MK4 cluster swap
machado
Canada
C?ID=59468
Hi, I have a 2003 jetta tdi standard, the customer wants to install a cluster from his parts car a 2005 jetta tdi bew standard as well. The reason he wants this done is because how the cluster looks. There is a current security code but ignore it, is caused by an aftermarket spare key sometimes doesn't read. I have security pin codes from both cars I understand the vin has to be written, coded and program the keys. The wiring diagram looks the same does anyone know if the cluster is compatible with this car.Mario
Auto-scan and part numbers would be a great start + go to retrofits........
Why not just swap the face plate?
rhinopower
C?ID=58979
Give part numbers please for both clusters
If you know how to use an eeprom reader, i can move the data from old cluster to new cluster for you very simply too, as well as radio code etc so everything will function correctly
machado
Canada
C?ID=59468
Sorry i forgot to post auto scan, new cluster # vw1j5920806Q VDO A2C53031735
Tuesday,07,January,2020,22:08:39:15785
VCDS Version: 19.6.1.0 (x64)
VIN: 3VWSP29M93M124983   License Plate: ETHAN   VW
Mileage: 328910km-204375mi   Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
          75 76
VIN: 3VWSP29M93M124983   Mileage: 328910km-204375miles
Address 01: Engine        Labels: 038-906-012-AGR.clb
   Part No: 038 906 012 GN
   Component: 1,9l R4 EDC G600SG  4308
   Coding: 00002
   Shop #: WSC 93377
   VCID: 62C01712EE72185FEF-4B00
   3VWSP29M93M124983     VWZ7Z0B6209707
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 -  - Intermittent
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0004097
   Shop #: WSC 00066 000 00000
   VCID: 336EA2565108C1D754-513C
   Part No: 1C0 909 605 A
   Component: 1N AIRBAG VW51 02   0006
   Coding: 12622
   Shop #: WSC 00066
   VCID: 22405712AEF2585FAF-5120
   Part No: 1J0 920 806 L
   Component: KOMBI+WEGFAHRSP VDO V64
   Coding: 07332
   Shop #: WSC 88888
   VCID: 3064AD5AF01EFACF29-5120
01176 - Key
01304 - Radio
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70E46D5A309EBACF69-5120
01304 - Radio
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00066
   VCID: 3776964615702DF768-4B00
   Component: 1H Tõrsteuer.FS KLO 0009
   Component: 1H Tõrsteuer.BF KLO 0009
   Component: 1H Tõrsteuer.HL KLO 0009
   Component: 1H Tõrsteuer.HR KLO 0009
01179 - Incorrect Key Programming
            35-00 - -
            27-00 - Implausible Signal
End-------------------------(Elapsed Time: 05:29)--------------------------
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Cluster will work ,I have done many of them.
Use Immobilizer 3 cluster matching procedure and you should be Ok if you have both SKC , from original and form 2005 cluster.
Maybe Marin but many are swappable in past anything 02.5> should indeed be Immo 3.
Happy New Year by the way haven't seen you in while.
I think OP should be more concerned with D2 coil being weak possibly/key issue or consider defeat since an old POS anyway, definitely better than being stuck!
Moving to Retrofits.
machado
Canada
C?ID=59468
All good now, new cluster is working. I took to long and battery died i also put the wrong pin and locked me out had to leave key on for a few minutes. Just google mk4 swap and tons of videos the hard part is getting the pin codes from both clusters. Thank you for your help, new cluster looks much better.Mario
