TJA activation Skoda Kodiaq MY 2017
Dp41n8w
C?ID=372411
Hello. Is it possible to activate TJA in kodiaq where is retrofitted Lane assistant? Car came from factory without lane assistant but somebody retrofitted lane assistant to the car.
Dp41n8w
C?ID=372411
Friday,23,August,2019,09:18:40:19148
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
VIN: TMBLK7NS9J8018655   License Plate: KODIAQ
Mileage: 49975km-31053mi   Repair Order:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 22 2B 36 42 44 47
          4B 52 5F 69 6C 6D 75 A5 D6 D7
VIN: TMBLK7NS9J8018655   Mileage: 49975km-31053miles
Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 3916
   Revision: B4H25---
   Coding: 0125003A04761D083000
   Shop #: WSC 32912 056 526860
   ASAM Dataset: EV_ECM20TDI01104L906026EJ 004004
   ROD: EV_ECM20TDI01104L906026EJ_004.rod
   VCID: 76B5E6CF28439177E05-8022
   Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2014
   Revision: 00H06V07
   VCID: 33331FDB7BB1C45F07B-8066
   Revision: 00000000    Serial number: 61907000001657
   Coding: 60076A9F54210B74477D070562C84906562AD0E2E046927D38615078E20A4200002F641A1B13111435351919323200
   Shop #: WSC 33361 790 00157
   VCID: 77ABEBCB2F49E87FFB3-8022
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0448148907
   Coding: 032C0C070F
   VCID: 3E253EEF40F31937F85-806A
   Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58132798
          U1400 00 [008] - -
                    Reset counter: 207
                    Mileage: 49824 km
                    Date: 2019.08.22
                    Time: 14:15:47
                    ZAT_pressed: OFF
                    Control Module Voltage: 9.863 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 141.0 /min
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Keyminder_Scan
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QGI10410
   Coding: 0010000000000500018281818181000000008181000000D400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide.rod
   VCID: 3C2134E756EF0B27D61-8068
   Part No SW: 565 907 044 BK    HW: 565 907 044 BK
   Component: Climatronic   H04 2001
   Revision: 00001K00
   Coding: 16010104004411011105004D0010102A
   Shop #: WSC 33361 790 00119
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   VCID: 6597B18385E56AEF59F-8030
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 61071543
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 86580307170138
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0655960F58A381F7F05-8052
   Subsystem 1 - Part No SW: 566 955 119     HW: 566 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS326 170531  051 0907
   Serial number: 887353F0401715100717
   Coding: 164DDD
   Component: RLHS  042 0105
   Serial number: S8Y17M07D11H19M21S29
   Coding: 0088DF
204802 - Remote key 3
          B147B 18 [009] - Current Too Low
                    Reset counter: 161
                    Mileage: 49611 km
                    Date: 2019.08.19
                    Time: 18:45:35
   Part No SW: 3Q0 919 298 B    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0029
   Serial number: 002706177478000
   Coding: 0231163A51
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
13639168 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
                    Reset counter: 203
                    Mileage: 49570 km
                    Date: 2019.08.19
                    Time: 13:31:44
   Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H02 0233
   Coding: 320067CB50FF8728749C8145304087
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4PDWGVTD
   Coding: 98CCC0C0000000005C5400CF000840000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0557910365A58AEFF9F-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 002 506 17
   Serial number: 35700000000526A0E72I
   Subsystem 2 - Part No SW: -----------    HW: 454 002 106 17
   Serial number: 35800000000FC4F4172X
   Subsystem 3 - Part No SW: -----------    HW: 454 800 607 17
   Serial number: 35100F2C37810000000E
   Subsystem 4 - Part No SW: -----------    HW: 454 800 607 17
   Serial number: 3520017D178100000005
   Subsystem 5 - Part No SW: -----------    HW: 454 801 806 17
   Serial number: 35500F1CF2510000000L
   Part No SW: 5Q0 953 521 LA    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0245
   Revision: FF036036    Serial number: 20170715500926
   Coding: 6414
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA1F4E7166FCB27961-8028
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Fault Frequency: 42
                    Reset counter: 210
                    Mileage: 49588 km
                    Date: 2019.08.19
                    Time: 14:55:59
                    Ubat 30 Voltage: 12.40 V
                    Internal error state: 0
                    LIN_Temp: 0
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 251
                    Slope: 133
                    kp: 18
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 34.00 °C
                    p_t_soll_1: 39.00 °C
                    p_t_soll_2: 44.00 °C
   Part No SW: 565 920 751 A    HW: 565 920 751 A
   Component: KOMBI         302 0310
   Coding: 07A5001CEF84000801887B031001000800000000
   Shop #: WSC 00073 003 104857
   VCID: 196FCD73F91D1E0F2D7-804C
   Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
   Component: STH-MQB       008 0075
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   VCID: 3A2D32FF5CDB3517C4D-806E
   Component: R64 D208L  004 0401
   Serial number: 00000000000000280445
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 02071710522008
   Coding: 0B0100344F087300FB03225A1E0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewNF.rod
   Subsystem 2 - Part No SW: 3V0 919 719 C    HW: 3V0 919 719 C
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000D0632170617
   Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Serial number: 75886100001707070E16
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 H    HW: 5Q0 907 155 H
   Component: U13DCAC  H25 0780
   Serial number: 0020097
   Serial number: HA1-00009.05.17
   Coding: 0101
   VCID: 4ACD623F0C3BA59754D-801E
   Serial number: 17000166599018
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD5D3412DB64F357-8024
   Serial number: Y0006QGI20404
   Serial number: 0000267793616
   Coding: 00150920DE00040000001100
   VCID: 47CB5B0B1F2958FF4B3-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0007
   Serial number: 00000000000015395155
   Coding: 010200
   Revision: 00000000    Serial number: 0001820838
   Coding: 01010111004001
   ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
   VCID: 40D940173A076FC78A9-8014
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1HJE021WUR
   Coding: 0323160000AA002AAA0000000000
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 59EF8D73B99DDE0FED7-800C
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 05071710800889
   Coding: 000000070100037200002D01190000000000000000000000000000000000
   VCID: 72BDDADF442B8D57CCD-8026
   Serial number: 0000267642465
   Coding: 00150120DE00040000001100
   VCID: 46D5560F182341F7B05-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000015350906
   Coding: 190200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 864 C    HW: 5Q0 035 864 C
   Component: MU-S-N-ER     H41 0456
   Serial number: SKZAZ2T5286323
   Coding: 03231601000000005111000200080A232F0208E401208500CE
   ROD: EV_MUStd4CTSAT_VW41.rod
   Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SKZ6ZHT2053381
   Subsystem 2 - Part No SW: 5L0 051 236 AS    HW: -----------
   Component: ECE2 2019/20  --- 1115
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0448369384
   Coding: 0100000202000000
   Shop #: WSC 33361 790 00133
   VCID: 42DD4A1F340B7DD79CD-8016
   Coding: 04231601A700201F000040
   VCID: 392F2DF359DD3E0FCD7-806C
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31442243300000
   Coding: 1B88
   VCID: 41DF4513310D66CF857-8014
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0717
   Revision: --------
   Coding: 03231601EA421A0D3F5EBE020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 11071712P21712
   Coding: 020307060000040100261345C150A900D0000E200020
   Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
   Component: LED1L         H06 0005
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EA5FEEF0073D937B85-802A
   Component: LED1R         H06 0005
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 02:15, VBatt start/end: 12.1V/12.1V)-----------
What is TJA?
darkchina811
ITALY
C?ID=333184
Traffic Jam Assist. I think it's possible, you have auto trans and the correct A5 camera.
but TJA requires a new dataset to be flashed to A5, and VCDS cannot do that. I wish.
Dp41n8w
C?ID=372411
If I can update the A5 camera then it should work? Is there any adoption channels that would work? I saw some Audi Page that I have to change some byte bits but there was no byte that was on the site.
Dp41n8w
C?ID=372411
Or can someone tell me what should "turn on" to activate TJA?
Dp41n8w
C?ID=372411
Yes I understood 😊. Thanks PetrolDave!
siLc
Tallinn, Estonia
C?ID=330192
H index camera is suitable for TJA, if memory serves. The camera will need to be reparameterized but you'll need the "other" tool for this.
