Q5 B8 - enable HBA with front camera
mikepl
Poland
C?ID=269489
i am trying to enable the HBA via the front camera. My car has lane assist and front radar (i know, probably not related) ex-factory but no HBA; has active (swiveling) xenon headlights and i was wondering if i can enable the HBA without adding any extra hardware.
I have googled and stumbled upon a recipe to retrofit but it all referenced the additional module at diagnostic address 20, which of course doesn't exist in my configuration. Is it possible to have the functionality via the existing camera?
Please post an Auto-Scan so people can see exactly how the vehicle is currently equipped.
mikepl
Poland
C?ID=269489
Of course, there you go:
Monday,27,May,2019,15:16:44:32319
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ8R0FA139145   License Plate:
Mileage: 40990km-25470mi   Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 1B 30 36 3C 42 44 46 47
          52 53 56 57 5C 5F 62 6C 6D 72
VIN: WAUZZZ8R0FA139145   Mileage: 40990km-25470miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CNCD)       Labels:. 06L-907-115-V1.clb
   Part No SW: 8R2 907 115 B    HW: 8T2 907 115
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 2A2A00322446010B2000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TFS0208R2907115B 001004
   ROD: EV_ECM20TFS0208R2907115B.rod
   VCID: 35614864943F49E23E-8060
17178 - Databus
21417 - Internal Control Module Error
          P2610 00 [032] - Engine Shut-down Timer
23129 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
15418 - Cam Adjustment Actuator B; Cylinder 3
          P11AC 00 [096] - Implausible Signal
   Part No SW: 8R0 927 158 AT    HW: 0BK 927 156 AM
   Component: 0BK 20TFSIRdW H19 1004
   Revision: --H19---
   Coding: 000001
   VCID: 0F2DDA8CD623533254-805A
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 BA    HW: 8R0 907 379 BA
   Component: ESP8 quattro  H09 0020
   Coding: 2D6DCC01
   Shop #: WSC 06335 000 00000
   VCID: 000FE9B0937D3C4ADD-8054
02214 - Tire Pressure Warning
                    Reset counter: 25
                    Mileage: 40993 km
                    Date: 2019.05.27
                    Time: 14:57:13
                    Hex Value: 0x3100
                    Hex Value: 0x4006
                    Hex Value: 0x1221
                    Hex Value: 0x1AB4
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
   Component: BCM2 2.0      H15 0711
   Coding: 05A54000000000000000
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Component: KLIMA 3 ZONEN H04 0122
   Revision: C1000000    Serial number: 01240420150267
   Coding: 642102C080
   VCID: 77FD826CC6B37BF2EC-8022
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00001060222601
   Coding: 260000108034AFF21981408300001D0D0F9CC70A26090201000008004401070200020034000000
   VCID: 7AFB9B58F5A1669A93-802E
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 150416  H12 0050
   Serial number: 90243014150409144508
   Coding: 01DD13
   Serial number: 20256754
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000304151193
   Subsystem 4 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Serial number: 0A3983A7000000000001
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0110
   Coding: 00CFB0
   VCID: 377D426C8633BBF22C-8062
00234 - Sensor for Automatic Distance Regulation Misadjusted
                    Reset counter: 154
                    Mileage: 33989 km
                    Date: 2018.09.28
                    Time: 18:29:34
                    Temperature: 21.0°C
                    Voltage: 14.46 V
                    Hex Value: 0x0035
                    Speed: 54.0 km/h
                    Lateral Accel.: -0.46 m/s^2
03263 - Functional Restriction
            000 -  -  - Intermittent
                    Fault Frequency: 73
                    Reset counter: 64
                    Mileage: 33748 km
                    Date: 2018.08.22
                    Time: 09:22:59
                    Temperature: 26.0°C
                    Voltage: 14.08 V
                    Hex Value: 0x002F
                    Speed: 39.6 km/h
                    Lateral Accel.: 1.37 m/s^2
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 09031500190002
   Coding: 070181
   VCID: 3A7B5B58B521A69AD3-806E
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003JPDC32TCW
   Coding: 30483531313030303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 489F3190F3CDC40A55-801C
   Serial number: 6334MSME505D2D73L
   Serial number: 6344MSME505D6017B
   Serial number: 6352QSME435350704
   Serial number: 6362QSME4153126EE
   Serial number: 63732SME0550246CX
   Serial number: 63832SME0850437E+
   Revision: --------    Serial number: 90372ODK000MG
   Coding: 0000DF
   VCID: 448725A0C7E5E06AB9-8010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 932 A    HW: 8R0 920 932 A
   Component: KOMBIINSTR.   H36 0567
   Revision: 00100000    Serial number: 03961NG4G
   Coding: 13E622007F010008070000
   VCID: 34677560974550EA09-8060
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z1541604F5
   Coding: 80CF07FF00
   VCID: 4C970D80EFB5282A71-8018
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 9990056403
   Serial number: 15112001765021200410
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Coding: 020100
   VCID: 39794454B027AD82DA-806C
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000121264
   Coding: 01010101000000000001000102
   VCID: 2D516004746F012246-8078
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000145016520
   Coding: 01581B00000000000000
   VCID: 428B23B8DDF1EE5A8B-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H05 0071
   Serial number: 0365958709
   Coding: 010311
   Shop #: WSC 06334 000 00000
   VCID: 3F8D2A4CA60383B2E4-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0365767652
   Coding: 010311
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000146626221
   Coding: 011D12205E20440004
   VCID: 4FAD1A8C1EA3133214-801A
   Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0020636351
   Coding: 010001010001
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 458138A4C4DFD962AE-8010
   Revision: 00002001    Serial number: 0365987650
   Coding: 013A0E20A0B938958730053680040047
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
   Revision: 00005001    Serial number: 94813043142906
   Revision:             Serial number: 0000146635302
   VCID: 4E93078819A91A3A1F-801A
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001652116
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7B5B58BD21A69AD3-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109DT0F8031174
   Coding: 010103010000000001
   VCID: 2B556E1C4A7B0F1258-807E
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801301904101
   Coding: 1C000000
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 60021542200152
   Coding: 0033004
   VCID: 377D426C4633BBF22C-8062
   Part No SW: 8R1 035 670 J    HW: 8R1 035 670 J
   Component: H-BNT-EU      H49 0897
   Revision: --------    Serial number: 516DZ0F7520716
   Coding: 160100060005A9EF7D80CB5E00000403040000000000000000
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Component: DU7 High  H42 0104
   Serial number: A130DM0F3330374
   Serial number: 00000002210214
   Component: CD-Database  5950
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000146601435
   Coding: 010C12204020240004
   VCID: 46833FA8F1D9D27AA7-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-JA2A2DX
   Coding: 1021010
   VCID: 34677560574550EA09-8060
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D715044A40F91A2F6-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000146601388
End-------------------------(Elapsed Time: 04:50)--------------------------
siLc
Tallinn, Estonia
C?ID=330192
On the Audi B8 platform, the Lane Assist and HBA setup seems to be quite different - the 5C camera only handles lane keeping and 20 camera handles HBA. Other Audis of this originating era (mid to late 2000s) also have HBA this way so I don't think you can set this up otherwise.
hadez16
C?ID=289891
Not possible.
HBA does need unit 20.
mikepl
Poland
C?ID=269489
Thanks everyone. I am going to have it anyway, mirrors with HBA cameras pop out on auction portals quite cheap - it's just a temporary lack of luck since my interior is black and all i found were gray or beige. Will the unit from another B8 platform (like A4) do, or i need to get something specific to a Q5.
Are they bound to the vehicle via CP? Or coding will suffice by itself? I do have a licensed ODIS instance however currently no GeKo rights and application is quite painful so that would spare me the visit to the dealers.
Apologies for somewhat trivial questions, but for years i was a Merc guy and it's first time i am into modification of another brand.
Thanks,
siLc
Tallinn, Estonia
C?ID=330192
Thanks,
The HBA mirror part number for a 2015 Q5 is 8T0857511AD with color code 4PK for the black one. It appears to be from the A5 B8 but ETKA also reveals the A4 B8 using earlier Q5 interior mirrors, so something from the A4 might also be suitable. AFAIK the mirror is not part of CP but modules would need coding as it's on the CAN.
