- Nov 5, 2018
- 47
- 7
- Europe - Hungary
- C?ID=338434
I would like to set up when the driver gets out from the car the doors lock automaticly.
How can I do that?
How can I do that?
Wednesday,21,August,2019,17:10:22:64377
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Workshop Code: 790 73430 000063
VIN: TMBLK7NS4J8095739 License Plate: 7AA7786
Mileage: 38305km-23801mi Repair Order:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 42 44 47 4B 52
5F 6C 75 D6 D7
VIN: TMBLK7NS4J8095739 Mileage: 38305km-23801miles
Address 01: Engine (J623-DFHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 EJ HW: 04L 907 309 P
Component: R4 2.0l TDI H25 3916
Revision: B4H25---
Coding: 0125001204261D083000
Shop #: WSC 33361 790 00120
ASAM Dataset: EV_ECM20TDI01104L906026EJ 004004
ROD: EV_ECM20TDI01104L906026EJ_004.rod
VCID: 76B5E5A318488A27E05-8023
Part No SW: 0DL 300 012 N HW: 0GC 927 711 G
Component: GSG DQ500 H06 2112
Revision: 00H06V07
VCID: 34311FAB4EB4D8371E1-8061
Part No SW: 5Q0 614 517 CQ HW: 5Q0 614 517 AC
Component: ESC H25 0423
Revision: 00000000 Serial number: 61548000000846
Coding: 60076A9F54290B71477E070362CC4906562AD0E2E046927530615078C209420B002F641A1B13111435351919323200
ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
VCID: 025D89734480A687DCD-8057
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0481936536
Coding: 032C0C070F
VCID: 3E253D8370F80267F85-806B
Part No SW: 565 907 044 BG HW: 565 907 044 BG
Component: Climatronic H04 2002
Revision: 00001K00
Coding: 16010104002110011005000800101022
Shop #: WSC 33361 790 00111
ASAM Dataset: EV_ACClimaBHBVW37X 006147
VCID: 619FA6FFA1C61D9FA57-8035
Air quality sensor:
Subsystem 3 - Part No SW: 5Q0 907 659 C HW: 5Q0 907 659 C
Component: G238 _AQS H30 0119
Serial number: 78826813
Part No SW: 5Q0 937 086 BL HW: 5Q0 937 086 BG
Component: BCM PQ37BOSCH 034 0245
Revision: -------- Serial number: 8658060618009G
ROD: EV_BCMBOSCH_018.rod
VCID: 0557926F55AE91BFF9F-8051
Subsystem 1 - Part No SW: 566 955 119 HW: 566 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS326 180430 051 0910
Serial number: 887353F0401812001640
Coding: 164DDD
Component: RLHS 050 0107
Serial number: S5Y18M06D05H05M00S48
Coding: 00885D
Part No SW: 3Q0 919 294 B HW: 3Q0 919 294
Component: PDC 8 Kanal H08 0029
Serial number: 002304187478081
Coding: 0071551011
ASAM Dataset: EV_EPHBO18VW3260000 007018
ROD: EV_EPHBO18VW3260000_007.rod
VCID: 38292B9B52DC3C57329-806D
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 3200600110FF8728749C8145004087
196741 - Sensor for Automatic Distance Control
[FCTSEN_BLOCKAGE]
Reset counter: 91
Mileage: 37593 km
Date: 2019.08.08
Time: 14:49:09
Voltage terminal 15: 13.6 V
Control Module temperature: 35 °C
Velocity_vehicle_reference: 24.11 m/s
Longitudinal_acceleration_vehicle_reference: -0.38 m/s²
Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH
Component: Airbag VW21 006 0712
Revision: -------- Serial number: 003W4PAJ8LYR
Coding: 98CCC0C0000000005C5400CF000840000065
ROD: EV_AirbaVW21TS6VW48X.rod
Subsystem 1 - Part No SW: ----------- HW: 454 002 105 18
Serial number: 357000000009A129703D
Subsystem 2 - Part No SW: ----------- HW: 454 002 005 18
Serial number: 35800000000F79BC803
Subsystem 3 - Part No SW: ----------- HW: 454 802 305 18
Serial number: 35100A7D9C714000000T
Subsystem 4 - Part No SW: ----------- HW: 454 802 205 18
Serial number: 35200BFA2EF14000000$
Subsystem 5 - Part No SW: ----------- HW: 454 801 405 18
Serial number: 35500AA58A114000000J
Part No SW: 5Q0 953 521 ER HW: 5Q0 953 569 A
Revision: FF034034 Serial number: 20180608400482
Coding: 1414
ROD: EV_SMLSVALEOMQB.rod
VCID: 0655956368A89AA7F05-8053
Part No SW: 565 920 751 A HW: 565 920 751 A
Component: KOMBI 304 0312
Coding: 07A4001CAB80000801882A011001000800000000
Shop #: WSC 73430 031 00120
VCID: 196FCE1FC916055F2D7-804D
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 27051810800667
Coding: 0B0100045F087300EB00024A1C0F00010001070000000000000000000000
Shop #: WSC 33361 790 00136
ROD: EV_GatewNF.rod
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000A1351050618
Subsystem 3 - Part No SW: 5QA 915 181 C HW: 5QA 915 181 C
Serial number: 75886100001805310790
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 H HW: 5Q0 907 155 H
Component: U13DCAC H25 0780
Serial number: 5023488
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Ruhestrom oberer Grenzwert überschritten]
Fault Frequency: 13
Reset counter: 80
Mileage: 27532 km
Date: 2019.05.25
Time: 06:18:05
Supply voltage: Terminal 30: 12.5 V
Terminal 15: OFF
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7084
Serial number: HA1-00019.04.18
Coding: 0101
VCID: 4CC1674B3644A0F7661-8019
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000189339013
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_AU37.rod
VCID: 33331CB74BBADF0F07B-8067
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0024
Serial number: Y0006RDI18788
Coding: 0010000000000500018480818180000000008181000000D400
ASAM Dataset: EV_SeatMemorDriveSide 002022
VCID: 3D273A8F7DFE197FE1F-8069
Component: TSG FS 011 0032
Serial number: 0000325126222
Coding: 00150120DE00040000001100
VCID: 47CB58672F2243AF4B3-8013
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000021364968
Coding: 010200
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0002552659
Coding: 01000010004000
ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
VCID: 40D9437B0A0C74978A9-8015
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial number: SKZ8Z1JJE04RQP3
Coding: 0323160000AA002AAA0000000000
ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
ROD: EV_AMPMst16C4Gen2ALPI.rod
VCID: 59EF8E1F8996C55FED7-800D
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 04061810522571
Coding: 000000070100037200002D00190000000000000000000000000000000000
Shop #: WSC 33361 790 00083
VCID: 72BDD9B374209607CCD-8027
Component: TSG BFS 011 0032
Serial number: 0000307791833
VCID: 46D5556328285AA7B05-8013
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000021829788
Coding: 190200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 840 C HW: 5Q0 035 840 C
Component: MU-S--ER H41 0472
Serial number: SKZAZ2U0707685
Coding: 03231600000000004111000200080A002F0208E40120850002
ROD: EV_MUStd4CTSAT_VW41.rod
VCID: 2D070ACFAD9E89FF51F-8079
Subsystem 1 - Part No SW: 565 919 605 C HW: 565 919 605 C
Component: ABT_Std-2 H52 8130
Serial number: SKZ6ZHV1523344
Component: RVC Compact H12 0231
Coding: 04231601A2002017000040
VCID: 392F2E9F69D6255FCD7-806D
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0718
Revision: --------
Coding: 03231601EA161A0D3B1C9E020045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW25.rod
VCID: 3C21378B66E41077D61-8069
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 7EA5FD833078C267B85-802B
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 01:46, VBatt start/end: 12.5V/12.5V)-----------
