2003 Jetta GLI Project - First Auto Scan
germanlvelez
Puerto Rico, USA
C?ID=385485
Hi all;
I just installed VCDS and performed an Auto Scan to my Jetta. I replaced the steering angle sensor and I'm rying to set it up correctly. Need some tips on how to do it. Also found several DTCs on the engine module. Your help is highly appreciated.
German
Friday,17,January,2020,17:43:47:07067
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
VIN: 3VWVH69MX3M060650   License Plate:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
          75 76
VIN: 3VWVH69MX3M060650   Mileage: 314400km-195359miles
Address 01: Engine        Labels: 022-906-032-BDF.lbl
   Part No: 022 906 032 CS
   Component: MOTRONIC ME7.1.1G   0004
   Coding: 00032
   Shop #: WSC 00066
   VCID: 5EE5999759262C479BB-5160
   3VWVH69MX3M060650     VWZ7Z0B5783956
16804 - Catalyst System; Bank 1
            P0420 - 35-10 - Efficiency Below Threshold - Intermittent
17880 - EVAP Leak Detection Pump
            P1472 - 35-10 - Short to Ground - Intermittent
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
            P1117 - 35-10 - Short to Ground - Intermittent
17606 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2
            P1198 - 35-10 - Electrical Malfunction - Intermittent
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 00028 000 00000
   VCID: 34311B3F822AD6171DF-5184
   Part No: 1C0 909 605 F
   Component: 04 AIRBAG VW61 0202 0001
   Coding: 12340
   Shop #: WSC 00066
   VCID: 270BFC7346FCAD8FA8D-513C
   Part No: 1J0 920 906 J
   Component: KOMBI+WEGFAHRSP VDO V11
   Coding: 07234
   VCID: 2F3B14536E0CF5CF60D-513C
01304 - Radio
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70B9D72FB3B2AA37397-513C
01304 - Radio
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00028
   VCID: 372B2C33965C3D0F38D-4B1E
   Component: 1H Tõrsteuer.FS KLO 0004
   Component: 1H Tõrsteuer.BF KLO 0004
   Component: 1H Tõrsteuer.HL KLO 0004
   Component: 1H Tõrsteuer.HR KLO 0004
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180
   Component:    Radio ZSW        0012
   Coding: 00401
   Shop #: WSC 00028
   VCID: 5DE79E9B5420375F821-513C
00856 - Radio Antenna
            36-10 - Open Circuit - Intermittent
End----------(Elapsed Time: 05:18, VBatt start/end: 12.5V/12.5V)-----------
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
It is VR6 ,possible need software update for CAT.
JACK we need you here :D:D:D
germanlvelez
Puerto Rico, USA
C?ID=385485
Thanks Uwe;
The steering angle sensor was set up as per the instructions. Need to replace the oxygen sensors for the engine issues. I’m glad to adquire the VCDS.
