Data logging using the Mobil app
Vettetruck89
Georgia, USA
Hello all,
I am a beginner for sure with respect to Vagcom and VCDS. I have a hexnet that I have successfully connected to my 2013 Audi S8 but I am not computer savvy by any stretch of my imagination.
Over the past several months I have been experiencing a starting problem with my car. Randomly, when attempting to start the car it will crank over and attempt to start but immediately fail. In order to get the car started I would have to open the door and hit the start button again to turn the car off and then put my foot back on the brake and press the start button again. The car will then crank over what seems to be several seconds( at least 10 times as long as normal) before starting with a rough idle for a moment. It then settles out and runs fine. My car does not have any check engine lights or stored DCTs . I have brought the car in several times for the dealer to troubleshoot and as one might expect they were unable to duplicate. I have captured it on video but want some evidence to present to the dealer.
I am asking for help in setting up a data logging system that I can start prior to starting my car to capture data that might help troubleshoot this issue. Any help will be greatly appreciated!
Jonathan
Speculation: A intermittent problem with fuel pressure.
Please post an Auto-Scan so people can see exactly how this car is equipped.
Assuming you saved it, open it in one browser window using [View Saved Files] in VCDS-Mobile, then copy and paste the text here.
Vettetruck89
Georgia, USA
Cleaned it up a bit
#hndoc:?
docid=0000541D&xt=hnh:BCEBBC600F057F71FF3DACCC77536FDD32FA174A2BA1C77C2F0C66F1E08EB728 Thu,Sep,26,2019,07:20:28 VCDS Mobile 0.4508.0.4
VIN: WAUD2AFD1DN016533
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42 46 47 52 53 56 5F 62 6C 6D 6F 72 7F 81 84 85 88 89 8B 	 8E 8F 90 A9 BA
7F-Inform. Electr. II -- Status: Malfunction 0010
84-Night Vision -- Status: OK 0000
8F-Pretension. Front Left -- Status: OK 0000
90-Pretension. Front Right -- Status: OK 0000
BA-Motor Mounts -- Status: OK 0000
Address 01: Engine (CGTA2 -----)	Labels: 4H-01.lbl
Part No SW: 4H0 907 557 E	HW: 4H0 906 014
Component: 4.0l V8TFSI / H61 0004
Revision: NCH61---
Coding: 022A00326546000E1000
Shop #: WSC 64407 002 1048576
ASAM Dataset: EV_ECM40TFS0114H0907557E 001004
ROD: EV_ECM40TFS0114H0907557E.rod
VCID: 322789CBFCD5E9BD0AE6B5-8067
No fault codes found.
Address 02: Auto Trans (J217)	Labels: 4H-02.lbl 	Part No SW: 4H1 927 158 EG	HW: 0BK 927 156 AG 	Component: 0BK 40TFSIUSA H16 1002 	Revision: --H16--- 	Coding: 000000 	Shop #: WSC 00000 000 00000 	ASAM Dataset: EV_TCMALX51011 002022 	ROD: EV_TCMALX51011_002.rod 	VCID: 79B57EE76123DAE58BACAA-802C 1 Fault Found: 2502 - Transmission Control Unit Incorrectly Coded 	P1749 00 [175] - 	MIL ON - Confirmed - Tested Since Memory Clear
 ----------------------------------------------------------------- Address 03: ABS Brakes (J104)	Labels: 4H0-907-379.clb 	Part No SW: 4H0 907 379 E	HW: 4H0 907 379 E 	Component: ESP PREMIUM H10 0352 	Revision: -------- 	Coding: C2FDB20043BF4D00E200 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_ESPPremi 005013 	ROD: EV_ESPPremi_005_AU64.rod 	VCID: 342B8FD306C1E78D181AA3-8061
----------------------------------------------------------------- Address 05: Acc/Start Auth. (J393)	Labels: 8K0-907-064-05.clb 	Part No SW: 4H0 907 064 DD	HW: 4H0 907 064 CD 	Component: BCM2 2.0 H33 0510 	Revision: 00002001 	Coding: 0D872006000000000000 	Shop #: WSC 43966 000 1048576 	VCID: 6E9F5DBB286D955D2E5E21-803B 	Subsystem 1 - 	Subsystem 2 - 	Part No SW: 4H0-905-852-C 	Component: J764 ELV MLB H40 0046
----------------------------------------------------------------- Address 06: Seat Mem. Pass (J521)	Labels: None 	Part No SW: 4H0 959 760 E	HW: 4H0 959 760 E 	Component: MEM-BFS H08 0153 	Revision: AA000000 	Coding: C018320085043201010001010101112131313333283333 	Shop #: WSC 02313 785 00200 	VCID: 352DB2D70DBBE6852F04D6-8060
----------------------------------------------------------------- Address 08: Auto HVAC (J255)	Labels: 4H0-820-043.clb 	Part No SW: 4H0 820 043 L	HW: 4H0 820 043 L 	Component: Klima 4 Zonen H20 0121 	Coding: 688121B85C 	Shop #: WSC 02313 785 00200 	ASAM Dataset: EV_AirCondiFront 001050 	ROD: EV_AirCondiFront_AU64.rod 	VCID: 29156EA7D103AA65BB8C5A-807C 1 Fault Found: 0137 - Motor for Right Side Window Defrost Flap 	B10D8 22 [009] - Signal Amplitude Too High 	Confirmed - Tested Since Memory Clear
----------------------------------------------------------------- Address 09: Cent. Elect. (J519)	Labels: 4H0-907-063-V1.clb 	Part No SW: 4H0 907 063 CG	HW: 4H0 907 063 	Component: BCM1 2.0 H12 0130 	Revision: 11012002 	Coding: 09072091077C9FF3BB000844A0003800009CD3088A0001218001085C7B00 	Shop #: WSC 02313 785 00200 	VCID: 6FA140BF2F679C55254854-803A 	Subsystem 1 - 	Part No SW: 4H1-955-119-C	Labels: 1Kx-955-119.clb 	Component: WWS641 120909H35 0080 	Coding: 0045F7 	Subsystem 2 - 	Part No SW: 8K0-955-559-C	Labels: 8K0-955-559.clb 	Component: RLS H04 0003 	Coding: 025523 	Subsystem 3 - 	Part No SW: 4H0-941-531-C 	Component: E1 - LDS H07 0044 	Subsystem 4 - 	Part No SW: 4G0-907-410-A 	Component: USHL4.2 H30 0030 	Subsystem 5 - 	Part No SW: 4H0-907-472-B 	Component: A31 LED Mod1LH03 0006 	Coding: 100000 	Subsystem 6 - 	Part No SW: 4H0-907-472-B 	Component: A27 LED Mod1RH03 0006 	Coding: 100000 	Subsystem 7 - 	Part No SW: 4H0-907-705-K 	Component: EVLS-SG H08 0300 	Coding: 020300 	Subsystem 8 - 	Part No SW: 4H0-907-658 	Component: AQ_Hum_SensorH03 0003
----------------------------------------------------------------- Address 10: Park/Steer Assist (J446)	Labels: 4H0-919-475-7X2.clb 	Part No SW: 4H0 919 475 AA	HW: 4H0 919 475 AG 	Component: PARKHILFE ACC H01 0083 	Revision: 11001001 	Coding: A80923 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_EPHVA18AU57X0000 004009 	ROD: EV_EPHVA18AU57X0000_004.rod 	VCID: 71A546C7395392A5337C42-8024
----------------------------------------------------------------- Address 13: Auto Dist. Reg (J428)	Labels: 4H0-907-561.clb 	Part No SW: 4H0 907 561 B	HW: 4H0 907 561 	Component: ACC3 H17 0400 	Coding: 7601010101 	Shop #: WSC 02313 785 00200 	ASAM Dataset: EV_AdaptCruisContrAU64X 002021 	ROD: EV_AdaptCruisContrAU64X_002.rod 	VCID: 2A1791ABD405A17DB2B64D-807F
----------------------------------------------------------------- Address 15: Airbags (J234)	Labels: 4H0-959-655.clb 	Part No SW: 4H0 959 655 D	HW: 4H0 959 655 D 	Component: Airbag10.43 H44 0041 	Revision: -------- 	Coding: 303143303230303030314A55304C34483053 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_AirbaAU10BPAAU64X 001014 	ROD: EV_AirbaAU10BPAAU64X_AU64.rod 	VCID: 3731B8DF17B70C953D38FC-8062 	Subsystem 1 - 	Part No SW: 4H0-959-339-A 	Component: BF-Gewichtss.H03 0040 	Serial Number: 5850000R12A01063PEªª 	Coding: 000000 	Subsystem 2 - 	Serial Number: 3575HRB40651KADSD8GR 	Subsystem 3 - 	Serial Number: 3585HRB40531KAE0D1M/ 	Subsystem 4 - 	Serial Number: 3515JRB40084UOUGTHHZ 	Subsystem 5 - 	Serial Number: 3525JRB40084UOUGPH8N 	Subsystem 6 - 	Serial Number: 3554VRB401G4UMPMCPSH 	Subsystem 7 - 	Serial Number: 3564VRB401G4UMPM9I1O
----------------------------------------------------------------- Address 16: Steering wheel (J527)	Labels: 4H0-953-568.clb 	Part No SW: 4H0 953 568 H	HW: 4H0 953 568 H 	Component: Lenks.Modul H03 0005 	Revision: -------- 	Coding: 0004BC 	Shop #: WSC 02391 785 00200 	VCID: 3833BBE31AA91BED3422F7-806D 	Subsystem 1 - 	Part No SW: 4H0-951-528-L 	Component: E221 - MFL H09 0010
----------------------------------------------------------------- Address 17: Instruments (J285)	Labels: 4H0-920-xxx-17.clb 	Part No SW: 4H0 920 880 G	HW: 4H0 920 880 G 	Component: TBenUSAACCNV- H51 0515 	Revision: 34081076 	Coding: 0B470803F740D705020100 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_RBD4K 004046 	ROD: EV_RBD4K_AU64.rod 	VCID: 2E1F9DBBE8EDCD5D6EDE61-807B
----------------------------------------------------------------- Address 19: CAN Gateway (J533)	Labels: None 	Part No SW: 4H0 907 468 AC	HW: 4H0 907 468 AC 	Component: J533--Gateway H12 0037 	Revision: -------- 	Coding: 00E1034800 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_GatewPkoUDS 001018 	ROD: EV_GatewPkoUDS_001_AU64.rod 	VCID: 72A749CB3C55A9BDCA6675-8027 	Subsystem 1 - 	Part No SW: 4H0-915-181-F 	Component: J367-BDM H08 0181 	Serial Number: 00000000004970338724 2 Faults Found: 12290 - Quiescent Current 	U1406 00 [008] - Too High 	Intermittent - Confirmed - Tested Since Memory Clear 12291 - Energy Management Active 	U140B 00 [008] - 	Intermittent - Confirmed - Tested Since Memory Clear
----------------------------------------------------------------- Address 1B: Active Steering (J792)	Labels: None 	Part No SW: 4H0 907 144 C	HW: 4H0 907 144 C 	Component: DYNAMIKLENK. H06 0100 	Revision: 51001005 	Coding: 090000 	Shop #: WSC 02391 785 00200 	VCID: 28136BA3CA098B6DA48227-807D
----------------------------------------------------------------- Address 20: High Beam Assist. (J844)	Labels: 8K0-857-511.clb 	Part No SW: 8K0 857 511 G	HW: 8K0 857 511 G 	Component: FLA H04 0020 	Revision: AB001001 	Coding: 04018B6B74745D545420363E00 	Shop #: WSC 02313 785 00200 	VCID: 352DB2D70DBBE6852F04D6-8060
----------------------------------------------------------------- Address 22: AWD (J492)	Labels: 4H0-907-163.clb 	Part No SW: 4H0 907 163 A	HW: 4H0 907 163 A 	Component: 4 Wheel Drive H15 0013 	Shop #: WSC 00000 000 	ASAM Dataset: EV_AllWheelDiffeQSPFR 003023 	ROD: EV_AllWheelDiffeQSPFR.rod 	VCID: 2711689FC7179C15AD982C-8072
----------------------------------------------------------------- Address 28: HVAC, Rear (E265)	Labels: None 	Part No SW: 4H0 919 158 K	HW: 4H0 919 158 K 	Component: Klima Fond H16 0121 	Coding: 2000000000 	Shop #: WSC 02313 785 00200 	ASAM Dataset: EV_AirCondiHeck 001039 	ROD: EV_AirCondiHeck_AU64.rod 	VCID: 3833BBE31AA903ED3422F7-806D
----------------------------------------------------------------- Address 34: Level Control (J197)	Labels: 4G0-907-553.clb 	Part No SW: 4H0 907 553 E	HW: 4H0 907 553 	Component: LUFE-DAEMPFER H17 0099 	Coding: 008006 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_AirSuspe 003024 	ROD: EV_AirSuspe_003_AU64.rod 	VCID: 2E1F9DBBE8EDCD5D6EDE61-807B
----------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136)	Labels: None 	Part No SW: 4H0 959 760 E	HW: 4H0 959 760 E 	Component: MEM-FS H08 0153 	Revision: AA000000 	Coding: C0183B0085053201010001010101112131313333203333 	Shop #: WSC 02313 785 00200 	VCID: 352DB2D70DBBE6852F04D6-8060
----------------------------------------------------------------- Address 3B: Sensor Elect. (J849)	Labels: None 	Part No SW: 4H0 907 637 L	HW: 4H0 907 637 G 	Component: SARA 6D red H02 0053 	Revision: -------- 	Shop #: WSC 00000 000 00000 	ASAM Dataset: EV_SARA2 005011 	ROD: EV_SARA2_005.rod 	VCID: 3833BBE31AA903ED3422F7-806D
----------------------------------------------------------------- Address 3C: Lane Change	Labels: None 	Part No SW: 4H0 907 566 A	HW: 4G0907568 	Component: J769 SWA MasterH02 0040 	Revision: 00H02000	Serial Number: 6PZ 010 287-07 	Coding: 0000003 	Shop #: WSC 02313 785 00200 	VCID: 2E1F9DBBE8ED555D6EDE61-807B 	Subsystem 1 - 	Part No SW: 4H0-907-568-A 	Component: J770 SWA Slave H02 0040 	Serial Number: 6PZ 010 287-27
----------------------------------------------------------------- Address 42: Door Elect, Driver (J386)	Labels: None 	Part No SW: 4H0 959 793 R	HW: 4H0 959 793 G 	Component: TSG FA H06 0263 	Revision: -------- 	Coding: 011F1F005E0062C202003017 	Shop #: WSC 02312 785 00200 	VCID: 48D3CB236A496B6D44C287-801D
----------------------------------------------------------------- Address 46: Central Conv. (J393)	Labels: 4H0-907-064-46.clb 	Part No SW: 4H0 907 064 DD	HW: 4H0 907 064 CD 	Component: BCM2 2.0 H33 0510 	Revision: 00002001 	Coding: 0106023A00FA7585B0B0C7C0020301000000000000000000000000000000 	Shop #: WSC 02313 785 00200 	VCID: 6E9F5DBB286D955D2E5E21-803B 	Subsystem 1 - 	Part No SW: 4H0-959-719 	Component: GTO BF H01 0080 	Subsystem 2 - 	Part No SW: 1K0-951-605-C 	Component: LIN BACKUP HOH05 1501 	Subsystem 3 - 	Part No SW: 4H0-959-591 	Component: J245 PS50.030H07 0006 	Coding: 101F00 	Subsystem 4 - 	Part No SW: 4H0-947-135-BK 	Component: DachelektroniH11 0080 	Coding: 010000 	Subsystem 5 - 	Part No SW: 4H0-959-591-A 	Component: V252 PS010 H05 0005 	Subsystem 6 - 	Part No SW: 3AA-962-243 	Component: GEB.F.HeckoefH12 0719
----------------------------------------------------------------- Address 47: Sound System (J525)	Labels: None 	Part No SW: 4H1 035 465	HW: 4H1 035 465 	Component: BO G3 D4 ANC H03 0130 	Revision: 09S00000 	Coding: 020101 	Shop #: WSC 02311 785 00200 	VCID: E48BBF9376A1AF0DC8FA53-80B1 1 Fault Found: 03405 - Bass Loudspeaker 	011 - Open Circuit
 ----------------------------------------------------------------- Address 52: Door Elect, Pass. (J387)	Labels: None 	Part No SW: 4H0 959 792 G	HW: 4H0 959 792 G 	Component: TSG BF H06 0261 	Revision: -------- 	Coding: 011F1F005E0062C202003007 	Shop #: WSC 02312 785 00200 	VCID: 3C3BA7F32E9137CDD04A0B-8069
----------------------------------------------------------------- Address 53: Parking Brake (----)	Labels: 4H0-907-801.clb 	Part No SW: 4H0 907 801 F	HW: 4H0 907 801 A 	Component: EPB-4 H03 0013 	Revision: -------- 	Shop #: WSC 00000 000 	ASAM Dataset: EV_ParkiBrake 001027 	ROD: EV_ParkiBrake_AU64.rod 	VCID: 2B1994AFDBFFB87549A040-807E
----------------------------------------------------------------- Address 56: Radio (R)	Labels: None 	Part No SW: 4H0 035 082 E	HW: 4H0 035 082 	Component: Radio U SIRIU H60 0121 	Revision: AB001007 	Coding: 020007010003000001 	Shop #: WSC 02391 785 00200 	VCID: 23097C8FB32F6835F17018-8076
----------------------------------------------------------------- Address 5F: Information Electr. (J794)	Labels: 4E0-035-6xx-5F.clb 	Part No SW: 4H0 035 746 E	HW: 4H0 035 746 C 	Component: H-BNT-NA H50 0622 	Revision: -------- 	Coding: 030200000201F9EF7D168B1E00000003140001000000000000 	Shop #: WSC 02391 785 00200 	VCID: 2A1791ABD405B97DB2B64D-807F 	Subsystem 1 - 	Part No SW: 8R0-060-884-BA 	Component: NAR 2013 0703 	Subsystem 2 - 	Part No SW: 4H0-919-604-F 	Component: DU8 D4 SV NB H47 0021 	Subsystem 3 - 	Part No SW: 4H1-919-600-H 	Component: E380 BDT D4 H09 0065 	Subsystem 4 - 	Part No SW: 8R0-060-961-E 	Component: CD-Database 4949
----------------------------------------------------------------- Address 62: Door, Rear Left (J388)	Labels: None 	Part No SW: 4H0 959 795 D	HW: 4H0 959 795 D 	Component: TSG HL H06 0262 	Revision: -------- 	Coding: 010F1F00400062C202003007 	Shop #: WSC 02312 785 00200 	VCID: 3C3BA7F32E9137CDD04A0B-8069
----------------------------------------------------------------- Address 6C: Back-up Cam. (J928)	Labels: None 	Part No SW: 4H0 907 428 A	HW: 7P6 907 441 D 	Component: TopView H05 0111 	Revision: 11001001 	Coding: 0209000101010000000102000000 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_CamerSysteTopViewAUDI 005022 	ROD: EV_CamerSysteTopViewAUDI_005.rod 	VCID: 2B1994AFDBFFB87549A040-807E
----------------------------------------------------------------- Address 6D: Trunk Elect. (----)	Labels: None 	Part No SW: 4H0 959 107 R	HW: 4H0 959 107 M 	Component: HDSG-Modul H11 0039 	Revision: 10011001 	Coding: 0210044100 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_DeckLidContrUnit 001025 	ROD: EV_DeckLidContrUnit.rod 	VCID: 3D3DAAF7358B26C5E7743E-8068 1 Fault Found: 0051 - Hall Sensors in Motor 1 for Rear Lid 	B1211 12 [008] - Short to Plus 	Intermittent - Confirmed - Tested Since Memory Clear
----------------------------------------------------------------- Address 6F: Centr. Conv. II (J773)	Labels: None 	Part No SW: 4H0 907 412	HW: 4H0 907 412 	Component: ALM H05 0004 	Revision: -------- 	Coding: 000000 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_Ambie 001008 	ROD: EV_Ambie.rod 	VCID: E389BC8F73AFB03531F058-80B6
----------------------------------------------------------------- Address 72: Door, Rear Right (J389)	Labels: None 	Part No SW: 4H0 959 795 D	HW: 4H0 959 795 D 	Component: TSG HR H06 0262 	Revision: -------- 	Coding: 010F1F00400062C202003007 	Shop #: WSC 02312 785 00200 	VCID: 3C3BA7F32E9137CDD04A0B-8069
----------------------------------------------------------------- Address 7F: Inform. Electr. II (J829)	Labels: None 	Part No SW: 4H0 035 774 F	HW: 4H0 035 774 D 	Component: H-BN-NA H50 0623 	Revision: -------- 	Coding: 03020000020100400100000400001300000000000000000000 	Shop #: WSC 02391 785 00200 	VCID: 2C1B97B3DEF1A74D40AA7B-8079 	Subsystem 1 - 	Part No SW: 4H0-919-607 	Component: DU10 RSE H41 0021 	Subsystem 2 - 	Part No SW: 4H0-919-607 	Component: DU10 RSE H41 0021 	Subsystem 3 - 	Part No SW: 4H0-919-709 	Component: E499 BDT 2 H07 0017 	Subsystem 4 - 	Part No SW: 8R0-060-961-E 	Component: CD-Database 4949 	Subsystem 5 - 	Part No SW: 8R0-060-884-BA 	Component: NAR 2013 0703 1 Fault Found: 00658 - Control Head 	012 - Electrical Fault in Circuit
----------------------------------------------------------------- Address 81: Gear Shift (J587)	Labels: 3Y0-927-731.clb 	Part No SW: 4H1 927 731 A	HW: 4H1 927 731 A 	Component: GSM-LL H08 0083 	Revision: 0L0D5014 	Shop #: WSC 00000 000 	ASAM Dataset: EV_GSM2x3Mono 001017 	ROD: EV_GSM2x3Mono.rod 	VCID: 2B1994AFDBFFB87549A040-807E
----------------------------------------------------------------- Address 84: Night Vision (J853)	Labels: 4H0-907-547.clb 	Part No SW: 4H0 907 547 F	HW: 4H0 907 547 	Component: NV-ECU-Gen1 H09 0042 	Coding: 1100 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_NightVisioGen1 001002 	ROD: EV_NightVisioGen1.rod 	VCID: 322789CBFCD5E9BD0AE6B5-8067
----------------------------------------------------------------- Address 85: On Board Cam. (J852)	Labels: None 	Part No SW: 4G0 907 217 A	HW: 4H0 907 217 A 	Component: DPC-SG H25 0038 	Revision: -------- 	Coding: E9060000 	Shop #: WSC 02313 785 00200 	ASAM Dataset: EV_OnBoardCamerDPC 001007 	ROD: EV_OnBoardCamerDPC.rod 	VCID: 260F659BC01D851D966E39-8073 1 Fault Found: 0001 - Front Heater for Lane-Holding Assist 	C1101 15 [008] - Open or Short to Plus 	Intermittent - Confirmed - Tested Since Memory Clear
----------------------------------------------------------------- Address 88: Multicont. Seat Driver (J873)	Labels: None 	Part No SW: 4H0 907 182 H	HW: 4H0 907 182 H 	Component: IVB H07 0042 	Coding: 764FF2 	Shop #: WSC 02313 785 00200 	ASAM Dataset: EV_IVBDriveSideFrnt 001003 	ROD: EV_IVBDriveSideFrnt.rod 	VCID: 2F2180BFEFE7C45565C894-807A
----------------------------------------------------------------- Address 89: Multicont. Seat Pass. (J872)	Labels: None 	Part No SW: 4H0 907 182 H	HW: 4H0 907 182 H 	Component: IVB H07 0042 	Coding: 364FF2 	Shop #: WSC 02313 785 00200 	ASAM Dataset: EV_IVBPasseSideFrnt 001003 	ROD: EV_IVBPasseSideFrnt.rod 	VCID: 2F2180BFEFE7C45565C894-807A
----------------------------------------------------------------- Address 8B: Adaptive Cruise 2 (J428)	Labels: 4H0-907-561.clb 	Part No SW: 4H0 907 541 B	HW: 4H0 907 541 	Component: ACC3 H17 0400 	Coding: 7601010101 	Shop #: WSC 02313 785 00200 	ASAM Dataset: EV_AdaptCruisContr2AU64X 002018 	ROD: EV_AdaptCruisContr2AU64X.rod 	VCID: 28136BA3CA09936DA48227-807D
----------------------------------------------------------------- Address 8E: Image Processing (J851)	Labels: 4G0-907-107.clb 	Part No SW: 4G0 907 107 E	HW: 4H0 907 107 	Component: BV-SG H31 0041 	Coding: 01A19A030111 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_BC7 001001 	ROD: EV_BC7.rod 	VCID: 28136BA3CA09936DA48227-807D
----------------------------------------------------------------- Address 8F: Pretension. Front Left (J854)	Labels: 4H0-980-94x-RGS.clb 	Part No SW: 4H0 980 945 B	HW: 4H0 980 945 C 	Component: RGS-VL H13 0080 	Coding: 0066F609031F0376070308014240C0010000 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_RGS_L 002004 	ROD: EV_RGS_L.rod 	VCID: 312586C7F9D3D2A573FC82-8064
----------------------------------------------------------------- Address 90: Pretension. Front Right (J855)	Labels: 4H0-980-94x-RGS.clb 	Part No SW: 4H0 980 946 B	HW: 4H0 980 946 C 	Component: RGS-VR H13 0080 	Coding: 0066F609031F0376070308014240C0010000 	Shop #: WSC 02391 785 00200 	ASAM Dataset: EV_RGS_R 002004 	ROD: EV_RGS_R.rod 	VCID: 322789CBFCD5E9BD0AE6B5-8067
----------------------------------------------------------------- Address A9: Struct. Borne Sound (J869)	Labels: 4H0-907-159.clb 	Part No SW: 4H0 907 159 A	HW: 4H0 907 159 A 	Component: SAS-GEN 2 H06 0003 	Shop #: WSC 00000 000 	ASAM Dataset: EV_SoundActuaGen2AU64X 003010 	ROD: EV_SoundActuaGen2AU64X.rod 	VCID: 2C1B97B3DEF1BF4D40AA7B-8079
----------------------------------------------------------------- Address BA: Motor Mounts (J931)	Labels: 4H0-907-145.clb 	Part No SW: 4H0 907 145 B	HW: 4H0 907 145 	Component: AEM - LEAR H05 0008 	Revision: 00001001 	Shop #: WSC 00000 000 	ASAM Dataset: EV_AEMLearAU64X 002016 	ROD: EV_AEMLearAU64X.rod 	VCID: 28136BA3CA09936DA48227-807D
End--(Elapsed Time: 05:09, VBatt start/end: 12.0/12.0 Vign: 0.0)-
Vettetruck89
Georgia, USA
Okay. I figured out how to start a log using VCDS Mobile. I went to the engine controller and selected functions/advanced measuring blocks. It displayed a list of functions to monitor and had a start log, stop log button.
I need to know what functions I should record and if there is a way to save the list of monitored functions so I dont have to spend 5 minutes setting everything up just to start my car. Also I have been interfacing with the hexnet in infrastructure mode because I am in my garage with WiFi access. Will I still be able to accomplish the above in access point which will be required everytime I start the car elsewhere?
Shaun
You can view the values you want and then make a bookmark of the measuring values page and reload it the next time you have a session open. You will need to click to start logging.
Yes, as long as you have the rod files downloaded already, which it looks like you do.
I would start with:
IDE00186 -- Fuel low pressure: actual value
IDE00188 -- Fuel high pressure: actual value
IDE00201 -- High fuel pressure: specified value
IDE00202 -- Low fuel pressure: specified value
You may also want to look at what happens to the fuel pressure after engine shut-down:
Note that your ECU uses the UDS protocol, which is discussed starting at about 3:00 in.
Vettetruck89
Georgia, USA
This data is monitoring high and low pressure fuel pressure during a failed start attempt today. The car also failed to start on second attempt but started on the third.
Sat,Sep,28,2019,12:21:56-VCID:322789CBFCD5E9BD0AE6B5-8067,VCDS Mobile: 0.4508 4H0 907 557 E,ADVMB,4.0l V8TFSI / H61 0004, ,,G592,F0,G375,F0,G575,F0,G241,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0, Marker,TIME,Loc. IDE00186,TIME,Loc. IDE00188,TIME,Loc. IDE00201,TIME,Loc. IDE00202,,,,,,,,,,,,,,,,, ,STAMP,,STAMP,,STAMP,,STAMP,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,, ,0.19,687.3,0.39,9.0960,0.60,4.9920,0.00,600.0,,,,,,,,,,,,,,,,, ,1.01,686.3,1.21,9.1005,1.42,4.9920,0.80,600.0,,,,,,,,,,,,,,,,, ,1.83,686.3,2.03,9.7595,2.24,4.9920,1.62,600.0,,,,,,,,,,,,,,,,, ,2.65,750.8,2.85,7.8905,3.06,4.9905,2.44,600.0,,,,,,,,,,,,,,,,, ,3.47,749.1,3.67,6.5765,3.88,6.5770,3.26,600.0,,,,,,,,,,,,,,,,, ,4.29,703.0,4.49,6.5860,4.70,6.6010,4.08,600.0,,,,,,,,,,,,,,,,, ,5.11,698.3,5.31,6.6120,5.52,6.6105,4.90,600.0,,,,,,,,,,,,,,,,, ,5.93,697.1,6.13,6.6120,6.34,6.6135,5.72,600.0,,,,,,,,,,,,,,,,, ,6.75,695.9,6.95,6.6315,7.16,6.6270,6.54,600.0,,,,,,,,,,,,,,,,, ,7.57,695.9,7.77,6.6300,7.98,6.6315,7.36,600.0,,,,,,,,,,,,,,,,, ,8.39,694.7,8.59,6.6380,8.80,6.6380,8.18,600.0,,,,,,,,,,,,,,,,, ,9.21,694.7,9.41,6.6425,9.62,6.6545,9.00,600.0,,,,,,,,,,,,,,,,, ,10.03,694.7,10.23,6.6560,10.44,6.6590,9.82,600.0,,,,,,,,,,,,,,,,, ,10.85,694.7,11.05,6.6590,11.26,6.6670,10.64,600.0,,,,,,,,,,,,,,,,, ,11.67,693.5,11.87,6.6700,12.08,6.6745,11.46,600.0,,,,,,,,,,,,,,,,, ,12.49,693.5,12.69,6.6835,12.90,6.6745,12.28,600.0,,,,,,,,,,,,,,,,, ,13.31,693.5,13.51,6.6835,13.72,6.6745,13.10,600.0,,,,,,,,,,,,,,,,, ,14.13,693.5,14.33,6.6835,14.54,6.6745,13.92,600.0,,,,,,,,,,,,,,,,, ,14.95,693.5,15.15,6.6835,15.36,6.6745,14.74,600.0,,,,,,,,,,,,,,,,, ,15.77,693.5,15.97,6.7080,16.18,6.6745,15.56,600.0,,,,,,,,,,,,,,,,, ,16.59,693.5,16.79,6.7080,17.00,6.6745,16.38,600.0,,,,,,,,,,,,,,,,, ,17.41,693.5,17.61,6.7080,17.82,6.6745,17.20,600.0,,,,,,,,,,,,,,,,, ,18.23,693.5,18.43,6.7080,18.64,6.6745,18.02,600.0,,,,,,,,,,,,,,,,, ,19.05,693.5,19.25,6.7080,19.46,6.6745,18.84,600.0,,,,,,,,,,,,,,,,, ,19.87,693.5,20.07,6.7080,20.28,6.6745,19.66,600.0,,,,,,,,,,,,,,,,, ,20.69,693.5,20.89,6.7080,21.10,6.6745,20.48,600.0,,,,,,,,,,,,,,,,, ,21.51,691.8,21.71,7.2315,21.92,4.9920,21.30,600.0,,,,,,,,,,,,,,,,, ,22.33,749.2,22.53,5.9830,22.74,4.9920,22.12,600.0,,,,,,,,,,,,,,,,, ,23.15,753.2,23.35,5.5865,23.56,4.9920,22.94,600.0,,,,,,,,,,,,,,,,, ,23.97,700.1,24.17,5.6050,24.38,4.9920,23.76,600.0,,,,,,,,,,,,,,,,, ,24.79,698.3,24.99,5.6200,25.20,4.9920,24.58,600.0,,,,,,,,,,,,,,,,, ,25.61,697.1,25.81,5.6305,26.02,4.9920,25.40,600.0,,,,,,,,,,,,,,,,, ,26.43,695.9,26.63,5.6340,26.84,4.9920,26.22,600.0,,,,,,,,,,,,,,,,, ,27.25,695.9,27.45,5.6400,27.66,4.9920,27.04,600.0,,,,,,,,,,,,,,,,, ,28.07,695.9,28.27,5.6415,28.48,4.9920,27.86,600.0,,,,,,,,,,,,,,,,, ,28.89,695.4,29.09,5.6550,29.30,4.9920,28.68,600.0,,,,,,,,,,,,,,,,, ,29.71,694.7,29.91,5.6550,30.12,4.9920,29.50,600.0,,,,,,,,,,,,,,,,, ,30.53,694.7,30.73,5.6610,30.94,4.9920,30.32,600.0,,,,,,,,,,,,,,,,, ,31.35,694.7,31.55,5.6645,31.76,4.9920,31.14,600.0,,,,,,,,,,,,,,,,, ,32.17,694.7,32.37,5.6580,32.58,4.9920,31.96,600.0,,,,,,,,,,,,,,,,, ,32.99,694.7,33.19,5.6825,33.40,4.9920,32.78,600.0,,,,,,,,,,,,,,,,, ,33.81,694.7,34.01,5.6825,34.22,4.9920,33.60,600.0,,,,,,,,,,,,,,,,, ,34.63,694.7,34.83,5.6825,35.04,4.9920,34.42,600.0,,,,,,,,,,,,,,,,, ,35.45,694.7,35.65,5.6825,35.86,4.9920,35.24,600.0,,,,,,,,,,,,,,,,, ,36.27,694.7,36.47,5.6825,36.68,4.9920,36.06,600.0,,,,,,,,,,,,,,,,, ,37.09,694.7,37.29,5.6825,37.50,4.9920,36.88,600.0,,,,,,,,,,,,,,,,, ,38.11,681.3,38.31,7.5400,38.52,4.9920,37.90,600.0,,,,,,,,,,,,,,,,, ,38.93,753.5,39.13,6.2400,39.34,4.9920,38.72,600.0,,,,,,,,,,,,,,,,, ,39.75,759.7,39.95,5.5490,40.16,4.9920,39.54,600.0,,,,,,,,,,,,,,,,, ,40.58,749.3,40.78,5.2925,40.98,4.9920,40.36,600.0,,,,,,,,,,,,,,,,, ,41.39,758.1,41.59,5.1460,41.80,4.9920,41.18,600.0,,,,,,,,,,,,,,,,, ,42.21,749.5,42.41,4.8765,42.62,4.9805,42.00,600.0,,,,,,,,,,,,,,,,, ,43.03,749.5,43.23,4.9920,43.44,4.9305,42.82,600.0,,,,,,,,,,,,,,,,, ,43.85,750.2,44.06,4.9290,44.26,4.8670,43.65,600.0,,,,,,,,,,,,,,,,, ,44.67,719.7,44.88,4.7830,45.08,4.7785,44.47,600.0,,,,,,,,,,,,,,,,, ,45.49,673.4,45.69,4.7310,45.90,4.6875,45.28,600.0,,,,,,,,,,,,,,,,, ,46.31,635.0,46.51,4.6205,46.72,4.5795,46.10,600.0,,,,,,,,,,,,,,,,, ,47.13,595.7,47.33,4.4745,47.54,4.4640,46.92,600.0,,,,,,,,,,,,,,,,, ,47.96,559.0,48.15,4.3625,48.37,4.3465,47.74,600.0,,,,,,,,,,,,,,,,, ,48.78,519.5,48.97,4.2470,49.19,4.2325,48.56,600.0,,,,,,,,,,,,,,,,, ,49.60,503.2,49.79,4.1825,50.01,4.1180,49.38,600.0,,,,,,,,,,,,,,,,, ,50.42,512.3,50.62,4.0370,50.83,4.0050,50.21,600.0,,,,,,,,,,,,,,,,, ,51.24,529.7,51.44,3.9580,51.65,3.8920,51.03,600.0,,,,,,,,,,,,,,,,, ,52.06,551.0,52.26,3.7760,52.47,3.7825,51.85,600.0,,,,,,,,,,,,,,,,, ,52.88,564.3,53.08,3.7360,53.28,3.6785,52.67,600.0,,,,,,,,,,,,,,,,, ,53.70,574.3,53.90,3.6085,54.10,3.4705,53.49,600.0,,,,,,,,,,,,,,,,, ,54.51,583.9,54.72,2.9550,54.92,2.3605,54.31,600.0,,,,,,,,,,,,,,,,, ,55.34,592.7,55.54,2.0540,55.74,1.8760,55.13,600.0,,,,,,,,,,,,,,,,, ,56.15,595.3,56.35,1.6380,56.56,1.6640,55.94,600.0,,,,,,,,,,,,,,,,,
Vettetruck89
Georgia, USA
This data is from the fuel pressure test post shutdown after the car was up to temperature.
Sat,Sep,28,2019,14:25:40-VCID:322789CBFCD5E9BD0AE6B5-8067,VCDS Mobile: 0.4508 4H0 907 557 E,ADVMB,4.0l V8TFSI / H61 0004, ,,G411,F0,G592,F0,G375,F0,G575,F0,G241,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0, Marker,TIME,Loc. IDE00025,TIME,Loc. IDE00186,TIME,Loc. IDE00188,TIME,Loc. IDE00201,TIME,Loc. IDE00202,,,,,,,,,,,,,,, ,STAMP,Coolant temperature,STAMP,Fuel low pressure: actual value,STAMP,Fuel high pressure: actual value,STAMP,High fuel pressure: specified value,STAMP,Low fuel pressure: specified value,,,,,,,,,,,,,,, ,,,,kPa,,MPa,,MPa,,kPa,,,,,,,,,,,,,,, ,0.00,98°C,0.00,613.2,0.00,2.5655,0.00,4.9920,0.00,600.0,,,,,,,,,,,,,,, ,0.43,98°C,0.66,613.3,0.85,2.5840,1.06,4.9920,0.24,600.0,,,,,,,,,,,,,,, ,1.46,98°C,1.67,613.4,1.88,2.5975,2.09,4.9920,1.27,600.0,,,,,,,,,,,,,,, ,2.48,98°C,2.71,613.4,2.90,2.6190,3.11,4.9920,2.29,600.0,,,,,,,,,,,,,,, ,3.51,99°C,3.72,613.4,3.93,2.6415,4.13,4.9920,3.31,600.0,,,,,,,,,,,,,,, ,4.53,99°C,4.76,613.4,4.95,2.6510,5.16,4.9920,4.34,600.0,,,,,,,,,,,,,,, ,5.56,99°C,5.77,613.4,5.98,2.6570,6.18,4.9920,5.37,600.0,,,,,,,,,,,,,,, ,6.58,99°C,6.81,613.4,7.00,2.6675,7.21,4.9920,6.39,600.0,,,,,,,,,,,,,,, ,7.61,99°C,7.82,613.4,8.03,2.7075,8.23,4.9920,7.41,600.0,,,,,,,,,,,,,,, ,8.63,99°C,8.86,613.4,9.05,2.7075,9.26,4.9920,8.44,600.0,,,,,,,,,,,,,,, ,9.66,99°C,9.87,613.4,10.08,2.7365,10.28,4.9920,9.46,600.0,,,,,,,,,,,,,,, ,10.68,99°C,10.91,613.4,11.10,2.7530,11.31,4.9920,10.49,600.0,,,,,,,,,,,,,,, ,11.71,99°C,11.92,613.5,12.13,2.7530,12.33,4.9920,11.51,600.0,,,,,,,,,,,,,,, ,12.73,99°C,12.96,614.2,13.15,2.7730,13.36,4.9920,12.54,600.0,,,,,,,,,,,,,,, ,13.76,99°C,13.97,614.5,14.18,2.7945,14.38,4.9920,13.56,600.0,,,,,,,,,,,,,,, ,14.78,99°C,15.01,614.6,15.20,2.8035,15.41,4.9920,14.59,600.0,,,,,,,,,,,,,,, ,15.81,99°C,16.02,614.6,16.23,2.8280,16.43,4.9920,15.61,600.0,,,,,,,,,,,,,,, ,16.83,99°C,17.06,614.6,17.25,2.8370,17.46,4.9920,16.64,600.0,,,,,,,,,,,,,,, ,17.86,99°C,18.07,614.6,18.28,2.8505,18.48,4.9920,17.67,600.0,,,,,,,,,,,,,,, ,18.88,99°C,19.11,614.6,19.30,2.8615,19.51,4.9920,18.69,600.0,,,,,,,,,,,,,,, ,19.91,99°C,20.12,614.6,20.33,2.8750,20.53,4.9920,19.71,600.0,,,,,,,,,,,,,,, ,20.93,99°C,21.16,614.6,21.35,2.8920,21.56,4.9920,20.74,600.0,,,,,,,,,,,,,,, ,21.96,99°C,22.17,614.6,22.38,2.9070,22.58,4.9920,21.77,600.0,,,,,,,,,,,,,,, ,22.98,99°C,23.21,614.6,23.40,2.9255,23.61,4.9920,22.79,600.0,,,,,,,,,,,,,,, ,24.01,99°C,24.22,614.6,24.43,2.9455,24.63,4.9920,23.81,600.0,,,,,,,,,,,,,,, ,25.03,99°C,25.26,614.6,25.45,2.9500,25.66,4.9920,24.84,600.0,,,,,,,,,,,,,,, ,26.06,99°C,26.27,614.7,26.48,2.9695,26.68,4.9920,25.86,600.0,,,,,,,,,,,,,,, ,27.08,99°C,27.31,615.5,27.50,2.9850,27.71,4.9920,26.89,600.0,,,,,,,,,,,,,,, ,28.11,99°C,28.32,615.7,28.53,3.0005,28.73,4.9920,27.91,600.0,,,,,,,,,,,,,,, ,29.13,99°C,29.36,615.7,29.55,3.0125,29.76,4.9920,28.94,600.0,,,,,,,,,,,,,,, ,30.16,99°C,30.37,615.8,30.58,3.0325,30.78,4.9920,29.96,600.0,,,,,,,,,,,,,,, ,31.18,99°C,31.41,615.8,31.60,3.0460,31.81,4.9920,30.99,600.0,,,,,,,,,,,,,,, ,32.21,99°C,32.42,615.8,32.63,3.0490,32.83,4.9920,32.01,600.0,,,,,,,,,,,,,,, ,33.23,99°C,33.46,615.8,33.65,3.0765,33.86,4.9920,33.04,600.0,,,,,,,,,,,,,,, ,34.26,99°C,34.47,615.8,34.68,3.0920,34.88,4.9920,34.06,600.0,,,,,,,,,,,,,,, ,35.28,99°C,35.51,615.8,35.70,3.0980,35.91,4.9920,35.09,600.0,,,,,,,,,,,,,,, ,36.31,99°C,36.52,615.8,36.73,3.1195,36.93,4.9920,36.11,600.0,,,,,,,,,,,,,,, ,37.33,99°C,37.56,615.8,37.75,3.1300,37.96,4.9920,37.14,600.0,,,,,,,,,,,,,,, ,38.36,99°C,38.57,615.8,38.78,3.1435,38.98,4.9920,38.16,600.0,,,,,,,,,,,,,,, ,39.38,99°C,39.61,615.8,39.80,3.1545,40.01,4.9920,39.19,600.0,,,,,,,,,,,,,,, ,40.41,99°C,40.62,615.8,40.83,3.1710,41.03,4.9920,40.21,600.0,,,,,,,,,,,,,,, ,41.43,99°C,41.66,615.8,41.85,3.1925,42.06,4.9920,41.24,600.0,,,,,,,,,,,,,,, ,42.46,99°C,42.67,615.8,42.88,3.2095,43.08,4.9920,42.26,600.0,,,,,,,,,,,,,,, ,43.48,99°C,43.71,615.8,43.90,3.2185,44.11,4.9920,43.29,600.0,,,,,,,,,,,,,,, ,44.51,99°C,44.72,615.8,44.93,3.2385,45.13,4.9920,44.31,600.0,,,,,,,,,,,,,,, ,45.53,99°C,45.76,616.0,45.95,3.2415,46.16,4.9920,45.34,600.0,,,,,,,,,,,,,,, ,46.56,99°C,46.77,616.4,46.98,3.2565,47.18,4.9920,46.36,600.0,,,,,,,,,,,,,,, ,47.58,99°C,47.81,616.0,48.00,3.2735,48.21,4.9920,47.39,600.0,,,,,,,,,,,,,,, ,48.61,99°C,48.82,616.5,49.03,3.2900,49.23,4.9920,48.41,600.0,,,,,,,,,,,,,,, ,49.63,99°C,49.86,616.8,50.05,3.3115,50.26,4.9920,49.44,600.0,,,,,,,,,,,,,,, ,50.66,99°C,50.87,616.9,51.08,3.3205,51.28,4.9920,50.46,600.0,,,,,,,,,,,,,,, ,51.68,99°C,51.91,616.5,52.10,3.3360,52.31,4.9920,51.49,600.0,,,,,,,,,,,,,,, ,52.71,99°C,52.92,616.9,53.13,3.3405,53.33,4.9920,52.51,600.0,,,,,,,,,,,,,,, ,53.73,99°C,53.95,616.6,54.15,3.3590,54.36,4.9920,53.54,600.0,,,,,,,,,,,,,,, ,54.76,99°C,54.97,616.9,55.18,3.3650,55.38,4.9920,54.56,600.0,,,,,,,,,,,,,,, ,55.78,99°C,56.00,616.8,56.20,3.3835,56.41,4.9920,55.59,600.0,,,,,,,,,,,,,,, ,56.81,99°C,57.02,616.9,57.23,3.3910,57.43,4.9920,56.61,600.0,,,,,,,,,,,,,,, ,57.83,99°C,58.05,617.0,58.25,3.4090,58.46,4.9920,57.64,600.0,,,,,,,,,,,,,,, ,58.86,99°C,59.07,616.9,59.28,3.4185,59.48,4.9920,58.66,600.0,,,,,,,,,,,,,,, ,59.88,99°C,60.10,617.0,60.30,3.4365,60.51,4.9920,59.69,600.0,,,,,,,,,,,,,,, ,60.91,99°C,61.12,617.0,61.33,3.4490,61.53,4.9920,60.71,600.0,,,,,,,,,,,,,,, ,61.93,99°C,62.15,617.0,62.35,3.4640,62.56,4.9920,61.74,600.0,,,,,,,,,,,,,,, ,62.96,99°C,63.17,617.0,63.38,3.4735,63.58,4.9920,62.76,600.0,,,,,,,,,,,,,,, ,63.98,99°C,64.20,617.0,64.40,3.4885,64.61,4.9920,63.79,600.0,,,,,,,,,,,,,,, ,65.01,99°C,65.22,617.0,65.43,3.5025,65.63,4.9920,64.81,600.0,,,,,,,,,,,,,,, ,66.03,99°C,66.25,617.0,66.45,3.5100,66.66,4.9920,65.84,600.0,,,,,,,,,,,,,,, ,67.06,99°C,67.27,617.0,67.47,3.5250,67.68,4.9920,66.86,600.0,,,,,,,,,,,,,,, ,68.08,99°C,68.30,617.0,68.50,3.5360,68.71,4.9920,67.89,600.0,,,,,,,,,,,,,,, ,69.10,99°C,69.33,617.0,69.52,3.5555,69.73,4.9920,68.91,600.0,,,,,,,,,,,,,,, ,70.13,99°C,70.34,617.0,70.55,3.5710,70.76,4.9920,69.93,600.0,,,,,,,,,,,,,,, ,71.16,99°C,71.37,617.0,71.57,3.5860,71.78,4.9920,70.96,600.0,,,,,,,,,,,,,,, ,72.18,99°C,72.39,617.0,72.60,3.5985,72.81,4.9920,71.98,600.0,,,,,,,,,,,,,,, ,73.21,99°C,73.42,617.0,73.62,3.6045,73.83,4.9920,73.01,600.0,,,,,,,,,,,,,,, ,74.23,99°C,74.44,617.0,74.65,3.6245,74.85,4.9920,74.03,600.0,,,,,,,,,,,,,,, ,75.26,99°C,75.47,617.0,75.67,3.6320,75.88,4.9920,75.06,600.0,,,,,,,,,,,,,,, ,76.28,99°C,76.49,617.0,76.70,3.6520,76.90,4.9920,76.08,600.0,,,,,,,,,,,,,,, ,77.30,99°C,77.53,617.0,77.72,3.6565,77.93,4.9920,77.11,600.0,,,,,,,,,,,,,,, ,78.33,99°C,78.54,617.0,78.75,3.6715,78.95,4.9920,78.13,600.0,,,,,,,,,,,,,,, ,79.35,99°C,79.58,617.0,79.77,3.6810,79.98,4.9920,79.16,600.0,,,,,,,,,,,,,,, ,80.38,99°C,80.59,617.0,80.80,3.6960,81.00,4.9920,80.18,600.0,,,,,,,,,,,,,,, ,81.40,99°C,81.63,617.0,81.82,3.7085,82.03,4.9920,81.21,600.0,,,,,,,,,,,,,,, ,82.43,99°C,82.64,617.0,82.86,3.7160,83.05,4.9920,82.23,600.0,,,,,,,,,,,,,,, ,83.46,99°C,83.68,617.0,83.87,3.7295,84.08,4.9920,83.26,600.0,,,,,,,,,,,,,,, ,84.48,99°C,84.69,617.0,84.90,3.7405,85.10,4.9920,84.28,600.0,,,,,,,,,,,,,,, ,85.50,99°C,85.73,617.0,85.92,3.7600,86.13,4.9920,85.31,600.0,,,,,,,,,,,,,,, ,86.54,99°C,86.74,617.0,86.96,3.7755,87.15,4.9920,86.33,600.0,,,,,,,,,,,,,,, ,87.56,99°C,87.79,617.0,87.97,3.7800,88.18,4.9920,87.36,600.0,,,,,,,,,,,,,,, ,88.58,99°C,88.79,617.0,89.00,3.7985,89.21,4.9920,88.39,600.0,,,,,,,,,,,,,,, ,89.61,99°C,89.83,617.0,90.03,3.8030,90.24,4.9920,89.42,600.0,,,,,,,,,,,,,,, ,90.64,99°C,90.85,617.0,91.06,3.8225,91.26,4.9920,90.43,600.0,,,,,,,,,,,,,,, ,91.66,99°C,91.89,617.0,92.07,3.8440,92.29,4.9920,91.46,600.0,,,,,,,,,,,,,,, ,92.68,99°C,92.89,617.0,93.11,3.8550,93.31,4.9920,92.49,600.0,,,,,,,,,,,,,,, ,93.71,99°C,93.93,617.0,94.13,3.8730,94.33,4.9920,93.51,600.0,,,,,,,,,,,,,,, ,94.74,99°C,94.94,617.0,95.15,3.8775,95.36,4.9920,94.54,600.0,,,,,,,,,,,,,,, ,95.75,99°C,95.99,617.0,96.18,3.8885,96.39,4.9920,95.57,600.0,,,,,,,,,,,,,,, ,96.79,99°C,97.00,617.0,97.21,3.9020,97.40,4.9920,96.58,600.0,,,,,,,,,,,,,,, ,97.81,99°C,98.04,617.0,98.22,3.9065,98.43,4.9920,97.61,600.0,,,,,,,,,,,,,,, ,98.83,99°C,99.05,617.0,99.26,3.9250,99.46,4.9920,98.64,600.0,,,,,,,,,,,,,,, ,99.86,99°C,100.08,617.0,100.28,3.9310,100.49,4.9920,99.67,600.0,,,,,,,,,,,,,,, ,100.89,99°C,101.10,617.0,101.31,3.9495,101.51,4.9920,100.68,600.0,,,,,,,,,,,,,,, ,101.91,99°C,102.14,617.0,102.33,3.9660,102.54,4.9920,101.72,600.0,,,,,,,,,,,,,,, ,102.94,99°C,103.15,617.0,103.36,3.9740,103.56,4.9920,102.74,600.0,,,,,,,,,,,,,,, ,103.96,99°C,104.19,617.0,104.38,3.9800,104.59,4.9920,103.77,600.0,,,,,,,,,,,,,,, ,104.99,99°C,105.20,617.0,105.41,3.9980,105.61,4.9920,104.79,600.0,,,,,,,,,,,,,,, ,106.01,99°C,106.24,617.0,106.43,4.0060,106.64,4.9920,105.82,600.0,,,,,,,,,,,,,,, ,107.04,99°C,107.25,617.0,107.46,4.0180,107.66,4.9920,106.84,600.0,,,,,,,,,,,,,,, ,108.06,99°C,108.29,617.0,108.48,4.0335,108.69,4.9920,107.87,600.0,,,,,,,,,,,,,,, ,109.09,99°C,109.30,617.0,109.51,4.0440,109.71,4.9920,108.89,600.0,,,,,,,,,,,,,,, ,110.11,99°C,110.34,617.0,110.53,4.0530,110.74,4.9920,109.92,600.0,,,,,,,,,,,,,,, ,111.14,99°C,111.35,617.0,111.56,4.0715,111.76,4.9920,110.94,600.0,,,,,,,,,,,,,,, ,112.16,99°C,112.39,617.0,112.58,4.0745,112.79,4.9920,111.97,600.0,,,,,,,,,,,,,,, ,113.19,99°C,113.40,617.0,113.61,4.0915,113.81,4.9920,112.99,600.0,,,,,,,,,,,,,,, ,114.21,99°C,114.44,617.0,114.63,4.0960,114.84,4.9920,114.02,600.0,,,,,,,,,,,,,,, ,115.24,99°C,115.45,617.0,115.66,4.1125,115.86,4.9920,115.04,600.0,,,,,,,,,,,,,,, ,116.26,99°C,116.48,617.0,116.68,4.1220,116.89,4.9920,116.07,600.0,,,,,,,,,,,,,,, ,117.29,99°C,117.50,617.0,117.71,4.1400,117.91,4.9920,117.09,600.0,,,,,,,,,,,,,,, ,118.31,99°C,118.54,617.0,118.73,4.1445,118.94,4.9920,118.12,600.0,,,,,,,,,,,,,,, ,119.34,99°C,119.55,617.0,119.76,4.1525,119.96,4.9920,119.14,600.0,,,,,,,,,,,,,,, ,120.36,99°C,120.59,617.0,120.78,4.1690,120.99,4.9920,120.17,600.0,,,,,,,,,,,,,,, ,121.39,99°C,121.60,617.0,121.81,4.1800,122.01,4.9920,121.19,600.0,,,,,,,,,,,,,,, ,122.41,99°C,122.63,617.0,122.83,4.1935,123.04,4.9920,122.22,600.0,,,,,,,,,,,,,,, ,123.44,99°C,123.65,617.0,123.86,4.1965,124.06,4.9920,123.24,600.0,,,,,,,,,,,,,,, ,124.46,99°C,124.68,617.0,124.88,4.2150,125.09,4.9920,124.27,600.0,,,,,,,,,,,,,,, ,125.49,99°C,125.70,617.0,125.91,4.2210,126.11,4.9920,125.29,600.0,,,,,,,,,,,,,,, ,126.51,99°C,126.73,616.9,126.93,4.2210,127.14,4.9920,126.32,600.0,,,,,,,,,,,,,,, ,127.54,99°C,127.75,615.9,127.96,4.2440,128.16,4.9920,127.34,600.0,,,,,,,,,,,,,,, ,128.56,99°C,128.78,615.8,128.98,4.2635,129.19,4.9920,128.37,600.0,,,,,,,,,,,,,,, ,129.59,99°C,129.80,615.8,130.01,4.2665,130.21,4.9920,129.39,600.0,,,,,,,,,,,,,,, ,130.61,99°C,130.83,615.8,131.03,4.2730,131.24,4.9920,130.42,600.0,,,,,,,,,,,,,,, ,131.64,99°C,131.85,615.8,132.06,4.2790,132.26,4.9920,131.44,600.0,,,,,,,,,,,,,,, ,132.66,99°C,132.88,615.8,133.08,4.2910,133.29,4.9920,132.47,600.0,,,,,,,,,,,,,,, ,133.69,99°C,133.90,615.8,134.11,4.3080,134.31,4.9920,133.49,600.0,,,,,,,,,,,,,,, ,134.71,99°C,134.93,615.8,135.13,4.3155,135.34,4.9920,134.52,600.0,,,,,,,,,,,,,,, ,135.74,99°C,135.95,615.2,136.15,4.3280,136.36,4.9920,135.54,600.0,,,,,,,,,,,,,,, ,136.76,99°C,136.98,614.6,137.18,4.3400,137.38,4.9920,136.57,600.0,,,,,,,,,,,,,,, ,137.79,99°C,138.00,614.6,138.20,4.3505,138.41,4.9920,137.59,600.0,,,,,,,,,,,,,,, ,138.81,99°C,139.03,614.6,139.23,4.3570,139.43,4.9920,138.61,600.0,,,,,,,,,,,,,,, ,139.83,99°C,140.06,614.6,140.25,4.3645,140.46,4.9920,139.64,600.0,,,,,,,,,,,,,,, ,140.86,99°C,141.07,614.6,141.28,4.3890,141.48,4.9920,140.66,600.0,,,,,,,,,,,,,,, ,141.88,99°C,142.11,614.6,142.30,4.3890,142.51,4.9920,141.69,600.0,,,,,,,,,,,,,,, ,142.91,99°C,143.12,614.6,143.33,4.4040,143.53,4.9920,142.71,600.0,,,,,,,,,,,,,,,
Whatever intermediate software you are using is stripping newlines from the text files. That makes them very difficult to read or interpret.
Vettetruck89
Georgia, USA
I am opening the log files in vcds mobile and selecting all the text an then pasting it into the message area in the forum post.
I am all ears if there is a better method. Perhaps it would work better if I powered up the hexnet with my laptop and accessed the log files using the non mobile program?
Sounds like an issue with bowser (or "browser view" used by the mobile app).
You can't access the files using the non-mobile program, but you can certainly point a browser on your computer at the HEX-NET, or you can just upload the files to your cloud account and then access 'em that way.
Vettetruck89
Georgia, USA
Okay. I think we might be barking up the wrong tree anyway. I looked at the data for the fuel pressure test and it steadily increases as time goes by starting at 613.2 and 2.5655 at the start of the test and ending at 614.6 and 4.4040 140 seconds into the test. The numbers seem reversed but I believe this might just be a difference is measuring units.
Vettetruck89
Georgia, USA
I made a rudimentary graph of fuel pressure over time from the first set of data logs while the car is failing to start. I don't see a smoking gun here. Note that the drop in pressure towards the end is after the car had started and was idling. I also noticed that the required pressure became variable during the time period. Perhaps based on engine load?
What should I look at next?
PetrolDave
Westbury, UK
C?ID=1423
That's a link to a file on your local hard drive - which isn't accessible by the internet.
You need to copy the file not a hosting service such as imgur and then post the direct link here.
Vettetruck89
Georgia, USA
This kinda died on the vine...I think the fuel pressure monitoring is a dead end. What else should I be logging. I have heard about faulty crank position sensors causing similar issues.
