Kessy auto lock when the driver gets out from the car.
Amarton
Europe - Hungary
C?ID=338434
Hi,
I would like to set up when the driver gets out from the car the doors lock automaticly.
How can I do that?
Wednesday,21,August,2019,17:10:22:64377
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4
Workshop Code: 790 73430 000063
VIN: TMBLK7NS4J8095739   License Plate: 7AA7786
Mileage: 38305km-23801mi   Repair Order:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 42 44 47 4B 52
          5F 6C 75 D6 D7
VIN: TMBLK7NS4J8095739   Mileage: 38305km-23801miles
Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 3916
   Revision: B4H25---
   Coding: 0125001204261D083000
   Shop #: WSC 33361 790 00120
   ASAM Dataset: EV_ECM20TDI01104L906026EJ 004004
   ROD: EV_ECM20TDI01104L906026EJ_004.rod
   VCID: 76B5E5A318488A27E05-8023
   Part No SW: 0DL 300 012 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2112
   Revision: 00H06V07
   VCID: 34311FAB4EB4D8371E1-8061
   Part No SW: 5Q0 614 517 CQ    HW: 5Q0 614 517 AC
   Component: ESC           H25 0423
   Revision: 00000000    Serial number: 61548000000846
   Coding: 60076A9F54290B71477E070362CC4906562AD0E2E046927530615078C209420B002F641A1B13111435351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
   VCID: 025D89734480A687DCD-8057
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0481936536
   Coding: 032C0C070F
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 3E253D8370F80267F85-806B
   Part No SW: 565 907 044 BG    HW: 565 907 044 BG
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 16010104002110011005000800101022
   Shop #: WSC 33361 790 00111
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   VCID: 619FA6FFA1C61D9FA57-8035
   Air quality sensor:
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 78826813
   Part No SW: 5Q0 937 086 BL    HW: 5Q0 937 086 BG
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: 8658060618009G
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0557926F55AE91BFF9F-8051
   Subsystem 1 - Part No SW: 566 955 119     HW: 566 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS326 180430  051 0910
   Serial number: 887353F0401812001640
   Coding: 164DDD
   Component: RLHS  050 0107
   Serial number: S5Y18M06D05H05M00S48
   Coding: 00885D
   Part No SW: 3Q0 919 294 B    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H08 0029
   Serial number: 002304187478081
   Coding: 0071551011
   ASAM Dataset: EV_EPHBO18VW3260000 007018
   ROD: EV_EPHBO18VW3260000_007.rod
   VCID: 38292B9B52DC3C57329-806D
   Component: ACCCONTIMQB   H02 0233
   Coding: 3200600110FF8728749C8145004087
196741 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FCTSEN_BLOCKAGE]
                    Reset counter: 91
                    Mileage: 37593 km
                    Date: 2019.08.08
                    Time: 14:49:09
                    Voltage terminal 15: 13.6 V
                    Control Module temperature: 35 °C
                    Velocity_vehicle_reference: 24.11 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.38 m/s²
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W4PAJ8LYR
   Coding: 98CCC0C0000000005C5400CF000840000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   Subsystem 1 - Part No SW: -----------    HW: 454 002 105 18
   Serial number: 357000000009A129703D
   Subsystem 2 - Part No SW: -----------    HW: 454 002 005 18
   Serial number: 35800000000F79BC803
   Subsystem 3 - Part No SW: -----------    HW: 454 802 305 18
   Serial number: 35100A7D9C714000000T
   Subsystem 4 - Part No SW: -----------    HW: 454 802 205 18
   Serial number: 35200BFA2EF14000000$
   Subsystem 5 - Part No SW: -----------    HW: 454 801 405 18
   Serial number: 35500AA58A114000000J
   Part No SW: 5Q0 953 521 ER    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20180608400482
   Coding: 1414
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 0655956368A89AA7F05-8053
   Part No SW: 565 920 751 A    HW: 565 920 751 A
   Component: KOMBI         304 0312
   Coding: 07A4001CAB80000801882A011001000800000000
   Shop #: WSC 73430 031 00120
   VCID: 196FCE1FC916055F2D7-804D
   Component: GW MQB High   518 5323
   Serial number: 27051810800667
   Coding: 0B0100045F087300EB00024A1C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00136
   ROD: EV_GatewNF.rod
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Serial number: 000000000A1351050618
   Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Serial number: 75886100001805310790
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 H    HW: 5Q0 907 155 H
   Component: U13DCAC  H25 0780
   Serial number: 5023488
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 13
                    Reset counter: 80
                    Mileage: 27532 km
                    Date: 2019.05.25
                    Time: 06:18:05
                    Supply voltage: Terminal 30: 12.5 V
                    Terminal 15: OFF
   Serial number: HA1-00019.04.18
   Coding: 0101
   VCID: 4CC1674B3644A0F7661-8019
   Serial number: 18000189339013
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   VCID: 33331CB74BBADF0F07B-8067
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RDI18788
   Coding: 0010000000000500018480818180000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D273A8F7DFE197FE1F-8069
   Serial number: 0000325126222
   Coding: 00150120DE00040000001100
   VCID: 47CB58672F2243AF4B3-8013
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000021364968
   Coding: 010200
   Revision: 00000000    Serial number: 0002552659
   Coding: 01000010004000
   ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
   VCID: 40D9437B0A0C74978A9-8015
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1JJE04RQP3
   Coding: 0323160000AA002AAA0000000000
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 59EF8E1F8996C55FED7-800D
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 04061810522571
   Coding: 000000070100037200002D00190000000000000000000000000000000000
   Shop #: WSC 33361 790 00083
   VCID: 72BDD9B374209607CCD-8027
   Serial number: 0000307791833
   VCID: 46D5556328285AA7B05-8013
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000021829788
   Coding: 190200
   Part No SW: 5Q0 035 840 C    HW: 5Q0 035 840 C
   Component: MU-S--ER      H41 0472
   Serial number: SKZAZ2U0707685
   Coding: 03231600000000004111000200080A002F0208E40120850002
   ROD: EV_MUStd4CTSAT_VW41.rod
   VCID: 2D070ACFAD9E89FF51F-8079
   Subsystem 1 - Part No SW: 565 919 605 C    HW: 565 919 605 C
   Component: ABT_Std-2  H52 8130
   Serial number: SKZ6ZHV1523344
   Coding: 04231601A2002017000040
   VCID: 392F2E9F69D6255FCD7-806D
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0718
   Revision: --------
   Coding: 03231601EA161A0D3B1C9E020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3C21378B66E41077D61-8069
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EA5FD833078C267B85-802B
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 01:46, VBatt start/end: 12.5V/12.5V)-----------
I've never heard of that being an option.
Amarton
Europe - Hungary
C?ID=338434
TWs/VW
NW Florida
C?ID=369048
I like this tweak. I just wish It could be coded to delay a few seconds...any ideas?
TW
TWs/VW
NW Florida
C?ID=369048
Delaying Passive Exit Door Slam Lock activation - maybe...
TW
Some time ago I coded in Automatic Door Locking. I like this tweak because now I never have to take the keys out of my pocket:
05 Acc/Start Auth > channel ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock > "activated"
The only problem is that it's too quick - it's a problem at times.
Searching thru '05 Acc/Start Auth' I also found the following line I hope will allow me to change the locking activation speed (time)..
ENG108167-Passive Entry Exit: minimum activity time locking sensor > "140 ms"
But there is also another line which might actually be the right one...
ENG126962-settime_trigger_exit_vehicle > "500 ms"
If anyone has any advise, before I start experimenting, I would really appreciate it.
TW
;SW:3Q0-959-435-L   HW:3Q0-959-435-L ---  Acc/Start Auth.
;Component:VWKESSYMQB    037 1204     Coding:1F30000723
;EV_KessyHellaMQBAB    4046    EV_KessyHellaMQBAB_004_VW37.rod
;Sunday    25    August    2019    15:58:17:27651
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 43D34EB83B13182F97B-8016
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15    not active     3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening    not active     3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request    not active     3
IDE00820-Activating and deactivating all development messages    not active     1
IDE02332-Deactivate production mode    0    3
IDE03251-Stop release for start-stop function    According to function requirements     1
IDE04159-Deactivation of start-stop function    not active     1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module    20 min    2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus    30 min    2
IDE09735-CU tailgate opener: sensor 1: threshold value 1    5    1
IDE09736-CU tailgate opener: sensor 1: threshold value 2    16    1
IDE09737-CU tailgate opener: sensor 1: threshold value 3    16    1
IDE09738-CU tailgate opener: sensor 1: threshold value 4    16    1
IDE09739-CU tailgate opener: sensor 1: threshold value 5    16    1
IDE09740-CU tailgate opener: sensor 2: threshold value 1    2    1
IDE09741-CU tailgate opener: sensor 2: threshold value 2    31    1
IDE09742-CU tailgate opener: sensor 2: threshold value 3    2    1
IDE09743-CU tailgate opener: sensor 2: threshold value 4    31    1
IDE09744-CU tailgate opener: sensor 2: threshold value 5    140    1
IDE09745-CU tailgate opener: sensor 1: timer value 1    170    1
IDE09746-CU tailgate opener: sensor 1: timer value 2    0    1
IDE09747-CU tailgate opener: sensor 1: timer value 3    9    1
IDE09748-CU tailgate opener: sensor 1: timer value 4    34    1
IDE09749-CU tailgate opener: sensor 1: timer value 5    45    1
IDE09750-CU tailgate opener: sensor 2: timer value 1    11    1
IDE09751-CU tailgate opener: sensor 2: timer value 2    165    1
IDE09752-CU tailgate opener: sensor 2: timer value 3    147    1
IDE09753-CU tailgate opener: sensor 2: timer value 4    204    1
IDE09754-CU tailgate opener: sensor 2: timer value 5    143    1
IDE09755-CU tailgate opener: sensor 1: burst length    16    1
IDE09756-CU tailgate opener: sensor 1: active screening    16    1
IDE09757-CU tailgate opener: sensor 2: burst length    2    1
IDE09758-CU tailgate opener: sensor 2: active screening    31    1
IDE09759-CU for tailgate opener: reset all counters    Unknown (224)    1
IDE09760-CU for tailgate opener: check sum    170    1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1    2    1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2    31    1
IDE09831-CU for tailgate opener: play protection increments    6    1
IDE09832-CU for tailgate opener: play protection decrements    25    1
IDE09833-CU for tailgate opener: play protection threshold active    255    1
IDE09834-CU for tailgate opener: play protection threshold inactive    5    1
IDE09835-CU for tailgate opener: play protection decrement interval    60    1
IDE09836-CU tailgate opener: sensor 1: control parameter    16    1
IDE09837-CU tailgate opener: sensor 2: control parameter    16    1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation    0    1
IDE09839-CU for tailgate opener: parameter set version    30    2
IDE10844-Control module rear lid opening: duration status query    4960 ms    1
IDE10845-Control module rear lid opening: vehicle type    2D     1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1    not activated     1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2    not activated     1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan    activated     1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept    activated     1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan    not activated     1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart    activated     1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin    not activated     1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active    not activated     1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door    not activated     1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit    not activated     1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit    not activated     1
ENG126956-ENG126976-Byte9_VIP-active_vip    activated     1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking    not activated     1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function    not activated     1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP    not activated     1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation    activated     1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15    not activated     1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine    not activated     1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning    1.00 s    1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff    1.00 s    1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off    10.00 s    1
ENG105462-CAN-timeout service-key message    260 ms    1
ENG105634-Correction value LED dimming    1    1
ENG114301-Cycletime for voltage monitoring during sleepmode    100 ms    1
ENG120046-Cyclic interior scan during clamp 15 on    10 s    1
ENG126961-deactivation_time_vip_slidingdoor    15 s    1
ENG126960-Debounce_time_detection    500 ms    2
ENG126959-Debounce_time_driver_presence    200 ms    1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle    300 ms    1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM    60.00 s    1
ENG105791-Delta value LED dimming curve first point 40 percent dimming    30.00%    1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming    5.00%    1
ENG105793-Delta value LED dimming curve second point 60 percent dimming    15.00%    1
ENG105794-Delta value LED dimming curve third point 80 percent dimming    10.00%    1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open    not activated     1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open    not activated     1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery    not activated     1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go    activated     1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start    activated     1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted    not activated     1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation    activated     1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door    activated     1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive    activated     1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection    not activated     1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv"    activated     1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT    activated     1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on    activated     1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load    not activated     1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt    not activated     1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt    not activated     1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible    not activated     1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk    not activated     1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles    not activated     1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel    left-hand drive     1
ENG105825-Diagnostic: wait time after power on    500 ms    1
ENG126943-Display_duration_emergency_off    3000 ms    1
ENG126944-Display_duration_error_mode_2_SPN    10 s    1
ENG126941-Display_duration_please_engage_P    10 s    1
ENG105898-Doorknob contact sensor disconnecting time    5400 min    1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up    2000 ms    1
ENG126955-duration_to_ZAT_continuous_actuation_detection    1000 ms    1
ENG129005-duration_to_ZAT_multi_actuation_detection    3000 ms    1
ENG126950-duration_ZAT_debounce    50 ms    1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose    30%    9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear    2.00 s    9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose    5.00 s    9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose    150    9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk    70%    9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate    500 ms    9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active    20.00 s    9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step    0E     5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step    5    5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4    70 mV/m    5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area    65 mV/m    5
ENG126966-environment_scan_cyclic_step1    700 ms    1
ENG126967-environment_scan_cyclic_step2    2000 ms    1
ENG126965-environment_scan_duration_step1    300 min    1
ENG126971-environment_scan_duration_step2    24 H    1
ENG126969-environment_scan_level_bem    2    1
ENG126968-environment_scan_responselevel_reduction    500    1
ENG126970-environment_scan_startdelay_time    5 s    1
ENG126958-Ignition_For_Immobilizer    Default     1
ENG129016-Initialization_diagnostics_switching_terminal    not activated     4
ENG107050-Interior scan: deceleration after comfort closing    3200 ms    1
ENG107051-Interior scan: max. engine speed for standing engine    10 km/h    1
ENG107052-Interior scan: opening threshold sliding roof    1%    1
ENG107053-Interior scan: opening threshold window lifter    5.00%    1
ENG107054-Interior scan: Speed - threshold    20 km/h    1
ENG153724-Interior_scans_clamp15_break_at_active_message    5000 ms    1
ENG153725-Interior_scans_clamp15_retry_at_active_message    5    1
ENG98656-internal    0 B    1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv    not activated     1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys    not activated     1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found"    not activated     1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening    activated     1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking    activated     1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted    installed     1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go    activated     1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate    activated     1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior    activated     1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing    activated     1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling    not activated     1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate    activated     1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery    not activated     1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc    not activated     1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open    activated     1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open    not activated     1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock    activated     1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown    activated     1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger    not activated     1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed    activated     1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit    activated     1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL    activated     1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1    not activated     1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept    not activated     1
ENG107211-Key Minder: delay reunlocking tailgate    500 ms    1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time    10 s    1
ENG107213-Key Minder: p_keyless_eventsearch_retries    2    1
ENG107363-LED dimming curve first point 20 percent dimming    40.00%    1
ENG153886-lf_shutdown_timeout_2nd_operation    5 s    1
ENG107592-MCTX Pause    1 B    1
ENG107593-MCTX pause for Go / Key Minder    20 ms    1
ENG107594-MCTX pause for Go authentification    14 B    1
ENG107595-MCTX settling phase    10 B    1
ENG129013-min_receptiontime_vit    0 ms    1
ENG126945-min_time_for_Terminal_50_request    200 ms    1
ENG244880-Minimum_holdtime_ak    500 ms    1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff    2    1
ENG126940-Number_of_ZAT_activations_to_DTC    10    1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout    2.00 s    1
ENG108166-Passive Entry Exit: entry request e-sliding door active time    500 ms    1
ENG108167-Passive Entry Exit: minimum activity time locking sensor    140 ms    1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY    220 ms    1
ENG108169-Passive Entry Exit: T_ACT_OP_2    5000 ms    1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement    200 ms    1
ENG108298-Proximity Sensor: duration of proximity Signal    10 s    1
ENG108299-Proximity Sensor: lower limit Impuls    2000 µs    1
ENG108300-Proximity Sensor: lower limit proximity-Impuls    12200 µs    1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle    10.0 km/h    1
ENG108302-Proximity Sensor: max. Impulslength    75 ms    1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls    20400 µs    1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic    14 ms    1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls    71 ms    1
ENG108306-Proximity Sensor: max. length of Entryimpuls    10400 µs    1
ENG108307-Proximity Sensor: max. length of Exitimpuls    40400 µs    1
ENG108308-Proximity sensor: max. length of signal hall sensor    100 s    1
ENG108309-Proximity Sensor: max. signal-length    120 s    1
ENG108310-Proximity sensor: max. tolerance data bit length    200 µs    1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle    20.0 km/h    1
ENG108312-Proximity Sensor: min. enginespeed for a running engine    300 /min    1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls    42 ms    1
ENG108314-Proximity Sensor: min. length of Entryimpuls    6200 µs    1
ENG108315-Proximity Sensor: min. length of Exitimpuls    24200 µs    1
ENG108316-Proximity sensor: min. tolerance data bit length    120 µs    1
ENG108317-Proximity Sensor: SP_X2    10 min    1
ENG108318-Proximity Sensor: SP_X3    1    1
ENG108319-Proximity Sensor: SP_X4    80    1
ENG108320-Proximity Sensor: SP_X5    1    1
ENG108321-Proximity Sensor: SP_X6    30 min    1
ENG108322-Proximity Sensor: SP_X7    1    1
ENG108323-Proximity Sensor: Time Power On    1960 ms    1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption    0 ms    1
ENG108325-Proximity sensor: turn-off limit from battery-manager    2    1
ENG108326-Proximity Sensor: upper limit intermission-length    10 ms    1
ENG153707-IDE00047-Rear_lid_power_opening_control_unit_data_set_upload-Parameter set version    0    37
ENG153707-IDE80001-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 1    1    37
ENG153707-IDE80002-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 2    1    37
ENG153707-IDE80003-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 3    0    37
ENG153707-IDE80004-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 4    0    37
ENG153707-IDE80005-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 5    16    37
ENG153707-IDE80006-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 6    16    37
ENG153707-IDE80007-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 7    16    37
ENG153707-IDE80008-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 8    16    37
ENG153707-IDE80009-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 9    2    37
ENG153707-IDE80010-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 10    31    37
ENG153707-IDE80011-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 11    2    37
ENG153707-IDE80012-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 12    31    37
ENG153707-IDE80013-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 13    140    37
ENG153707-IDE80014-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 14    10    37
ENG153707-IDE80015-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 15    10    37
ENG153707-IDE80016-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 16    0    37
ENG153707-IDE80017-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 17    0    37
ENG153707-IDE80018-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 18    9    37
ENG153707-IDE80019-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 19    0    37
ENG153707-IDE80020-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 20    not active     37
ENG153707-IDE80021-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 21    active     37
ENG153707-IDE80022-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 22    not active     37
ENG153707-IDE80023-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 23    Bottom     37
ENG153707-IDE80024-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 24    Dynamic     37
ENG153707-IDE80025-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 25    3    37
ENG153707-IDE80026-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 26    not active     37
ENG153707-IDE80027-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 27    Dynamic     37
ENG153707-IDE80028-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 28    5    37
ENG153707-IDE80029-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 29    6    37
ENG153707-IDE80030-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 30    active     37
ENG153707-IDE80031-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 31    19    37
ENG153707-IDE80032-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 32    2    37
ENG153707-IDE80033-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 33    12    37
ENG153707-IDE80034-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 34    4    37
ENG153707-IDE80035-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 35    Do not reset     37
ENG153707-IDE80036-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 36    16    37
ENG153707-IDE80037-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 37    16    37
ENG153707-IDE80038-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 38    16    37
ENG153707-IDE80039-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 39    16    37
ENG153707-IDE80040-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 40    2    37
ENG153707-IDE80041-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 41    31    37
ENG153707-IDE80042-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 42    2    37
ENG153707-IDE80043-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 43    31    37
ENG153707-IDE80044-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 44    224    37
ENG153707-IDE80045-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 45    10    37
ENG153707-IDE80046-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 46    10    37
ENG153707-IDE80047-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 47    0    37
ENG153707-IDE80048-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 48    0    37
ENG153707-IDE80049-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 49    0    37
ENG153707-IDE80050-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 50    0    37
ENG153707-IDE80051-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 51    6    37
ENG153707-IDE80052-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 52    25    37
ENG153707-IDE80053-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 53    255    37
ENG153707-IDE80054-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 54    5    37
ENG153707-IDE80055-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 55    60    37
ENG153707-IDE80056-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 56    143    37
ENG153707-MAS01078-Rear_lid_power_opening_control_unit_data_set_upload-Vehicle type    45    37
ENG153707-MAS14087-Rear_lid_power_opening_control_unit_data_set_upload-time delay activation    Activation after 2s     37
ENG120045-Reduced current for transponder-ID request    0 Step    1
ENG126939-rpm_threshold_engine_runnning    100 /min    1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol    5 Step    1
ENG108576-Scan Procedure: cycle convenience coverage limiting    65 ms    1
ENG108577-Scan Procedure: Number of Repeats    1    1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause    100 ms    1
ENG108579-Scan Procedure: Timeout Authentification Result    150 ms    1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go    190 ms    1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi    700 ms    1
ENG108582-Scan Procedure: Timeout LF Repetition    100 ms    1
ENG108585-ScanProcedure: Timeout Entry Response    260 ms    1
ENG108586-ScanProcedure: Timeout Response    100 ms    1
ENG126963-settime_trigger_entry_vehicle    500 ms    1
ENG126962-settime_trigger_exit_vehicle    500 ms    1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG    not activated     1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted    activated     1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event    not activated     1
ENG129024-ENG98656-Sonstiges_byte1-internal    not activated     1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure    not activated     1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active    activated     1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data    not activated     1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold    not activated     1
ENG129025-ENG142122-sonstiges_byte2-sad_existing    activated     1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing    activated     1
ENG244883-Speed_ threshold_for_start_request_plausibilisation    10 km/h    1
ENG129007-Speed_threshold_for_driving_cycle_detection    3.0 km/h    1
ENG129006-Speed_threshold_for_moving_vehicle_detection    1.0 km/h    1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff    7.0 km/h    1
ENG109053-Standard dimming value ZAT    80%    1
ENG126938-Terminal_15_adaption_body_control_module    Default     1
ENG126946-Terminal_S_Timeout    30 min    1
ENG102207-Time Sensor Power Off Group 2    3600 min    1
ENG129027-Time_frame_VIP_kick_forecast    5    1
ENG126942-time_to_drive_cycle_detection    1.00 s    1
ENG126947-time_to_ignore_ignition_trigger    35 s    1
ENG126954-time_to_ZAT_Open_circuit_detection    1000 ms    1
ENG126951-time_to_ZAT_Short_circuit_fault_detection    60 s    1
ENG126949-time_ZAT_actuation_detection    3000 ms    1
ENG126952-time_ZAT_lock_after emergency_shutoff    1000 ms    1
ENG126953-time_ZAT_lock_after_normal_shutoff    500 ms    1
ENG129009-Timeframe_request_immobilizer_terminal_approval    10000 ms    1
ENG129019-timeout_convenience_coverage_limiting    75 s    1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking    1.00 s    1
ENG244884-Toggle_offtime_other_doorhandle    2.00 s    1
ENG244885-Toggle_offtime_same_doorhandle    2.00 s    1
ENG109974-Voltage monitoring: overvoltage Delta    500 mV    1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU    16000 mV    1
ENG109976-Voltage monitoring: overvoltage for Keyless Go    27000 mV    1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta    0 mV    1
ENG109978-Voltage monitoring: undervoltage Delta    500 mV    1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU    9000 mV    1
ENG109980-Voltage monitoring: undervoltage for Keyless Go    6000 mV    1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta    0 mV    1
ENG120047-ZAT init value    0%    1
ENG110364-ZAT nominal voltage    13.0 V    1
ENG110365-ZAT post-carridge during clamp 15 off    10 min    1
ENG153750-ZAT_clamp58xt_signal_factor    0.2    1
ENG153751-ZAT_clamp58xt_signal_offset    3    1
ENG153752-ZAT_first_fall_time_high_low_state    900 ms    1
ENG153753-ZAT_first_rise_time_low_high_state    100 ms    1
ENG153754-ZAT_motor_signal_timer_1    3000 ms    1
ENG153755-ZAT_motor_signal_timer_2    3000 ms    1
ENG153756-ZAT_pwm_offset_1_lower_limit    5%    1
ENG153757-ZAT_pwm_offset_2_lower_limit    10%    1
ENG153758-ZAT_pwm_peak1_upper_limit    90%    1
ENG153759-ZAT_pwm_peak2_upper_limit    100%    1
ENG153760-ZAT_second_fall_time_high_low_state    2000 ms    1
Elapsed Time: 00:56
Don't your doors have touch sensors that lock the doors when you touch the sensors?
I've had a number of cars with Kessy and have never had to take the keys out of my pockets to lock the doors.
TWs/VW
NW Florida
C?ID=369048
TW
Elapsed Time: 00:56
Yes, the door handles are equipped with locking sensors; a feature I was not aware of initially. However, door slam locking on the other hand is absolutely effortless – the activation time is my only concern. I'll experiment with adjusting the 'setting trigger' code and see what happens.
Question: If the default value is in milliseconds (ms), can seconds (s) usually be substituted?
> 05 Acc/StartAuth > ENG126962-settime_trigger_exit_vehicle > "500 ms"
TW
Unlikely. If a channel has milliseconds as the unit, you'll have to enter milliseconds as the new value.
Mari
C?ID=150535
Depends on the range of the value... 1000ms = 1 second ;) So give it a try and put 2000 as new value!
TWs/VW
NW Florida
C?ID=369048
Enabling Automatic Door Locking (Door Slam Locking)
I successfully coded Automatic Door Locking and Menu option in the Infotainment system. I like this tweak because locking is now effortless; however, there is a downside I haven't been able to fix. When active, the lock activation is instantaneous on closing the driver's door - my wife can't get to the rear door (passenger side) quick enough to access the back seat area.
Adaptations applied:
> 09 Cent. Elect. > channel ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock > "adjustable"
I've tried a couple of adaptations to adjust (or delay) the auto lock activation time without success. First, I changed the Settime Trigger from 500 ms (default) to 5000 ms - no affect. Then, I also changed the Minimum Activity Time Locking Sensor from 140 ms (default) to 2440 ms (maximum) - also no affect:
> 05 Acc/Start Auth > ENG108167-Passive Entry Exit: minimum activity time locking sensor > "2440 ms"
> 05 Acc/Start Auth > ENG126962-settime_trigger_exit_vehicle > "5000 ms"
There are some other lines in the Acc/Start Auth module I might try, but they don't look promising; but after all, I was just shooting in dark from the start anyway...any help would be most appreciated.
> 05 Acc/Start Auth > ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling > not activated (default)
> 05 Acc/Start Auth > ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout > 2.00 s (default)
> 05 Acc/Start Auth > ENG129014-Timeout_trigger_terminal_deactivation_central_locking > 1.00 s (default)
TW
quailallstar
Ormond Beach, FL
C?ID=53119
This is the same question I've been asking myself! There has to be some way to enable a longer delay in between the time the vehicle door "slams" and then auto locks.
TWs/VW
NW Florida
C?ID=369048
I agree quailallsar, but so far none of my experiments have worked.
TW
South Molton, UK
But only if VW included that as a changeable option in their firmware... if it's a hard coded delay then it will be what it is.
findcoop
Canada
C?ID=6102
Leave the front door open until you're done in the back? An option to lock as you walk away would be great, instead of triggering on the door close.
TW
TW: without intending any offense, just simply keep adding zeros to the number (assuming the adaption channel will allow many digits) - 1,000 ms = 1 sec.
So, the default value of 500 ms = half a second!
