2006 Audi A6 C6 ABS Fault 01435
Dani
FL - USA
C?ID=324359
Question 1: Very screwed. You will need to replace or rebuild the module. I highly recommend ModuleMaster, they are fast and professional.
Question 2: I've seen reports in other forums where people continued driving without the module installed. They got all sorts of errors on the dash and it was generally annoying, but they did it. I DO NOT recommend doing that, simply because you will have no traction control or other safety features while your module is not installed, but it is technically a possibility. Your actual braking power is entirely hydraulic (assisted by the brake booster, which is vacuum-powered), so they will technically still work without the control module.
And for the record, I drove for several months with a faulty module before I finally broke down and sent one out for repair. I found a spare, so I never drove without my module, and that's the route I recommend you take as well.
Thanks for your input, much appreciated.
The most annoying part is the parking brake error as it goes off when the car slows and stops. Then it gives out that ear piercing BEEEEEEP each time I start driving again (comes on at about 10 mph). :banghead:
I guess it's trying to communicate with the tire which almost makes me think maybe there's a problem with the actual brake(s)... I did hear a little "crunch" sound coming from the front maybe a day or so before the ABS/ESP first popped up.
Figured maybe some dirt/debris got in there as the road home has been a construction site as of late... My brakes should be fine, they're maybe a year old and I don't drive that much (maybe 30 miles day during the week, work commute).
FWIW, the ABS module is responsive - it scans. If the brake pressure sensor is bad, that's located inside the pump, right? At least that's what I read... So, on a rebuild, do they rebuilt the pump, the module or both?
If the issue is inside the pump, can it be replaced by itself?
Just really a bad start to the new year... Damn. :(
   #122
Dani
FL - USA
C?ID=324359
Thought I'd share the good news. As of last weekend, the problem appears solved. :D I do not miss the beeps and flashing lights in my dash. ;)
Been driving with the fuses for the parking brake pulled to limit beeps to starting the car.
Picked up a rebuilt module with pump off ebay that was the exact same part # as my bad one.
Decided to try and replace JUST the module first, without the pump and the subsequent mess and extra work, hoping that the fault wasn't the sensor in the pump.
This dude's video made it a definitely annoying but strangely simple undertaking. https://www.youtube.com/watch?v=trFLvIFi-6w
Needed some help figuring out coding but VCDS Dana proved an expert. :thumbs: Phew.
Now on to the newest issue: A/C is on the fritz in 90°F Florida. :facepalm: Always something! :banghead:
   #123
davisev5225
C?ID=263265
If you haven't flushed your brake fluid within the past 2 years, you probably should. ;)
Good to hear you worked yours out as well. Poor engineering to require everyone to replace or rebuild the module, but at least there's places that will do it.
