Default Dashboard cluster turn off a3 8p
dark41
Unverified
Poland
hi,
I have a problem with my audi a3 8p 2003 2.0tdi
Dashboard cluster constantly turn off (witch radio i must enter code) for few seconds. In 15 minute period it can turn off 5 times depends on weather (when colder it turn off more often, but it can be coincidence)
strange thing is when I start engine and do nothing dashboard cluster works fine but when i try to move dashboard cluster start to turn off
vcds : 18058
dark41
Unverified
Poland
I will get back my diagnoistic cable in few weeks but cluster 17- instruments have no faulty only faulty code tied to cluster is 18058 p1650 - 000 -
I notice clsuter start turn off always when i move car and cluster always reset to the same time and trip odometer
is it posibble ecu has different data than cluster how to check it witch diagnostic cable ?
sorry for my english i not native speaker
South Molton, UK
It sounds to me like you have a connection problem if the cluster turns off when you move the car...
Spacewalker
Poland
C?ID=159607
i checked wiring is ok,
take a look your message .....
cluster turn off when you move car ... so must be a vibation issue
how you check wires - look on it from 1m ?...come one
simple pull new wires (GND, KL30, KL15) ....COMPLETLY NEW ...to baypass old one
once you baypass old loom, you can say - is no wire issue
then look into cluster inside , or swap cluster
dark41
Unverified
Poland
ok but if it is vibration it will hapen when i pull wire in cluster i tried and nothing hapened i will tray buy new wiring
but strange is that cluster works fine all the time when i start the car and dont move. when I move car cluster will start to reset even why I stop the car and for a while do nothing, if it is vibration or Soldering defects it will happen all the time thanks
dark41
Unverified
Poland
it is all faulty codes some are because im recently have problem with accu winter and i dont use car often
i notice when i start car and cluster reset . cluster didnt rise mileage
Address 01: Engine
18058 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
RPM: 1680 /min
Torque: 0.0 Nm
Speed: 59.0 km/h
Voltage: 14.21 V
Bin. Bits: 00101000
Torque: 172.0 Nm
Torque: 0.0 Nm
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Torque: 172.0 Nm
Voltage: 11.40 V
Bin. Bits: 00101000
Temperature: 7.2°C
Bin. Bits: 00110000
Address 03: ABS Brakes
Address 08: Auto HVAC
0601 - Potentiometer On Positioning Motor for Central Flap (G112)
Fault Status: 00101010
Reset counter: 160
Mileage: 202546 km
Date: 2019.06.22
Time: 00:00:19
Voltage: 14.40 V
(no units): 255.0
Temperature: 5.5°C
Address 09: Cent. Elect
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 19: CAN Gateway
Fault Frequency: 35
Reset counter: 163
Date: 2019.06.22
Time: 00:32:27
Fault Status: 00101110
Fault Frequency: 18
Reset counter: 163
Time Indication: 15
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Address 44: Steering Assist
02546 - Steering Limit Stop
Mileage: 2520 km
Temperature: 4.0°C
Voltage: 10.90 V
Voltage: 10.70 V
Address 52: Door Elect, Pass.
00106 - Signal Central Locking SAVE/LOCK Passenger Side
Address 56: Radio
Fault Frequency: 17
Reset counter: 163
Time Indication: 15
Bin. Bits: 10
Reset counter: 163
Time Indication: 15
dark41
Unverified
Poland
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8PX4A0XXXXX                         Mileage: 202550km/125858miles
25-Immobilizer -- Status: Sporadic communication error 1000
Mike@Gendan
Swansea, UK
C?ID=57030
That's a gateway installation list.
We need the FULL UNEDITED AUTO-SCAN
