Resolved Instrument Cluster Fault Code 1048578 - No Basic Setting
Resolved
   #21
darkmatter
C?ID=224357
My car has been to the Audi dealer who has correctly reset the service interval counter, this has cleared the fault. It looks like the previous dealer who serviced the car made a mistake.
Here is the final control module map.
;SW:8U0-920-990-A   HW:8U0-920-990-A ---  Instruments,,,,
;Component:KOMBI_COLOUR  H14 0030, Coding:42CF00,,,
;EV_Kombi_UDS_VDD_AU10,A04391,EV_Kombi_UDS_VDD_AU10.rod,,
;Tuesday,24,February,2015,17:01:18:04481
;VCDS Version: Release 14.10.1 (x64)  Data version: 20150130,,,,
;VCID: 3B7502F6B27421F97B2-806E,,,,
Activating and deactivating all development messages,not active ,,,
Automatic door locking,Display ,,,
Day,24,,,
Day counter,1160 d,,,
Deactivate seat belt warning,No ,,,
Display correction of consumptions and operating range,100%,,,
Display correction of fuel gauge,0.0 °,,,
Display format,not active ,,,
Distance,27960 km,,,
Driving profiled for range remaining,6.4,,,
(1)-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation ,,,
(2)-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure ,,,
(3)-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality ,,,
(4)-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster ,,,
ESI: distance driven from inspection,13000 km,,,
ESI: maximum value km-driving distance/inspection,30000 km,,,
ESI: maximum value of time between inspections,730 d,,,
ESI: minimum value km-driving distance/inspection,15000 km,,,
ESI: minimum value of time between inspections,730 d,,,
ESI: oil quality,good oil quality ,,,
ESI: Resetting ESI,no warning ,,,
ESI: soot entry,14700 km,,,
ESI: thermal load,7800 km,,,
ESI: time from inspection,287 d,,,
Expanded display of traffic sign detection,On ,,,
FIX: Distance covered since last mileage-dependent inspection,13000 km,,,
Fix: Max. distance until next mileage-related inspection,30500 km,,,
FIX: Maximum time until next time-dependent inspection,730 d,,,
FIX: Time since last time-dependent inspection,1 d,,,
Hour,17 H,,,
Indicator light for start-stop operation,On ,,,
Language version,English ,,,
Language version in instrument panel insert control module,English ,,,
Minute,1 min,,,
Month,2,,,
Seat belt warning,Version 4 ,,,
(1)-Service-key settings-p_write_delay_time,40 s,,,
(2)-Service-key settings-p_write_delay_speed,20 km/h,,,
(3)-Service-key settings-p_write_distance,20 km,,,
(4)-Service-key settings-p_forcewrite_qual_time,10 s,,,
(5)-Service-key settings-p_main_switch_keyless,On ,,,
(6)-Service-key settings-p_main_switch_basis,On ,,,
SIA: maximum value of distance to service,14500 km,,,
SIA: maximum value of time to service,365 d,,,
Source for synchronization of time,GPS ,,,
Speed threshold of dynamic oil pressure warning,kein Offset ,,,
(1)-Speed warning-,active ,,,
(2)-Speed warning-Unit,Miles per hour ,,,
(3)-Speed warning-Speed,80,,,
Staging,not active ,,,
Synchronization duration radio clock,0 min,,,
(1)-Units adjusted-Temperature,°C ,,,
(2)-Units adjusted-Distance,miles ,,,
(3)-Units adjusted-Speed,Miles per hour ,,,
(4)-Units adjusted-Pressure,bar ,,,
(5)-Units adjusted-Volume,gallons (UK) ,,,
(6)-Units adjusted-Time,24h ,,,
(7)-Units adjusted-Date,dd_mm_yy ,,,
(8)-Units adjusted-Consumption,Miles per gallon (UK) ,,,
Upshift display in center panel,not active ,,,
Year,2015,,,
Service_Key_Clear_All_Counters,Yes ,,,
   #22
CocoPops
C?ID=65608
Interestingly, I'm now suffering from the same issue.
Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
   Part No SW: 8U0 920 990 E    HW: 8U0 920 990 E
   Component: KOMBI_COLOUR  H01 0240
   Coding: 42CF01
   Shop #: WSC 00049 770 00118
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 3F868C35A65840B9E2-806A
          B2010 00 [009] -  -
                    Reset counter: 138
                    Mileage: 29559 km
                    Date: 2016.09.01
                    Time: 11:17:36
Oh and guess when my car was serviced.... Yup, 1st September 2016!
   #23
Who serviced it?
Feel free to post an Adaptation map from the cluster, maybe we can figure out what it's unhappy about.
CocoPops
C?ID=65608
Sure thing:
;SW:8U0-920-990-E   HW:8U0-920-990-E ---  Instruments
;Component:KOMBI_COLOUR  H01 0240, Coding:42CF01
;EV_Kombi_UDS_VDD_AU10,A04399,EV_Kombi_UDS_VDD_AU10.rod
;Thursday,26,January,2017,21:17:30:09724
;VCDS Version: Release 17.1.1 (x64)  Data version: 20170107 DS267.0
;VCID: 3F868C35A65840B9E2-806A
IDE00301-Distance,34260 km
IDE00342-ESI: Resetting ESI,no warning
IDE00343-Language version,English
IDE00344-Seat belt warning,Version 4
IDE00492-MAS00900-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation
IDE00492-MAS02010-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure
IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality
IDE00492-MAS02013-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster
IDE00493-Display correction of fuel gauge,0.0 °
IDE00499-Display correction of consumptions and operating range,100 %
IDE00500-Hour,21 H
IDE00501-Minute,17 min
IDE00502-Year,2017
IDE00503-Month,1
IDE00504-Day,26
IDE00505-Speed threshold of dynamic oil pressure warning,kein Offset
IDE00510-ESI: distance driven from inspection,4700 km
IDE00511-ESI: time from inspection,147 d
IDE00512-ESI: minimum value km-driving distance/inspection,14500 km
IDE00513-ESI: maximum value km-driving distance/inspection,30600 km
IDE00514-ESI: maximum value of time between inspections,730 d
IDE00515-ESI: oil quality,good oil quality
IDE00517-ESI: soot entry,6000 km
IDE00518-ESI: thermal load,3400 km
IDE00819-Day counter,939 d
IDE00820-Activating and deactivating all development messages,not active
IDE00827-ESI: minimum value of time between inspections,730 d
IDE01087-Staging,active
IDE01153-SIA: maximum value of distance to service,14500 km
IDE01154-SIA: maximum value of time to service,365 d
IDE02327-Indicator light for start-stop operation,On
IDE02494-Automatic door locking,Display
IDE03329-Driving profiled for range remaining,6.8
IDE03346-IDE00301-Units adjusted-Distance,miles
IDE03346-IDE00316-Units adjusted-Time,24h
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour
IDE03346-MAS02201-Units adjusted-Temperature,°C
IDE03346-MAS03032-Units adjusted-Volume,gallons (UK)
IDE03346-MAS03033-Units adjusted-Consumption,Miles per gallon (UK)
IDE03346-MAS03034-Units adjusted-Pressure,bar
IDE03348-MAS01456-Speed warning-Speed,85
IDE03348-MAS01561-Speed warning-Unit,Miles per hour
IDE03348-MAS03206-Speed warning-Speed warning,active
IDE03349-FIX: Max. distance until next mileage-related inspection,31600 km
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection,4700 km
IDE03352-FIX: Time since last time-dependent inspection,147 d
IDE03360-Upshift display in center panel,not active
IDE03371-Synchronization duration radio clock,0 min
IDE03372-Source for synchronization of time,GPS
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
IDE03568-ENG102019-Service-key settings-p_main_switch_basis,On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
IDE03867-Deactivate seat belt warning,No
IDE04103-Language version in instrument panel insert control module,English
IDE04112-Display format,not active
IDE05193-Expanded display of traffic sign detection,On
IDE06425-Roller test bench mode: functional,not active
IDE07221-Cylinder shut-off,No display
MAS03555-Lap counter,On
ENG119824-boost_pressure,On
ENG108924-Service_Key_Clear_All_Counters,Yes
ENG114944-Start_up_screen,No display
ENG112416-IDE01766-velocity_detection-Distance impulses,4
ENG112416-MAS01209-velocity_detection-Speed source,Distance impulses
Elapsed Time: 00:18
CocoPops
C?ID=65608
Just followed Wolfgangs ma/min values from 30600 to 30000 and 14500 to 15000.
Sorted!
Definitely worth storing this somewhere...
It was serviced by local Audi dealer btw (official)
   #26
CocoPops
C?ID=65608
For completeness, here is the channel map POST change:
;Thursday,26,January,2017,21:26:42:09724
IDE00500-Hour,21 H
IDE00501-Minute,26 min
IDE00502-Year,2017
IDE00503-Month,1
IDE00504-Day,26
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km
Elapsed Time: 00:18
PS Glad it's resolved, I'm headin back inside... it's reading 0.0degrees out here :D
   #27
Sorted!
I wonder if there was a version of ODIS that had incorrect scripts in it for a while?
AJB
C?ID=61832
Moin,
maybe I'm too many tolate but I think, the reason for this basic setting issue is based here:
Please change the values max driving distance to 30000,
Please change the values min driving distance to 15000 km.
and minimum value of time between inspections to 365 d
GOOD LUCK:)
Thank You! In case it helps anyone else, I came across this thread as I had the "No Basic Setting" fault code on Instruments on my 2013 Audi A3 (8V model, UK spec). This exact same fix (including the exact same original distances of 30600 and 14500) worked perfectly.
My car didn't have the fault code when new, but had been serviced by an Audi main dealer, so I guess they introduced the troublesome distances during their service reset.
Thanks again!
   #29
EDBOC
C?ID=225153
Same Issue on Audi A1 62 Plate that went into local UK Audi dealer for a service
Thanks for sharing AIB Wolfgang
Originally Posted by AIB Wolfgang View Post
Moin,
   #30
vmmltu
Lithuania
C?ID=394547
Hello, I'm new to VCDS. My mothers Golf VII has 2 remaining DTC's after deleting all and test driving. One is as above and I think that numbers are okay. Need a little help. Thank you :) Here is Auto-Scan and adaptation map of address 17:
Monday,04,May,2020,12:57:03:12071
VIN: WVWZZZAUZGW198440   License Plate: JCG545
Mileage: 74321km-46180mi   Repair Order: 2020_05_04_patikrinimas
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZGW198440   Mileage: 74321km-46180miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 2328
   Revision: R7H25---
   Coding: 0125003223241D082000
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001004
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B83C1EF33070223969-803E
   CAN Converter 01:
Readiness: 0010 0001
   Part No SW: 0CW 300 048 K    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0612
   Revision: 00005005    Serial number: CU501511125842
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 44D14A537E192D5B373-8010
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 93105000012122
   Coding: 01FA6AA124291174077B060441C32980562488E0608294F300220078C202
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 79AFEBA7495BA0B3145-802C
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020004200100011005000000101002
   VCID: 6A8DC4EB3CFD1B2BEDF-803E
   Geber fьr Kдltemitteldruck/Kдltemitteltemperatur:
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061532800105
   Coding: 00001A46C24122F30BA44080B11C07081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F9B6719BBB033045-805C
   Component: WWS    151030  043 0551
   Serial number:         151114191639
   Component: RLHS  037 0059
   Serial number: S2Y15M12D01H02M54S38
   Coding: 90A8DD
   Serial number: 000000000ZY1529308VQ
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033487141
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [009] - Alert Emergency Activation Stage 1
                    Reset counter: 231
                    Mileage: 74316 km
                    Date: 2020.05.01
                    Time: 17:58:54
   Revision: --------    Serial number: 39391532504511
   Coding: 0031051011
   VCID: 43D3494F7B172A630E9-8016
   Serial number: 003F6R19MW5Y
   VCID: 41DF4347610B38731C5-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 211 15
   Serial number: 3576700000094581D71X
   Subsystem 2 - Part No SW: -----------    HW: 480 001 211 15
   Serial number: 3586700000054281D71R
   Subsystem 3 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 35165029B1E34435D2CH
   Subsystem 4 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3526502A51E34431109Z
   Subsystem 5 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3556502A11E34434422Z
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20151201500178
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDB45BF17FF4E836A1-806A
   Part No SW: 5G1 920 740 A    HW: 5G1 920 740 A
   Component: KOMBI         202 6420
   Coding: 07A419082B80000801082A001400000000000000
   VCID: 2411EAD39E590D5B173-8070
          B2010 00 [009] - -
          [Steuergerдt keine oder falsche Grundeinstellung]
                    Reset counter: 231
                    Mileage: 74316 km
                    Date: 2020.05.01
                    Time: 17:58:54
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004243096
   Coding: 030100043F085700FB00024A1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29150002329470015475
   Coding: 28FFFF
   Serial number: 3959488403
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 101015BJ916677
   Coding: 003002208000040000001000
   Serial number: 00000000000008165141
   Coding: 110000
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0103
   Serial number: 141015BJE03294
   Coding: 003000208E00040000801000
   VCID: 42DD4C4B640D236B05F-8016
   Serial number: 00000000000008199730
   Coding: 090000
   Coding: 029A00000B000200
   VCID: 40D946436A01317B13B-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 819 A    HW: 3Q0 035 819 A
   Component: MU-S--ER      523 0629
   Coding: 02730000FF00000051110001000908001F0100840120010001
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2F3B15FFC79FBE03FA1-807A
   Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
   Component: ABT_Std-2  H43 4064
   Serial number: VWZ6Z9R3311321
End----------(Elapsed Time: 01:35, VBatt start/end: 14.9V/13.1V)-----------
;SW:5G1-920-740-A   HW:5G1-920-740-A ---  Instruments
;Component:KOMBI         202 6420	 Coding:07A419082B80000801082A001400000000000000
;EV_DashBoardVDDMQBAB	9046	EV_DashBoardVDDMQBAB_009_VW37.rod
;Monday	4	May	2020	13:14:21:12071
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: 2411EAD39E590D5B173-8070
IDE00295-Oil temperature display	On 	1
IDE00301-Distance	74321 km	3
IDE00342-ESI: Resetting ESI	no warning 	1
IDE00343-Language version	English 	1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK	Manual reset: not possible 	3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel	MFA3-Reset 	3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas	MFA3-Reset 	3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection	MFA3-Reset 	3
IDE00499-Display correction of consumptions and operating range	100%	1
IDE00500-Hour	13 H	1
IDE00501-Minute	14 min	1
IDE00502-Year	2020 yr	2
IDE00503-Month	5 mon	1
IDE00504-Day	4 d	1
IDE00510-ESI: distance driven from inspection	3302 km	3
IDE00511-ESI: time from inspection	227 d	2
IDE00512-ESI: minimum value km-driving distance/inspection	15000 km	2
IDE00513-ESI: maximum value km-driving distance/inspection	30000 km	2
IDE00514-ESI: maximum value of time between inspections	730 d	2
IDE00515-ESI: oil quality	poor oil quality 	1
IDE00517-ESI: soot entry	0 km	2
IDE00518-ESI: thermal load	4900 km	2
IDE00711-Trip recorder	not installed 	1
IDE00819-Day counter	1612 d	2
IDE00820-Activating and deactivating all development messages	not active 	1
IDE00827-ESI: minimum value of time between inspections	365 d	2
IDE01153-SIA: maximum value of distance to service	20000 km	2
IDE01154-SIA: maximum value of time to service	365 d	2
IDE02489-Display depiction	Version 1 	1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.8 l	5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.8 l	5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	12.7 l	5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.7 l	5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.7 l	5
IDE03329-Driving profiled for range remaining	6.0 l/100km	2
IDE03346-IDE00301-Units adjusted-Distance	Kilometers 	3
IDE03346-MAS01230-Units adjusted-Date	yy_mm_dd 	3
IDE03346-MAS01456-Units adjusted-Speed	Kilometers per hour 	3
IDE03346-MAS02201-Units adjusted-Temperature	Degrees Celsius 	3
IDE03346-MAS02957-Units adjusted-Time	24h 	3
IDE03346-MAS03032-Units adjusted-Volume	Liter 	3
IDE03346-MAS03034-Units adjusted-Pressure	bar 	3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)	kg per 100 km 	3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Liters per 100 km 	3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive	kWh per 100 km 	3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground	kilogram (kg) 	3
IDE03348-MAS01456-Speed warning-Speed	0	2
IDE03348-MAS01561-Speed warning-Unit	Kilometers per hour 	2
IDE03348-Speed warning-	not active 	2
IDE03349-FIX: Max. distance until next mileage-related inspection	30000 km	2
IDE03350-FIX: Maximum time until next time-dependent inspection	365 d	2
IDE03351-FIX: Distance covered since last mileage-dependent inspection	3300 km	2
IDE03352-FIX: Time since last time-dependent inspection	227 d	2
IDE03372-Source for synchronization of time	internal clock 	1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On 	5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s	5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	On 	5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On 	5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h	5
IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s	5
IDE03568-ENG104099-Service-key settings-p_write_distance	20 km	5
IDE03867-Deactivate seat belt warning	No 	1
IDE04169-Display correction of consumption and operating range: gas	100%	1
IDE05930-Service notification in days	30 d	1
IDE05931-FIX: Reset value for next mileage-dependent inspection	30000 km	2
IDE05932-FIX: Reset value for next time-dependent inspections	365 d	2
IDE05971-Vehicle Positioning System Interface Control Module	not installed 	1
IDE06425-Roller test bench mode: functional	not activated 	1
IDE06588-Ignition active message: actuator	Driver door 	1
IDE06922-No-voltage display	Unknown (2)	1
IDE07221-Cylinder shut-off	Display 	1
IDE08140-Driving profiled for range remaining CNG	6.0 kg/100 km	2
IDE08247-Driving profile for range remaining LPG	10.0 l/100km	2
IDE11086-Service notification	30 d	1
MAS03685-Digital speedometer	Display 	1
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF 	20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF 	20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF 	20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF 	20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF 	20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF 	20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF 	20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF 	20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF 	20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF 	20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF 	20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF 	20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF 	20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF 	20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF 	20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF 	20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF 	20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF 	20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF 	20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF 	20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF 	20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF 	20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF 	20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF 	20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF 	20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF 	20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF 	20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF 	20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF 	20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF 	20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF 	20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF 	20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF 	20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF 	20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF 	20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF 	20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF 	20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF 	20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	OFF 	20
ENG119875-defuel_threshold	9 l	1
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0	12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2	32	12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3	66	12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4	96	12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5	DC 	12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD 	12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	0	12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	0	12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	0	12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	5	12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	14	12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64	12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0	12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A 	12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3	32	12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4	64	12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5	96	12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD 	12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	2	12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	2	12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	17	12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	32	12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	46	12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64	12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1	0	12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2	0A 	12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3	32	12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4	64	12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5	DC 	12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6	FD 	12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1	3	12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2	3	12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3	8	12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4	20	12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5	55	12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6	64	12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1	0	12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2	0A 	12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3	32	12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4	64	12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5	96	12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6	FD 	12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1	5	12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2	5	12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3	0C 	12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4	17	12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5	32	12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6	64	12
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00 	20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32 	20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64 	20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 C8 	20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4 	20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00 	20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 0E 	20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 41 	20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 C8 	20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD 	20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0	12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	0A 	12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	32	12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	64	12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	96	12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6	FD 	12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	1	12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	1	12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	7	12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	12	12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	1E 	12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6	64	12
ENG119874-Gas_functionality	not active 	1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xd_log_bus_parkinglight 	1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	parking_light 	1
ENG119882-init_fuel_algorithm	No 	1
ENG130585-Leaving_warning_delay	1.6 s	1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s	16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 °C	16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 °C	16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 °C	16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.0 km	16
ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h	16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min	16
ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s	16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.0 °C	16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s	16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2	16
ENG119825-Picture_Upload_Download	not active 	1
ENG119876-Service_Key_Clear_All_Counter	Yes 	1
ENG130584-Statistic_phev_mileage	5 km	1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms	2.0 s	18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s	18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt	35 s	18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms	18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms	255 s	18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s	18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms	6 s	18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms	20 s	18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms	900 s	18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms	10 s	18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms	3 s	18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms	10 s	18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ	0.20 s	18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse	3	18
ENG109442-ENG101663-time_parameter_display-tDD15_off	0.3	18
ENG109442-ENG103975-time_parameter_display-tDD15_on	0	18
ENG109442-ENG100026-time_parameter_display-tDDWUP	0	18
ENG112418-ENG112412-total_range_gas-consumption_factor	0	4
ENG112418-ENG112411-total_range_gas-consumption_profile	consumption_profile_calculation 	4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor	consumption_factor_CAN 	4
ENG112418-ENG99298-total_range_gas-State	not active 	4
Elapsed Time: 00:29
fyshu_87
Romania
C?ID=509888
Hi guys, I also have an Audi A1 1.4 tsi 2011 with the same problem.you can help me whith that.Thanks in advances.
Thursday,24,March,2022,17:18:32:25726
VCDS Version: 22.3.0.1 (x64)  HEX-NET2 CB: 0.4613.4
Data version: 20220225 DS336.1
VIN: WAUZZZ8X8BB063872   License Plate: 0770507972
Mileage: 179320km-111424mi   Repair Order:
Chassis Type: 8X-AU21 (8X0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 5F
VIN: WAUZZZ8X8BB063872   Mileage: 179320km-111424miles
Address 01: Engine (FO1-CAXA)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 BG    HW: 03C 906 016 BG
   Component: 1.4l R4/4V TS H08 8080
   Revision: LEH08---    Serial number:                CVN: 4859DC30
   Coding: 00190012000401000000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_ECM14TFS01103C906016BG 001004
   ROD: EV_ECM14TFS01103C906016BG.rod
   VCID: E59C593855E701C3DC4-80B0
   VINID: 9D196AAAA22821248018320708933A0F12
Readiness: 1110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AH    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0004
   Revision: --------
   Coding: 310448E9237300B58C2D12E9C4D300510C00
   Shop #: WSC 00046 000 00000
   VCID: 845A64BCBE5DD8CB6BA-80D0
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 8X0 820 043 A    HW: 8X0 820 043 A
   Component: Klima 1 Zone  H12 0050
   Serial number: 00000000032875
   Coding: 6400080000
   ASAM Dataset: EV_AirCondiFrontAU210 006031
   ROD: EV_AirCondiFrontAU210_006.rod
   VCID: B236F26454A9A67B896-80E6
Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
   Part No SW: 8X0 907 063 D    HW: 8X0 907 063 D
   Component: BCM PQ35  M   108 0621
   Revision: 00108 AB
   Coding: 06000A2FA0051800201840E02100094C537F720A21EF5D22E40887870045
   VCID: BD2CD1589D776903644-80E8
   Subsystem 1 - Part No SW: 8K0 955 559     HW: 8K0 955 559
   Component: RLS  H04 0003
   Serial number: 11238166
   Coding: 02562D
Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
   Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
   Component: Airbag10.41   H04 0008
   Revision: --------    Serial number: 003JJ000YV2M
   Coding: 30314539303330303036554A304C38583053
   ASAM Dataset: EV_Airba1041BPAAU210 001015
   ROD: EV_Airba1041BPAAU210.rod
   VCID: C8C2B08CC2353CABC72-809C
   Serial number: 3554VRB406507S8S59P$
   Serial number: 3575HRB406709REC3993
   Serial number: 3585HRB405F09QC889FF
   Rear end impact crash sensor:
   Serial number: 3515ZRB405L08IF8L9I%
Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
   Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
   Component: LENKS.MODUL   009 0136
   Revision: FF010015    Serial number: 20110126200447
   Coding: 1184004000
   VCID: B924C54889DF552348C-80EC
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
   Part No SW: 8X0 920 930     HW: 8X0 920 930
   Component: KOMBI         H07 0124
   Coding: 01DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
   VCID: F7A00370FF4B83537E8-80A2
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung / Adaption]
                    Reset counter: 252
                    Mileage: 179324 km
                    Date: 2022.03.24
                    Time: 17:15:46
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   Part No SW: 8X0 907 468 A    HW: 8X0 907 468 A
   Component: GAT 4CAN 1L M H04 0083
   Revision: 1C060023    Serial number: 2341C111140035
   Coding: FBCF0064000100010053
   VCID: C3D8A7A0FB931FF3120-8096
   Subsystem 1 - Part No SW: 8K0 915 181 G    HW: 8K0 915 181 G
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370414340
   Serial number: 11014000312021200181
   Component: IMMO          H07 0124
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 D    HW: 8X0 959 793 D
   Component: TSG FA        H09 0409
   Coding: 011E02200000000100
   VCID: CECE869420D1E29B8DE-809A
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 11251
   Shop #: WSC 00046
   VCID: AF30FB104E5B8B93E68-80FA
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 D    HW: 8X0 959 792 D
   Component: TSG BF        H09 0409
   VCID: CDCC81982DD7D983F44-8098
   Part No SW: 8X0 907 357     HW: 8X0 907 357
   Component: ****LWR12**** H02 0040
   Serial number: 110113-0004-047
   Coding: 1131941010022500
   ROD: EV_HeadlRegulBasic_AU21.rod
   VCID: FF50EB50D77BBB13368-80AA
   Part No SW: 8X0 035 193     HW: 8X0 035 192 A
   Component: RMC Cnct Nav  H45 0530
   Coding: 01000000008051070023000103010000000000
   VCID: F5BC0978E5C7F1436C4-80A0
   Subsystem 1 - Part No: 8X0 919 884 C
   Component: P11-50-10.06  1006
   Subsystem 2 - Part No SW: 8X0 919 603     HW: 8X0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9462L+0A0048587
End----(Elapsed Time: 01:09, VBatt start/end: 12.1V/12.2V. VIgn 12.0V)-----
    SW:8X0-920-930   HW:8X0-920-930 ---  Instruments
    Component:KOMBI         H07 0124     Coding:01DE00
    EV_Kombi_UDS_VDD_AU10    A04086    EV_Kombi_UDS_VDD_AU10.rod
    Thursday    24    March    2022    17:09:40:25726
    VCDS Version: Release 22.3.0 (x64)  Data version: 20220225 DS336.1
IDE00301-Mileage    179320 km    2
IDE00342-ESI: Resetting ESI    Resetting     1
IDE00343-Language variant    English     1
IDE00344-Seat belt warning    Variant 2     1
IDE00492-MAS00900-ESI: Coding of Service Interval Extension (SIE)-Oil level    Oil level evaluation     1
IDE00492-MAS02010-ESI: Coding of Service Interval Extension (SIE)-Oil pressure    dynamic oil pressure     1
IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality    poor oil quality     1
IDE00492-MAS02013-ESI: Coding of Service Interval Extension (SIE)-TOG    Oil level thermal sensor connected to instrument cluster     1
IDE00493-Display correction of fuel gauge    0.0 °    1
IDE00499-Display correction of consumptions and operating range    100 %    1
IDE00500-Hour    17 H    1
IDE00501-Minute    10 min    1
IDE00502-Year    2022    2
IDE00503-Month    3    1
IDE00504-Day    24    1
IDE00505-Speed threshold of dynamic oil pressure warning    kein Offset     1
IDE00510-ESI: distance driven from inspection    0 km    2
IDE00511-ESI: time from inspection    0 d    2
IDE00518-ESI: thermal load    0 km    2
IDE00819-Day counter    4069 d    2
IDE00820-MAS01172-Activating and deactivating all development messages-Development messages    not active     1
IDE00820-ENG98891-Activating and deactivating all development messages-Reserved    0    1
IDE01087-Staging    not active     1
IDE01153-SIA: maximum value of distance to service    30000 km    2
IDE01154-SIA: maximum value of time to service    730 d    2
IDE02327-Indicator light for start-stop operation    On     1
IDE02494-Automatic door locking    Readout     1
IDE03329-Driving profiled for range remaining    7.1    2
IDE03346-IDE00301-Units adjusted-Mileage    Kilometers     2
IDE03346-IDE00316-Units adjusted-Time    24h     2
IDE03346-MAS01230-Units adjusted-Date    dd_mm_yy     2
IDE03346-MAS01456-Units adjusted-Speed    Kilometers per hour     2
IDE03346-MAS02201-Units adjusted-Temperature    °C     2
IDE03346-MAS03032-Units adjusted-Volume    Liters     2
IDE03346-MAS03033-Units adjusted-Consumption    Liters per 100 km     2
IDE03346-MAS03034-Units adjusted-Pressure    bar     2
IDE03348-MAS01456-Speed warning-Speed    20    2
IDE03348-MAS03206-Speed warning-Speed warning    not active     2
IDE03349-FIX:Max. distance driven until next mileage-related inspection    55400 km    2
IDE03350-FIX: Maximum time until next time-dependent inspection    730 d    2
IDE03351-FIX: Distance covered since last mileage-dependent inspection    0 km    2
IDE03352-FIX: Time since last time-dependent inspection    0 d    2
IDE03360-Upshift display in center panel    active     1
IDE03371-Synchronization duration radio clock    0 min    1
IDE03568-ENG102019-Service-key settings-p_main_switch_basis    On     5
IDE04103-Language version in instrument panel insert control module    German     1
IDE04112-Display format    not active     1
ENG108924-Service_Key_Clear_All_Counters    Yes     1
   #32
This is clearly wrong, but I'm not sure what the correct value should be:
I would try 30000.
Don Keener
C?ID=234118
Well, Ive managed to create the same error in our '15 Golf Mk VII... My intent was to change the service/inspection intervals to 7500mi/18months.
B2010 00 [009] - -
[Steuergerät keine oder falsche Grundeinstellung]
Reset counter: 27
Mileage: 91048 km
Date: 2023.06.12
Time: 11:26:55
Any thoughts on what Ive done wrong would be appreciated.
Thanks!!
The lines I changed were
IDE01153-SIA: maximum value of distance to service12000 km
IDE01154-SIA: maximum value of time to service547 d
IDE03349-FIX:Max. distance driven until next mileage-related inspection12000 km
IDE03350-FIX: Maximum time until next time-dependent inspection547 d
IDE05931-FIX: Reset value for next mileage-dependent inspection12000 km
IDE05932-FIX: Reset value for next time-dependent inspections547 d
As well as these to set the correct miles and distance since last service/inspection
IDE00510-ESI: distance driven from inspection6542 km
IDE00511-ESI: time from inspection403 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection6500 km
IDE03352-FIX: Time since last time-dependent inspection403 d
I noticed 510 and 3351 are not tracking each other (car has been driven a bit since those values were set to 6500km when I initially made the changes). Perhaps 3351 only ticks in larger increments?
Note, I did exactly the same changes to our '14 EOS and it is happy as a clam... no codes.
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VW917AU4GM004412   Mileage: 91048km-56574miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 K    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---    CVN: F837D62B
   Coding: 091A00122424002F0000
   Shop #: WSC 00066 790 00218
   ASAM Dataset: EV_ECM18TFS0208V0906264K 001004
   ROD: EV_ECM18TFS0208V0906264K.rod
   VCID: 44D1B0400E10BC8A6B3-8010
   VINID: 0E69C90474651177400041010836EEA404
   Part No SW: 09G 927 749 AP    HW: 09G 927 749 AP
   Component: AISIN AG6 G3  129 2943
   CVN: 1351BC5C
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW23.rod
   VCID: 074B674C7FA657924E1-8052
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 51635000001014
   Coding: 01FA6AA124200970007B020181C5298056249000408194B400430050C002
   Shop #: WSC 01383 790 50316
   VCID: 4BC39B7C234E73F2AA9-801E
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 00020004200100000000000000000002
   VCID: 05576D4445AA45823CD-8050
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 T    HW: 5Q0 937 087 T
   Revision: --------    Serial number: 86581206150680 Dataset Number: 5GM063v____ 0059
   Coding: 000018424001804169644000000403001000000000000000000000000000
   VCID: 4CC19860264074CAA33-8018
   Wiper motor control module:
   Component: WWS    150508  043 0581
   Serial number:         150701032338
                    Reset counter: 67
                    Mileage: 91006 km
                    Date: 2023.06.09
                    Time: 11:54:14
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): OFF
                    Status Bremslichtschalter (CAN): OFF
                    OFF: operated
                    Position lamps: Not operated
                    Automatic high beam assist: Not operated
                    Low beam: Not operated
                    Parking light left: Not operated
                    Parking light right: Not operated
                    last_wakeup: no cause for fault protection
                    Voltage: 11.9 V
                    Outside temperature: 33.5 °C
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM02GCFN Dataset Number: 5GM003V____ 0041
   VCID: 51FF8914C1625922D05-8004
   Seat occupied recognition passenger side:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J1500030IOV0I
   Coding: 303133
   Subsystem 2 - Part No SW: -----------    HW: 480 002 205 15
   Serial number: 35700000000EF590641Q
   Subsystem 3 - Part No SW: -----------    HW: 480 002 305 15
   Serial number: 358000000007C760A41K
   Subsystem 4 - Part No SW: -----------    HW: 480 400 705 15
   Serial number: 3510002BB1A2DCD3E0ET
   Subsystem 5 - Part No SW: -----------    HW: 480 400 705 15
   Serial number: 3520002BF1A87874B1CL
   Subsystem 6 - Part No SW: -----------    HW: 480 401 205 15
   Serial number: 3550002BF1A2DCD3D26U
   Subsystem 7 - Part No SW: -----------    HW: 480 401 205 15
   Serial number: 3560002C31A878736263
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20190914400112
   Coding: 8410
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   VCID: 3C21C8A076E0C44A133-8068
   Part No SW: 5G1 920 840 A    HW: 5G1 920 840 A
   Component: KOMBI         242 6420
   Coding: 0BB4010AA180CF0502086A001000000000000000
   VCID: 25170DC4E56A65825CD-8070
          B2010 00 [009] - -
                    Reset counter: 27
                    Mileage: 91048 km
                    Date: 2023.06.12
                    Time: 11:26:55
   Part No SW: 5Q0 907 530 AE    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2223
   Revision: --------    Serial number: 02061510001047 Dataset Number: 5G0067V____ 2214
   Coding: 0101000830085900FB0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   GVL: 01503C0000000000400C00008000C80000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 74B120801E304C0A1B3-8020
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150001121320065222
   Coding: 31FFFF
   Serial number: 2606150605077Y Dataset Number: V03935214VB 0007
   Coding: 003003200000040100000000
   VCID: 41DFB9541102A9A2405-8014
   Component: EPS_MQB_ZFLS  126 1061
   Dataset Number: 5GM074V____ 0517
   Coding: 0102
   VCID: 43D3B35C0B1EBBB2529-8016
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 14061506050520 Dataset Number: V03935214VC 0007
   VCID: 40D9BC501A08A0AA4FB-8014
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Serial number:                Dataset Number: 5G0CV1v____ 0001
   Coding: 02730000FF00000051220001001808001F0100D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6C8138E0460094CAC33-8038
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H52 1028
   Serial number: VWZ8Z9RES002HF
1600 - Data Set Implausible
          B2012 00 [008] - -
          [Control module (data record download) - implausible data record for sound audio parameters]
                    Reset counter: 62
                    Mileage: 90992 km
                    Date: 2023.06.09
                    Time: 10:22:35
                    Voltage terminal 30: 11.1 V
1659 - Data Set Implausible
          B2012 00 [008] - -
          [Control module (data record download) - implausible data record for sound announcement audio parameters (optional)]
                    Reset counter: 62
                    Mileage: 90992 km
                    Date: 2023.06.09
                    Time: 10:22:35
1660 - Data Set Implausible
          B2012 00 [008] - -
          [Control module (data record download) - implausible data record for sound cabriolet audio parameters (optional)]
                    Reset counter: 62
                    Mileage: 90992 km
                    Date: 2023.06.09
                    Time: 10:22:35
1661 - Data Set Implausible
          B2012 00 [008] - -
          [Control module (data record download) - implausible data record for sound configuration audio parameters (optional)]
                    Reset counter: 62
                    Mileage: 90992 km
                    Date: 2023.06.09
                    Time: 10:22:35
          B11CF 53 [009] - Deactivated
                    Reset counter: 20
                    Mileage: 90943 km
                    Date: 2023.06.08
                    Time: 09:46:01
                    Voltage terminal 30: 11.5 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: available.
                    SDARS_tuner_status_2-Antenna current: 141 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
   Component: OCULowMQBUS   007 0564
   Dataset Number: 561098V____ 0409
   Coding: 02730002C28214017F1E06000000
   Shop #: WSC 00066 790 00323
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:15, VBatt start/end: 13.0V/13.0V)-----------
;SW:5G1-920-840-A   HW:5G1-920-840-A ---  Instruments
;Component:KOMBI         242 6420     Coding:0BB4010AA180CF0502086A001000000000000000
;EV_DashBoardVDDMQBAB    9046    EV_DashBoardVDDMQBAB_009_VW26.rod
;Monday    12    June
;VCDS Version: Release 23.3.1 (x64)  Data version: 20230421 DS346.2
;VCID: 25170DC4E56A65825CD-8070
IDE00301-Mileage    91048 km    3
IDE00343-Language variant    US English     1
IDE00499-Display correction of consumptions and operating range    109%    1
IDE00500-Hour    11 H    1
IDE00501-Minute    30 min    1
IDE00502-Year    2023 yr    2
IDE00503-Month    6 Months    1
IDE00504-Day    12 d    1
IDE00510-ESI: distance driven from inspection    6542 km    3
IDE00511-ESI: time from inspection    403 d    2
IDE00518-ESI: thermal load    300 km    2
IDE00819-Day counter    2892 d    2
IDE01153-SIA: maximum value of distance to service    12000 km    2
IDE01154-SIA: maximum value of time to service    547 d    2
IDE02489-Display depiction    Variant 1     1
IDE03329-Driving profiled for range remaining    8.1 l/100km    2
IDE03346-IDE00301-Units adjusted-Mileage    miles     3
IDE03346-MAS01230-Units adjusted-Date    mm_dd_yy     3
IDE03346-MAS01456-Units adjusted-Speed    Miles per hour     3
IDE03346-MAS02201-Units adjusted-Temperature    Degrees Fahrenheit     3
IDE03346-MAS02957-Units adjusted-Time    12h AM_PM     3
IDE03346-MAS03032-Units adjusted-Volume    gallons (US)     3
IDE03346-MAS03034-Units adjusted-Pressure    psi     3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)    Miles per gallon (US)     3
IDE03348-MAS01561-Speed warning-Unit    Miles per hour     2
IDE03349-FIX:Max. distance driven until next mileage-related inspection    12000 km    2
IDE03350-FIX: Maximum time until next time-dependent inspection    547 d    2
IDE03351-FIX: Distance covered since last mileage-dependent inspection    6500 km    2
IDE03352-FIX: Time since last time-dependent inspection    403 d    2
IDE03372-Source for synchronization of time    GPS     1
IDE05930-Service notification in days    20 d    1
IDE05931-FIX: Reset value for next mileage-dependent inspection    12000 km    2
IDE05932-FIX: Reset value for next time-dependent inspections    547 d    2
IDE06425-Dynamometer mode: functional    not activated     1
IDE07221-Cylinder shut-off    Readout     1
IDE11086-Service notification    20 d    1
MAS03555-Lap counter    Conditions not correct or request sequence error    1
MAS03685-Digital speedometer    Readout     1
As a general rule, if you want shorter than stock intervals, it's better to leave the stock intervals in place and immediately after you do a reset, lie to the cluster and add some miles. Assuming your interval was 10,000 miles, you'd tell the car that it had 2500 miles since service immediately after a reset.
Don Keener
C?ID=234118
I ended up 'backing out' the adaptations a few at a time and checking the fault to see when it goes away. I had removed everything except 1153 and 1154 and the fault remained. So... I changed 1154 from my desired 547 days to 365 days and bingo.. fault resolved. So it seems that the car wont allow an oil change interval longer than 365 days. It accepted the reduction of mileage interval from 10K to 7500 so I have a partial victory! Ill just set a calendar reminder for about 6 months after oil change to go in and subtract 182 days from 511 and be happy. The factory 'inspection' intervals are so large (2 yr 20K miles) that the oil change will always trip first and I reset both after oil change/service so I will never see an alert for inspection.
Thanks!!!
