Audi A4 B8 bi xenon led+ lamps from GB to EU
daniel.b
Europe
C?ID=318819
Hello
I have a question whether it is possible to recode lamps from GB to EU in a car Audi A4 B8 2013 bi xenon led plus lamps without shutters using VCDS?
Saturday,21,December,2019,16:09:01:07292
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4441.4
VIN: WAUZZZ8K9DA094318   License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 20 42 44 46 47 52 53 56 5F 62 72
VIN: WAUZZZ8K9DA094318   Mileage: 289830km-180092miles
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CGLD)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 KJ    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   H25 2840
   Revision: 45H25---
   Coding: 12194012242401080000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018KJ 003006
   ROD: EV_ECM20TDI01103L906018JG.rod
   VCID: FCB4ABA277F79BAA01-80A8
4807 - EGR System
          P0401 00 [104] - Insufficient Flow
                    Fault Frequency: 88
                    Mileage: 276674 km
                    Date: 2019.09.07
                    Time: 22:31:34
                    Engine speed: 1866.50 /min
                    Normed load value: 14.1 %
                    Vehicle speed: 51 km/h
                    Coolant temperature: 74 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 14.540 V
                    Unlearning counter according OBD: 37
                    Air mass: specified value: 284.1 mg/stroke
                    Air mass: actual value (mg/stroke): 383.0 mg/stroke
                    EGR Solen.val.: actual value: 15.99 %
                    Throttle valve adapter: actual value: 24.41 %
                    Charge air pressure specified value: 1074 hPa
                    Charge air pressure: actual value: 1174 hPa
                    Mean injection quantity: 4.69 mg/stroke
          U1113 00 [032] - -
          U1113 00 [032] - -
5582 - Oil Pressure Switch for reduced Oil Pressure
          P164D 00 [032] - Malfunction
Readiness: 0 1 0 0 0
   Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
   Component: ESP8 front    H09 0100
   Coding: 161544
   Shop #: WSC 06325 000 00000
   VCID: 804CDF52131FFF4A5D-80D4
   Part No SW: 8K0 907 064 GE    HW: 8K0 907 064 FE
   Component: BCM2 2.0      H11 0621
   Coding: 03B24000000000000000
   VCID: F9BAB2B670C5AE821A-80AC
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0512000042983014
   Serial number: 2312000137546008
   Part No SW: 8K2 820 043 AJ    HW: 8K2 820 043 AJ
   Revision: D1000000    Serial number: 01190620121475
   Coding: 342402E000
   VCID: F1AA8A9628B5E6C2A2-80A4
00457 - Control Module for Network (J519)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 173
                    Mileage: 211829 km
                    Date: 2018.02.26
                    Time: 22:18:34
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000438822302
   Coding: 260000108074AFC00081400300001D0D001D070827090201000008000400000200020024000000
   VCID: FAB8ADBA75C3A59A13-80AE
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 220612  H06 0080
   Serial number: SWF12060225006
   Coding: 00FD11
   Serial number: 20367152
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001906120641
   Subsystem 4 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 3BE8C436000000000001
01229 - A/C Humidity Sensor (G260)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 173
                    Mileage: 211829 km
                    Date: 2018.02.26
                    Time: 22:22:58
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD93XVHF
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 60724 001 1048576
   VCID: C8DC077273AF070AD5-809C
   Serial number: 6334MSME6650285BG
   Serial number: 6344MSME6F44080FQ
   Serial number: 6352QSME051B5444B
   Serial number: 6362QSME601A0C7CQ
   Serial number: 63732SME7B15376C8
   Serial number: 63832SME12174C6C2
          B1000 1B [137] - Resistance Too High
                    Mileage: 254803 km
                    Date: 2019.04.08
                    Time: 18:06:20
9437467 - Igniter 2 for Driver's Airbag
          B1001 1B [137] - Resistance Too High
                    Mileage: 254803 km
                    Date: 2019.04.08
                    Time: 18:06:20
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120630000591
   Coding: 000017
   VCID: CFEE2C6E9EC1D03294-809A
   Component: E221 - MFL  H00 0000
01426 - Controls in Steering Wheel (E221)
                    Reset counter: 188
                    Mileage: 254803 km
                    Date: 2019.04.08
                    Time: 18:06:18
   Part No SW: 8K0 920 982 E    HW: 8K0 920 982 E
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RBK685M6D
   Coding: 338410000A012600010000
   VCID: B620798A015B81FAB7-80E2
   Part No SW: 8R0 907 468 J    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0051
   Revision: 1Z090025    Serial number: 2541Z1260400D5
   Coding: 80CF07FF00
   VCID: C6C0094A71BB117A27-8092
   Serial number: 8022457701
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 12163002015011200410
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02029164747464545425363E00
   VCID: FCB4ABA27FF79BAA01-80A8
03576 - Contol Module for High Beam Assistant: Visibility Limited
            000 -  -  - Intermittent
                    Fault Frequency: 53
                    Reset counter: 203
                    Mileage: 266623 km
                    Date: 2019.07.04
                    Time: 22:46:11
   Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000032820680
   Coding: 011002204001410001
   VCID: D0EC2F1283FFCFCA8D-8084
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0018664000
   Coding: 100000000001
   Shop #: WSC 18366 000 1048576
   ROD: EV_RCEPSAU48X_008.rod
   VCID: B42443821F2793EA89-80E0
2305 - Function Restriction due to Start Voltage Interruption
          U1410 00 [008] - -
          [Funktionseinschränkung der Lenkung durch Spannungseinbruch bei niedriger Geschwindigkeit]
                    Reset counter: 201
                    Mileage: 285178 km
                    Date: 2019.11.09
                    Time: 16:30:18
                    Write only channel
   Revision: 00002001    Serial number: 0179132299
   Coding: 013B062220B900408020023680000000
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 219
                    Reset counter: 144
                    Mileage: 242931 km
                    Date: 2019.01.26
                    Time: 14:17:06
02615 - Fuel Tank Cap; Lock
                    Fault Status: 00101001
                    Fault Frequency: 46
                    Reset counter: 215
                    Mileage: 281229 km
                    Date: 2019.10.07
                    Time: 23:01:53
   Revision: 00005001    Serial number: 94813004168502
   VCID: AD1256E6F40DC222C6-80F8
   Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000032840323
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000108430
   ROD: EV_ParkiBrake_AU48.rod
   VCID: B83C77B2034F778AA5-80EC
459520 - Function Restriction due to Faults in Other Modules
          U1113 00 [000] - -
          [FC_SIGNAL_ESP_FL_RADGESCHW_ERROR_VALUE]
   Part No SW: 4G0 035 061 D    HW: 4G0 035 061
   Component: Radio U DAB   H60 0100
   Revision: AB001007    Serial number: 470F20C7532996
   Coding: 010103010000000001
   VCID: 9E70812A89AB29BA4F-80CA
   Part No SW: 8R2 035 652 A    HW: 8R2 035 652
   Component: B-BN-EU       H62 0175
   Revision: --------    Serial number: 147F00C7511995
   Coding: 01010101000681ED01800B4E000000030000
   VCID: B228459AED339DDA9B-80E6
   Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
   Component: DU6 Basic  H42 0098
   Serial number: 9465F%0C2550499
   Subsystem 2 - Part No SW: 8T0 919 611     HW: 8T0 919 611
   Component: E0380 Bedient  H01 0100
   Serial number: 00000001198984
            000 -  -
                    Mileage: 211829 km
                    Date: 2018.02.26
                    Time: 22:22:24
                    Voltage: 12.30 V
   Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000033174557
   Coding: 010002204001210001
   VCID: C3C6105E4289245200-8096
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000033177501
End----------(Elapsed Time: 01:43, VBatt start/end: 12.2V/12.1V)-----------
Check a parts catalog to be sure, but I would expect the headlights are different LHD vs. RHD.
Now in the BCM at address 09, you could try turning on Bit 6 in Byte 4, "Tourist Mode adjustable via MMI/Car Menu" and then use the MMI to set the Tourist Mode active in the MMI, but I really don't think this is a proper, long-term solution.
