I'm
Glen: OK-first a bit of Leuchte programming theory! The way that the good Burghers in Germany have organised the commands for a leutche channel set (i.e. 19 x adaptation channels) is in groups of four adaptation channels (let's call these a Leuchte channel sub-set). Each sub-set itself has four adaptation channels. I have highlighted a sub-set in my table for each DRL.
As you can see, each of these sub-sets contains two alpha characters in the first two channels which can be separately assigned to different functions, and the pair is then jointly controlled by a dimming value and HD command in the remaining two channels (see later paragraph). Note that the last line in the other three channel sub-sets is a dimming direction command.
Look at the command lines in the last two channels in each of the four sub-sets and you will see that they always refer to the alpha-pair in the first two lines. It matters which Alpha is used because there is a preset priority sequence for the alpha characters. That is, the priority of the commands when the alpha pairs compete is always: GH>EF>CD>AB. This principle is illustrated beautifully by the settings in channels (8) and (9) in my table which relate to the Park lights. So, what the original VW programmers have said is, if the rotary light switch on your car is in the "Park" position, then over-ride the DRL function, but keep the lights illuminated at full brilliance (i.e. 127)- A good thing to do (I think)!
The fact that the B channel has a setting of not active simply means that it doesn't have another function attached to it. This means that the (6) and (7) command lines only control one activity in your car (that being the DRLs). So short answer to your question is (potentially) YES -that's it, but only if the physical gear is in the car.
Incidentally, I'm sure that the entry "always" for channel (6) in the highlighted sub-set looks a bit odd to you! The reason for this entry relates to the term HD in the command line. HD means HeckDeckle, which is the german word for the trunk lid. So "always" means that the DRL should illuminate regardless of the position of the trunk lid, which makes sense. But some of the entries in your adap map for the BCM for channel (6) have the setting "only if closed" - if used, this setting is invariably for the rear lights.
Here end-eth the lesson - thanks for obliging me !!
Answer to your second question is NO. I wasn't aware that you wanted to switch-off the DRLs, I had understood that you only wanted to switch them on! If you want to control the DRLs via the discover media screen, there is a further channel change necessary .
Select (2)-Daytime Running Lights- Tagfahrlicht Aktivierung durch BAP oder Bedienfolge möglich ---change setting to active.
Finally, it was remiss of me not to mention that modifications to the adaptation settings will require that you enter the magic number (31347) into the security screen before proceeding.
hi don,
Looks like this is set to active already on my map
