Hello
I have a question whether it is possible to recode lamps from GB to EU in a car Audi A4 B8 2013 bi xenon led plus lamps without shutters using VCDS?
Saturday,21,December,2019,16:09:01:07292
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4441.4
VIN: WAUZZZ8K9DA094318 License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 20 42 44 46 47 52 53 56 5F 62 72
VIN: WAUZZZ8K9DA094318 Mileage: 289830km-180092miles
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CGLD) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 KJ HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2840
Revision: 45H25---
Coding: 12194012242401080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018KJ 003006
ROD: EV_ECM20TDI01103L906018JG.rod
VCID: FCB4ABA277F79BAA01-80A8
4807 - EGR System
P0401 00 [104] - Insufficient Flow
Fault Frequency: 88
Mileage: 276674 km
Date: 2019.09.07
Time: 22:31:34
Engine speed: 1866.50 /min
Normed load value: 14.1 %
Vehicle speed: 51 km/h
Coolant temperature: 74 °C
Intake air temperature: 14 °C
Voltage terminal 30: 14.540 V
Air mass: specified value: 284.1 mg/stroke
Air mass: actual value (mg/stroke): 383.0 mg/stroke
EGR Solen.val.: actual value: 15.99 %
Throttle valve adapter: actual value: 24.41 %
Charge air pressure specified value: 1074 hPa
Charge air pressure: actual value: 1174 hPa
Mean injection quantity: 4.69 mg/stroke
U1113 00 [032] - -
U1113 00 [032] - -
5582 - Oil Pressure Switch for reduced Oil Pressure
P164D 00 [032] - Malfunction
Readiness: 0 1 0 0 0
Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG
Component: ESP8 front H09 0100
Coding: 161544
Shop #: WSC 06325 000 00000
VCID: 804CDF52131FFF4A5D-80D4
Part No SW: 8K0 907 064 GE HW: 8K0 907 064 FE
Component: BCM2 2.0 H11 0621
Coding: 03B24000000000000000
VCID: F9BAB2B670C5AE821A-80AC
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0512000042983014
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000137546008
Part No SW: 8K2 820 043 AJ HW: 8K2 820 043 AJ
Revision: D1000000 Serial number: 01190620121475
Coding: 342402E000
VCID: F1AA8A9628B5E6C2A2-80A4
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 173
Mileage: 211829 km
Date: 2018.02.26
Time: 22:18:34
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000438822302
Coding: 260000108074AFC00081400300001D0D001D070827090201000008000400000200020024000000
VCID: FAB8ADBA75C3A59A13-80AE
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 220612 H06 0080
Serial number: SWF12060225006
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20367152
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001906120641
Subsystem 4 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 3BE8C436000000000001
01229 - A/C Humidity Sensor (G260)
014 - Defective
Fault Status: 01101110
Reset counter: 173
Mileage: 211829 km
Date: 2018.02.26
Time: 22:22:58
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD93XVHF
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 60724 001 1048576
VCID: C8DC077273AF070AD5-809C
Serial number: 6334MSME6650285BG
Serial number: 6344MSME6F44080FQ
Serial number: 6352QSME051B5444B
Serial number: 6362QSME601A0C7CQ
Serial number: 63732SME7B15376C8
Serial number: 63832SME12174C6C2
Mileage: 254803 km
Date: 2019.04.08
Time: 18:06:20
9437467 - Igniter 2 for Driver's Airbag
B1001 1B [137] - Resistance Too High
Mileage: 254803 km
Date: 2019.04.08
Time: 18:06:20
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20120630000591
Coding: 000017
VCID: CFEE2C6E9EC1D03294-809A
Component: E221 - MFL H00 0000
Reset counter: 188
Mileage: 254803 km
Date: 2019.04.08
Time: 18:06:18
Part No SW: 8K0 920 982 E HW: 8K0 920 982 E
Component: KOMBIINSTR. H35 0553
Revision: 00000000 Serial number: RBK685M6D
Coding: 338410000A012600010000
VCID: B620798A015B81FAB7-80E2
Part No SW: 8R0 907 468 J HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0051
Revision: 1Z090025 Serial number: 2541Z1260400D5
Coding: 80CF07FF00
VCID: C6C0094A71BB117A27-8092
Serial number: 8022457701
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 12163002015011200410
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02029164747464545425363E00
VCID: FCB4ABA27FF79BAA01-80A8
03576 - Contol Module for High Beam Assistant: Visibility Limited
Fault Frequency: 53
Reset counter: 203
Mileage: 266623 km
Date: 2019.07.04
Time: 22:46:11
Part No SW: 8K0 959 793 S HW: 8K0 959 793 Q
Component: TSG FA H02 0506
Revision: Serial number: 0000032820680
Coding: 011002204001410001
VCID: D0EC2F1283FFCFCA8D-8084
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0018664000
Coding: 100000000001
Shop #: WSC 18366 000 1048576
ROD: EV_RCEPSAU48X_008.rod
VCID: B42443821F2793EA89-80E0
2305 - Function Restriction due to Start Voltage Interruption
U1410 00 [008] - -
[Funktionseinschränkung der Lenkung durch Spannungseinbruch bei niedriger Geschwindigkeit]
Reset counter: 201
Mileage: 285178 km
Date: 2019.11.09
Time: 16:30:18
Write only channel
Revision: 00002001 Serial number: 0179132299
Coding: 013B062220B900408020023680000000
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 219
Reset counter: 144
Mileage: 242931 km
Date: 2019.01.26
Time: 14:17:06
02615 - Fuel Tank Cap; Lock
Fault Status: 00101001
Fault Frequency: 46
Reset counter: 215
Mileage: 281229 km
Date: 2019.10.07
Time: 23:01:53
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813004168502
VCID: AD1256E6F40DC222C6-80F8
Part No SW: 8K0 959 792 S HW: 8K0 959 792 Q
Component: TSG BF H02 0506
Revision: Serial number: 0000032840323
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000108430
ROD: EV_ParkiBrake_AU48.rod
VCID: B83C77B2034F778AA5-80EC
459520 - Function Restriction due to Faults in Other Modules
U1113 00 [000] - -
[FC_SIGNAL_ESP_FL_RADGESCHW_ERROR_VALUE]
Part No SW: 4G0 035 061 D HW: 4G0 035 061
Component: Radio U DAB H60 0100
Revision: AB001007 Serial number: 470F20C7532996
Coding: 010103010000000001
VCID: 9E70812A89AB29BA4F-80CA
Part No SW: 8R2 035 652 A HW: 8R2 035 652
Component: B-BN-EU H62 0175
Revision: -------- Serial number: 147F00C7511995
Coding: 01010101000681ED01800B4E000000030000
VCID: B228459AED339DDA9B-80E6
Subsystem 1 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0098
Serial number: 9465F%0C2550499
Subsystem 2 - Part No SW: 8T0 919 611 HW: 8T0 919 611
Component: E0380 Bedient H01 0100
Serial number: 00000001198984
Reset counter: 40
Mileage: 211829 km
Date: 2018.02.26
Time: 22:22:24
Voltage: 12.30 V
Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000033174557
Coding: 010002204001210001
VCID: C3C6105E4289245200-8096
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000033177501
End----------(Elapsed Time: 01:43, VBatt start/end: 12.2V/12.1V)-----------
