1.9tdi bls engine code.New battery, new tandem pump. new temp sensor. new fuel pipes and clamps.new fuel filter and rings. waiting for a new injector harness to arrive. but one in looks fine and ohm resistance is 0.1 with continuity on all wiring. all earths cleaned from chassis and engine. Egr valve removed and cleaned. can hear pump in the tank running for 1-2 seconds. hard starting and idle seems fine. when driving seems ok then starts to juddering in 3,4th gears. then stalls and wont start up again until it cools but again it is hard starting. starting motor shows as 295rpm. The battery replaced was 62 amp and now 72 amp.
van still struggles to start and once its started and hot, the engine wont start again.
once the faults are cleared, they stay clear. Some of these faults are from when ive had things unplugged.
apologies for wording
Monday,24,June,2019,21:18:02:18214
VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4
VIN: WV1ZZZ2KZAX063763 License Plate:
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 46 52 56
VIN: WV1ZZZ2KZAX063763 Mileage: 246670km-153273miles
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 PD HW: 03G 906 021 CG
Component: R4 1,9L EDC 000SG 2387
Revision: --H11--- Serial number: VWX7Z0I93NQ0KX
Coding: 0000071
Shop #: WSC 00000 256 01574
VCID: 70B9D32AE6A761E73A1-8024
000769 - Cylinder 1
P0301 - 000 - Misfire Detected - Intermittent
Fault Status: 00110000
Mileage: 246664 km
Time: 11:52:20
RPM: 819 /min
Load: 0.0 %
Voltage: 14.21 V
Inj. Quantity: 2.96 mg/str
Temperature: 67.5°C
(no units): 0.0
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - Intermittent
Fault Frequency: 6
Mileage: 246665 km
Time: 01:49:13
RPM: 840 /min
Load: 0.0 %
Duty Cycle: 100.6 %
Bin. Bits: 00000000
Mass Air / Rev.: 240.0 mg/str
Mass Air / Rev.: 0.0 mg/str
000770 - Cylinder 2
P0302 - 000 - Misfire Detected
Fault Status: 01110000
Mileage: 246667 km
Time: 00:15:57
RPM: 798 /min
Load: 0.0 %
Voltage: 14.44 V
Temperature: 46.8°C
(no units): 0.0
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High - Intermittent
Mileage: 246667 km
Time: 00:16:11
RPM: 819 /min
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00000100
Temperature: 66.6°C
Temperature: 47.7°C
012295 - Camshaft Position Sensor (G40)
P3007 - 000 - No Signal - Intermittent
Mileage: 246677 km
Time: 06:29:59
RPM: 294 /min
Load: 100.0 %
Voltage: 11.17 V
Bin. Bits: 00000100
Idle Stabilization: 0.0°KW
(no units): 32.0
Readiness: 0 1 0 0 1
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0020801
Shop #: WSC 35110 377 00157
VCID: 76B5E53284C34FD7E0D-8022
Part No SW: 2K0 820 047 BM HW: 2K0 820 047 BM
Component: Climatic PQ35 143 1515
Revision: 00143033 Serial number: 00000000000000
VCID: 71BFD62EEDAD68EF35F-8024
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 01000003455243
Coding: 00804F030004100057000000000000000009FB075C000120000000000000
Shop #: WSC 35110 377 08192
VCID: 323D1922282B13F70C5-8066
Subsystem 1 - Part No: 1T2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 071009 021 0512
Coding: 00038805
Shop #: WSC 35110
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 2Q AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037TR05HC4I
Coding: 0012881
VCID: 7DA7FA1EA1F51C8FA17-8028
Part No SW: 1K0 953 549 CT HW: 1K0 953 549 CT
Component: J0527 053 0111
Coding: 0000001
VCID: 065595F2F4235F57F0D-8052
Part No SW: 2K0 920 944 C HW: 2K0 920 944 C
Component: KOMBIINSTRUMENT VDD 1222
Revision: V0002000 Serial number: VWX7Z0I93NQ0KX
Coding: 0016401
Shop #: WSC 00288 210 87232
VCID: 2C01075A0A0F4507469-8078
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 221009F1000624
Coding: 89801F06000202007401
VCID: 698FBE4EC57D902F7DF-803C
Component: IMMO VDD 1222
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 02 0160
Coding: 0000000
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 018A0C087F2D8C0D4858061000C0
VCID: 005983EAD6077167CA1-8054
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Coding: 0000000
VCID: 75B7E23E99C544CFE97-8020
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 013 0036
Revision: 00000000 Serial number: VWZ1Z2I6759399
Coding: 0000020001
VCID: 6597B27E2565B44F597-8030
Fault Status: 00101011
Reset counter: 54
Mileage: 246617 km
Time: 20:59:35
Reset counter: 54
Mileage: 246617 km
Time: 20:59:35
End----------(Elapsed Time: 00:52, VBatt start/end: 12.5V/12.5V)-----------
