2011 Passat CC Xenon failure
naushad2982
Kenya
C?ID=58306
Hey guys I have the above vehicle that has a Xenon failure,
When you switch the lights on both lamps go on properly and stay on for about a minute,
after that they both Go off simultaneously,
The errors logged dont make sense as it appears 09 central electrics is logging faults for headlamp low beams on both sides even though
this vehicle is fitted with xenon lamps.
this leads me to belive that we are dealing with a faulty coding issue.
So far ive checked that all fuses are in the correct place and of the correct rating as per Erwin VW online.
Ive also measured the powers and grounds (using a power probe) and have full battery voltage and proper ground at the headlight socket .
Has anyone dealt with this before? any input is appriciated
Tuesday,16,July,2019,09:53:43:54859
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Euro Tecnik Ltd
VIN: WVWZZZ3CZCE702650   License Plate: KCU 520Y
Mileage: 57230km-35561mi   Repair Order: LY Passat CC
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 36 37 42 44 46 4C 4F 52
          53 55 56 61 62 6C 72 77
VIN: WVWZZZ3CZCE702650   Mileage: 57230km-35561miles
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 06J 997 027 F    HW: 06J 907 309 B
   Component: MED17.5.2        05 7706
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 0404000C24070160
   Shop #: WSC 27202 001 1048576
   VCID: 3828DED47E5EEF77329-806C
053271 - Please Check Fault Codes in Control Module for ABS Brakes
               U1017 - 015 -
                    Fault Status: 01101111
                    Fault Frequency: 19
                    Mileage: 57083 km
                    Date: 2013.12.03
                    Time: 17:38:12
                    RPM: 704 /min
                    Load: 13.3 %
                    Temperature: 101.0°C
                    Temperature: 66.0°C
                    Absolute Pres.: 830.0 mbar
                    Voltage: 12.827 V
               P0300 - 000 -  - Intermittent
                    Mileage: 57184 km
                    Date: 2013.12.05
                    Time: 20:18:28
                    RPM: 755 /min
                    Load: 12.2 %
                    Temperature: 51.0°C
                    Temperature: 33.0°C
                    Voltage: 12.573 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
                    Mileage: 57184 km
                    Date: 2013.12.05
                    Time: 20:18:32
                    RPM: 785 /min
                    Load: 13.3 %
                    Temperature: 51.0°C
                    Temperature: 33.0°C
                    Voltage: 12.446 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - Intermittent
                    Mileage: 57184 km
                    Date: 2013.12.05
                    Time: 20:18:32
                    RPM: 785 /min
                    Load: 13.3 %
                    Temperature: 51.0°C
                    Temperature: 33.0°C
                    Voltage: 12.446 V
   Part No SW: 0AM 300 058 Q    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6563
   Revision: 00043014    Serial number: CU501506157279
   Shop #: WSC 56478 002 1048576
   VCID: 3FDAB5C85B70D84FF33-806A
006279 - Wheel-Speed Signal from ABS Control Module
               P1887 - 000 - Implausible Signal
                    Fault Frequency: 53
                    Reset counter: 10
                    Mileage: 57083 km
                    Date: 2013.12.03
                    Time: 17:38:15
   Part No SW: 3AA 614 109 AG    HW: 3AA 614 109 AG
   Component: J104   C2 450M VD44 0023
   Revision: --H07---    Serial number: 00000005208805
   Coding: 0001914
   Shop #: WSC 05311 000 08193
   VCID: 72BC2CFC58A24527CCD-8026
03842 - RPM Sensor Rear Right: Incorrect Signal
                    Fault Frequency: 77
                    Reset counter: 63
                    Mileage: 57083 km
                    Date: 2013.12.03
                    Time: 17:38:17
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.75 V
                    Bin. Bits: 00011111
                    Count: 157
                    Hex Value: 0x0000
                    Fault Frequency: 50
                    Reset counter: 68
                    Mileage: 57083 km
                    Date: 2013.12.03
                    Time: 17:38:27
                    Hex Value: 0x0000
                    Voltage: 12.75 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 C    HW: 3AA 907 044 C
   Component: Climatronic   H03 0101
   Revision: 00001K01
   Coding: 0010002008
   Shop #: WSC 00015 115 08193
   VCID: 3038E6F49AAE37377A9-8064
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 0465
   Revision: BD421001
   Coding: 0008000000000000008C0280940009642355000064200D20E484462400C1
   Shop #: WSC 05311 123 08193
   VCID: 41DEB3302184AEBF857-8014
   Subsystem 1 - Part No SW: 3C8 955 119 G    HW: 3C8 955 119 G  Labels: 1KX-955-119.CLB
   Component: WWS464 161111  010 0604
   Serial number: 161111
   Coding: 00B795
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0024
   Serial number: Y12M01D04h19m26s25S1
   Coding: 0280DD
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 11
                    Reset counter: 68
                    Mileage: 57083 km
                    Date: 2013.12.03
                    Time: 18:23:30
                        Term 15 On
                    Voltage: 14.10 V
                    Fault Frequency: 11
                    Reset counter: 68
                    Mileage: 57083 km
                    Date: 2013.12.03
                    Time: 18:23:30
                        Term 15 On
                    Voltage: 14.10 V
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0016
   Revision: --------    Serial number: 28261200501936
   Coding: 308104
   ASAM Dataset: EV_EPHVA18VW47X0000 001005
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3E24C8CC50FAD147F85-806A
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__703 VW10 HI   1918
   Revision: 23016000    Serial number: 003K0P086UAG
   Coding: 0012339
   VCID: 4CC092041AC673D7661-8018
   Subsystem 1 - Serial number: 6332MTS612983421
   Subsystem 2 - Serial number: 6342MTS633693431
   Subsystem 3 - Serial number: 6351HTS6QQ3QU9KJ
   Subsystem 4 - Serial number: 6361HTS63ON3V9KJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20120102301372
   Coding: 099A270001
   Shop #: WSC 32505 001 1048576
   VCID: 6B823198730894EF0FB-803E
   Coding: E30000
365080 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
                    Fault Frequency: 49
                    Reset counter: 108
                    Mileage: 57083 km
                    Date: 2019.07.13
                    Time: 18:56:10
   Part No SW: 3C8 920 870 K    HW: 3C8 920 870 K
   Component: KOMBI         H04 0609
   Coding: 140F01
   Shop #: WSC 30001 810 194785
   VCID: 3332E9F86BB80C2F07B-8066
   Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway H41 1623
   Revision:   H41       Serial number: 281111F6000339
   Coding: 469007
   Shop #: WSC 05314 000 00000
   VCID: 3E24C8CC507AD147F85-806A
                    Fault Status: 00110100
                    Reset counter: 104
                    Mileage: 57123 km
                    Date: 2013.12.04
                    Time: 15:57:12
03981 - Pause recommendation not available
                    Fault Status: 01110000
                    Reset counter: 68
                    Mileage: 57222 km
                    Date: 2013.12.05
                    Time: 21:05:19
   Part No SW: 3AA 959 799 A    HW: 3AA 959 799 A
   Component:    IMMO         083 0400
   Revision: 00083000    Serial number: VWZCZ000000000
   VCID: 46D4A02C04AA8987B05-8012
01176 - Key
                    Reset counter: 107
                    Mileage: 57159 km
                    Date: 2013.12.04
                    Time: 22:52:44
   Revision: A1001003    Serial number: 7661547527
   VCID: 290E0B90B9F446FFBD7-807C
   Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2601
   Revision: 00H05000
   Coding: 000039
   VCID: 3332E9F86B380C2F07B-8066
01901 - Lumbar Support Height Adjustment Motor (V229)
                    Fault Status: 00101100
                    Reset counter: 105
                    Mileage: 57083 km
                    Date: 2013.12.03
                    Time: 23:08:17
   Part No SW: 1T0 035 680 D    HW: 1T0 035 680 D
   Component: RNS-MID       H61 3970
   Revision: AB001001    Serial number: VWZ6Z7M9006110
   Coding: 04000402040000A0000F
   VCID: 2F3AE588871028CF633-807A
                    Reset counter: 104
                    Mileage: 57123 km
                    Date: 2013.12.04
                    Time: 15:57:11
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0538
   Revision: 12110009    Serial number: 0004140429
   Coding: 0013B7
   Shop #: WSC 05311 115 08193
   VCID: 6D863F804D1C9ADF11F-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000002646374
   Coding: 010090
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 205    3301
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3536D7E0694C121F29F-8060
                    Fault Status: 11100101
                    Mileage: 57083 km
                    Date: 2013.12.03
                    Time: 17:38:60
                    Battery Volts: 12.7 V
                        DU
                    Temperature: 71.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
01316 - ABS Control Module
                    Fault Status: 11101101
                    Reset counter: 63
                    Mileage: 57083 km
                    Date: 2013.12.03
                    Time: 17:39:01
                    Voltage: 12.63 V
                        DU
                    Temperature: 71.0°C
                    RPM: 758 /min
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 09 KESSY PQ47   083 0341
   Coding: 01900A0001C60E76360494157200DFCE1058011324379C
   Subsystem 4 - Part No: 3AA 962 243
   Component: GEB.F.Heckoef       0719
   Component: EZE_2         H41 1623
   Coding: 00000008
   VCID: 6FBA2588479068CF233-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0538
   Revision: 14110009    Serial number: 0004155828
   Coding: 0013B6
   VCID: 6E84388C401A61C7285-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000002635502
   Coding: 010090
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000576312
   Coding: 0022157
                    Fault Status: 01101101
                    Reset counter: 68
                    Mileage: 56412 km
                    Date: 2013.11.16
                    Time: 14:13:05
                    Voltage: 12.30 V
                    Count: 105
                    Hex Value: 0x12E3
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 071600000B000200
   VCID: 372ADDE87FC0E00F3B3-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
5277959 - Swivel Module Left
          C1089 07 [009] - Mechanical Failure
                    Reset counter: 63
                    Mileage: 57083 km
                    Date: 2019.07.13
                    Time: 18:11:36
9574144 - Bulb for Low Beam Headlamp Left
          B1217 00 [009] - -
                    Fault Frequency: 25
                    Reset counter: 68
                    Mileage: 57083 km
                    Date: 2019.07.13
                    Time: 17:48:01
9574400 - Bulb for Low Beam Headlamp Right
          B1218 00 [009] - -
                    Fault Frequency: 28
                    Reset counter: 68
                    Mileage: 57083 km
                    Date: 2019.07.13
                    Time: 17:48:00
13705987 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_HR]
                    Fault Frequency: 49
                    Reset counter: 68
                    Mileage: 57083 km
                    Date: 2019.07.13
                    Time: 17:39:11
                    Reset counter: 104
                    Mileage: 57123 km
                    Date: 2013.12.04
                    Time: 15:57:11
   Component: Batt.regelung H41 1623
   Coding: 03260858
   VCID: 71BE23F051A47E3F357-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900448277
   Part No SW: 3C8 907 441 A    HW: 3C8 907 441 A
   Component: J772__Rearview      0140
   Revision: 00H10000    Serial number: 525PA8-J1Z9072
   Coding: 0020008
   VCID: 28080E94AEFE7FF7A29-807C
   Part No SW: 5K0 035 730 A    HW: 5K0 035 730 A
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007661430221
   Coding: 0201000000010110
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 231219B8DB589CAFF7B-8076
0022 - Radio
          U1066 00 [000] - No Communication
          [Steuergerät Radio (RNS): kein Signal/Kommunikation]
End----------(Elapsed Time: 02:09, VBatt start/end: 12.1V/12.1V)-----------
siLc
Tallinn, Estonia
C?ID=330192
There is another thread on this forum with another CC with the same revision (3AA937087J) of BCM having trouble with exterior lights. I wouldn't be surprised if the BCM was faulty.
Or maybe a bad ground?
