2013 Jetta Hybrid - Hybrid Error light on
paulfesta
C?ID=321424
Girlfriend reported to me hybrid error light on, and car running on gas, no electric. I cleared all codes (I saved the prior scan and can post that too but it's mostly related to a prior battery issue, low voltage this, that, and the other thing..), and when put it into gear, car was working on electric, but within a second of hitting the accelerator pedal in D, hybrid light comes on, and car works on only gas. Pulled over, cleared code, put in gear, and again, almost instantly after hitting accelerator, Hybrid error light comes on, same code popping up. Did this a couple more times for troubleshooting purposes, and same result each time.
Did some googling with really odd results, so I come here again, this forum has been kind to me.. Anybody point me to my next troubleshooting step?
Edit: A little more troubleshooting. Ran output tests and monitored Brake Pressure sensor value. Sitting in park the number is roughly 280. Depress brake and pressure momentarily goes up to low 300s, then with brake held settles down to like 260. Let off brake and pressure momentarily rises to mid to high 300's, then settles back to approx 280.
One more weird thing, not sure how helpful it will be, but I duplicated 4 or 5 times: If I clear the engine code, then turn off car(push button) with no lights on dash, open door, close door, then start car (press and hold brake, press start button), the engine starts for a second, then shuts down, EPC light on, hybrid light on, engine light on. Car won't do anything. Need to stop engine, open and close door, then starting car, it 'works' in that now just the hybrid light is on and car will run on gas and move. I can shut it off and restart over and over as long as hybrid error light on. Clear code, stop engine, open and close door, then start car consistently acts as described, all 3 lights come and car won't go. Weird.
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 4F 51
          52 55 56 61 62 72 8C
VIN: 3VW637AJ7DM259408   Mileage: 216610km-134595miles
Address 01: Engine (J623-CNLA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023     HW: 04E 907 309 B
   Component: 1.4l TFSI hy  H01 7928
   Revision: V8H01---    Serial number: 00000000000000
   Coding: 00250012442401000000
   Shop #: WSC 00003 444 00000
   ASAM Dataset: EV_ECM14TFS01104E906023 002024
   ROD: EV_ECM14TFS01104E906023_002.rod
   VCID: 5DE767B83DBD56CF821-8008
4363 - Brake Booster Pressure Sensor
          P0556 00 [039] - Implausible Signal
                    Mileage: 216616 km
                    Date: 2019.11.26
                    Time: 02:00:29
                    Engine speed: 2016.00 /min
                    Normed load value: 78.4 %
                    Vehicle speed: 53 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 14.442 V
                    Median injection timing: 5.007 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
Readiness: 1110 1101
   Part No SW: 0CG 300 045 G    HW: 0AM 927 769 H
   Component: GSG DSG AG7     441 5802
   Revision: 00044014    Serial number: CU501808016597
   Shop #: WSC 04940 001 00001
   VCID: 2D07F778011DE64F521-8078
   Part No SW: 1K0 907 379 AR    HW: 1K0 907 379 AR
   Component: ESP MK60EC1   H31 0135
   Revision: 00H31001
   Coding: A14B400C49272003850F02E492210440A71800
   VCID: 025D74C4E403C937DF3-8056
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 A
   Revision: 00085000    Serial number: 0153838823
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02014
   VCID: 3431E21CEEB7B7871DF-8060
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: -----------    HW: -----------
   Component: Climatronic   0202
   Revision: --------
   Coding: 0010401002
   Shop #: WSC 00066 000 00120
   ASAM Dataset: EV_ACClimaBHBVW361Hybri 001001
   ROD: EV_ACClimaBHBVW361Hybri.rod
   VCID: 6FBB2D70C711D45F20D-803A
   Air Conditioning Compressor:
   Subsystem 1 - Part No SW: 5C0 820 803 F    HW: 5C0 820 803 F
   Component: J842 eKK  H03 0001
Address 09: Cent. Elect.
   Part No SW: 5C0 959 655 J    HW: 5C0 959 655 J
   Component: AirbagVW10    101 0911
   Serial number: 003KLD00384T
   Coding: 00004838
   Shop #: WSC 00066 790 00184
   ASAM Dataset: EV_AirbaVW10SMEVW360 001024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 392FD328C9D54AEFCE9-806C
   Serial number: 6940000Y120000NAR40Y
   Coding: 303036
   Serial number: 3572MSME1C437271ZZZU
   Serial number: 3582MSME7B407271ZZZX
   Serial number: 3516KSME0D322720ZZZI
   Serial number: 3526KSME62222720ZZZD
   Serial number: 3556LSME0D4C601FZZZ2
   Serial number: 3566LSME531A581FZZZ0
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20170424200947
   Coding: 000A140000
   Shop #: WSC 01286 386 08256
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 025D74C4E483C937DF3-8056
   Serial number: 0653981
   Coding: 820000
   Part No SW: 5C6 920 970 D    HW: 5C6 920 970 D
   Component: KOMBI         H08 0710
   Coding: 281E01
   Shop #: WSC 00066 000 00198
   VCID: 2D07F7780D9DE64F521-8078
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 06121203290523
   Coding: 351002
   VCID: 76B51814B8CBE597E3B-8022
   Component: IMMO          H08 0710
   Coding: 000007
   VCID: 6A8D3C64FCF33177773-803E
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000242907004
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F3BED700791945F60D-807A
   Component: SG EXT.PLAYER H18 0546
   Revision: A1001003    Serial number: 7663774802
   Coding: 020100
   VCID: 2A0DFC643CF3F177B73-807E
   Part No SW: 5C0 035 274 B    HW: 5C0 035 274 B
   Component: RNS315-NAR    H53 0319
   Serial number: VWZAZ2M4270747
   Coding: 04090041010006000000100A
   Shop #: WSC 01383 790 50316
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 1F1B1DB0773104DFD0D-804A
1048669 - Tuner for Satellite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 229
                    Mileage: 216616 km
                    Date: 2019.11.26
                    Time: 01:55:32
   Revision: 13110009    Serial number: 0005849774
   Coding: 0004B5
   VCID: 5BE369A023A958FFFC5-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1508
   Serial number: 00000007341606
   Coding: 000490
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   VCID: 372BD510F3415C9F38D-8062
Address 46: Central Conv.
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0002652
   VCID: 26150854286BD51793B-8072
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030100
   VCID: 6FBB2D70C791D45F20D-803A
   Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Serial number:     WRH0007ELJV
   Coding: 180000
Address 51: Electric Drive (J841)       Labels: None
   Part No SW: 5C0 907 080 E    HW: 5C0 907 080 C
   Component: VW361H0108000 H02 0535
   Revision: 00H02000    Serial number: 00000000000000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM04510115C0907080E 001021
   ROD: EV_DMCM04510115C0907080E.rod
   VCID: 25170F58556DDE0F9A1-8070
   Revision: 15110009    Serial number: 0005904346
   Coding: 0004B4
   VCID: 5CE16ABC26A75FC7F5F-8008
   Slave Passenger:
   Component: J389__TSG-HR  008 1508
   Serial number: 00000007365163
   Coding: 000490
   Component: AFS-ECU       H04 0111
   Coding: 081200010B000200
   ROD: EV_HeadlRegulVWAFSPt_VW32.rod
   VCID: 372BD510FFC15C9F38D-8062
   Subsystem 1 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AH
   Component: Batt.regelung H50 1634
   Coding: 16660164
   VCID: 71BF2B08D1A5C2AF369-8024
   Subsystem 1 - Part No SW: 1S0 915 181 A    HW: 1S0 915 181 A
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970493988
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 5C6 915 182 B    HW: 5C6 915 182 B
   Component: BECM          H09 0601
   Serial number: 288 SYEQ727B41
   ASAM Dataset: EV_BECM06020115C6915182 005021
   ROD: EV_BECM06020115C6915182.rod
   VCID: 2A0DFC643C73F177B73-807E
End----------(Elapsed Time: 01:29, VBatt start/end: 14.8V/14.8V)-----------
DrPeter
16.4905° S, 151.7375° W
The fault code [P0556 00] refers to the [G294 - brake Booster Pressure Sensor] which is located on the Brake Booster vacuum hose.
The G294's pressure is in hPa, so a value of 280-300 or so is not bad, since that would indicate a vacuum and around 280-300 mbar.
I would remove the G294 sensor and re-check the values to see if they are closer to the 980-1020 range (1 atmosphere of pressure), unless you are at a higher elevation, then the values would be less.
The G294 is a 5-volt sensor, so you should have ground on pin (1) and 4.5 to 5.5v on pin (3), the signal is on pin (4) and pin (3) is not used.
The part number of the G294 should be as per VIN, (036 906 051 G), there are no supersessions.
Hope this helps,
drpeter
Jef
HQ
Tacking onto this...
Ignition on, unplug G294
/1 to ground, should be less than 24Ω
/3 to ground, about 5.02 volts
/4 to ground, about 5.65 volts
Also I think Peter was trying to say "and pin (2) is not used"... there isn't a wire in /2 of the connector.
paulfesta
C?ID=321424
Thank You.. Tests confirm what you say, ohms about 13 on 1 to ground, 5.02 volts on pin 3 and 5.62 volts on pin 4.
Does this point to replacing that sensor? At $120 I hate to just swap parts out..
Jef
HQ
As per VW/Audi, pretty much every test plan for an electrical item boils down to this: Is the wiring good? If yes, replace said item. Still have issues, replace control module.
Assuming there are no leaks or clogs for the vacuum system that said sensor monitors, I would replace the sensor.
What happens if you qualify tracks to controller with a "decade box" & to verify the blocks in VCDS and to extinguish the DTC?
Did you JPPSG yet?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Any shared tracks or poor ground causing any FOD deviation of the sensor?
paulfesta
C?ID=321424
Replaced sensor, problem remains. I clear the code and it comes back fairly quickly. I ran some output tests on brake related items, that log is pasted below, not sure it will be any help. I cleared the code, then started the log, then stepped on brake for a second or so, and released. A split second after releasing pedal, hybrid light comes back on, code is back.. That seems to be a repeatable scenario. Clear code, step on brake, as brake is released, light come on.. Any other thoughts before I take it to the dealer to get bent over?
04E 906 023 ADVMB 1.4l TFSI hy H01 7928
G019 F0 G231 F0 G232 F0 G283 F0 G286 F0 G287 F0 G364 F0
Marker TIME Loc. IDE00150 TIME Loc. IDE03805 TIME Loc. IDE03805-ENG127323 TIME Loc. IDE04858 TIME Loc. IDE04872 TIME Loc. IDE04875 TIME Loc. IDE06049
STAMP Pressure in brake booster STAMP Test of brake booster pump: result STAMP Test of brake booster pump: result-Test_Program_Channel 603 STAMP Brake booster low pressure actual value STAMP Brake pedal value sensor: relative value filtered STAMP Brake pedal value sensor: learned zero point offset value STAMP Pressure in brake booster: raw value
hPa hPa % % hPa
0.29 316.02 0.35 Test off 0.04 235 0.1 710.55 0.14 0 0.19 87.94 0.24 316.02
0.65 316.02 0.71 Test off 0.4 235 0.44 710.55 0.49 0 0.54 87.94 0.6 316.02
1.02 316.02 1.07 Test off 0.75 235 0.81 710.55 0.86 0 0.91 87.94 0.96 316.02
1.41 316.02 1.46 Test off 1.13 235 1.18 710.55 1.24 0 1.29 87.94 1.35 316.02
1.77 316.02 1.82 Test off 1.5 235 1.55 710.55 1.6 0 1.65 87.94 1.71 317.23
2.11 317.23 2.16 Test off 1.86 235 1.91 709.34 1.96 0 2.01 87.94 2.06 317.23
2.44 325.66 2.49 Test off 2.21 235 2.25 709.34 2.3 0 2.35 87.94 2.39 322.03
2.79 410.12 2.85 Test off 2.54 235 2.6 670.74 2.64 49.28 2.69 87.94 2.74 395.63
3.16 454.73 3.21 Test off 2.89 235 2.94 592.34 2.99 90.72 3.04 87.94 3.1 449.92
3.52 475.23 3.56 Test off 3.25 235 3.31 560.98 3.37 99.33 3.41 87.94 3.46 472.85
3.87 651.37 3.91 Test off 3.61 235 3.66 519.96 3.71 63.37 3.75 87.94 3.81 651.37
4.21 645.35 4.25 Test off 3.96 235 4.02 380 4.06 0 4.11 87.94 4.16 645.35
4.54 641.72 4.6 Test off 4.3 235 4.35 383.63 4.39 0 4.44 87.94 4.49 642.93
4.91 640.51 4.96 Syst.n.OK 4.64 235 4.69 384.84 4.74 0 4.79 87.94 4.85 640.51
5.28 640.51 5.34 Syst.n.OK 5.01 227 5.06 386.05 5.11 0 5.17 87.94 5.23 639.34
5.66 603.13 5.71 Syst.n.OK 5.38 227 5.44 387.23 5.49 0 5.54 87.94 5.6 615.2
6.02 524.73 6.07 Syst.n.OK 5.76 227 5.81 460.82 5.86 0 5.91 87.94 5.96 536.76
6.36 472.85 6.41 Syst.n.OK 6.11 227 6.16 524.77 6.22 0 6.27 87.94 6.31 477.66
6.71 420.98 6.75 Syst.n.OK 6.46 227 6.5 574.22 6.55 0 6.6 87.94 6.65 430.63
7.04 381.17 7.09 Syst.n.OK 6.8 227 6.85 623.71 6.89 0 6.94 87.94 6.99 385.98
Why are 0x09 & 0x46 offline and is terminal relays functioning, are the doors unlocked?
Did you check the adaptation for the auxiliary pump for brake vacuum if supported or accumulation?
Are you only making brake vacuum from the engine or is it available during hybrid operations too?
paulfesta
C?ID=321424
I very much appreciate the help, but I'm not sure how to check the things you ask (except the doors are unlocked..:-)..) I'm fairly computer savvy, and a rather good troubleshooter in general, but most of my mechanic experience has been with older cars. I have a scan tool, and the ross tech adaptor for the Jetta, but my knowledge in using them is novice level (maybe slightly above novice). If it's easy enough to give a more laymans explanation, I would really appreciate it..
I'm suspecting the booster pump, and was going to check the fuses and relays for the booster pump, but I can't find an accurate fuse/relay diagram for the car. Why they wouldn't put it in the owners manual or on the fuse covers is beyond me.. I've checked alldata and googled a bunch, and nothing Ive found so far matches exactly what I see in the car for fuses/relays. I have pulled and looked at many fuses, all good so far, and I swapped around relays that were the same part number, but that's not definitive of anything. Any chance you know where I could get an accurate fuse/relay diagram?
As to the question on whether brake vacuum is available during hybrid operations, I suspect not, and that is the reason for the code. I suspect that when the conditions call for the pump, it doesn't work, hence the code, but without an accurate fuse/relay diagram, I'm kinda stuck.
paulfesta
C?ID=321424
I haven't been on here in awhile and I came to day to post something else and someone had asked for resolution on this, and I see I never posted that, Sorry.. It was the booster pump that was bad. Changed the pump, problem solved.
JMR
Romania
C?ID=432218
That seems to be a problem on this hybrid cars
