- Joined
- Apr 9, 2014
- Messages
- 2,310
- Reaction score
- 2,259
- Location
- Tartu, Estonia
- VCDS Serial number
- C?ID=195131
This 2018 ecoUP didn't have cruise from factory.
I helped a guy out and installed it. All new wiring done from scratch. Also added wire for later MFSW.
VCDS is missing out a ton of information. Like Coding table for BCM and ECU.
Luckily it is like Polo BCM so cruise bit was same, ECU info I got luckily from another scan.
I'm still unaware of coding for MFSW and trip buttons to uncode.
Engine - Byte 5 Bit 5 Cruise installed
BCM - Byte 17 bit 7 Cruise Installed
He also had issues with G85 sensor. Seems like VCDS isn't able to calibrate these things anymore as it requires switching to EOL-mode to perform calibration. From ODIS log I can see something about Seed Key login before adaption is carried out.
Experienced similar thing with newer VW Caddy and Transporter ABS also.
Saturday,19,October,2019,02:56:44:10298
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4513.4
Dealer/Shop Name: LeVWFreaks.eu
VIN: WVWZZZAAZJD License Plate: TÕRUKESE SÕBRA UP VEAVABA
Mileage: 19870km-12346mi Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 03 09 10 15 17 19 25 44 5F 61
VIN: WVWZZZAAZJD Mileage: 19870km-12346miles
Address 01: Engine (------CPGA) Labels: None
Part No SW: 04C 906 020 EE HW: 04C 907 309 AF
Component: R3 1.0l CPI H12 3828
Revision: U5H12---
Coding: 00110030002401000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM10CPI01104C906020EE 001004
ROD: EV_ECM10CPI01104C906020EE.rod
VCID: 629D5738C4CD32B7BF3-8036
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels: 1S0-614-517.clb
Part No SW: 1S0 614 517 P HW: 1S0 614 517 P
Component: EBC 460 ESP H17 0030
Serial number: A01R5TR
Coding: 12BF247129B602F748FE24F994AD40505F0100
ASAM Dataset: EV_Brake1ESPEBC460TRW 002107
ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
VCID: 3C21C94006E92447D5F-8068
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 1S0 937 090 H HW: 1S0 937 090 H
Component: BCM PQ25 1MX4 H82 0752
Revision: BW082001 Serial number: 5000 103180756
Coding: 62B8290000010000080001D06CABACD079C0706D60CF2D602101000B0800
VCID: 3829D55032510867317-806C
Subsystem 1 - Part No SW: 6R0 959 591 D HW: 6R0 959 591 D
Component: J245 PS72.405 H04 0005
Serial number: 0000FST001ZIC5Z00000
Coding: 181000
Address 10: Park/Steer Assist (J446) Labels:| 1Sx-919-475.clb
Part No SW: 1S0 919 475 B HW: 1Q0 919 475
Component: PARKHILFE 3K H03 0013
Revision: -------- Serial number: 32931809606569
Coding: 108004
ASAM Dataset: EV_EPHVA14VW1200000 001009
ROD: EV_EPHVA14VW1200000.rod
VCID: 392FD05409DB116FCE9-806C
Part No SW: 1S0 959 655 C HW: 1S0 959 655 C
Component: VW10Airbag02W H03 0007
Revision: -------- Serial number: 003UB00666EX
Coding: 000000000000000000000000000000003257
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
VCID: 3E25C34810F53657FBB-806A
Serial number: 3575HRB400U5DPT679OC
Serial number: 3585HRB401G5DNAKFH1T
Serial number: 3557BRB40535ALPUM8B+
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1S0 920 870 B HW: 1S0 920 870 B
Component: KOMBI H05 0010
Revision: X0005001 Serial number: 00000000000000
Coding: 114A010000
ASAM Dataset: EV_KombiUDSMM9RM10 A05808
ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
VCID: 3039ED70DAA1D027797-8064
Part No SW: 1S0 909 901 HW: 1S0 937 090 H
Component: GW-K-CAN TP20 H82 0752
Revision: BW082001
Coding: 001000
VCID: 70B92D701AA19027397-8024
Part No SW: 5K0 953 234 HW: 1S0 920 870 B
Component: IMMO H05 0010
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A8D3F183CFD6AF7773-803E
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AN HW: 6R1 909 144 E
Component: EPS_TRW_ALow 313 3150
Serial number: CI4G0601
Coding: 000700
Shop #: WSC 63672 002 1048576
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 035372BC3B979BBFD45-8056
Part No SW: 1S0 035 867 HW: 1S0 035 867
Component: MU-E--EU 069 7358
Serial number: 20031800020627
Coding: 02210000280000004011000101000200000004C40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: 71BF2874112B992F369-8024
Part No SW: 1S0 907 534 HW: 1S0 937 090 H
Component: Batt.regelung H82 0752
Coding: 032B7864
Subsystem 1 - Part No SW: 1S0 915 181 C HW: 1S0 915 181 C
Component: J367-BDM H08 0270
Serial number: 55086C07015861933171
End----------(Elapsed Time: 00:46, VBatt start/end: 13.2V/13.2V)-----------
