2009 Caddy 1.9 TDI 5 Speed - Won't start
Gashhey
C?ID=350180
1.9tdi bls engine code.New battery, new tandem pump. new temp sensor. new fuel pipes and clamps.new fuel filter and rings. waiting for a new injector harness to arrive. but one in looks fine and ohm resistance is 0.1 with continuity on all wiring. all earths cleaned from chassis and engine. Egr valve removed and cleaned. can hear pump in the tank running for 1-2 seconds. hard starting and idle seems fine. when driving seems ok then starts to juddering in 3,4th gears. then stalls and wont start up again until it cools but again it is hard starting. starting motor shows as 295rpm. The battery replaced was 62 amp and now 72 amp.
van still struggles to start and once its started and hot, the engine wont start again.
Monday,24,June,2019,21:18:02:18214
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
VIN: WV1ZZZ2KZAX063763   License Plate:
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 46 52 56
VIN: WV1ZZZ2KZAX063763   Mileage: 246670km-153273miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 PD    HW: 03G 906 021 CG
   Component: R4 1,9L EDC  000SG  2387
   Revision: --H11---    Serial number: VWX7Z0I93NQ0KX
   Coding: 0000071
   Shop #: WSC 00000 256 01574
   VCID: 70B9D32AE6A761E73A1-8024
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
                    Fault Status: 00110000
                    Mileage: 246664 km
                    Time: 11:52:20
                    RPM: 819 /min
                    Voltage: 14.21 V
                    Inj. Quantity: 2.96 mg/str
                    Temperature: 67.5°C
                    (no units): 0.0
000258 - Mass Air Flow Sensor (G70)
               P0102 - 000 - Signal too Low - Intermittent
                    Mileage: 246665 km
                    Time: 01:49:13
                    RPM: 840 /min
                    Duty Cycle: 100.6 %
                    Bin. Bits: 00000000
                    Mass Air / Rev.: 240.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected
                    Fault Status: 01110000
                    Mileage: 246667 km
                    Time: 00:15:57
                    RPM: 798 /min
                    Voltage: 14.44 V
                    Temperature: 46.8°C
                    (no units): 0.0
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
               P2185 - 000 - Signal too High - Intermittent
                    Mileage: 246667 km
                    Time: 00:16:11
                    RPM: 819 /min
                    Voltage: 14.44 V
                    Bin. Bits: 00000100
                    Temperature: 66.6°C
                    Temperature: 47.7°C
012295 - Camshaft Position Sensor (G40)
               P3007 - 000 - No Signal - Intermittent
                    Mileage: 246677 km
                    Time: 06:29:59
                    RPM: 294 /min
                    Load: 100.0 %
                    Voltage: 11.17 V
                    Bin. Bits: 00000100
                    Idle Stabilization: 0.0°KW
                    (no units): 32.0
Readiness: 0 1 0 0 1
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
   Component: MABS MK70M          0104
   Revision: 00H32001
   Coding: 0020801
   Shop #: WSC 35110 377 00157
   VCID: 76B5E53284C34FD7E0D-8022
   Part No SW: 2K0 820 047 BM    HW: 2K0 820 047 BM
   Component: Climatic PQ35   143 1515
   Revision: 00143033    Serial number: 00000000000000
   VCID: 71BFD62EEDAD68EF35F-8024
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 01000003455243
   Coding: 00804F030004100057000000000000000009FB075C000120000000000000
   Shop #: WSC 35110 377 08192
   VCID: 323D1922282B13F70C5-8066
   Subsystem 1 - Part No: 1T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 071009 021  0512
   Coding: 00038805
   Shop #: WSC 35110
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 2Q AIRBAG VW52  025 2400
   Revision: 06025000    Serial number: 0037TR05HC4I
   Coding: 0012881
   VCID: 7DA7FA1EA1F51C8FA17-8028
   Part No SW: 1K0 953 549 CT    HW: 1K0 953 549 CT
   Component: J0527           053 0111
   Coding: 0000001
   VCID: 065595F2F4235F57F0D-8052
   Part No SW: 2K0 920 944 C    HW: 2K0 920 944 C
   Component: KOMBIINSTRUMENT VDD 1222
   Revision: V0002000    Serial number: VWX7Z0I93NQ0KX
   Coding: 0016401
   Shop #: WSC 00288 210 87232
   VCID: 2C01075A0A0F4507469-8078
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0111
   Revision:   H07 01    Serial number: 221009F1000624
   Coding: 89801F06000202007401
   VCID: 698FBE4EC57D902F7DF-803C
   Component: IMMO            VDD 1222
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 02 0160
   Coding: 0000000
   Part No: 1K0 959 433 CP
   Coding: 018A0C087F2D8C0D4858061000C0
   VCID: 005983EAD6077167CA1-8054
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75B7E23E99C544CFE97-8020
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  013 0036
   Revision: 00000000    Serial number: VWZ1Z2I6759399
   Coding: 0000020001
   VCID: 6597B27E2565B44F597-8030
                    Fault Status: 00101011
                    Reset counter: 54
                    Mileage: 246617 km
                    Time: 20:59:35
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 54
                    Mileage: 246617 km
                    Time: 20:59:35
End----------(Elapsed Time: 00:52, VBatt start/end: 12.5V/12.5V)-----------
once the faults are cleared, they stay clear. Some of these faults are from when ive had things unplugged.
apologies for wording
Gashhey
C?ID=350180
Yes, which is both annoying and confusing.
I'm currently on replacing the injector wiring harness and ill get back to you to update you guys.
ECU is dry and clean, all earths have been cleaned.
EGR valve has been cleaned.
tandem pump been replaced.
no other fault codes.
it seems when it gets hot, it wont start.
Gashhey
C?ID=350180
just replaced wiring loom, still no different.
It has now caused a Cylinder 2 Misfire fault code.
Vag82
Finland
C?ID=321257
Check engine wire loom under the battery and air filter box.
I have once repaired one of 1.9tdi altea xl there was 4 wires faulty wires that makes same kind of problems...
