Discover media mib2
gidyon06
New Member
morning guys,
i wonder if anyone can help on here, my discover media (retrofit) has stuck on vw start up screen. i have tried the reboot with the power button and this has made no difference. i have just disconnected power from the unit to see if that makes a difference but i was wondering if anyone on here had come across this ? is there anyway of getting unit to work normal. it is also stuck on CarPlay as no buttons are responsive.
What happens if you try to access it with VCDS?
DV52
C?ID=194404
^^ I think that Uwe is asking that you post-up a full copy of the autoscan for the vehicle (unedited and unabridged).
Of course anything is possible - I had a MIB unit here from a local forum colleague with similar symptoms and it transpired that he had changed the start-up screen version on his MIB to a value that didn't exist in the module firmware. The changed parameter was duly accepted by the module, however- when the MIB attempted to start-up, it desperately tried to load the screen version for the car as set by the owner- but it coouldn't. There were no time-out settings in his MIB that forced a default start-up screen to appear and I don't recall that there were any error messages in VCDS (I think). Had me bamboozled for quite a while - the only way that I was able to find the fault was by looking at my colleague's history reports. BINGO -there it was - an incorrectly set software switch for the start-up screen.
I'm not suggesting that your MIB problem is the same - just trying to highlight that much can be gleaned from an autoscan report, and perhaps also posting-up a copy of your history files?
Donfull
gidyon06
New Member
Thursday,13,June,2019,17:55:09:50816
VCDS Version: 19.6.0.2 (x64)
VIN: WV1ZZZ2KZDX062214   License Plate:
Mileage: 149930km-93162mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61 76
VIN: WV1ZZZ2KZDX062214   Mileage: 149930km-93162miles
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 PD    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 8014
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114034032501080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023PD 003010
   ROD: EV_ECM16TDI02103L906023PB.rod
   VCID: 77FBDD0ECE0BC4F7A0-8022
Readiness: 1110 1000
   Revision: 00H31001
   Coding: 433C400D092803FCC20D02E5901DC091310000
   Shop #: WSC 35110 377 08192
   VCID: 7DF7CF26E437EEA7FA-8028
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0304
   Revision: 00001016
   Coding: 0000004003
   VCID: 0009B6D29BC5834F91-8054
   Part No SW: 5K0 937 086 P    HW: 5K0 937 086 P
   Component: BCM PQ35 M+   021 0068
   Revision: BD021001
   Coding: 4F1A583A8025F16A088800829000016403810088424F8520648087000041
   VCID: 418F73D6D84F4A47DE-8014
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 05101  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 2K0 919 475     HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0004
   Revision: --------    Serial number: 32961228601607
   Coding: 108001
   ASAM Dataset: EV_EPHVA14VN3370000 001006
   ROD: EV_EPHVA14VN3370000.rod
   VCID: 70E9E612AB6593CF61-8024
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag02B H07 0013
   Revision: --------    Serial number: 003HL00EBP49
   Coding: 000000000000000000000000000000003242
   VCID: 356717069487F6E772-8060
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Revision: --------    Serial number:  90422LFT001CS
   Coding: 108A100000
   Shop #: WSC 00028 028 00311
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 72EDEC1AA569A1DF97-8026
   Serial number: 0033053
   Coding: 820000
267264 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 14
                    Mileage: 149935 km
                    Date: 2019.06.13
                    Time: 17:52:33
   Part No SW: 2K0 920 975 L    HW: 2K0 920 975 L
   Coding: 781801
   VCID: 397F1B36B89F128796-806C
   Part No SW: 7N0 907 530 BJ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1682
   Revision:   H58       Serial number: 091016F1000263
   Coding: 357421
   VCID: 79FFDB36F01FD287D6-802C
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 14
                    Mileage: 149935 km
                    Date: 2013.11.03
                    Time: 17:52:39
   VCID: 6ADDF47A8DB9691F2F-803E
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2130
   Coding: 0135792
   Shop #: WSC 00020 790 00000
   VCID: 397F1B36709F128796-806C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   Shop #: WSC 33377 001 1048576
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Component: Tuer-SG         009 2128
   Coding: 0135792
   VCID: 3A7D043A7599199F9F-806E
00830 - Convertible Top Control Module (J256)
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 7N5 035 680 C    HW: 7N5 035 680 C
   Component: MU-S-ND-ER    H31 0359
   Serial number: SEZAZ2S5018754
   Coding: 063307013C00000011111101008808001F0109D6002001004F
   Shop #: WSC 11867 022 05673
   ROD: EV_MUStd4CTSAT_SK26.rod
   VCID: 3363291E9AF3E8D75C-8066
   Subsystem 1 - Part No SW: 6P0 919 866 H    HW: -----------
   Component: ECE1 2016/17  --- 0635
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 14
                    Mileage: 149935 km
                    Date: 2019.06.13
                    Time: 17:52:32
                    Voltage terminal 30: 11.8 V
                    Byte_Coding_Condition-byte_0_condition: ERROR
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
15360256 - Component Protection
          U1101 00 [009] - Active
                    Reset counter: 14
                    Mileage: 149935 km
                    Date: 2019.06.13
                    Time: 17:52:32
                    Voltage terminal 30: 11.7 V
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 14
                    Mileage: 149935 km
                    Date: 2019.06.13
                    Time: 17:52:35
                    BAP-BAP_Function_ID: 02
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
   Component: Batt.regelung H58 1682
   Coding: 030F1873
   VCID: 71EFE316A86F9AC76E-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900314039
Address 76: Park Assist (J446)       Labels:* None
   Coding: 108001
End-------------------------(Elapsed Time: 02:47)--------------------------
gidyon06
New Member
That is copy of scan if anyone can help
siLc
Tallinn, Estonia
C?ID=330192
Well, we won't know what the missing messages errors are with your older VCDS dongle. You can start by removing address 76 from your CAN gateway installation list as its already present on address 10. Then you can go over the Discover Media's coding to see if any features are enabled which are not physically present in your particular vehicle or vice-versa. Then erase all fault codes and see what comes back. This component protection fault shouldn't be affecting function as the unit seems to be "unlocked" and working otherwise?
gidyon06
New Member
All was working fine until Friday gone was trying to get the park pilot image to return and the unit seemed to lock but using powers button it reset, then I was in a menu on the unit itself and it said skins but seemed unresponsive and unit algae been stuck on start up screen since and CarPlay still works
siLc
Tallinn, Estonia
C?ID=330192
I'm not really sure 2K0 919 475 is a suitable module for DM for the parking aid image to work correctly. For only rear parking sensors, the correct module is 1K8 919 465A. This module has different connectors so you'll need to either rewire or buy an adapter.
For the DM being stuck, remove the radio fuse for some time and see what happens.
gidyon06
New Member
it was working intermittently then when i fitted new gateway so i had the 5f compatibility it stopped. i have the 1k8 one with adapter leads to go in but pointless if can't get radio to work
i have removed the unit completely and left out overnight didn't make a difference
