We got in a Q7 3.0tdi year 2011 that was running but with fault low fuel pressure.
Local VW dealer changed High pressure pump, and after that they could not get it running. They don`t have Audi license anymore so they could not do any adaptations on it they said, so they have given up get it running after one week...
I have now updated it to the newest Audi SW version, can clear fault codes on engine, but once I try to start it they come back, also not starting either.
Fault codes are no power to injector bank A and B, P2146 and P2149. They are cleared in the autoscan, but attached after that.
Anyone know what next step is to try? Or what could cause this? Car was running after all before they changed the pump.
Thanks in advance if anyone could help here.
Tuesday,21,January,2020,17:46:29:37173
VCDS Version: 19.6.2.0 (x64)
Dealer/Shop Name: ES Tuning
Workshop Code: 123 00123 012345
VIN: WAUZZZ4L3BD009290 License Plate: Q7
Mileage: Repair Order: etter0009
Address 01: Engine Labels: 059-907-401-V2.clb
Control Module Part Number: 4L1 910 401 H HW: 4L0 907 401 C
Component and/or Version: 3.0TDI EDC17 H37 0009
Software Coding: 2A2A4012A57601020000
Work Shop Code: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L1910401H 001014 (AU56)
ROD: EV_ECM30TDI0114L1910401H.rod
VCID: 2854453853622E0FCF-807C
5060 - Supply Voltage for Fuel Injector Group A
P2146 00 [101] - Open Circuit
Mileage: 180436 km
Date: 2020.01.19
Time: 20:49:41
Engine speed: 195.00 /min
Normed load value: 100.0 %
Coolant temperature: 1 °C
Intake air temperature: 2 °C
Voltage terminal 30: 9.540 V
Allowed number of injections-Bits 0-7: 3
Injection release status-Bits 0-7: 56
Desired injection characteristic-Bits 0-7: 56
Mean injection quantity: 39.31 mg/stroke
Rail pressure regulation: status-Bits 0-7: 5
Fuel high pressure: actual value: 346300 hPa
Control Module temperature: 21.6 °C
5061 - Supply Voltage for Fuel Injector Group B
P2149 00 [101] - Open Circuit
Mileage: 180436 km
Date: 2020.01.19
Time: 20:49:41
Engine speed: 193.50 /min
Voltage terminal 30: 9.600 V
Fuel high pressure: actual value: 574600 hPa
Control Module temperature: 20.4 °C
