C74800B273C-8078
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 G
   Component: Heizgeraet      H09 0140
   Revision: 0000000C    Serial number: 00000009021078
   Coding: 0000101
   VCID: 60C41D18B3D2964FC7-8034
00664 - Fuel gauge
   Part No SW: 4F0 907 468 Q    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0047
   Revision: MB300033    Serial number: 3300M10720017E
   Coding: 00CF07
   VCID: 3D7A846CA4E09BA78C-8068
   Subsystem 1 - Part No SW: 8K0 915 181 D    HW: 8K0 915 181 D
   Component: J367-BDM  H07 0125
   Serial number: 00000000002799187804
   Component: J532_DCDCStab  H16 0038
   Serial number: 10230001370011200180
                    Reset counter: 236
                    Mileage: 180435 km
                    Date: 2020.01.14
                    Time: 19:47:22
                    Bin. Bits:    10111
                    Voltage: 13.80 V
                    Count: 7
02256 - Quiescent Current
            001 - Upper Limit Exceeded
                    Fault Status: 01100001
                    Reset counter: 236
                    Mileage: 180435 km
                    Date: 2020.01.14
                    Time: 22:37:00
   Part No SW: 4F0 857 511 K    HW: 4F0 857 511 K
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 02019064747464545425363E
   VCID: 3064AD5863B266CF17-8064
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 H    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7870
   Revision: --H03001    Serial number: 15.1528-0123.2
   Coding: 0015520
   VCID: 2F66AE24BE8C79370E-807A
                    Fault Frequency: 10
                    Reset counter: 20
                    Mileage: 180435 km
                    Date: 2020.01.14
                    Time: 19:48:04
                    Error Code: 13
Address 3C: Lane Change        Labels: None
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 009 014-10
   Coding: 0010101
   Subsystem 1 - Part No: 4L0 910 568 C
   Component: J0770_SWA_Slave_H01 0050
   Subsystem 2 - Serial number: 6PZ 009 014-30
   Subsystem 3 - Serial number: 5F16.08.1000H010003C910691ÿ
   Subsystem 4 - Serial number: 910691ÿ
02857 - Supply Voltage for Lane Change Assistance Control Module 2
                    Reset counter: 21
                    Mileage: 180432 km
                    Date: 2020.01.17
                    Time: 21:56:12
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0361
   Revision:             Serial number: 0008000005527
   Coding: 011C02205040440004
   VCID: 4894E5B8FB22CE0F2F-801C
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01345264760000
   Coding: 3539077
   VCID: 356A9C4C5CD043E744-8060
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000556863
   Coding: 0011001
   VCID: 5EB823E089A6A0BFF5-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0361
   Revision:             Serial number: 0008000003477
   VCID: 4796E684F63CC17726-8012
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Component: AFS 1           H01 0010
   Coding: 0000032
   VCID: 2B5EBA348A94051722-807E
   Component: AFS-Modul links H07 0004
   Subsystem 2 - Part No: -----------
   Component: AFS-Modul rechts
02234 - Right Headlight Power Output Stage (J668)
                    Fault Status: 11100100
                    Reset counter: 236
                    Mileage: 180435 km
                    Date: 2020.01.14
                    Time: 19:47:22
03798 - Output Module 2 for Right Headlamp
                    Reset counter: 236
                    Mileage: 180435 km
                    Date: 2020.01.14
                    Time: 19:47:22
   Part No SW: 4G0 035 056     HW: 4G0 035 056
   Component: Radio U STD   H51 0051
   Revision: AB001007    Serial number: 469H40A7559603
   Coding: 010003020100000000
   VCID: 5EB823E049A6A0BFF5-800A
   Part No SW: 4L0 035 666 B    HW: 4L0 035 666 A
   Component: H-BN-EU       H49 0107
   Revision: --------    Serial number: 473I20A7535368
   Coding: 0101000600049BEF31002315EF6300030001
   VCID: 2C5CB9284F9A022F2B-8078
   Subsystem 1 - Part No: 8R0 060 884 R
   Component: EUR 2010  1107
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466G00A0058886
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 B
   Component: E0380 Bedient  H05 0060
   Serial number: 00000001669447
   Component: CD-Database  1886
   Part No SW: 4F0 959 795 Q    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000107612432
   Coding: 010800204040230004
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 236
                    Mileage: 180435 km
                    Date: 2020.01.15
                    Time: 12:49:42
Address 69: Trailer (J345)       Labels: None
   Part No SW: 4L0 907 383 D    HW: 4L0 907 383 D
   Component: Anhaenger     H08 0072
   Revision: 2C001002    Serial number: 00000133852463
   Coding: 0101010000000000
   VCID: 3260A7506DBE54DF61-8066
02588 - Swiveling Trailer Hitch
                    Fault Status: 11100101
                    Reset counter: 174
   Part No SW: 4L0 910 441 B    HW: 4L0 907 441 B
   Component: J772__Rearview      0030
   Revision: --H04---    Serial number: 525PA8-J0742YH
   Coding: 1031001
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H55 0500
   Revision: --H55001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CDC79284F1AC22F6B-8038
   Subsystem 3 - Serial number: RD06.09.10--H55001001B0186ÿ
   Subsystem 4 - Serial number: 1B0186ÿ
                    Reset counter: 20
                    Mileage: 180435 km
                    Date: 2020.01.06
                    Time: 08:57:28
   Component: ILM HINTEN 2    H05 0070
   Revision: AAH05061    Serial number: 107530114-----
   Coding: 0003587
   VCID: 26484B009176387FFD-8072
   Component: J_245_EE16_SKB10H11 0220
   Subsystem 2 - Part No: 4L0 910 591 A
   Component: J_394_EE16_SKB10H11 0220
   Subsystem 3 - Part No: 4L0 910 591 A
   Component: J_392_EE16_SKB10H11 0220
02960 - Lamp in Bumper; Rear Left
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 236
                    Mileage: 180435 km
                    Date: 2020.01.14
                    Time: 19:47:22
                    Bin. Bits:  000 001
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000107612496
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H02 0100
   Revision: 00H02000    Serial number: 85131024010419
   Coding: 0231066
   VCID: 2C5CB9288F9A022F2B-8078
End-------------------------(Elapsed Time: 04:02)--------------------------
Gateway Installation List:  4F0 907 468 Q
Yamahaboy
Norway
C?ID=61326
A little update today.
Have got the car running when I took of power supply for injector 1 and 5. Car starts running, idle but of course rough. When I connect one of the injectors again it stops right away. Without them connected it idles for hours.
Number 1 injector don`t have right Ohm, it flucting from zero to 185ohm, so this is porobably gone. But number 5 is 187ohm on, so I suspect wiring trouble...
Or...could it be the ecu that cause this? I took it out now and it is heavy corroded outside, water has been on dripping on this for a long time it looks.Haven`t the ecu yet but will take a look tomorrow.
Now I have this fault codes.
5334 - Turbocharger Boost Control Position Sensor Circuit
          P2564 00 [175] - Signal too Low
                    Mileage: 180436 km
                    Date: 2020.01.20
                    Time: 23:27:44
                    Engine speed: 864.50 /min
                    Normed load value: 48.2 %
                    Coolant temperature: 45 °C
                    Intake air temperature: 6 °C
                    Voltage terminal 30: 13.980 V
                    Charge Pressure Actuator: activation: 84.99 %
                    Charge Pressure Actuator: acknowledgment: -4.82 %
                    Turbocharger boost control: offset closed: 0.00 %
                    Turbocharger boost control: offset open: 0.00 %
                    High press turbocharger actuator: actual uncond volt value: 0.0 mV
5075 - Fuel Injector for Cylinder 1 (N30)
          P1237 00 [175] - Open Circuit
                    Mileage: 180436 km
                    Date: 2020.01.20
                    Time: 23:27:44
                    Engine speed: 849.50 /min
                    Normed load value: 63.5 %
                    Voltage terminal 30: 13.840 V
                    Mean injection quantity: 20.56 mg/stroke
                    Rail pressure regulation: status-Bits 0-7: 15
                    Fuel high pressure: actual value: 330300 hPa
                    Control Module temperature: 12.8 °C
5433 - Fuel Injector for Cylinder 5 (N83)
          P1241 00 [175] - Open Circuit
                    Mileage: 180436 km
                    Date: 2020.01.20
                    Time: 23:27:44
                    Engine speed: 856.50 /min
                    Normed load value: 49.4 %
                    Voltage terminal 30: 13.880 V
                    Mean injection quantity: 18.63 mg/stroke
                    Fuel high pressure: actual value: 314100 hPa
5080 - Injector: Cylinder 2 (N31)
          P0202 00 [172] - Circuit Malfunction
                    Mileage: 180436 km
                    Date: 2020.01.20
                    Time: 23:28:25
                    Engine speed: 1270.00 /min
                    Normed load value: 99.6 %
                    Coolant temperature: 48 °C
                    Intake air temperature: 7 °C
                    Voltage terminal 30: 14.160 V
                    Mean injection quantity: 24.27 mg/stroke
                    Fuel high pressure: actual value: 628400 hPa
                    Control Module temperature: 13.2 °C
Readiness: 1 4 0 0 1
So when you going to change or swap faulty injector to isolate?
Yamahaboy
Norway
C?ID=61326
Have to get my injector extraction tool first, number 1 was really stuck....
Tried to look in erwin but could not find what tourqe the injector clamp bolt should have.
Anyone knows it?
Yamahaboy
Norway
C?ID=61326
More update.
Got WD and there is all good from the ecu pin out to the injectors. Took out the ecu last night. It has been opened before I can see, and they have used another sealing than stock. Cant se much error on the pcb, or water, but suspect there is something wrong inside there.
Have found a used ecu, but is it possible to make clone full ecu on this? Immo problem?
Data transfer is possible by mail not clone or GeKo FaZit session at dealer or authorized VAG agent?
Yamahaboy
Norway
C?ID=61326
I have different tools, like dimsport trasdata and vcp, so I can read full and Flash full file, also frf. But how can the OTP area be fixed?
Local vw dealer can only do vw, so they are not for any help.
PIRATED VERSIONS OR LICENSED! :rolleyes:
Hey Bob knob, it would probably be a better conversation not in this forum and to RTFB the data sheets on the OTP & of the controllers chip set you are seeking to repair?
https://www.infineon.com/dgdl/TC1_3_ArchOverview_1.pdf?fileId=db3a304312bae05f0112be86204c0111
OTP One-Time Programmable <<<<< You do understand what this means right or do you believe you found a new "hole or glitch point"? :p
Yamahaboy
Norway
C?ID=61326
Only license version i have on all my tools, all original with annual fee.
I am fully aware of what OTP means, thats why I am asking if there is any other way to fix this beside make a immo off file?
OTP has nothing to do with immobilizer being turned off so WTF are talking about?
Maybe read the manuals and ask for tech support for your alleged licensed tools from supplier?
Yamahaboy
Norway
C?ID=61326
I know that immo don’t is in the OTP area, but it is still a problem for a 100% clone. Thats why I asked for some tip. And of course I have sent the readout, both bootmode and E-gpt dim file to dimsport support for their help and waiting for their reply.
If someone could tell me how I can upload pictures I can take a picture of my valid license of my tool, just to clarify that I am not flashing around with clone tools.
A 100 percent clone is no issue either because you can read a chips entire data + OTP and simply install a new tricore and write it with same data, next Bob?
You could also in theory do a forward boot loader on the processor itself or attached, if seeking to emulate the old OTP and write that at will, ever hear of a barking spider boot?
I guess the only factor is can you actually do work and walk to school or are seeking a free bag lunch?
Cloning is illegal & implies two, data transfer is not!
https://www.ncsl.org/print/cj/autotheftreport.pdf
https://www.justice.gov/archives/jm/criminal-resource-manual-1375-proving-violations-18-usc-511
https://www.justice.gov/archives/jm...removing-motor-vehicle-identification-numbers
https://www.justice.gov/archives/jm...certain-motor-vehicles-or-motor-vehicle-parts
https://www.nhtsa.gov/sites/nhtsa.dot.gov/files/documents/vin_errors.pdf
This is why tuners which tie their illegal acts to a VIN number function or by identity hash, they become one further step under the blade & open to TM and Patent fraud on the USPTO too, huh? :p
maiwand
C?ID=40516
tpi number 2042043/10 injector seals and coper washer. fault codes Supply Voltage for Fuel Injector Group A and b
