Urgent help needed please! (8K Audi Immo)
invernesspl
C?ID=345478
I've recently purchased Ross-tech Hex-V2, still learning how it all works.
I have a 2012 Audi A4 Allroad that I collected today, I have 2 original keys with the car, however the keys will not turn on the ignition or lock/unlock the car. The car is currently sat on a rental car transporter trailer and I cannot release the parking brake or unlock the steering lock to get the car off the trailer!! (The rental company wants the trailer back asap!
I have checked the wiki help, and have tried to release the parking brake by using the 'Lining change mode'. however this produces an error message and does not work.
I have also tried to look at what keys are registered with the car, but I get an odd number (32865) where I think it should just say '2' (see photo)
PHOTO:
Maybe i'm looking in the wrong place, if anyone could give me any advice how to check for the keys in the system, or even how to recode these keys back in to the system that would be much appreciated. The 2 keys I have are the original keys for the car, i've no idea why they no longer work?
Failing that, If anyone knows how to release the parking brake without the ignition on, or release the steering lock!
This car has the key that pushes in to the dashboard btw, not the flip key. And the chassis is an 8K
Many thanks
Zenerdiode
Newcastle, England
C?ID=24330
Pressing SET on the dash a few times or so will show Lx/x on the dashboard. Please post what you have instead of the x.
Please post a full Auto-Scan of the Allroad. Also please post the Advanced ID from 05-Acc/Start Authorisation.
invernesspl
C?ID=345478
Hi, Here is the full autoscan and advance ID. I have tried pressing set a few times and it just shows the mileage and clock, nothing else happens.
Friday,31,May,2019,07:42:25:41168
Mileage: 61590km-38270mi   Repair Order:
Chassis Type: 8R0
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 72
   Mileage: 61590km-38270miles
04-Steering Angle -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
Address 01: Engine
   Part No SW: 8K9 907 379 L    HW: 8K9 907 379 L
   Coding: 011544
   Shop #: WSC 06335 000 00000
   VCID: 4BC3644423CF1D5F3BF-801E
   Part No SW: 8K0 907 064 GC    HW: 8K0 907 064 FC
   Component: BCM2 2.0      H11 0621
   Coding: 03B24000000000000000
   VCID: 77ABE8B40FC749BFAF7-8022
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0512000051877021
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 2312000170630016
   Part No SW: 8K2 820 043 T    HW: 8K2 820 043 T
   Revision: D1000000    Serial number: 01050820121142
   Coding: 642402C000
   VCID: 3A2D31807C5594D7909-806E
   Part No SW: 8K0 907 063 DD    HW: 8K0 907 063 DD
   Revision: 04016001    Serial number: 00000459292402
   Coding: 290000308034A7C00081000300001F1F001D070827080201000008000000030000000024000000
   VCID: 74B1DFB81EB122A78A5-8020
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 300712  H06 0080
   Serial number: SWF12070305276
   Coding: 00FD11
   Serial number: 20482151
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002407124589
Address 15: Airbags
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20130726000443
   Coding: 000017
   Shop #: WSC 54929 000 1048576
   VCID: 51FF762CC1E3378F413-8004
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 C    HW: 8K0 920 982 C
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RBH7AFK7D
   Coding: 3384290202012600010000
   VCID: 34311FB85E3162A74A5-8060
   Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0051
   Revision: 1Y050025    Serial number: 2541Y127270196
   Coding: 80CF07FF00
   VCID: 44D14F780E91D227FA5-8010
   Serial number: 8472447901
   Serial number: 12194002420011200410
   Revision: 00001000    Serial number: 0022742561
   Coding: 100000000001
   Shop #: WSC 00860 210 94821
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34311FB85EB162A74A5-8060
   Revision: 00002001    Serial number: 0181213698
   Coding: 013B062220BA00408030023680000000
01403 - Glass-Break Sensors; Rear
                    Reset counter: 207
                    Mileage: 61598 km
                    Date: 2019.05.30
                    Time: 19:48:57
   Revision: 00005001    Serial number: 94813005169002
   VCID: 2D070ADCBD1B336F05B-8078
Address 52: Door Elect, Pass.
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000082855
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 38292B8842D986C766D-806C
   Part No SW: 4G0 035 061 D    HW: 4G0 035 061
   Component: Radio U DAB   H60 0100
   Revision: AB001007    Serial number: 470G/0C7533755
   Coding: 010103010000000001
   VCID: 1E65DD10C0BDD8F78C1-804A
02983 - Connection between Impedance Converter 1 and Window Antenna
                    Reset counter: 207
                    Mileage: 61593 km
                    Date: 2019.04.10
                    Time: 10:47:56
                    Voltage: 14.80 V
   Part No SW: 8R2 035 652 A    HW: 8R2 035 652
   Component: B-BN-EU       H62 0175
   Revision: --------    Serial number: 147GW0C7515061
   Coding: 01010101000681ED01800B4E000000030000
   VCID: 323D19A0A4256C97589-8066
   Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
   Component: DU6 Basic  H42 0098
   Serial number: 9465H00C2563098
   Subsystem 2 - Part No SW: 8T0 919 611     HW: 8T0 919 611
   Component: E0380 Bedient  H01 0100
   Serial number: 00000001232687
Address 62: Door, Rear Left
Address 72: Door, Rear Right
End----(Elapsed Time: 01:14, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
invernesspl
C?ID=345478
ADVANCE ID
PHOTO:
Zenerdiode
Newcastle, England
C?ID=24330
Ah, you have to do the Auto-Scan with the ignition switched on - but you can't, because of the key not being recognised...
On that screenshot you posted for the Advanced ID of 05; see the button labelled [Advanced ID - 1A] - please click that and then post the results here as text.
invernesspl
C?ID=345478
This is what Advanced ID says:
Friday,31,May,2019,10:22:19:41168
VCDS Version: Release 18.9.1 (x64)
Control Module Part Number: 8K0 907 064 GC
  Component and/or Version: BCM2 2.0      H11 0621
           Software Coding: 03B24000000000000000
            Work Shop Code: WSC 06335
Advanced Identification
     Identification: HLH-W41
     Date: 30.07.12
     Manufacturer number: 1002
     Test stand number: 0089
Flash Status
     Programming Attempts(data): 0
     Successful Attempts(data): 0
     Flash Tool Code(data): 00000 000 00000
Software
     Theft prot.: 02.02.00
     KWP2000: 02.30.00
Misc.
     Hardware number: 8K0 907 064 FC
     Workshop System Name: J393
     Equipment/PR Code: 0000000000000000
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: --------------------
Car Info
     Chassis Number: WAUZZZ8K0DA117808
Immobilizer
     Transponder ID (Current val.): E1A99399
     Transponder ID 1: BEECEEAB
VCDS Info:
       Labels: 8K0-907-064-05.clb
Zenerdiode
Newcastle, England
C?ID=24330
Immobilizer
Thank you. This shows the system is reading one of your existing keys, so they need to be programmed I'm afraid. They are write-once to an immobiliser system; so it's Dealer or someone with online ODIS who will be able to program. VCDS can't.
This also explains why you couldn't see the L2 x/x on the display.
Lastly, please register your HEX-V2 so you may enjoy Verified VCDS User status. :)
OP joined the forum in July 2019 and registered his HEX-V2 in March 2019. Unfortunately we have no way of automatically catching that, but I just took care of it manually. He's now Verified, and this is moving to Car Repair Support.
invernesspl
C?ID=345478
Thanks so much for your help. SO is that the transponder ID 1, showing it has a key? And is it only showing 1 key? So I know for future reference!
I just took the car to Audi on the trailer, but they won't programme the key until I have a log book in my name, which could take a month from DVLA. Managed to get it off the trailer though by borrowing a friends garage 4 post lift, it just fitted on there with 1cm to spare each side! Very lucky. Putting it back on the trailer to take it to Audi is going to be just as much fun!
@UWE, thank you for verifying my VCDS :)
Stu.
Zenerdiode
Newcastle, England
C?ID=24330
Yes (transponder ID 1), and only one key, yes. I have an 8K too; and in AdvID I have three Transponder IDs, which corresponds to having two main keys and the flat, plastic emergency key. Indeed when I switch the ignition or start, the Transponder ID (Current val.): XXXXXXXX matches one of my stored transponder IDs. It also changes to one of the other values when I use another key.
Try your other key, see if the Transponder ID (Current val.): changes. What's your story behind the car? Have you been duped that they were correct keys and it's otherwise a good runner?
invernesspl
C?ID=345478
I've clearly got a lot to learn about the VCDS!
The car was stolen recovered, purchased from an insurance company, the keys were provided but I was aware the car wouldn't start, I didn't realise the keys were not programmed to the car hense why I got caught out!
So I have two keys, does that mean there is likely a third key somewhere that did work on the car?
Zenerdiode
Newcastle, England
C?ID=24330
Well, just my own opinion of what has possibly happened, is when it was stolen, the thieves didn’t get one of the original keys; they cracked the BCM2 and added their own. It’s quite common, I’m afraid. (WatchDog did a feature on it a few years ago). The process of adding a key, deletes all others.
The insurance company usually insists on all keys being handed back before they’ll pay out. So those keys you have may indeed be the originals for the car; but no longer programmed as I’ve described. They may be able to be programmed back, saving a few £s, but still a main dealer job. :(
Could you imagine if others here or I was turned to the dark side?
Literally could be gone in less than 30 seconds........maybe less!
:rolleyes:
Sometimes the high road is a boring fork in the road!
invernesspl
C?ID=345478
Is that when they have equipment that listens for the key code to duplicate it? I have heard about that. So they must have to use VCDS to add their own key to the car then?
I've applied for the new log book, so hopefully will be here soon, and then Audi will program both keys for £90, which isn't too bad I guess.
Nope, it would have been some other tool. VCDS cannot add a key to a B8.
