Golf MK7 Gti DSG Japanese Import Help Needed !!
TD&MCK Car Sales
C?ID=160148
Hi, Can you help with some info please !!! *
i have Just purchased a 2014 mk7 Golf Gti DSG that is a Japanese
Import (i live in UK !)
need help with a Couple of things if possible ??
Can i change the frequency on the radio FM to uk as can not get FM
channels past 88khz ??? It has discovery Pro Nav Fitted (which the
navigation isn’t working ?)
The language for the voice control is in English USA, if i go to
instruments 17 adaptations i see an option for English UK but it wont
let me change ? think i need security access code ??
Also, have done a full scan, cleared the faults than scanned again and still got some faults !! can you help please..
Scan below
 Thanks TD&MCK Car Sales
 www.tdmck.co.uk
sales@tdmck.co.uk
 Monday,12,January,2015,17:42:35:17628
 VCDS Version: 14.10.0.0
 Data version: 20141022
 Dealer/Shop Name: TDMCK
 VIN: WVWZZZAUZEW243462   License Plate: SCAN MK7GTI
 Mileage: 3071km-1908mi   Repair Order:
> Chassis Type: AU (5Q0)
> Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 42 44 52 55 5F A5
>            A9
> VIN: WVWZZZAUZEW243462   Mileage: 3071km-1908miles
> 01-Engine -- Status: OK 0000
> 02-Auto Trans -- Status: OK 0000
> 03-ABS Brakes -- Status: OK 0000
> 05-Acc/Start Auth. -- Status: OK 0000
> 08-Auto HVAC -- Status: OK 0000
> 09-Cent. Elect. -- Status: OK 0000
> 10-Park/Steer Assist -- Status: OK 0000
> 13-Auto Dist. Reg -- Status: OK 0000
> 14-Susp. Elect. -- Status: OK 0000
> 15-Airbags -- Status: Malfunction 0010
> 16-Steering wheel -- Status: OK 0000
> 17-Instruments -- Status: OK 0000
> 19-CAN Gateway -- Status: OK 0000
> 2B-Steer. Col. Lock -- Status: OK 0000
> 42-Door Elect, Driver -- Status: OK 0000
> 44-Steering Assist -- Status: OK 0000
> 52-Door Elect, Pass. -- Status: OK 0000
> 55-Headlight Range -- Status: Malfunction 0010
> 5F-Information Electr. -- Status: OK 0000
> A5-Frt Sens. Drv. Assist -- Status: OK 0000
> A9-Struct. Borne Sound -- Status: OK 0000
> Address 01: Engine (J623-CHHB)       Labels: 06K-907-425-V1.clb
>     Part No SW: 5G0 906 259     HW: 06K 907 425 B
>     Component: 2.0l R4 TFSI  H13 0007
>     Revision: --H13---
>     Coding: 091D00324464050B3000
>     Shop #: WSC 01357 011 00200
>     ASAM Dataset: EV_ECM20TFS0215G0906259 001011
>     ROD: EV_ECM20TFS0215G0906259_VW37.rod
>     VCID: 6BDF86F582C12C79AA9-803E
> No fault code found.
> Readiness: 1010 0001
> Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
>     Part No SW: 0D9 300 040 S    HW: 02E 927 770 AQ
>     Component: DQ250-6F MQB  H52 4307
>     Revision: 05852204    Serial number: TFK01311261470
>     Coding: 0014
>     ASAM Dataset: EV_TCMDQ250021 001001
>     ROD: EV_TCMDQ250021_SE37.rod
>     VCID: 2757BAC55EA9C8190E1-8072
> Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
>     Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
>     Component: ESC           H31 0557
>     Revision: 00000000    Serial number: 63373000000082
>     Coding: 01FA93A13424296F037B060681C5A980C92C94C0608195F7F84250B8C209
>     Shop #: WSC 27263 001 1048576
>     ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
>     ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
>     VCID: 7CFDB5A9F7AFBBC1333-8029
> Address 05: Acc/Start Auth. (J518)       Labels: 5Q0-959-435.clb
>     Part No SW: 5Q0 959 435 A    HW: 5Q0 959 435
>     Component: VWKESSYMQB    021 0604
>     Revision: 00021000    Serial number: 0322004877
>     Coding: 030C0C
>     ASAM Dataset: EV_KessyHellaMQBAB 002011
>     ROD: EV_KessyHellaMQBAB_VW37.rod
>     VCID: 3A7173B1BD1B45F161F-806F
> Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
>     Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
>     Component: Climatronic   H02 0805
>     Revision: 00001K06
>     Coding: 00120004100100001105000011101800
>     ASAM Dataset: EV_ACClimaBHBVW37X 003018
>     ROD: EV_ACClimaBHBVW37X_VW37.rod
>     VCID: 387569B9831757E197B-806D
> Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
>     Part No SW: 5Q0 937 085 T    HW: 5Q0 937 085 T
>     Component: BCM MQBAB HNA H16 0124
>     Serial number: 00011334600181
>     Coding: 03011A42424122FB49E44000000C07281800000000000000000000000000
>     ASAM Dataset: EV_BCMCONTI 012001
>     ROD: EV_BCMBOSCH_SE37.rod
>     VCID: 4A912371EDFBD571F1F-801F
>     Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
>     Component: WWS    131207  042 0551
>     Serial number:         131211073646
>     Coding: 0E4DDD
>     Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels:
> 5Q0-955-547.CLB
>     Component: RLFS  024 0042
>     Serial number: Y13M12D12H00M23S17S7
>     Coding: 31E8DD
> Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
>     Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
>     Component: PARKHILFE 8K  H03 0142
>     Revision: --------    Serial number: 39331335104631
>     Coding: 0071051011
>     ASAM Dataset: EV_EPHVA18AU3700000 002024
>     ROD: EV_EPHVA18AU3700000.rod
>     VCID: 3E797FA1A13369D15D7-806B
> Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
>     Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
>     Component: ACC Bosch MQB H04 0200
>     Serial number: 12121376510562
>     Coding: 021C1700FE0339
>     ASAM Dataset: EV_ACCMRRBoschVW372 001014
>     ROD: EV_ACCMRRBoschVW372_AU37.rod
>     VCID: 366967818903A191857-8063
> Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
>     Part No SW: 5Q0 907 376     HW: 5Q0 907 376
>     Component: DAEMPFUNGS-SG H15 0115
>     Serial number: 26111341350177
>     ASAM Dataset: EV_DRCONTITEMIC 001019
>     ROD: EV_DRCONTITEMIC.rod
>     VCID: 76E9A781C983E191457-8023
> Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
>     Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
>     Component: AirbagVW20    014 0386
>     Serial number: 003MLR02CYH9
>     Coding: 98FCC0C0000000005C5400CF00C800000065
>     ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
>     ROD: EV_AirbaVW20SMEVW37X_VW37.rod
>     VCID: 7F0742A5E6B9A0D9161-802A
>     Seat belt tensioner; left:
>     Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
>     Component: BeltPretRevFL  H35 0341
>     Serial number: 34169667B17021441081
>     Coding: 333135
>     Seat belt tensioner; right:
>     Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
>     Component: BeltPretRevFR  H35 0341
>     Serial number: 34169668B19021470327
>     Coding: 333135
>     Crash sensor for side airbag; driver side:
>     Subsystem 3 - Part No SW: -----------    HW: 480 001 012 13
>     Component: SideSensor_Df  001 0887
>     Serial number: 35767000000A69A43E0+
>     Coding: 2D2D2D
>     Crash sensor for side airbag; front passenger side:
>     Subsystem 4 - Part No SW: -----------    HW: 480 002 111 13
>     Component: SideSensor_Pf  001 0887
>     Serial number: 358670000009D64C3E04
>     Coding: 2D2D2D
>     Crash sensor for side airbag; rear; driver side:
>     Subsystem 5 - Part No SW: -----------    HW: 480 400 712 13
>     Component: SideSensor_Dr  001 6149
>     Serial number: 3516502BD122056541D%
>     Coding: 2D2D2D
>     Crash sensor for side airbag; rear; passenger side:
>     Subsystem 6 - Part No SW: -----------    HW: 480 400 712 13
>     Component: SideSensor_Pr  001 6149
>     Serial number: 35265029F11FBE94828Y
>     Coding: 2D2D2D
>     Crash sensor for front airbag; driver side:
>     Subsystem 7 - Part No SW: -----------    HW: 480 400 612 13
>     Component: FrontSensor_D  001 6149
>     Serial number: 35565029F1220563C31%
>     Coding: 2D2D2D
> 2 Faults Found:
> 9634901 - Control Module for Front Left Belt Tensioner
>            B1304 55 [009] - Not configured
>            Confirmed - Tested Since Memory Clear
>               Freeze Frame:
>                      Fault Status: 00000001
>                      Fault Priority: 2
>                      Fault Frequency: 1
>                      Reset counter: 233
>                      Mileage: 3071 km
>                      Date: 2015.01.12
>                      Time: 17:32:45
> 9635157 - Control Module for Front Right Belt Tensioner
>            B1305 55 [009] - Not configured
>               Freeze Frame:
>                      Fault Priority: 2
>                      Fault Frequency: 1
>                      Reset counter: 233
>                      Mileage: 3071 km
>                      Date: 2015.01.12
>                      Time: 17:32:45
> Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
>     Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
>     Component: Lenks. Modul  002 0110
>     Revision: --------    Serial number: 09121304220607
>     Coding: 0C10
>     ASAM Dataset: EV_SMLSKLOMQB 017001
>     ROD: EV_SMLSKLOMQB_SE37.rod
>     VCID: 7BFFB6B5F2A1BCF93A9-802E
> Address 17: Instruments (J285)       Labels: 5G0-920-XXX-17.clb
>     Part No SW: 5G6 920 870 C    HW: 5G6 920 870 C
>     Component: KOMBI         320 2210
>     Coding: 27AD09187F80060002886A03040000
>     Shop #: WSC 38100 001 00001
>     ASAM Dataset: EV_DashBoardVDDMQBAB 008031
>     ROD: EV_DashBoardVDDMQBAB_AU37.rod
>     VCID: 2F6752E576599059C61-807A
> Address 19: CAN Gateway (J533)       Labels: Redir Fail!
>     Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
>     Component: GW MQB High   125 1164
>     Revision: --------    Serial number: 0001363940
>     Coding: 030100042B085900EF00027E9C0F00010001000000000000000000000000
>     ASAM Dataset: EV_GatewLear 010015
>     ROD: EV_GatewLear.rod
>     VCID: 3F8702A5A63960D9561-806A
>     Alternator:
>     Multifunction unit control module:
>     Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
>     Component: E221__MFL-DC1  H06 0038
>     Serial number: 27130001974610073472
>     Coding: 2DFFFF
>     Battery Monitoring Control Module:
>     Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
>     Component: J367-BDMHella  H03 8043
>     Serial number: 5395092103
> Address 2B: Steer. Col. Lock (J764)       Labels: 5Q0-905-861.clb
>     Part No SW: 5Q0 905 861 A    HW: 5Q0 905 861 A
>     Component: ELV-MQBA      H01 0120
>     Revision: 00000000    Serial number: 13000275822003
>     Coding: DD00000000000000
>     ASAM Dataset: EV_ELVMarquMQB 004111
>     ROD: EV_ELVMarquMQB_AU37.rod
>     VCID: 346D5D899F7FB381BB3-8061
> Address 42: Door Elect, Driver (J386)       Labels: 5QX-959-X93-42.clb
>     Part No SW: 5Q0 959 593 B    HW: 5Q0 959 593 B
>     Component: TSG FS        020 0025
>     Serial number: 07121302090757
>     Coding: 003F1320D001048000001000
>     ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
>     ROD: EV_DCUDriveSideEWMAXCONT.rod
>     VCID: 40850159DBC71F212FB-8015
>     Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
>     Component: FOND_FHSG_DRV  005 0005
>     Serial number: 00000000000001338605
>     Coding: 1D0000
> Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
>     Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
>     Component: EPS_MQB_ZFLS  503 5043
>     Coding: 9103
>     ASAM Dataset: EV_SteerAssisMQB 010031
>     ROD: EV_SteerAssisMQB_SE37.rod
>     VCID: 356B608D9405AA898CD-8060
> Address 52: Door Elect, Pass. (J387)       Labels: 5QX-959-X92-52.clb
>     Part No SW: 5Q0 959 592 B    HW: 5Q0 959 592 B
>     Component: TSG BFS       020 0025
>     Serial number: 08121302091280
>     Coding: 003F1120DE01048000801000
>     ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
>     ROD: EV_DCUPasseSideEWMAXCONT.rod
>     Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
>     Component: FOND_FHSG_PSG  005 0005
>     Serial number: 00000000000001326692
>     Coding: 050000
> Address 55: Headlight Range (J745)       Labels: 7P6-907-357.clb
>     Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
>     Component: AFS-ECU       H07 0080
>     Revision: --------    Serial number: --------------
>     Coding: 029603000B010200
>     ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
>     ROD: EV_HeadlRegulVWAFSMQB.rod
>     VCID: 3D7B78ADAC3572C944D-8068
>     Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329
>     Component: LeiMo links  H05 0012
>     Coding: 2E0000
>     Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329
>     Component: LeiMo rechts  H05 0012
>     Coding: 2E0000
> 1 Fault Found:
> 5275648 - Left/Right Driving Switch-Over Active
>            C1080 00 [009] -  -
>               Freeze Frame:
>                      Fault Priority: 6
>                      Fault Frequency: 1
>                      Reset counter: 233
>                      Mileage: 3071 km
>                      Date: 2015.01.12
>                      Time: 17:32:45
> Address 5F: Information Electr. (J794)       Labels: None
>     Part No SW: 5G0 035 050     HW: 5G0 035 050
>     Component: MU-H-N-JP     H41 0227
>     Serial number: K5F AW74A00OR9
>     Coding: 02730006FF00000021330001001000001F0203260100010076
>     ASAM Dataset: EV_MUHig4CAW7 001105
>     ROD: EV_MUHig4CAW7_VW37.rod
>     VCID: 59B3CC3D585DAEE9485-800C
>     Media Player Position 1:
>     Subsystem 1 - Part No SW: 5G0 919 606     HW: 5G0 919 606
>     Component: ABT_High  H51 0022
>     Serial number: VWZ8Z9NJ6007ER
>     Engine Control Module 2:
>     Subsystem 2 - Part No SW: V03 959 800 GH    HW: -----------
>     Component: JPN 2013/2014  --- 7127
>     Serial number: --------------------
>     Door Electronics Driver Side:
>     Subsystem 3 - Part No SW: 8V0 919 813     HW: 8V0 919 813
>     Component: DSRC UNIT  H04 0001
>     Serial number: 502080139301
>     Brake Assistance:
>     Subsystem 4 - Part No SW: 8V0 035 504 A    HW: 8V0 035 504 A
>     Component: VICS Antenna  H03 0001
>     Serial number: 503080011003
>     Door Electronics Rear Left:
>     Subsystem 5 - Part No SW: V03 959 800 EG    HW: -----------
>     Component: Gracenote  --- 2006
> Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
>     Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
>     Component: MQB_MFK       H05 0051
>     Serial number: 00000151765
>     Coding: 0100000000020303000400000101010100
>     ASAM Dataset: EV_MFKBoschAU370 001001
>     ROD: EV_MFKBoschAU370.rod
> Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
>     Part No SW: 5G0 907 159     HW: 4H0 907 159 A
>     Component: SAS-GEN 2     H06 0013
>     Serial number: 131122201534
>     ASAM Dataset: EV_SoundActuaGen2AU64X 003010
>     ROD: EV_SoundActuaGen2AU64X.rod
> End-------------------------(Elapsed Time: 04:45)--------------------------
Moved to Tweaks.
Mari
C?ID=150535
The FM band in Japan is 76–90 MHz.
I'm sure the software on the Discovery Pro is intended for Japan, maye the software can be "changed" to get UK/European freqencies for the radio. I don't know if this is possible... I also think this has anything to do with navigation! Can you check in the menu of the radio if you receive any GPS-signals or not!
GaryM
Oxford, UK
C?ID=226919
Radio
At a best guess you may well need a firmware update for the radio assuming it has the necessary hardware to support UK radio frequencies.
Airbag Faults
I'm not sure what your airbag faults are but there were a couple of other posts on this forum with the same errors. Unfortunately no-one came back with a resolution so the issues remained unanswered.
Headlight Range Fault
It looks like the car's headlights have been set to Tourist Mode / Travel Mode so it can be driven on the right without dazzling oncoming cars. When you turn the ignition on you should see the bulb fault indicator warning lamp in the instrument cluster flash on and of for a couple of seconds which is to remind you that Travel/Tourist Mode is switched on. On some models (the Skoda Octavia Mk2 for instance) this setting can be controlled from an option in the MFD so I would look there first in case it's on the Golf Mk7 too. In the Octavia MFD it's listed as "Travel Mode" under "Lights & Vision" and you can just tick or untick as required...
If there is no option in your MFD and assuming your label files have the required mappings then you should be able to set it back by following the guide in the following post (assuming the Mk7 Golf has the same or similar adaptation settings as the Mk6 Golf). You have nothing to lose by looking in the "55-Headlight Range" adaptation screen and seeing if you get the "Travel/Tourist Mode" option listed. If you do then you will obviously need to set the "New Value" to 0 to turn the Tourist Mode / Travel Mode back off...
Hopefully someone else can offer some advice on how to fix your other issues.
TD&MCK Car Sales
C?ID=160148
Yes I can get gps as I get a compass on the radio and in the clocks that shows me direction I'm travelling (North/south etc)
TD&MCK Car Sales
C?ID=160148
Radio
Airbag Faults
Thanks for the reply,
Who/where can I get firmware update please ??
I've go no airbag warnings etc so not sure if they are airbag faults ? The car is fitted with a DRSC unit in the glovebox with ETC on it ( it's something to do with electronic toll collection ) and the DRSC is some crash prevention thingy ??
When I first start the car I get a message in the dash display saying
'Proactive occupant protection not available ' ??? Not sure what this means !!
Will check the travel mode option thing tomorrow and see but my main concern is the radio/nav !!
Was looking at buying a second hand infotainment unit for discover pro but been told it won't work due to component protection??
Thanks for all info
Glenn
raf0468
C?ID=120244
'Proactive occupant protection not available'
this message is telling you that the control module in the seat belts are not configured to the the central airbag ecu.
i came across this when i installed a used pair from a donor vehicle,
anyone with vas online or the dealer can do this for you..
GaryM
Oxford, UK
C?ID=226919
It looks like there was a firmware update file floating around the web for the Discover Pro called DiscoverProFW200 but any links now appear to be dead so you will probably need to take a trip to the dealer and try to get them to attempt to do a firmware update for you. However, if the unit is specific to another region (Japan) then I guess there is still the possibility that it can't actually be updated with firmware for another region.
For Navigation maps you could try downloading and installing them from the navigation.com website. Again, if the unit is region specific then there may be issues trying to load on European maps. There is only one way to find out and that is to just try ans see what happens.
As for fitting a replacement UK / European spec Discover Pro unit, you could get the Component Protection removed by Q7 Audi Car Parts who are conveniently just down the road from you in Manchester (see this eBay listing). At £80 it's not cheap but it might end up being the only realistic option you have. If they are willing to remove Component Protection then maybe they would also be willing to attempt a firmware update on your existing unit instead for a fee. Certainly worth asking.
The airbag faults aren't for the airbags themselves but for the automatic seatbelt tensioners that fire in the event of a heavy impact. I may be wrong but I didn't think the failure of these brought up the airbag warning lamp so that is why you won't be getting the airbag lamp illuminated. The "Proactive occupant protection not available" message will almost certainly have something to do with these seatbelt tensioning errors.
Regarding the ETC unit in the glove compartment, DRSC is just the type of radio communication technology that is utilised by the ETC unit. It won't have anything to do with crash prevention. It sounds like that unit is just an aftermarket addition to the car so I think it should be safe for you to just rip it out and bin it.
Back to the headlamp fault, it looks like the headlamp aim can actually be changed in the infotainment center on the Golf Mk7 (see post #4 in this thread). Looking at your Auto-Scan results again for the Headlight Range faults, the fault was first triggered on 12th January at 17:32 so assuming you already had the car in your possession on Tuesday it suggests that you probably inadvertently changed that setting in the infotainment center while you were playing around without realising what it was for. At least you won't have to mess around using VCDS to set it back again.
NZDubNurd
New Zealand
C?ID=230482
We gat a LOT of japanese used imports here in NZ.
It's not uncommon for the radios to be japan specific, but I don't know if yours will be or not.
A lot of the BMW gear from the 2000's was japan ONLY, and had to be swapped for a euro version to work outside japan.
It may be worth you having a look on www.vask.org.nz (although it's giving some weird malware warning, though it's a popular NZ Audi/VW site).
DV52
C?ID=194404
Glen? Replied to your PM (on VWW) about this . My response is not inconsistent with what's being said here!
TD&MCK Car Sales
C?ID=160148
Thanks for the replies, going to try and get a second hand infotainment unit and take it from there, dont know why the seatbelt faults are there are 100% sure it has not been involved in any accidents !!
GaryM
Oxford, UK
C?ID=226919
The fault codes for the seat belt pretensioners are because they haven't been coded to the car. I can only guess that the original tensioners were replaced for some reason when the car was in Japan but were never coded to the car. As no warning lights appear in the instrument cluster, maybe whoever replaced them was unaware that they needed to be coded or maybe they knew but couldn't be bothered to get it sorted before the car was exported.
This is one of the other threads detailing the same seat belt pretensioner fault...
Unfortunately there is no resolution on that thread due to lack of a valid security code to enable the required recoding to be done using VCDS, but on another forum the same person resigned themself to the fact that it would need to be resolved by a dealer who had online access to the required security codes (which would be done using their dealer VAS system)...
So maybe you are going to have to end up taking the car to a dealer unless RT are able to find out what the security code needed actually is so you can try and do it yourself using VCDS. It might be worth you posting a new thread in the Car Repair Support section of the forum relating to this specific individual problem and hopefully one of the RT guys will then pick it up from there.
TD&MCK Car Sales
C?ID=160148
thanks for the reply gary
sorry to mither you all again !! i have ben and purchased a second hand infotainment unit part number 5G0035020D from a VW breakers yard, i have plugged it into my car (glovebox) and the unit works other than it says component protection on the screen and i have no volume !! the sat-nav maps load and i can work everything through the screen as before but no volume and component protection on screen !! any help advise ?? i am going to post this on the forum as well to see..
thank you again
glenn
AIB Wolfgang
Hi Glenn,
there for you have to go to the dealership. They only can eleminate this protection.
GaryM
Oxford, UK
C?ID=226919
At a guess, once you get the Component Protection is removed you will probably (hopefully) find that the volume then becomes controllable. I've read on some Audi forums that some controls don't seem to work when Component Protection is active. Unfortunately you won't know for sure until you get a dealer / VAG specialist to remove the Component Protection.
TD&MCK Car Sales
C?ID=160148
Booked in Friday morning so fingers crossed!!
GaryM
Oxford, UK
C?ID=226919
It's always good to have conclusion to a thread so please post back and let us know what the outcome is :)
Dana
Western PA, USA
Hi guys. First of all, thanks for all of the helpful replies in this thread!
Gary, we have another SA code to test in that 15-Airbag controller so I'll reply in that thread. Hopefully, the OP has an opportunity to test it before the trip to the dealer .. but if it fails to work I would have them match the new belts when sorting the CP problem.
TD&MCK Car Sales
C?ID=160148
Hi again...
Good news and bad news !!
had the component protection removed and now have volume again !!
everything else works as it should, all my FM radio stations and all in english including voice control...except...
the navigation is not working ! i dont even get a compass in my clocks now !
when i press nav on the disc pro it just says "the navigation data in the infotainment system are not valid, please check data" ??? any suggestions guys please ?
also had the seatbelt faults cleared so no more warnings in
the other thing is when i start the system it says GTD on the screen now and not GTI (as the infotainment system came from a gtd) ?? any ideas how to change this ?
youve all been a great great help so far
glenn
