Retrofit AID in Golf 7 GTD 2014 Error only in display! No Autoscan
djthema
Italy
C?ID=382547
Hi
I have retrofitted in my golf 7 gtd 2014 the AID, not have error in AUTO SCAN;
but in display have this error:
ERROR IN THE CALCULATION OF AUTONOMY
djthema
Italy
C?ID=382547
Hi
Not have error in autoscan......only in the display
DV52
C?ID=194404
^^^ djthema: hi - VCDS autoscan reports can be useful in all sorts of ways: yes, they are useful in identifying errors (DTC s) on the vehicle, but they also have the advantage of telling forum colleagues what sort of equipment is fitted to the car - plus, autoscan reports also tell us how the long code string on each module is set,
So- notwithstanding that "not have error in AUTO SCAN" , please post-up a copy (unedited and in English)
EDIT: oops - great minds think alike (and fools seldom......)!!
MasterTommy
Amsterdam
C?ID=295586
Again, autoscan please :)
djthema
Italy
C?ID=382547
Friday,18,October,2019,19:28:28:36623
VIN: WVWZZZAUZEW169209   License Plate:
Mileage: 30341km-18853mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
VIN: WVWZZZAUZEW169209   Mileage: 30341km-18853miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EQ    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 6284
   Revision: 81H22---
   Coding: 011D0032032405082000
   ASAM Dataset: EV_ECM20TDI01104L906021EQ 002006
   ROD: EV_ECM20TDI01104L906021ER.rod
   VCID: 78A81321825BBB37F17-802C
   Part No SW: 0D9 300 040 J    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 4027
   Revision: 05652104    Serial number: TFK01309271755
   ROD: EV_TCMDQ250021.rod
   VCID: 1E6425B9403F2507DBB-804A
          P1734 00 [002] - -
   Part No SW: 5Q0 907 379 AA    HW: 5Q0 907 379 G
   Component: ESC           H31 0457
   Revision: 00000000    Serial number: 628330000010CC
   Coding: 01FA62A1342609750379060041CC2980462C90C0608294F50062507AC109
   VCID: 7BA20C2DB36D902F9C5-802E
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00020114202100011005000000101000
   VCID: 66944D59D8EF3DC753B-8032
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011329104429
   Coding: 00141A46C24122FB4BE44000001C0728100A000000000000000000000000
   Shop #: WSC 12345 123 12345
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77AA101D8F45B44FF8D-8022
   Component: WWS    131012  042 0551
   Serial number:         131014133932
   Component: RLFS  024 0042
   Serial number: Y13M10D09H11M38S49S1
   Coding: 00A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO24736938
   Coding: 181801
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Revision: --------    Serial number: 61131328801038
   Coding: 0031251051
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 3D26C235EDF95E1FE21-8068
   Component: AirbagVW20    014 0385
   Serial number: 003F6R01TFR.
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41DEBEC591013AFF869-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 210 13
   Serial number: 3576700000050379DD0Z
   Subsystem 2 - Part No SW: -----------    HW: 480 000 210 13
   Serial number: 3586700000010379DD0W
   Subsystem 3 - Part No SW: -----------    HW: 480 401 710 13
   Serial number: 3516502A71230BB4F077
   Subsystem 4 - Part No SW: -----------    HW: 480 401 710 13
   Serial number: 3526502AF11FBEA2213M
   Subsystem 5 - Part No SW: -----------    HW: 480 401 510 13
   Serial number: 3556502991142C85E106
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0085
   Revision: FF026026    Serial number: 20131011400219
   Coding: 0400
   ASAM Dataset: EV_SMLSVALEOMQB 001011
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDAB83DE7F54C0FF0D-806A
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         408 3195
   Coding: 03AD41082B90000800086A000400000000000000
   Shop #: WSC 00046 123 12345
   VCID: 2A0CF9690C77D9A7B73-807E
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0001165062
   Coding: 030100040B087300FF00066A1C0F00010001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 3B22CC2DF3ED502FDC5-806E
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27130001506960073376
   Coding: 29FFFF
   Serial number: 5199551503
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 08101301101316
   Coding: 003F0320D000040000001000
   Serial number: 00000000000003086053
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 8301
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: 3332E40DDBBD986F045-8066
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 12101301101476
   Coding: 003F0120DE00040000801000
   VCID: 3E24C539E0FF4507FBB-806A
   Serial number: 00000000000003102712
   Coding: 090000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0080
   Coding: 029A01000B000200
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
   Component: MU-S-N-ER     851 0842
   Coding: 02731001FF00000011510000000A00001F0602F4012000004E
   Shop #: WSC 00046 000 00000
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 313EEE0521A1AA7F769-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV0750013
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Part No SW: 5G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0011
   Serial number: 130918201213
   VCID: 6B823C6DC30D00AF0C5-803E
End----------(Elapsed Time: 01:10, VBatt start/end: 12.9V/12.6V)-----------
djthema
Italy
C?ID=382547
long ago I installed the drive select mode in vw (original kit)...........is possible that the problem is solved by refresh the fecs in gataway
downtime
C?ID=280813
Is your drive select working? If yes then the FeCs are ok.
DV52
C?ID=194404
your AID thinks that the car is hybrid, scan and adaptations from 17 might help :)
m87a: perhaps Byte 2 on the hex17 module? Current value from auto-scan for Byte 2 = hex41 -which means that Bits 3-7 value=hex40 - which means that instrument module is set-up for Vehicle variant, derivative 9. I have no idea what "derivative 9 " is, but it's unusual!
djthema
Italy
C?ID=382547
my old analogic cluster:
System description KOMBI
SoftwareVersion 2210
HardwareVersion 314
VW/Audi part number 5G6920870A
Hardware part number 5G6920870A
Coding 07AD09082B90000800086A00000000
ASAM/ODX file identification EV_DashBoardVDDMQBAB
ASAM/ODX file version 008031
i try 09 but have the error
vastechnics
C?ID=143747
Flash gateway to newer version.
Codeme
Manchester, UK
C?ID=231524
In 17 instrument long code u need to change the tank version to your car will go away.
DV52
C?ID=194404
^^^ hmm........ here's the compare table for both hex17 modules:
Name	Old module		AID Module
Byte	Hex	 Binary	        Hex	Binary
0	07	00000111	03	00000011
1	AD	10101101	AD	10101101
2	09	00001001	41	01000001
3	08	00001000	08	00001000
4	2B	00101011	2B	00101011
5	90	10010000	90	10010000
6	00	00000000	00	00000000
7	08	00001000	08	00001000
8	00	00000000	00	00000000
9	08	00001000	08	00001000
10	6A	01101010	6A	01101010
11	00	00000000	00	00000000
12	00	00000000	04	00000100
13	00	00000000	00	00000000
14	00	00000000	00	00000000
15		00000000	00	00000000
16		00000000	00	00000000
17		00000000	00	00000000
18		00000000	00	00000000
19		00000000	00	00000000
Tank version is set by Byte 2, Bit 0-2. Both are set to Tank characteristic curve, Version 2.
I'm not sure what Byte 12, Bit 2 does on AID module (Radio station listings?) - perhaps someone else can advise?
Looks to be dimming. Terminal 58xt vs. Terminal 58xd. But don't ask me what the difference is.
Byte 5, bit 6 should be "Powertrain hybrid", but that's not set.
m87a
Bosnia and Herzegovina
C?ID=156900
not really sure since on a lot of modules on mqb first 3 bytes are vehicle coding and some options (derivatives) so worth a try, also you can put a GTI or GTD AID in diesel or gas car and it will display correct RPM's probably info from ECU but a lot of other stuff is coding and adaptations channels
maybe with update it will help
vastechnics
C?ID=143747
This is coding from GTD facelift with OEM AID:
Component: KOMBI 407 3193
Coding: 07AD11182F80000801886B011401000000000000
VCID: 2A0CF40DAC758817B4D-807E
Believe me update firmware off gateway and problem solved.
m87a
C?ID=156900
talked to a colleague and he confirmed for range error when retrofitting AID flash gateway to fix it
djthema
Italy
C?ID=382547
thanks i try to flash gataway
