Hi There,
First time poster so sorry if I get something wrong!
I was trying to get my TPMS up and working on my C6 S6. It is the Direct type with the wheel speed sensors. I had previously disabled all the TMPS to get rid of the warning but decided to buy some new sensors and try to get it working. Now they are not genuine Audi sensors but seemed reputable and came "pre-coded".
Once the sesnors were installed I enabled everything on the Instrument and gateway as well as MMI coding. I put the fuse back in and got the warning back up and could see the module on VCDS again. I used the MMi to put module in the learn state and went for a drive. After about 25 mins I got a fault code come up and when i queried the module it looked like it had not picked up the sensors.
On further investigation and datalogs I recorded from group 16 measuring block the wheel sensor status which is the last received data. This confirmed the module was actually picking up all four sensors. The tyre pressure seemed correct. i went round all 4 tyres and adjusted them and the reported pressure matched my manual gauge. But it seems no matter what I do rerunning the learn procedure it will not assign a sensor to a wheel. Anyone got any experience with this? Is it possible to manually assign the Sensor ID to a wheel using VCDS?
There does not seem to be a lot of information on this issue when i searched. Everyone says the module just learns it! I have attached my Autoscan. Any help would be really appreciated.
Cheers
Ed
Cheers
Ed
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 37 42 46 47 4F
52 53 55 56 61 62 65 6C 72 76 77
VIN: ***** Mileage: 141730km-88066miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 C HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0060
Revision: 59H14--- Serial number:
Coding: 010D0003190F0160
Shop #: WSC 00191 264 15243
VCID: 24101E21A2DCE6078E1-8070
P1653 - 008 - - Intermittent
Mileage: 141030 km
Date: 2019.06.24
Time: 20:51:12
Temperature: 21.0°C
Temperature: 24.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.811 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Fault Status: 01101000
Mileage: 141738 km
Date: 2019.07.15
Time: 20:29:16
Temperature: 35.0°C
Temperature: 36.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.303 V
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI RdW 0030
Revision: --H01--- Serial number: 0100633
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 2F3AE10DFB1A555F633-807A
006231 - Load Signal
P1857 - 001 - Error Message from ECU - Intermittent
Fault Status: 00100001
Mileage: 141030 km
Date: 2019.06.23
Time: 17:01:37
RPM: 896 /min
RPM: 800 /min
(no units): 30.0
(no units): 21.0
Temperature: 21.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 P HW: 4F0 614 517 P
Component: ESP 8.0 quattro H05 0070
Coding: 0020920
VCID: 313EE775ED2E43AF757-8064
Reset counter: 107
Mileage: 141030 km
Date: 2019.06.24
Time: 20:52:15
Hex Value: 0x0000
Hex Value: 0x42A2
Hex Value: 0x0024
Hex Value: 0x0191
Hex Value: 0x00FF
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100668631
Coding: 0000151
Shop #: WSC 00847 210 175223
VCID: 63925D3DE752A13FB7B-8036
Subsystem 1 - Part No: 4F0 910 131 G
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 KSG H27 0080
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F1 910 732 E HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 351AF077534070
Coding: 0011002
Shop #: WSC 02335 785 00200
VCID: 26140429D4E01417905-8072
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000657018
Subsystem 3 - Serial number: 0101.02.070000000100011148ÿ
Subsystem 4 - Serial number: 011148ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030204757
Coding: 0525578
VCID: 1C6026C19AACDEC7361-8048
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Coding: 0015121
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Reset counter: 107
Mileage: 141028 km
Date: 2019.06.23
Time: 22:34:00
Reset counter: 107
Mileage: 141028 km
Date: 2019.06.23
Time: 22:34:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBG3153590
VCID: 1A6C20D99098A0F724D-804E
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276U8100484
Coding: 0000001
Shop #: WSC 02324 785 00200
Address 11: Engine II Labels: Redir Fail!
Mileage: 141030 km
Date: 2019.06.24
Time: 20:51:43
Temperature: 21.0°C
Temperature: 24.0°C
Voltage: 11.684 V
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0N17J8
Coding: 0013382
VCID: 290E0F15C5FE3B6FBD7-807C
Subsystem 1 - Serial number: 6332CSME15284F163
Subsystem 2 - Serial number: 6342CSME161B4C01+
Subsystem 3 - Serial number: 6352QSME1E0F106DR
Subsystem 4 - Serial number: 6362QSME200C0C59I
Subsystem 5 - Serial number: 63734SME1D730B33%
Subsystem 6 - Serial number: 63834SME1E0B085DB
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90055070120553
Coding: 0102142
Shop #: WSC 02323 785 00200
VCID: 669444291460D417505-8032
Component: Lenkradmodul H07 0090
Reset counter: 107
Mileage: 141030 km
Date: 2019.06.23
Time: 22:35:28
Reset counter: 107
Mileage: 141030 km
Date: 2019.06.23
Time: 22:36:23
Part No SW: 4F0 910 930 C HW: 4F0 920 980 P
Component: KOMBIINSTR. M73 H19 0120
Revision: 00000000 Serial number: 5H254XMC6
Coding: 2129448
Shop #: WSC 00581 210 64475
VCID: 23121D3DA7D2E13FF7B-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B071168250
Coding: F555DEF7303A06
Shop #: WSC 02334 785 00200
VCID: 6C8036010A8CEE47061-8038
Part No SW: 4E0 910 888 P HW: 4E0 919 887 L
Component: MNS ECE H48 1060
Revision: 00000000 Serial number: 364AX077633885
VCID: 3B22C55D3F62B9FFDFB-806E
Reset counter: 107
Mileage: 141030 km
Date: 2019.06.23
Time: 22:35:59
Hex Value: 0x5D0F
Hex Value: 0xFECF
Hex Value: 0x0047
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: A%@
Coding: 0020090
Shop #: WSC 02327 785 00200
VCID: 2C00F601CA0C2E47461-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01033243870000
Coding: 0402171
VCID: 2E04FC09FC105C57685-807A
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
01697 - Footwell Lighting; Rear Right (W46)
Reset counter: 126
Mileage: 72064 km
Date: 2012.11.29
Time: 09:16:22
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000151314
Coding: 0000117
Shop #: WSC 00048 210 176595
VCID: 25160325A9E61F0F99F-8070
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000311512
Coding: 0011114
VCID: 5EE46CC9CC308CD7985-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: AHA
Coding: 0020090
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0008021
VCID: 20181231B6C4FA27EA9-8074
Reset counter: 107
Mileage: 141024 km
Date: 2019.06.23
Time: 22:35:56
Voltage: 6.42 V
Count: 200
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394AY077729355
Coding: 0000001
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000010285
Shop #: WSC 24059 576 58588
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2701290851
Coding: 344630393135313035442056413032373031323930383531
Shop #: WSC 00000 512 00290
02272 - Quiescent Current Stage 1
Fault Frequency: 160
Mileage: 132701 km
Date: 2017.11.29
Time: 18:36:22
02273 - Quiescent Current Stage 2
Fault Frequency: 87
Mileage: 132701 km
Date: 2017.12.09
Time: 12:54:09
02276 - Quiescent Current Stage 5
Fault Frequency: 79
Mileage: 132701 km
Date: 2017.12.09
Time: 12:54:19
02277 - Quiescent Current Stage 6
Mileage: 141731 km
Date: 2019.07.15
Time: 10:50:05
Reset counter: 107
Mileage: 141030 km
Date: 2019.06.23
Time: 22:36:45
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0019498
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900042396
Coding: 0022725
Shop #: WSC 00000 785 00200
VCID: 221C1839B8C8E837FCD-8076
002 - Lower Limit Exceeded - Intermittent - MIL ON
Fault Status: 10100010
Reset counter: 118
Mileage: 141725 km
Date: 2019.07.15
Time: 10:00:00
(no units): 0.0
Voltage: 14.20 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6Y300T
Coding: 1020205
VCID: 1E642CC98CB0CCD7D85-804A
Reset counter: 107
Mileage: 141030 km
Date: 2019.06.23
Time: 22:34:39
Reverse OFF
Count: 3
Reset counter: 107
Mileage: 141030 km
Date: 2019.06.23
Time: 22:35:12
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0019498
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330702900342
Coding: 0221116
VCID: 28080A11DEF40267A29-807C
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007649753
Coding: 0010920
Shop #: WSC 00205 210 90077
End----(Elapsed Time: 02:06, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
Wednesday,17,July,2019,13:28:31:29074
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Ed George
VIN: WAUZZZ4F27N118965 License Plate:
Mileage: 141730km-88066mi Repair Order:
VIN: WAUZZZ4F27N118965 Mileage: 141730km-88066miles
Readiness: 0110 1101
Coding: 0000001
Coding: 0020920
Coding: 0000151
Coding: 0011002
Coding: 0525578
Coding: 0015121
Coding: 00064784
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Coding: 0000001
Coding: 0013382
Coding: 0102142
Coding: 2129448
Coding: 0020090
Coding: 0402171
Reset counter: 126
Mileage: 72064 km
Date: 2012.11.29
Time: 09:16:22
Coding: 0000117
Coding: 0011114
Coding: 0020090
Revision: --H04---
Coding: 0008021
Coding: 0000016
Coding: 0000001
Mileage: 141738 km
Date: 2019.07.17
Time: 13:13:49
Coding: 0019498
Coding: 0022725
Reset counter: 118
Mileage: 141725 km
Date: 2019.07.15
Time: 10:00:00
(no units): 0.0
Voltage: 14.20 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1020205
Coding: 0019498
Coding: 0221116
Coding: 0010920
End----------(Elapsed Time: 02:02, VBatt start/end: 12.1V/12.2V)-----------
