Audi A6 TPMS learning of sensor positions
Eddyg
C?ID=307189
Hi There,
First time poster so sorry if I get something wrong!
I was trying to get my TPMS up and working on my C6 S6. It is the Direct type with the wheel speed sensors. I had previously disabled all the TMPS to get rid of the warning but decided to buy some new sensors and try to get it working. Now they are not genuine Audi sensors but seemed reputable and came "pre-coded".
Once the sesnors were installed I enabled everything on the Instrument and gateway as well as MMI coding. I put the fuse back in and got the warning back up and could see the module on VCDS again. I used the MMi to put module in the learn state and went for a drive. After about 25 mins I got a fault code come up and when i queried the module it looked like it had not picked up the sensors.
On further investigation and datalogs I recorded from group 16 measuring block the wheel sensor status which is the last received data. This confirmed the module was actually picking up all four sensors. The tyre pressure seemed correct. i went round all 4 tyres and adjusted them and the reported pressure matched my manual gauge. But it seems no matter what I do rerunning the learn procedure it will not assign a sensor to a wheel. Anyone got any experience with this? Is it possible to manually assign the Sensor ID to a wheel using VCDS?
There does not seem to be a lot of information on this issue when i searched. Everyone says the module just learns it! I have attached my Autoscan. Any help would be really appreciated.
Cheers
Ed
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 37 42 46 47 4F
          52 53 55 56 61 62 65 6C 72 76 77
VIN: *****   Mileage: 141730km-88066miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
   Part No SW: 4F1 910 552 C    HW: 4F1 907 552
   Component: 5.2L V10/4V FSI    ª0060
   Revision: 59H14---    Serial number:
   Coding: 010D0003190F0160
   Shop #: WSC 00191 264 15243
   VCID: 24101E21A2DCE6078E1-8070
005715 - Please check DTC Memory of ABS Controller
               P1653 - 008 -  - Intermittent
                    Mileage: 141030 km
                    Date: 2019.06.24
                    Time: 20:51:12
                    Temperature: 21.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.811 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Mileage: 141738 km
                    Date: 2019.07.15
                    Time: 20:29:16
                    Temperature: 35.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.303 V
   Part No SW: 4F2 910 156 M    HW: 09E 927 156 C
   Component: AG6 09E 5,2 FSI RdW 0030
   Revision: --H01---    Serial number:        0100633
   Shop #: WSC 02325 785 00200
   VCID: 2F3AE10DFB1A555F633-807A
006231 - Load Signal
               P1857 - 001 - Error Message from ECU - Intermittent
                    Fault Status: 00100001
                    Mileage: 141030 km
                    Date: 2019.06.23
                    Time: 17:01:37
                    RPM: 896 /min
                    RPM: 800 /min
                    (no units): 30.0
                    (no units): 21.0
                    Temperature: 21.0°C
                    T.B. Angle: 0.0°
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 P    HW: 4F0 614 517 P
   Component: ESP 8.0 quattro H05 0070
   Coding: 0020920
   VCID: 313EE775ED2E43AF757-8064
                    Reset counter: 107
                    Mileage: 141030 km
                    Date: 2019.06.24
                    Time: 20:52:15
                    Hex Value: 0x0000
                    Hex Value: 0x42A2
                    Hex Value: 0x0024
                    Hex Value: 0x0191
                    Hex Value: 0x00FF
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100668631
   Coding: 0000151
   Shop #: WSC 00847 210 175223
   VCID: 63925D3DE752A13FB7B-8036
   Subsystem 1 - Part No: 4F0 910 131 G
   Component: FBSAUDIC6 KSG   H27 0080
   Part No SW: 4F1 910 732 E    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 351AF077534070
   Coding: 0011002
   Shop #: WSC 02335 785 00200
   VCID: 26140429D4E01417905-8072
   Subsystem 2 - Serial number: 00000000657018
   Subsystem 3 - Serial number: 0101.02.070000000100011148ÿ
   Subsystem 4 - Serial number: 011148ÿ
   Part No SW: 4F0 910 043 A    HW: 4F2 820 043 Q
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000052    Serial number: 00000030204757
   Coding: 0525578
   VCID: 1C6026C19AACDEC7361-8048
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Coding: 0015121
   Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H04 0190
   Coding: 00064784
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
                    Reset counter: 107
                    Mileage: 141028 km
                    Date: 2019.06.23
                    Time: 22:34:00
00532 - Supply Voltage B+
                    Reset counter: 107
                    Mileage: 141028 km
                    Date: 2019.06.23
                    Time: 22:34:00
   Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
   Component: MP3-Changer     H44 0390
   Revision: 00044000    Serial number: AUZ5ZBG3153590
   VCID: 1A6C20D99098A0F724D-804E
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276U8100484
   Shop #: WSC 02324 785 00200
Address 11: Engine II        Labels: Redir Fail!
                    Mileage: 141030 km
                    Date: 2019.06.24
                    Time: 20:51:43
                    Temperature: 21.0°C
                    Temperature: 24.0°C
                    Voltage: 11.684 V
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4F AIRBAG AUDI8RH30 0280
   Revision: 09H30000    Serial number: 0037LD0N17J8
   Coding: 0013382
   VCID: 290E0F15C5FE3B6FBD7-807C
   Subsystem 1 - Serial number: 6332CSME15284F163
   Subsystem 2 - Serial number: 6342CSME161B4C01+
   Subsystem 3 - Serial number: 6352QSME1E0F106DR
   Subsystem 4 - Serial number: 6362QSME200C0C59I
   Subsystem 5 - Serial number: 63734SME1D730B33%
   Subsystem 6 - Serial number: 63834SME1E0B085DB
   Revision: 00H08000    Serial number: 90055070120553
   Coding: 0102142
   Shop #: WSC 02323 785 00200
   VCID: 669444291460D417505-8032
                    Reset counter: 107
                    Mileage: 141030 km
                    Date: 2019.06.23
                    Time: 22:35:28
                    Reset counter: 107
                    Mileage: 141030 km
                    Date: 2019.06.23
                    Time: 22:36:23
   Part No SW: 4F0 910 930 C    HW: 4F0 920 980 P
   Component: KOMBIINSTR. M73 H19 0120
   Revision: 00000000    Serial number: 5H254XMC6
   Coding: 2129448
   Shop #: WSC 00581 210 64475
   VCID: 23121D3DA7D2E13FF7B-8076
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B071168250
   Coding: F555DEF7303A06
   Shop #: WSC 02334 785 00200
   VCID: 6C8036010A8CEE47061-8038
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 L
   Component: MNS ECE         H48 1060
   Revision: 00000000    Serial number: 364AX077633885
   VCID: 3B22C55D3F62B9FFDFB-806E
                    Reset counter: 107
                    Mileage: 141030 km
                    Date: 2019.06.23
                    Time: 22:35:59
                    Hex Value: 0x5D0F
                    Hex Value: 0xFECF
                    Hex Value: 0x0047
   Component: TSG FA          H12 0120
   Revision: 00000000    Serial number: A%@
   Coding: 0020090
   Shop #: WSC 02327 785 00200
   VCID: 2C00F601CA0C2E47461-8078
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01033243870000
   Coding: 0402171
   VCID: 2E04FC09FC105C57685-807A
01697 - Footwell Lighting; Rear Right (W46)
                    Reset counter: 126
                    Mileage: 72064 km
                    Date: 2012.11.29
                    Time: 09:16:22
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H10 0240
   Revision: PROD_01     Serial number: 00000000151314
   Coding: 0000117
   Shop #: WSC 00048 210 176595
   VCID: 25160325A9E61F0F99F-8070
   Revision:             Serial number: 00000000311512
   Coding: 0011114
   VCID: 5EE46CC9CC308CD7985-800A
   Component: TSG BF          H12 0120
   Revision: 00000000    Serial number: AHA
   Coding: 0020090
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0008021
   VCID: 20181231B6C4FA27EA9-8074
                    Reset counter: 107
                    Mileage: 141024 km
                    Date: 2019.06.23
                    Time: 22:35:56
                    Voltage: 6.42 V
                    Count: 200
   Coding: 0000016
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 L
   Revision: 00000000    Serial number: 394AY077729355
   Revision: 00000000    Serial number: 00000000010285
   Shop #: WSC 24059 576 58588
   Component: von VA0  2701290851
   Coding: 344630393135313035442056413032373031323930383531
   Shop #: WSC 00000 512 00290
02272 - Quiescent Current Stage 1
                    Fault Frequency: 160
                    Mileage: 132701 km
                    Date: 2017.11.29
                    Time: 18:36:22
                    Fault Frequency: 87
                    Mileage: 132701 km
                    Date: 2017.12.09
                    Time: 12:54:09
02276 - Quiescent Current Stage 5
                    Fault Frequency: 79
                    Mileage: 132701 km
                    Date: 2017.12.09
                    Time: 12:54:19
                    Mileage: 141731 km
                    Date: 2019.07.15
                    Time: 10:50:05
                    Reset counter: 107
                    Mileage: 141030 km
                    Date: 2019.06.23
                    Time: 22:36:45
   Coding: 0019498
   Revision: 00050100    Serial number: 00000900042396
   Coding: 0022725
   Shop #: WSC 00000 785 00200
   VCID: 221C1839B8C8E837FCD-8076
                    Fault Status: 10100010
                    Reset counter: 118
                    Mileage: 141725 km
                    Date: 2019.07.15
                    Time: 10:00:00
                    (no units): 0.0
                    Voltage: 14.20 V
                    (no units): 19.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 4F0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J6Y300T
   Coding: 1020205
   VCID: 1E642CC98CB0CCD7D85-804A
                    Reset counter: 107
                    Mileage: 141030 km
                    Date: 2019.06.23
                    Time: 22:34:39
                        Reverse OFF
                    Count: 3
                    Reset counter: 107
                    Mileage: 141030 km
                    Date: 2019.06.23
                    Time: 22:35:12
                        Reverse OFF
                    Count: 3
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Coding: 0019498
   Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
   Component: Parkhilfe 8-Kan H12 0060
   Revision: 00H12000    Serial number: 06330702900342
   Coding: 0221116
   VCID: 28080A11DEF40267A29-807C
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H16 1130
   Revision: 00000000    Serial number: 00000007649753
   Coding: 0010920
   Shop #: WSC 00205 210 90077
End----(Elapsed Time: 02:06, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
Wednesday,17,July,2019,13:28:31:29074
Dealer/Shop Name: Ed George
VIN: WAUZZZ4F27N118965   License Plate:
Mileage: 141730km-88066mi   Repair Order:
VIN: WAUZZZ4F27N118965   Mileage: 141730km-88066miles
Readiness: 0110 1101
   Coding: 0020920
   Coding: 0000151
   Coding: 0011002
   Coding: 0525578
   Coding: 0015121
   Coding: 00064784
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Coding: 0013382
   Coding: 0102142
   Coding: 2129448
   Coding: 0020090
   Coding: 0402171
                    Reset counter: 126
                    Mileage: 72064 km
                    Date: 2012.11.29
                    Time: 09:16:22
   Coding: 0000117
   Coding: 0011114
   Coding: 0020090
   Revision: --H04---
   Coding: 0008021
   Coding: 0000016
                    Mileage: 141738 km
                    Date: 2019.07.17
                    Time: 13:13:49
   Coding: 0019498
   Coding: 0022725
                    Reset counter: 118
                    Mileage: 141725 km
                    Date: 2019.07.15
                    Time: 10:00:00
                    (no units): 0.0
                    Voltage: 14.20 V
                    (no units): 19.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 1020205
   Coding: 0019498
   Coding: 0221116
   Coding: 0010920
End----------(Elapsed Time: 02:02, VBatt start/end: 12.1V/12.2V)-----------
Drive the car a bit to make sure the sensors are awake, then show us all the MVB's in 65-TPMS.
[Applications]
[Controller Channel Map]
Controller Address = 65
Login or security access: Leave blank
Function: Measuring Values
Output: CSV file
[Go]
Post the whole map here.
grant@gendan
Did you clear the fault codes before running the learn procedure?
I can see there are ABS fault codes and voltage level faults in other systems. It may be picky about running the learning procedure when you have fault codes in systems.
What happened between the 2 scans? The top scan and bottom scan have the same mileage but show different fault codes. Did you clear the fault codes before running the 2nd AutoScan?
Eddyg
C?ID=307189
Hi UWE,
please see below.
;SW:4F0-910-273-B   HW:4F0-907-273-A ---  Tire Pressure
;Component:Reifendruck 3   H05 0100, Coding:0022725
;Wednesday,17,July,2019,17:04:24:29074
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 221C1839B8C8E837FCD-8076
Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
1, , ,no Value, , , ,2.70 bar,Pressure,
2, , ,no Value, ,N/A,,N/A,,
3,       2.080.905.734 Status 00h         ,Wheel Sensor,
4, , ,no Value, , , ,2.92 bar,Pressure,
5, , ,no Value, ,N/A,,N/A,,
6,       2.080.635.994 Status 00h         ,Wheel Sensor,
7, , ,no Value, , , ,2.67 bar,Pressure,
8, , ,no Value, ,N/A,,N/A,,
9,       2.080.666.539 Status 00h         ,Wheel Sensor,
10, , ,no Value, , , ,2.67 bar,Pressure,
11, , ,no Value, ,N/A,,N/A,,
12,       2.081.333.346 Status 00h         ,Wheel Sensor,
13, , ,no Value, , , ,2.50 bar,Pressure,
14, , ,no Value, ,N/A,,N/A,,
15,       0.000.000.000 Status 00h         ,Wheel Sensor,
16,2.081.333.346 Status 71h UB. iO  2.52bar,Wheel Sensor,
17,0140   0001   0000   00   00   00   29AA,Wheel Sensor,
20,0.080 V,Voltage,2.280 V,Voltage,N/A,,N/A,,
21,8E0907277   ,Antenna,
40,1400353625   1400353626   1400325644    ,,
41,1400348028   0000000000   0000000000    ,,
42,0000000000   0000000000   1400325781    ,,
50,    0000    0000    0000    0000    0000,,
51,    0000    0000    0000    0000    0000,,
52,Deactivated, ,0.00 s,Time,255.0,(no units),OK, ,
125,0.0 km/h,Speed,ABS 1, ,640 /min,RPM,Engine 1, ,
126,24.5°C,Temperature,HVAC 1, ,Term 15 On, ,14.00 V,Voltage,
127,2-Wire, ,N/A,,N/A,,N/A,,
130,Door Closed, , , ,OFF, ,N/A,,
140,Gateway 0, ,N/A,,N/A,,N/A,,
Grant,
I did not clear all fault codes and I did have the battery go flat on me hence all the low voltage codes. I have cleared these on the driveway and not driven since. so you may be picking up on this. I have not cleared the code on the TPMS this time around but yes I have cleared the TPMS code and tried to do the learn but not with all the rest of the codes cleared.
Will give that a quick try now!
Ed
Hmm... MVB 16 is: "Sensor Status (from last Received Wheel ID)" and the ID there (2.081.333.346) does not match any of the other IDs in the lower numbered blocks.
The IDs in the lower-numbered blocks are all for sensors with a status of "00h", which implies they are in storage mode.
Color me confused.
Dana
Western PA, USA
Typically those systems do just learn the new sensor IDs but you would firstly need to Learn or Store new wheels via the MMI menu before setting off on the test drive. The problem is, if any one of the 4 sensors don't pickup properly while on that test drive the sensors do not match/learn to the module in my experience.
If you have a point and shoot TPMS tool, or a nearby workshop that will test the sensors for a reasonable cost, I would make sure the replacement sensors are the proper frequency in addition to verifying each of the sensors have a unique serial number. Universal sensors can often have the same ID in more than one sensor (which won't work) and the incorrect frequency (i.e. incorrect sensors) won't work either.
After verifying the sensors are both correct with unique serial numbers for each wheel we can check to see if the LIN antenna (MVB 21,8E0907277 ,Antenna,) happens to be the newest revision because there were some issues/TSBs with those.
NEtech
C?ID=56995
What about MWB 12 (Right rear wheel) 2.081.333.346 :confused:
My understanding for testing is, release air of each wheel with more that 0.2 bar pr minute, it is then going to sending mode (x2h), and check data of that wheel in MWB 16.
Eddyg
C?ID=307189
I have done the reset through the MMi several times now. When I do this the values in MVB 3,6,9 and 12 all go back to 0.000.000.000 status 00h. After the drive the IDs then get applied to the MVB 3,6,9, 12.
There are definitely 4 different IDs being picked up by the system and I have gone round each wheel individually watching MVB 16 and dropping the pressure in each wheel to verify it is the correct sensor.
Rear Right is 2.081.333.346
Front Right is 2.080.666.539
Rear Left is 2.080.635.994
Front Left is 2.080.905.734
I assume if the frequency was wrong or the IDs were the same this would have shown up on this test. Interestingly I don't believe the system has "assigned" the Ids to the correct wheel in terms of MVB 3,6,9 and 12.
MVB 16 shows each sensor with a status and pressure but this never carries through to the other MVB. Is it likely to be the aftermarket sensors? I have been going back and forth with them and they think its a car issue..
