Adaptation Problem in 8E central electronics -09 with HEX V2 adapter
Egon
Sweden
C?ID=193181
Don't know what you do or how you do things... Using a non genuine version of Windows isn't that smart either ;)
Try by selecting the item you want to change from the pull-down menu instead of changing channel-number(s)...
Ok...there!! i've fixed the non geuine windows that had nothing to do with the issue AT ALL so the genuine windows comment was basically your own irrelevant personal opinion.
and it's not a matter of me successfully accessing adaptation channel options with one adapter then forgetting how to do the exact same thing a few seconds later with the other adapter.
!!!!!!!!!!THIS IS MY ISSUE!!!!!!!!!!!
hello everybody!
my friends older, cheaper AI adapter can access and make more changes than my newer, more expensive HEX-V2 adapter is able to do! WHY??!?!?!
i spoke to the swedish www.VCDS.se and told them, and they told me that the HEX should be better and access and change more S*IT than the AI adapter but it DON'T!
07-03-2019, 08:59 PM Uwe told me
Unfortunately it's s 4th of July week both guys who need to look at this are on vacation.
then never answered me again!
THATS my issue!!!
don't get sidetracked with personal opinions about my desktop background, the font i use when i'm typing, the batterylevel on my computer right now or some other irrelevant f*cking things!
it's simple!.. if YOU don't know, im not asking YOU!
i'm asking if SOMEBODY knows?!?! if someone actually knows, THATS the one person i'm asking..
thank you.
   #22
golfi_vend
Tartu, Estonia
C?ID=195131
I'm having issue too with 8E platform and different Hex-NET and V2 devices.
I believe it being to due the issue this car diagnostic is built.
I dislike that high-end device like Hex-NET isn't able to access it correctly, but I do understand that main developent focus goes on newer models(ie...MQB) and that may be reason that some stuff may have been missed.
Same thing like when Vas-PC moved to ODIS. Older stuff had some bugs.
   #23
Dana
Western PA, USA
Hello Egon,
If you still have access to both interfaces please try the following:
HEX-USB+CAN or similar Legacy Interface (good baseline info):
[Options]
Change the Debug level from 0 to 1024
[Apply]
[Select]
[09-Cent. Elect.]
We know it will communicate with all of the channels so select a single channel, Read and wait for data to populate.
Exit the controller and [Exit] VCDS.
Please slide the files with .dlm extensions in the Debug folder into a new folder named HUC1024. By default that would be: C:\Ross-Tech\VCDS\Debug
Make sure the Debug folder is empty after completing the HEX-USB+CAN testing.
HEX-NET -or- HEX-V2:
Debugging needs to be performed with the USB wire (not wireless).
1) Repeat the Debug level 1024 instructions above. Make sure to read the same single channel. Please move the .dlm files into a folder called: HV21024
Again, make sure the Debug folder is empty after completing that sequence.
2) Change the Debug level from 0 to 1028
Repeat the original steps. Both .dlm and .edl files will be generated moving forward. Please move those into a folder named HV21028 so the Debug folder is empty.
3) The last debug level in VCDS is 1044. We would want to repeat the VCDS steps saving .dlm and .edl files to a new folder called HV21044.
Zipping all of those up and sending them to support via e-mail would give us the most comprehensive set of files to use to find the bug without a car present.
If you don't have time for all of those steps please get 1024s using each interface which will give us a starting point.
   #24
golfi_vend
Tartu, Estonia
C?ID=195131
I'm now having similar issue with A6. Not sure if related or not, but I've sent debugs to support.
   #25
Egon
Sweden
C?ID=193181
Please let me know when you get some answers! :thumbs:
   #26
Dana
Western PA, USA
Thanks Magnus, We received the files. Hopefully they shed light on this concern!
Egon
Sweden
C?ID=193181
Hello!
Does anybody have some new information about our issue? :)
   #28
Egon
Sweden
C?ID=193181
Anything yet?
   #29
golfi_vend
Tartu, Estonia
C?ID=195131
I'm having a Audi A4 B6/B7 in the shop where I can make a Hex-NET debug from in few days. Need to fix CKP sensor and water leak issues first to have a good reference scan....
   #30
Egon
Sweden
C?ID=193181
Well to get some closure to this thread.
I've got a used AI adapter and all my problems regarding these issiues magically resolved themselves!
Good luck to the rest of you.
   #31
Ar393
C?ID=398414
Cant get address 09 to take VIN
Sorry to rehash a thread, but I have searched and I have not actually found an answer.
I purchased a 2003 A4 Wagon with some issues. I narrowed most of it down to the gasket under the ECM housing was not in place (I also checked the drains in the plenum) and water had dumped into foot-well, CECM, and all the a-pillar connections. The floor padding/foam was soaked but the CCCM in the box was dry. I took a few days to dry everything out. The CECM (8E0 907 279 E) had corrosion inside it. a few of the pins in the t-20/t-13 connections in the a-pillar were corroded as well. I cleaned up a bunch of the connections but I still will need to bypass a few of the connections to correct some of the open to short, open to ground issues.
The previous owner had the ABS module replaced I believe because the module was not coded correctly for the car. I recoded that properly and have done some things here and there. They also swapped out the steering wheel, which sucks, I would rather have the MFSW, so I had to recode that for the 3 spoke wheel that is on the car.
I called up VW and they said the proper part now for my VIN is the 8E0 907 279 F. I grabbed one from eBay and I installed it. I coded it properly, but I can't get it to take my VIN. I can't even get my old one to take my VIN (what I mean is I can't get to the adaptation to read, test, save) for either CECM.
Some addresses I can adapt things, other ones, I again have the same issue with the "read" not returning a value (even though I can read the 081 group via the measuring block, but when I read them in the adaptation, nothing happens and the "new value" is solid).
Hex-V2 purchased directly from you guys, latest firmware, software.
Below is the auto-scan with the "new" CECM:
Tuesday,19,May,2020,18:11:23:62646
VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUVT68E73A346543   License Plate:
Chassis Type: 8E (Ben - Audi A4)
Scan: 01 03 08 09 15 16 17 25 36 46 55 56
VIN: WAUVT68E73A346543   Mileage: 353100km-219406miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E0 909 559 E    HW: 8E0 909 059
   Component: 3.0L V6/5V      G   0004
   Coding: 0016711
   Shop #: WSC 63351 000 00000
   VCID: 372B2D4A4352CFD3A28-5160
Readiness: 0110 1101
   Part No: 4B0 614 517 H
   Component: ABS/ESP allrad      1728
   Coding: 04495
   Shop #: WSC 12345
   VCID: 2615F00E91F8465B09E-51F2
   Part No: 8E0 820 043 L
   Component:   A4 Klimaautomat   1116
   Coding: 00000
   Shop #: WSC 63351
   VCID: 2A0D043E85E0623B2D6-513C
00710 - Defroster Flap Positioning Motor (V107)
            41-00 - Blocked or No Voltage
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  RDW 0517
   Coding: 00011
   Shop #: WSC 63351
   VCID: 353727425C5E3DC3B04-4B00
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 - -
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 C
   Component: Airbag 8.4EP        2000
   Coding: 0010607
   VCID: 372B2D4A4352CFD3A28-5184
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
            011 - Open Circuit - MIL ON
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0308
   Coding: 01042
   Shop #: WSC 63351
   VCID: 3E25386E6968FE9B61E-4B00
   Part No: 8E0 920 950 L
   Component: KOMBI+WEGFAHRS. RB4 D36
   Coding: 01400
   Shop #: WSC 05314
   VCID: 323D1C5EAD302AFB956-5160
   WAUVT68E73A346543     AUZ6Z0C0063197
01316 - ABS Control Module
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   Shop #: WSC 63351
   VCID: 71BFD352688651E3ACC-4B3C
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1311
   Coding: 26444
   Shop #: WSC 12345
   VCID: 72BDDC5E6DB06AFB556-4B00
   Subsystem 1 - Part No: 8E1959801
   Component: Tõrsteuer.FS BRM 0003
   Component: Tõrsteuer.BF BRM 0003
01134 - Alarm Horn (H12)
            29-00 - Short to Ground
   Part No: 4Z7 907 357
   Coding: 00060
   Shop #: WSC 63351
   VCID: 04518A864734544B77A-4B3C
Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
   Part No: 8E0 035 195 F
   Component: symphony II NP2    0051
   Coding: 01005
   Shop #: WSC 03751
   VCID: 2A0D043E85D0623B2D6-4E62
00879 - Connection to Speaker Front Right
            36-00 - Open Circuit
End----(Elapsed Time: 01:39, VBatt start/end: 10.7V/10.5V. VIgn 10.5V)-----
This was my original scan:
Wednesday,04,March,2020,11:03:45:62646
          67 69 75 76 77
VIN: WAUVT68E73A346543   Mileage: 351130km-218182miles
   Coding: 0016711
   VCID: 372B2D4A4352CFDF38F-5160
16805 - Warm Up Catalyst; Bank 1
            P0421 - 001 - Efficiency Below Threshold - MIL ON
16815 - Warm Up Catalyst; Bank 2
            P0431 - 001 - Efficiency Below Threshold - MIL ON
Readiness: 0000 1000
   Coding: 00000
   VCID: 2615F00E91F84657939-51F2
            30-00 - Open or Short to Plus
            35-00 - -
            66-10 - Not Matched - Intermittent
   Coding: 00000
   Shop #: WSC 63351
   VCID: 2A0D043E85E06237B71-5160
            41-10 - Blocked or No Voltage - Intermittent
   Part No: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0305
   Coding: 00001
   VCID: 34311A46572424C71DD-4B00
01753 - Windshield Wiper Motor (V) Stage 1
            31-10 - Open or Short to Ground - Intermittent
   Coding: 0010607
   VCID: 372B2D4A4352CFDF38F-5184
   Coding: 02042
   Shop #: WSC 63351
   VCID: 3E25386E6968FE97FB9-4B00
01426 - Controls in Steering Wheel (E221)
            49-00 - No Communications
   Coding: 03200
   Shop #: WSC 05314
   VCID: 323D1C5EAD302AF70F1-5184
   Coding: 00002
   Shop #: WSC 63351
   VCID: 71BFD352688651EF36B-4B3C
   Coding: 12044
   Shop #: WSC 63351
   VCID: 72BDDC5E6DB06AF7CF1-4B00
16 Faults Found:
00962 - Alarm via. Tilt Sensor
            35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 - -
01369 - Alarm triggered by Hood Switch
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
01574 - Alarm triggered by Door Contact Switch; Rear Right
            35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
            35-00 - -
00955 - Key 1
            35-10 - - - Intermittent
00956 - Key 2
01403 - Glass-Break Sensors; Rear
            36-10 - Open Circuit - Intermittent
01561 - Rear left door
            59-10 - Can't Unlock - Intermittent
01562 - Rear right door
   Coding: 00060
   Shop #: WSC 63351
   VCID: 04518A8647345447EDD-4B5C
   Coding: 01005
   Shop #: WSC 03751
   VCID: 2A0D043E85D06237B71-4E62
End----------(Elapsed Time: 05:20, VBatt start/end: 14.4V/14.2V)-----------
Here are screengrabs of what I see when I try to do the adaptation in address 09 in the "original" E version:
https://photos.app.goo.gl/GtrZUGZtENELaSuo6
https://photos.app.goo.gl/h7nhap76PcpcEFAh9
https://photos.google.com/share/AF1...?key=U1h5c3V3UmR5QW1IdWdOZmpjWUFidWxSSXJZb0d3
Your first three picture links produce a "404 Not Found" error.
I think we got a handle on this problem recently. Stand by...
Ar393
C?ID=398414
We may not have a proper solution until we get hands on a car that exhibits the problem, but do try what he did.
Will do. Also I did try using a different laptop with a fresh install of VCDS before posting here with no luck. It was also a win 10x64 laptop. I will post again when I have the debug files.
   #35
Ar393
C?ID=398414
Also,
I noticed this behavior as well that the other guy mentioned in the other thread. In some of the measuring blocks, I get data, and then alternately I get "Data for Group XXX Not Available" here and there.
Could this be a USB3/3.1 issue? The computer is ready for data way faster than the car is able to send it, and when it doesn't get it, it just gives up?
   #36
Ar393
C?ID=398414
I just sent you guys the debug file for address 09 as requested. I also included the log as well as two screenshots.
After reading the other thread I tried two things with the same exact result. One set of attempts I plugged a USB2 hub into my USB3 (my laptop has one USB3, two USB-Cs), the other attempt the HEX-V2 was directly connected to the USB3 port via the ross-tech cable.
I decided to try clicking multiple times & multiple intervals to see if anything different would happen. In my first attempt, I also ran it through a USB2 hub, and when I clicked five times rather quickly, I was able to enter a new value. This is shown in one of the screenshots I emailed you guys with the log and debug file. After a few tries of this, I could also test and save. This is shown in the second screenshot in the email.
I click "read" five times fast and it reads, yay!:confused:
I get to enter the new value, yay!:eek:
I get to test it, yay!:o
I get to save it, yay!:)
I confirm I'm saving it, yay!:D
The log says I adapted it, yay!:thumbs:
I check channel 81, boo!:facepalm:
The VIN didn't change, cry.:banghead:
Wednesday,20,May,2020,11:21:08:62646
VIN: WAUVT68E73A346543   License Plate: USB2
Control Module Part Number: 8E0 907 279 F
  Component and/or Version: int. Lastmodul  RDW 0517
           Software Coding: 00011
            Work Shop Code: WSC 63351
            35-00 - -
                Address 09: Cent. Elect.  (8E0 907 279 F)
11:23:21 Group 081: Advanced Control Module Identification II
  WAUPL68E94A274951 000000012110Ï5    Vehicle Ident. Number (VIN)
11:23:23 Group 081: Advanced Control Module Identification II
Address 09,8E0 907 279 F,channel 81,adapted from,0,to,46992,
11:27:52 Group 081: Advanced Control Module Identification II
11:29:01 Group 081: Advanced Control Module Identification II
11:29:03 Group 081: Advanced Control Module Identification II
11:29:56 Group 081: Advanced Control Module Identification II
I tried the same thing going straight into the USB3 port. Same exact results:
Wednesday,20,May,2020,11:44:58:62646
VIN: WAUVT68E73A346543   License Plate: USB3
11:44:49 Group 081: Advanced Control Module Identification II
11:45:05 Group 081: Advanced Control Module Identification II
Adaptation Channel 081:
Stored value
Stored value 0
Component Protection (Vehicle Identification Number)
  PIN ?
Stored value 0
  PIN ?
11:48:45 Group 081: Advanced Control Module Identification II
   #37
Dana
Western PA, USA
Thanks for the feedback and Scan/Debug files via e-mail.
This is a long shot but you might want to try increasing the default Blk Int from 55 to 100 (or 150) on the VCDS Program Options screen followed by Apply and repeating Adp 081 in address 09. With any luck that gets you over the hump so the VIN will transfer.
Side note, using Apply should revert back to defaults when you close and restart VCDS but Save would keep the alternative values even after restarting VCDS. If a higher Blk Int happens to resolve this Adp problem, you notice that MVBs are more stable and/or future Auto-Scans happen to show all 4 subsystems under address 46 (instead of 1.5 per the emailed scan) you may want to Save it. There's a [Restore Defaults] button that you can use in the event that it causes new problems later.
   #38
Ar393
C?ID=398414
Copy. I will try it and let you guys know, hopefully in the next couple of hours.
ok.
   #39
Ar393
C?ID=398414
SOLVED!!!!!!!!!!!
increase the default Blk Int from 55 to 150 on the VCDS Program Options screen followed by "save" and repeating Adp 081 in address 09
:thanks::cool:
There is no Guul, only Dana.
I am 99% sure the remaining issues are corroded contacts in the terminals on the a-pillar. I will check the wiring diagrams I have found so I know which wires to splice and be done with all the codes! (Then all that's left is the upper control arms...but that is for a different forum)
Wednesday,20,May,2020,16:55:08:62646
   Coding: 0016711
   Coding: 00000
   Shop #: WSC 63351
   VCID: 2A0D043E85E0623B2D6-5160
   Coding: 00011
   Coding: 0010607
   Coding: 01400
   Shop #: WSC 05314
   Coding: 00002
   Shop #: WSC 63351
   Coding: 26444
   Shop #: WSC 12345
   Coding: 00060
   Shop #: WSC 63351
   VCID: 04518A864734544B77A-4B5C
   Coding: 01005
   Shop #: WSC 03751
End----------(Elapsed Time: 02:06, VBatt start/end: 12.1V/12.1V)-----------
Ha, I said "all that's left", yeah right.
   #40
Ar393
C?ID=398414
So at 150 (im pretty sure) I get the 1 subsystem
   Coding: 26444
   Shop #: WSC 12345
I get this at 100.
                Address 46: Central Conv.       Labels: 8E0-959-433-MAX.clb
Control Module Part Number: 8E0 959 433 BB
  Component and/or Version: Komfortgerát T7B    1311
           Software Coding: 26444
            Work Shop Code: WSC 12345
           Additional Info: 8E1959801      Tõrsteuer.FS BRM 0003
           Additional Info: 8E1959802E     Tõrsteuer.BF BRM 0003
           Additional Info:    Tõrsteuer.HL BRM 0003
and well, the first scan with 1.5 was what I got at 55.
I went through every scan I had. with the Audi a4, 2003 b6 3.0 V6/30v 6MT Quattro wagon (everything in this thread) I never showed 4 subsystems.
I have one scan of a Passat glx wagon, 2002 b5.5 2.8L V6/20v AT 4Mo, and that has all 4 systems.
   Part No: 1C0 959 799 C
   Component: 81 Komfortgerát HLO 0004
   Coding: 00258
   Shop #: WSC 04940
   VCID: 372B2D4A4652CFDF38F-4B00
   Subsystem 1 - Part No: 1C0959801
   Component: 0Q Tõrsteuer.FS KLO 0001
   Subsystem 2 - Part No: 1C0959802A
   Component: 0Q Tõrsteuer.BF KLO 0002
   Subsystem 3 - Part No: 1C0959811
   Component: 0Q Tõrsteuer.HL KLO 0002
   Subsystem 4 - Part No: 1C0959812
   Component: 0Q Tõrsteuer.HR KLO 0002
would the Audi not showing all 4 subsystems be a comms issue or a CCCM issue with not showing 4 subsystems?
What direction should be I playing with the "blk int" or is there other stuff I should log/debug and send you guys?
