2006 Audi A6 C6 ABS Fault 01435
   #101
davisev5225
C?ID=263265
Vehicle Identification No. WAUKH74F86N124065
Model audi a6 av. qu. 3.2
A6
Date of production 15.12.2005
Model year 2006
Sales type 4F55NL
Engine Code BKH
Transmission Code HYR
PART NUMBER
4F0 614 517 Q / L / N
4F0 614 517 P
4F0 910 517 P
Minor bit of confusion: the Audi website says the current part number is 4F0 614 517 J.
https://parts.audiusa.com/p/Audi_20...n-ABS-Modulator-unit/48311345/4F0614517J.html
Is there something I'm missing and there's a reason it's not on your list? Just trying to do as much research and cross-referencing as I can before I try and find a unit, new or used.
   #102
MartinsX
Riga, Latvia
C?ID=268515
4F0 614 517 C, 4F0 614 517 J are for A6 vehicles equipped with ACC - PR 8T4
4F0 614 517 L, 4F0 614 517 N are for A6 vehicles with classic CC (PR 8T1) or without CCS (PR 8T0)
4F0 614 517 P, 4F0 614 517 Q are for S6. Not sure are they fully compatible with those above.
   #103
davisev5225
C?ID=263265
That was helpful, thanks. AudiUSA.com is apparently not the best resource, despite being the official site for Audi of America...
   #104
MartinsX
Riga, Latvia
C?ID=268515
To be completely sure use PL24 and check with Your VIN or ask someone with subscription to this resource to do it for You.
I use another source of information, it has no VIN filter.
   #105
davisev5225
C?ID=263265
I took your info and called the parts desk of my local Audi dealer, and they confirmed that the "N" suffix is the current revision for my VIN. They were just as confused as I was as to why the AudiUSA site was trying to sell me the "J" suffix.
   #107
davisev5225
C?ID=263265
OK, I have an "N" suffix on order from eBay right now; I'm hoping this doesn't turn out to be a dud.
Any differences in coding that I need to be aware of, or do I just copy the existing coding from my "L" module to the new one?
   #110
davisev5225
C?ID=263265
I should have listened to my instincts, I knew eBay was nothing but trouble.
First sign of trouble: The seller advertised an "N" module, which is what was stamped on the hydraulic unit, but an "L" module was attached. OK, no big deal, that's the original revision in my car. After a lot of wrangling, and a drill and screw extractor because one of the stupid specialty screws stripped, I finally got it installed.
Second sign of trouble: the moment I plugged it in (with the car electrics completely turned off because I'm not a moron), it sounded like an electric motor was spinning up. My old module didn't do that. Over to VCDS, and I find (3) error codes. The expected steering angle, the G201 pressure sensor (with an unchanging pressure reading of -37.83), and 01200 - ABS Supply Voltage. It also got extremely hot in one of the top corners during the (5)ish minutes I had it plugged in.
The only silver lining here is I *MIGHT* be able to send it off to ModuleMasters and have it rebuilt, while keeping my (mostly) working module in my car. But after spending $450 on this module (because it was the only "N" module available, and I figured the newer revision is probably better), I've got to wait for the end of the week to get my next paycheck before I can do that, and then ModuleMasters has a 5-business-day turn-around...
:banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
   #111
davisev5225
C?ID=263265
Dredging this old thread back up for a moment, I just installed my ModuleMaster-repaired controller. Now to see if it holds up over the next week or two.
   #113
davisev5225
C?ID=263265
Dragging this thread back up one more time in order to provide positive confirmation of a resolution. The rebuild module was the solution.
For anyone else who's as stubborn as me about being frugal, save yourself the headache and go straight for a replacement or rebuild module.
Dani
FL - USA
C?ID=324359
I'm a bit late to the party... have the same problem. ABS Fault 01435.
Mine is a 2005 A6 Quattro 3.2L
And yep, I have been to the Wiki article for this fault. I should point out that I'm just a regular Audi driver, not a tech of any sort. So please go easy on me. :D
Here's what happened:
A couple of days ago, the ESP and ABS lights came on. Once I started driving, the Parking Brake fault in the center came on as well. It goes off as soon as the wheels stop turning and comes back on when I start driving.
And yes, that beep can drive someone to madness. LOL
I checked the parking brake and it appears to be functioning as normal. The car drives and brakes normally.
I did have a low battery a week prior and needed jumping. So I ran a scan and it returned 4 Quiescent Current faults. It was time for a new battery, which I replaced yesterday. I ran another scan today to see if I could reset the faults, thinking maybe the voltage problem caused a glitch.
I can't seem to get it cleared. :cry:
Here is the full scan from today, and I hope I'm doing this right: :D
Sunday,12,January,2020,11:25:38:43060
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
VIN: WAUDG74F25N122676   License Plate:
Mileage: 191680km-119104mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 42 46 47 4F 52 53
          55 56 61 62 65 67 72 77
VIN: WAUDG74F25N122676   Mileage: 191680km-119104miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 4F2 910 559 B    HW: 4F1 907 559 E
   Component: 3.2l V6 FSI         0020
   Revision: --H21---    Serial number:
   Coding: 01050109190F0120
   Shop #: WSC 05139 444 83890
   VCID: 2B03FA8C1F0FB31F4C5-807E
000632 - Fuel Injector #6 (N84)
               P0278 - 006 - Contribution/Balance Fault - Intermittent
                    Fault Status: 00100001
                    Reset counter: 7
                    Mileage: 191121 km
                    Date: 2019.12.17
                    Time: 17:02:10
                    RPM: 1312 /min
                    Mass Air / Rev.: 256.2 mg/str
                    Temperature: 81.0°C
                        Part Throttle
                    Load: 43.9 %
                    Speed: 38.0 km/h
               P1602 - 008 - Voltage too Low - Intermittent
                    Fault Status: 00001000
                    Reset counter: 14
                    Mileage: 191277 km
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 22.5°C
                        Engine Off
               P1653 - 008 -
                    Fault Status: 01101000
                    Fault Frequency: 12
                    Mileage: 191277 km
                    Date: 2019.12.30
                    Time: 08:26:23
                    RPM: 1568 /min
                    Mass Air / Rev.: 158.1 mg/str
                    Temperature: 24.0°C
                        Idle
                    Load: 19.6 %
   Part No SW: 4F1 910 156 H    HW: 09L 927 156
   Component: AG6 09L 3.2 FSI USA 0020
   Revision: --H01---    Serial number:        4028906
   Coding: 0000002
   Shop #: WSC 02325 785 00200
   VCID: 290F008415F3A10FBE9-807C
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H03 0090
   Coding: 0020895
   VCID: 2D07F494211BBD2F521-8078
                    Reset counter: 221
                    Mileage: 191635 km
                    Date: 2020.01.10
                    Time: 07:36:19
                    Hex Value: 0x0000
                    Hex Value: 0x4382
                    Hex Value: 0x001C
                    Hex Value: 0xB1AD
                    Hex Value: 0x00FF
                    Reset counter: 221
                    Mileage: 191681 km
                    Date: 2005.02.01
                    Time: 12:02:36
                    Hex Value: 0x0000
                    Hex Value: 0x4382
                    Hex Value: 0x0024
                    Hex Value: 0x0196
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H30 0160
   Revision: 27100401    Serial number: 10600300155096
   Coding: 0000015
   Shop #: WSC 06402 785 00200
   VCID: 639352AC375F3B5FB45-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 EZS   H44 0070
   Component: FBSAUDIC6 KSG   H26 0080
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Fault Status: 01111011
                    Reset counter: 220
                    Mileage: 191658 km
                    Date: 2020.01.10
                    Time: 13:37:14
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 220
                    Mileage: 191658 km
                    Date: 2020.01.10
                    Time: 13:37:14
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 360DK057523670
   Coding: 0000003
   Shop #: WSC 05139 444 104911
   VCID: 313FE8E43D23D9CF769-8064
   Subsystem 1 - Part No: 4F0 910 609 B
   Component: Bedienteil MMIC6H07 0010
   Subsystem 2 - Serial number: 00000000143950
   Subsystem 3 - Serial number: 0120.04.050000000100010067ÿ
   Subsystem 4 - Serial number: 010067ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 J
   Component: KLIMABETAETIGUNGH11 0150
   Revision: 00000026    Serial number: 00000000140982
   Coding: 0524326
   VCID: 5BE36A4C0F2F039FFC5-800E
01853 - Heated Seat; Left Front (Z45)
                    Reset counter: 218
                    Mileage: 191635 km
                    Date: 2020.01.10
                    Time: 07:36:24
                    Temperature: 21.0°C
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0002121
   Shop #: WSC 02335 785 00200
   VCID: 66954BB8C46D4E7753B-8032
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
                    Fault Frequency: 27
                    Reset counter: 221
                    Mileage: 191632 km
                    Date: 2020.01.10
                    Time: 07:36:00
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7162212
   VCID: 1C6129504AA144A735F-8048
Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
   Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
   Component: SDAR XM         H04 0670
   Revision: 00000000    Serial number: AUZ4Z7D3022210
                    Reset counter: 218
                    Mileage: 191635 km
                    Date: 2020.01.10
                    Time: 07:36:20
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
   Component: 56 AIRBAG AUDI8RH29 0310
   Revision: 10H29000    Serial number: 00359D08CD6Q
   Coding: 0013622
   VCID: 26150BB804ED8E7793B-8072
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME090C33570
   Subsystem 3 - Serial number: 6342CSME097E1B228
   Subsystem 4 - Serial number: 6351HSME07172617+
   Subsystem 5 - Serial number: 6361HSME070A2202Y
   Subsystem 6 - Serial number: 6371VSME07284D23M
   Subsystem 7 - Serial number: 6381VSME07286733K
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90025051100025
   Coding: 0002041
   Shop #: WSC 02323 785 00200
   Component: Lenkradmodul    H02 0030
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
   Component: KOMBIINSTR. M73 H10 0630
   Revision: 01000000    Serial number: 4R850TV45
   Coding: 2129263
   Shop #: WSC 50451 001 1048576
   VCID: 1E6523585CBD56B7DBB-804A
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H10 0060
   Revision: 10          Serial number: 120080542881C4
   Coding: 6CFE73CD1B5904
   VCID: 270B06BC03E7977FA8D-8072
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   VCID: 619F58A42D43294FA69-8034
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H11 0040
   Revision: 00-00000
   Coding: 0051947
   Shop #: WSC 02327 785 00200
                    Reset counter: 6
                    Mileage: 191681 km
                    Date: 2020.01.11
                    Time: 15:44:15
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
   Component: Komfortgeraet   H18 0120
   Revision: 01200018    Serial number: 01003941210000
   Coding: 4618301
   VCID: 2E05F3982C1DC6376BB-807A
                    Fault Status: 01101100
                    Reset counter: 221
                    Mileage: 165174 km
                    Date: 2017.08.24
                    Time: 17:20:11
Address 47: Sound System        Labels: None
   Part No SW: 4F5 910 223 F    HW: 4F5 035 223 E
   Component: DSP-High C6     H14 0330
   Revision: PROD_01     Serial number: 00000000030664
   Coding: 0000026
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H10 0050
   Revision:             Serial number: 00000000089631
   Coding: 0001114
   VCID: 5EE563581C3D16B79BB-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H11 0040
   Revision: 00-00000
   Coding: 0051947
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   Shop #: WSC 02334 785 00200
   VCID: 5DE76454113B0DAF821-8008
                    Fault Status: 00101101
                    Fault Frequency: 43
                    Reset counter: 5
                    Mileage: 191632 km
                    Date: 2020.01.10
                    Time: 07:39:10
                    Voltage: 13.04 V
                    Count: 236
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0040
   Coding: 0000016
   Shop #: WSC 05139 444 109253
   VCID: 698F4084D573610F7E9-803C
   Subsystem 1 - Part No: 4F0 941 329 A
   Component: AFS-Modul links H05 0010
   Subsystem 2 - Part No: 4F0 941 329 A
   Component: AFS-Modul rechtsH01 0010
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 394ES057543740
   Coding: 0000002
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000027842
   Shop #: WSC 05139 444 58901
   VCID: 231312AC77DF7B5FF45-8076
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  0330207712
   Coding: 344630393135313035432056413030333330323037373132
   Shop #: WSC 57227 000 1048576
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H11 0030
   Coding: 0051754
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273     HW: 4F0 907 273
   Component: Reifendruck 3   H04 0080
   Revision: 00040080    Serial number: 00000700004988
   Coding: 0062221
   Shop #: WSC 05139 444 59514
   VCID: 60995DA026492047A97-8034
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000504220168
   Shop #: WSC 12336 024 394758
   VCID: 3431E1F0C231ECE71DF-8060
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H11 0030
   Coding: 0051754
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H10 1130
   Revision: 00000000    Serial number: 00000007521822
   Coding: 0010900
   VCID: 280905800EF99807A17-807C
End----------(Elapsed Time: 01:53, VBatt start/end: 13.9V/13.9V)-----------
Here is the code from just the ABS module:
Sunday,12,January,2020,11:29:23:43060
Control Module Part Number: 4F0 910 517 L HW: 4F0 614 517 L
Component and/or Version: ESP 8.0 quattro H03 0090
Software Coding: 0020895
Work Shop Code: WSC 02325 785 00200
Reset counter: 222
Mileage: 191681 km
Date: 2020.01.12
Time: 11:27:18
Hex Value: 0x0000
Hex Value: 0x4382
Hex Value: 0x001C
Hex Value: 0xB1AC
Hex Value: 0x00FF
Address 03: DTCs cleared
Address 03,4F0 910 517 L,recoded (Short coding),from,0020895,to,0020895,(02325/785/00200),
Address 53,4F0 910 801 ,recoded (Short coding),from,0005022,to,0005022,(02334/785/00200),
I guess my question is, how screwed am I? :facepalm:
If it's the sensor, it can't be replaced individually, right? It would require the whole ABS to be exchange?
My second question is: this is my only car. How safe is it for me to drive it if you discount me going crazy with the BEEEEEPING each time I start rolling again? :eek:
Any help would be so greatly appreciated.
Dani
FL - USA
C?ID=324359
Did you JPPSG yet and report pattern to NHTSA & check for campaign?
Hi Jack, nice to meet you. ;)
I have no idea what you just said... LOL
Sorry, I'm a noob to the forum. Also not a tech.
Invested in the VCDS about 6 months after buying the car back in 2017 when it had the dreaded start/access auth module issue and turned possum on me. Got the module rebuilt. <phew>
So looks like I may need a new abs module? Is there a how to remove/replace vid? My brother will likely be doing that part of the repair. I can do any coding that may be required...
   #117
NostraJackAss
Hello............ :rolleyes:
JPPSG The entire thread please.........
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
The RTFB will absolutely have a procedure.
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
NHTSA
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
   #118
Dani
FL - USA
C?ID=324359
Re. JPPSG - I thought I posted all relevant info on the car incl. complete auto scan... :(
Re. NHTSA - sure, I can do that although I don't see the immediate relevance. :confused:
Re. RTFB - erWin Audi USA? Looks intimidating for a lay[wo]man. LOL But OK, I'll scan through that.
Hopefully someone has a youtube vid on this or something. For now, I'll continue to drive it until I get this figured out.
Have a nice Sunday. :)
davisev5225
C?ID=263265
Question 1: Very screwed. You will need to replace or rebuild the module. I highly recommend ModuleMaster, they are fast and professional.
Question 2: I've seen reports in other forums where people continued driving without the module installed. They got all sorts of errors on the dash and it was generally annoying, but they did it. I DO NOT recommend doing that, simply because you will have no traction control or other safety features while your module is not installed, but it is technically a possibility. Your actual braking power is entirely hydraulic (assisted by the brake booster, which is vacuum-powered), so they will technically still work without the control module.
And for the record, I drove for several months with a faulty module before I finally broke down and sent one out for repair. I found a spare, so I never drove without my module, and that's the route I recommend you take as well.
