Default Dashboard cluster turn off a3 8p
dark41
Unverified
Poland
hi,
I have a problem with my audi a3 8p 2003 2.0tdi
Dashboard cluster constantly turn off (witch radio i must enter code) for few seconds. In 15 minute period it can turn off 5 times depends on weather (when colder it turn off more often, but it can be coincidence)
strange thing is when I start engine and do nothing dashboard cluster works fine but when i try to move dashboard cluster start to turn off
vcds : 18058
dark41
Unverified
Poland
I will get back my diagnoistic cable in few weeks but cluster 17- instruments have no faulty only faulty code tied to cluster is 18058 p1650 - 000 -
I notice clsuter start turn off always when i move car and cluster always reset to the same time and trip odometer
is it posibble ecu has different data than cluster how to check it witch diagnostic cable ?
sorry for my english i not native speaker
PetrolDave
Westbury, UK
C?ID=1423
It sounds to me like you have a connection problem if the cluster turns off when you move the car...
dark41
Unverified
Poland
i checked wiring is ok,
Spacewalker
Poland
C?ID=159607
take a look your message .....
cluster turn off when you move car ... so must be a vibation issue
how you check wires - look on it from 1m ?...come one
simple pull new wires (GND, KL30, KL15) ....COMPLETLY NEW ...to baypass old one
once you baypass old loom, you can say - is no wire issue
then look into cluster inside , or swap cluster
dark41
Unverified
Poland
ok but if it is vibration it will hapen when i pull wire in cluster i tried and nothing hapened i will tray buy new wiring
but strange is that cluster works fine all the time when i start the car and dont move. when I move car cluster will start to reset even why I stop the car and for a while do nothing, if it is vibration or Soldering defects it will happen all the time thanks
PetrolDave
Westbury, UK
C?ID=1423
I think we should all wait for the Auto-Scan before making any further suggestions :popcorn:
dark41
Unverified
Poland
it is all faulty codes some are because im recently have problem with accu winter and i dont use car often
i notice when i start car and cluster reset . cluster didnt rise mileage
Address 01: Engine
18058 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
RPM: 1680 /min
Torque: 0.0 Nm
Speed: 59.0 km/h
Voltage: 14.21 V
Bin. Bits: 00101000
Torque: 172.0 Nm
Torque: 0.0 Nm
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Torque: 172.0 Nm
Voltage: 11.40 V
Bin. Bits: 00101000
Temperature: 7.2°C
Bin. Bits: 00110000
Address 03: ABS Brakes
Address 08: Auto HVAC
0601 - Potentiometer On Positioning Motor for Central Flap (G112)
Fault Status: 00101010
Reset counter: 160
Mileage: 202546 km
Date: 2019.06.22
Time: 00:00:19
Voltage: 14.40 V
(no units): 255.0
Temperature: 5.5°C
Address 09: Cent. Elect
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 19: CAN Gateway
Fault Frequency: 35
Reset counter: 163
Date: 2019.06.22
Time: 00:32:27
Fault Status: 00101110
Fault Frequency: 18
Reset counter: 163
Time Indication: 15
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Address 44: Steering Assist
02546 - Steering Limit Stop
Mileage: 2520 km
Temperature: 4.0°C
Voltage: 10.90 V
Voltage: 10.70 V
Address 52: Door Elect, Pass.
00106 - Signal Central Locking SAVE/LOCK Passenger Side
Address 56: Radio
Fault Frequency: 17
Reset counter: 163
Time Indication: 15
Bin. Bits: 10
Reset counter: 163
Time Indication: 15
dark41
Unverified
Poland
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8PX4A0XXXXX                         Mileage: 202550km/125858miles
Spacewalker
Poland
C?ID=159607
I like that game
Mike@Gendan
Swansea, UK
C?ID=57030
That's a gateway installation list.
We need the FULL UNEDITED AUTO-SCAN
